View Full Version : Forced Induction
- Gsr Turbo question
- Sohc greddy turbo peeps
- b16 head gsr block full race ram horn cut the block or manifold?
- AFRs richer in 3rd than 2nd gear, which gear to tune??
- identifying turbonetics
- Quick question. Vacuum line size.
- Weird as hell....
- H22 Civic 680whp 441wtq
- What would 20w-50 do????
- B16A JRSC head gasket? Coolent in oil.
- RC 440's VS dsm 450's
- HELP. USPS lost my pakage with 2 tial wastegates
- manifold/wg hood clearance?
- check this s2000 bay out
- egt gauge
- New Setup, missing some power. HELP!
- how much boost can b16 stock block hold?? im rebuilding
- Whats Boost Controller Are You Using???
- Precision or Tuner Toys injectors?
- wastegate doesn't seem to close completely after boost...what's wrong?
- Who sells the Divided T4/T67R?
- painting my intercooler?
- HELP I DUNNO>>>>>>
- Filter and Oil talk.
- do i need other things?
- T1 Race Development 432whp on pump
- Whats The Oil Pressure AT IDLE??????
- Difference from Wet and Dry Nitrous?
- Oil return/ Leaky hot side/ need some suggestions........
- Turbo/Nitrous
- Do you guys recommend this!?
- Help oil pressuer drops???????
- Wanted to share some pics of XS Power Top Mount Turbo Kit
- Help me with my slow spool! Turbo-LS
- turbo disassembly?
- Dash Problem...
- oil pressure line
- Not Honda problem / other car 2g 95 talon Everything looses voltage when Ignition is turned
- Car needs to be cranked 3 times before it starts???
- NOOB here gt28 question
- nos question?
- Compression/leakdown test on my 2jz-ge
- AEM 5 Bar MAP less accurate than AEM 3.5 Bar Map?
- What are you guys usung to datalog
- have u seen this clutch b-fore ?
- Oil gauge Hook up????????
- Supercharging High Compression?
- aftermarket oem sized pistons for turbo build
- Block Guards
- Main bearing clearence question.
- question abotu 99 accord turbo
- Could this cause..............
- 3bar map vaccume
- Who runs resistors like this for dsm injectors
- TURBO COMPARRISON
- Vacuum leak....places to find/look
- WHAT PISTON ARE THE BEST
- Super charge VS Turbo charge
- have you guys seen this log vs. tube mani
- do i have too?
- Crome Tuners in Colorado?
- new motor, new tune, new problems
- can someone give me some realistic dyno numbers on a b20b/vtec turbo swap
- let me see some dumptubes that come out the bumpers.
- Greddy Turbo Kit on Eg (92-95) Civic D16y1/D16z6..... check light?
- ARP headstud question please help
- IHI turbo
- Turbonetics Deltagate Mark II hook up
- NC Emissions Problems - ANY IDEAS?
- What type of downpipe is this
- synapse boost controller
- DSM to D series?
- startinga new project LS on Boost. which stock pistons B16 or LS ????
- hulkhb jason crp turbo......
- am i good to go?
- My Boosted DA
- Compression Calculator How Accurate
- turbo timer question????
- crome - uberdata .bin compatability??
- another look at my compression test thread
- Realistic goal 330whp gt2871r/gsr setup inside
- plz need diameter of Tial springs
- b16 oil pump mods?
- Whats the best honda motor to supercharge?
- turbo question
- Wanna convert your Steel Hard Fuel Line into AN line ? Step by Step info inside
- AMSOIL OR REDLINE
- Cast Iron.
- OBD2/inspection question/00 si
- Intake Butterfly Plate Issue
- low oil pressure? help please
- how are you guys mounting your intercoolers (crx)
- Supertech ti retainers, springs and valves...... what keepers?
- Looking for a suitable turbo
- 35R vs t3/t67ho b.b
- ARP Headstud washers...
- What oil filter do you use?
- dangerous temps?
- Would it be better to run a 3inch downpipe and no exhaust or is it better with a full 3 inch exhaust
- Recommendation for SoCal engine builder
- Tial BOV :: what spring? :: motor isn't running yet :: h22
- Expired Nitrous Bottle: Testing
- Turbo Kit For Sale
- AVCR Problem. (boost not regulated)
- honda assy lube ok to torque rod bolts?
- HELPPPPP..........
- ported jdm itr intake manifold???
- going from a z6 to y8 head on my build... a few ????
- Volvo turbo for b series
- FUEL PUMP ??
- Anyone running a larger front tire size for street traction??
- MSD HVC coil question
- 2.5" downpipe w/2.5" or 3" exhaust?
- Intake Manifolds: Golden Eagle design vs. JG design
- which intake manifold is best for 20psi
- vaccume issue
- Turbo installation started, some pictures...
- civic rad. mounting in teg
- 160K Boosted GSR????
- oil in intake manifold
- Looking for GT3255E oil feed line adapters/fittings...HELP!
- what is corect motor temp with turbo
- ls/t video at the track
- internal wastegate question...
- new car in hawaii
- Exhaust or No Exhaust????
- Installing CROME
- How much would you sell this block for?
- Post Your B18C1 Turbo Setups
- what spring do i have?
- WhatS CROME???
- Post Your Turbo Setups HERE!!!
- better tranny for turbo (350-400whp)
- Please advice on upgrading my Greddy kit
- ignition timing for jrsc at
- HELP KNOCK?????
- what would make my car break up in vtec??
- Which boost controller do u use?
- Smaller Pulley on a JRSC
- New: World's Highest Flowing 50mm BOV
- methanol/water injection nozzle placement?
- Help with getting turbo lsvtec working / ostrich / crome WTF!!!!
- Where to buy these fittings? (pic included)
- HCP ek mount kit front crossbar clearance for my turdbo setup?
- GT4088R compressor housing size
- Boosted Stock sleeve LS-V
- SPA GAUGE QUESTION?????
- problems w/ high vacuum on deceleration
- is this a good shop to get a tune
- Single nitrous setup
- Is it neccesary to run a boost gauge with a Profec spec-B II ebc
- civic ls turbo
- b16 info
- need help already searched best way to hook up catch can
- 2dr ex: what kit?
- Weird turbo oil leak, please help
- Tuning and break-in of new motor ???
- smoke comming off the valve cover hole ?
- Custom I/C Piping...Where to buy?
- open turbo?
- Anybody use the Twin Scroll GT35R yet?
- injectors?
- Heat shield and wheel questions...
- Are my pistons trash????
- Only boosting like 2 psi
- Where is the quickest 1/4 times FI on drag radials thread?
- Pistons the good bad and the ugly
- at what boost levels are you guys modding your stock PCV system?
- Anybody from MN heard on RS Motor for tuning hondata S300
- How to protect an intercooler?
- Mild steel vs stainless steel flanges, and 3/8" vs 1/2"
- pre-turbo???
- FPR HELP
- The Ultimate H build from BEEYond Engineering.
- Help torque specs
- Please reccomend a tuner that will actually answer the telephone in Orlando Florida
- cams with turbo ?
- adapter
- how much power can i make on my 97 itr tranny?
- HELP!!! Turbo istalled no boost totally lost!!!
- Boosting soon. H23 block vs. H22
- Turbo whirring, intermittent oil burning
- Catch Can Puking oil at the track
- 72mm BDL TB + Victor X IM ::Searched::
- E-boost controller install
- Eagle rods info
- looking for something i can't seem to find...
- sohc turbo set up?
- Having 2nd thoughts about my B16. need opinion
- HondaEMS (TCS) vs. Action 2MD Clutch Review *LONG*
- Greddy Profec B Spec 2, PSI display... extremely inaccurate
- Boosted cars in california
- oil pressure question?
- where can i find...
- Do I need a New Fuel pump??
- RC 550 Injector HP Limit
- COMPREX(pressure wave supercharger) anyone ever see or use one
- Loosing Tach signal Please Help
- Hondata or crome pro tuning
- white smoke from exhaust during boost, new Garrett turbo.
- Fuel Setup? ? ? ?
- I SEARCHED, I READ! Still need help, i'm a turbo n00b!
- Stock head sufficent?
- turbo???
- Turbo problem... Help
- inconspicuous turbo setups?
- 91oct + E85??????
- i need 2 get a turbo manifold 4 my prelude
- turbo build help??
- Good turbo cam for d16y7??
- Substitue for my autometer boost gauge thats actually accurate....?
- Downpipe question...
- Need to choose a performance air filter that doesnt let ANY dirt in.....
- stock sohc turbo?
- full rich afr on deceleration
- Finally got a retune!
- Apexi avc-r problem
- b16 turbo
- Neptune
- aem true boost question
- Tuned my stock bore b16 on c16 today woohoo..........
- Downpipe Heat and Clearance Questions need answers
- crower cams
- Wastegate Tube on Dp
- Apexi AVCR boost Control???
- Does anyone have outlet flange for 50mm Turbosmart wg?
- Please help: With my fuel injector cel
- Stockinternal B16a2 Full-race T67.
- dyno prof changes
- Question on my setup
- Tunners- Spokane Area?????????
- turbo efficiency vs. extra bolt ons???
- msd injector question
- wastegate question?
- honda + vgt turbo + banks controller, possible?
- Converting 98 Prelude SH to obd1?
- IAT sensor melt on D16Z6
- can you run a turbo kit without boosting it??? bad explaination, look inside pls.
- piston difference?
- went to the track tonight
- Need opinion for venting
- Rev Limiter
- Cleaning Write up DIY 56K beware
- CromePro USERS, Chime in!
- Tial BOV stuck closed..
- FMU
- oil return picture - angled okay?
- Broke into 640whp, stock head, stock fuel lines, FPR and ITR cams=50+whp
- loose bearing=low oil psi??
- Attn AEM EMS tuners, spark with stock ecu, no spark with aem. help!!!
