View Full Version : Forced Induction
- Precision turbo 6262 turbo gone bad. Whats caused this?
- Civic Sir (Vti) from Brazil !
- Anyone knowledgeable on NITROUIS!!!!
- Question about return line
- No boost in neutral? Is this normal?
- My second shot at boost.
- walbro fuel pump questions
- shiny oil after dyno work
- 3431E PTE Turbo on Built D16??
- Down on power, turbo to blame?
- Need turbo selection advice
- Could someone post pics of their turbo coolant/oil lines routing?
- b16 turbo intake manifold question
- My stock block LST project!
- Intercooler predicament
- Turboing B18B1 with Turbonetics T72 turbo
- Car overheating!
- OMG ghetto budget build (your doing it wrong!?!?!)
- No room for radiator with new top mount , any suggestions ?????
- JDM ITR B18c
- d16z6 questions before I turbo it
- boost problems
- custom supercharger anyone?
- What are you tuned on???(hondata chrome ect)
- Hondata S300 experts, step on in!
- pte 5431 billet wheel turbo
- ls vtec turbo takes 3.5 oil qts or smoke
- Turbo parts
- daily gsr rebuild boostin
- b16a2 turbo choice
- catch can / crankcase ventilation
- y7 head flow/ compression on d15z1 block
- turbo integra over heating
- CP vs SRP
- Water problem on Dart B18 block and GSR head
- Clutch slips under boost... but only in 1st gear
- Iowa dyno tuning shops?
- 93 civic built b16 turbo radiator hose pressure
- oil drain line
- changed rail and injectors now car runs like ass
- Cast piston power limit on E85?
- SuperCharge
- ICM bypass, removed, deleted, binned.... AEM, T1 , MSD
- where did you guys go to get tune? and were you guys happy ? in northern cali
- A1000 with 850cc injectors?
- would be adequate a Turbocharger precision 3231e for a d16z6
- Stock b20vtec turbo results
- GSR vs ITR Longblock
- How much power will I make?
- vortech dealers
- new valveseals, good compression but still burning oil
- how to turbo
- finally tuned!!!
- 00' Civic B18b1 Turboed??
- Largest turbo trim I can fit on a b16 without grinding some off the block
- ring gap clearance
- built jdm b16a lots of smoke from valve cover and catch can?
- Help! RSX goes into limp mode at high RPM
- wire for turbo blanket
- What power Goal should I go for
- thoughts on this turbo?
- Built H22 turbo selection
- Private Label B series TopMount Manifold
- Blacktop Dsm Injector Help PLEASE.
- Identify This Turbo... HELP FAST
- how do I fix this braided line? pic
- turbo head parts?
- cam seal stuck in pvc black box opening instead of block off plug, need HELP!!
- best size spring for wastegate
- No longer hear vtec crossover after turbo install?
- 463whp 310wtq(15psi) KMOD Performance Custom Turbo Kit
- Bogs under boost.
- Downstar or Chasebays fuel line kit??
- 700hp h22 spark plug question
- b16 turbo smoking?... comments/ thoughts
- help finding out what holset this is.
- Out of Ideas hopefully you can help
- Injector Dynamics Atomization and Spray Pattern Videos
- D16 W/ Boost Head question
- Golden Eagle Sleeved GSR Block Must See!!!
- gtx35r or 6765
- E85 Fuel Filter You Using???
- d16z6 vitara rich/lean/air/fuel problems?
- forced induction engines daily driven vs valve guides.
- Reasons for a blown engine?
- LSV-T Balancing
- 94 civic gsr-t
- Norcal Engine Building Shops
- Biggest intercooler that will fit on a 95 civic sedan and hatch
- Turbo F20b build - what do you think?
- -------93 Del Sol Turbo Catch Can HELP!----
- intercooler piping
- Psi keeps getting lower on d16z6
- Integra Type R Intercooler fitment
- Help identify turbo
- f20b boost
- Precision turbo. Please identify!
- QUICK QUESTION NEED HELP P2W CLEARANCE
- Anyone consider running the SP quick spool valve?
- b18b1 turbo rebuild questions
- Integra AIT sensor code 10 issue Hot weather
- 5 BOLT DOWNPIPE 3"?
- 1st time building engine, couple questions
- new/new b16a2 numbers you'll like
- Choosing correct turbo & IC piping size
- Different Turbo's, Which?
- Stock turbos?
- alternator jdm b16 vs usdm b16
- Go-autoworks turbo kit
- Head's Up Valvoline VR-1 Full Synthetic Racing 20w50 Oil On Sale!!
- eBay Turbo Kits? Yay or Nay?
- Greddy 18g manifold B series
- COOLING HELP: Water Spray
- cp pistons on back order
- 8:1 compression FML what to do?
- Are these stock sleeves?
- White smoke coming out of exhaust one time...any ideas?
- A/C Manifold?
- q16 or e85
- Good deal on T3 Turbo?
- bit of help
- D16 Turbo Build, HELP me on my first build please
- Need help on injector
- How to choose a Manifold properly?
- turbo gsr build/E85
- Odd cutting out issue with turbo D16z6
- New dyno numbers B16a
- Wastegate options
- total noob... ls vtec egay turbo
- HELP!!! D-turbo choice
- Vortech Supercharger Help!!
- Piston to wall + Piston rings end gap clearances
- DSM 1G Bov!?!?
- Wastegates?
- Mishimoto IC?
- where to get 3" silencer
- which arp head studs to use??
- Need HELP purchasing turbo
- code 10 IAT sensor
- Turbo kit question
- Edelbrock Performer x VS Victor x
- Equal Length Meaning?
- Where did you read to learn about forced induction?
- Inconsistent misfire.tried everything!! LSvtec GE sleeved Pro1 3582R setup
- Slow Ls/vtec turbo build
- eaton M62 from Japan
- gte electric supercharger(leaf blower)5 psi vortex
- sees engine brake, than wont rev
- go-autoworks intercoolers?
- Street Turbo?
- safely removing the evap purge system?
- waiste gate line
- what cams to use?
- Stock Gsr With T4 T67...
- Headwork opinions
- Divided/un-divided manifold for twin scroll
- anyone else's skunk2 cams fit this poorly?? many pics included
- boosting my jdm b16a with emusa turbo kit.
- Quiet Turbo Exhausts?
- Precision Turbo repairability
- Greddy Evo2, Turbo?
- Gsr turbo suggestion
- Question regarding BOV's
- jackson racing s/c
- Mid compression Gsr turbo build
- Anyone know about this Holset?
- Ughhh i hate to search!!! help lol
- new tune b16a2
- b18c5 turbo build
- 2000 gsr turbo build
- B16 Turbo
- Was going to go for TD05-16G for my ITR but..
- ramhorn manifold in crx?
- Did I get the wrong injectors? pic inside
- Boosted B16A
- Hp #s e85 vs e98 On my hta86
- decking a stock block
- Beware before you buy...
- struggling to start
- h2b turbo?
- spark plug setup
- LS Vtec turbo rebuild! Lots of pics -*Now parting out/selling*
- OEM honda single layer exhaust manifold gasket.
- Wastegate spring question
- b18c1 300-350hp suggestions
- turbo build helpp lsv turbo
- new turbo setup all help would be nice
- 700 hp goal h22 build turbo help
- t3 t4 .63 vs .48 exhaust housing physical size
- dump tube and flex tube
- Fuel psi
- no-start after dyno tune
- single cam slammer. can dd this???
- lean and rich problem
- Evo 8 Turbo
- b16a2 custom supercharger kit with fmic
- turbo kit HP?
- OBD1 + B18 Boosted + HFC + Tuned = PASS GA Emission ???
- oil feed
- Injectors for my B16 vtec head MSD?
- Car will not boost past 5psi
- Dump pipe
- My EK B18C with B16A head turbo build
- bottom end built for boost?
- top fuel turbo kit
- SC44 2.5 or 3" Downpipe??
- new to hondas but building a track car
- Why more hp, less tyre distance!?
- Best bang for my buck
- head porting advice (NOT A DIY)
- Chipped Compressor Wheel, Big Deal?
- Silver Surfer
- turbo suggestions
- hondata 4bar
- Removing turbo... need re tune?
- Cai intake vs cf elbow with aftermarket filter
- Turbo K Series Civic
- wrap vs. coating
- Another gsr 6262
- Need some info on turbo downpipes Help!!
- 780 injectors too much?
- stock gsr turbo setups here
- what you guys think bout this set up (lsv sleeved 84mm 2.0L)
- Major adjustment issues with crome
- White smoke and excessive crankcase pressure after recent build
- 72mm TB to big?
- Help with dd turbo setup
- Painting a waste gate?
- How to prove block is sleeved?
- 2L built ls vtec what turbo?
- 500+whp ls-vtec sc61 e85 powered by cast iron log manifold possible?
- AEM UEGO wideband wiring
- Any one with a precision 6069 on a 1.8L?
- Ferrea valve springs with Skunk2 Pro 1 cams
- need advice
- GT2971R what will it run?
- GReddy Internal Wastegate Actuator
- oem bearings are too tight, where do i go next?
- Boostie 2012
- High/low boost setup!
- intercooler setuo question
- 2000 prelude jrsc prelude front and rear main seal issue
- Best nitrous kit
- first oil change with new turbo setup and original motor
- diy replaced valveseals and lapped valves, does it look ok?
- 6765 exhaust housing size choice
- B18B1 Turbo Question?
- help identify this turbonetics
- 1999 Honda civic si help
