View Full Version : Forced Induction
- ls turbo or ls/vtec turbo?
- got oil coming out of my BOV
- Has anyone ever dealt with www.turbomanifolds.com?
- AEM EMS Questions
- Compression ratio vs. lbs of boost
- what kind of tranny is this?
- Turbo Selection
- do they just sell .......???????
- Turbo R's please help????
- VAFC hack instructions
- My For Sale List:
- raising boost - *17psi spike!*
- new track times - *w/vafc hack*
- Weak spark problem :(
- LS/Turbo (help please =)
- what should my idle fuel pressure be
- Greddy AF o2 in stock o2 place...bad idea?
- for sale
- Hondata updates tunes library with another 40 base maps
- Position available
- who has installed pistons/rods with engine in car?
- ECU question
- Help!!! Replacement B&M FPR Brass Nipple
- F-Max Or Drag Gen 3????
- Boosted sohc Times
- Nitrous and Boost
- Street/Strip
- who can get MSD products cheap?
- some basic turbo questions
- interesting. . .check the link.
- heres a thinker.....
- Why do so many people say the typical a/f guag sucks?
- headgaskets
- drag wheels and slicks...
- Anyone boost a sohc non-vtec?
- Is there some reason more people here aren't running methanol/water injection?
- obdII automatic to obd1 automatic wiring
- Good sixe turbo help??
- Dynoed yesterday...guess its AEM EMS time. Info inside.
- Attentio EMS users
- Finally a turbocharged Honda production motor in the US
- d16 300+ whp!
- timing retard w/ turbo
- Ever try a super 20g?
- I need help...rear main oil seal won't come out.
- How much money should i set aside for tuning?
- cheapest place to get cometic gasket?
- ls/vtec detonating when switching cam? (vafc hack and stock ls computer being used)
- which is considered "out" on the vortec FMU?
- Supercharged ls
- HELP i need a manifold for h23 (prelude) which one?
- Need help with my fuel setup.
- waste gate presure source?
- visit to Area 51
- Blue wire on S-AFC use.
- trim question about t3/t4
- Kiwi Manifolds
- NX Ntercooler?
- Is this going to cause some problems? pics
- drag 3 air filter doesnt clear the hood, does yours?
- help me decide whice turbo to get!
- In need of a dump tube
- What amp fuse for a nx kit
- Greddy Type R BOV
- Anyone from MN familiar with Turbo Installs?
- Different turbo need a different fuel/timing map?
- When going boost, what guages are needed?
- Turbo Gods + Darksider’s…Setup Critique and Pricing
- Rant he turbo teg last night
- Fmax's downpipe
- My for sale list!
- fmu question
- Supercharger Install gone Awry
- BOV flutters, do i loosen or tighten?
- O-rings vs raised sleeves
- A little cooling issue
- Turbo SOHC!!!!read!!
- My fuel setup, you comments are welcome and appreciated. (LONG)
- help diagnos the problem.
- Custom turbo-how to regulate boost?
- Price Check: Putting in pistons and rods?
- Check my for sale list. Turbo stuff
- DIY charge pipes
- NuImage Manifolds?
- 3" thermal exhaust on eg hatch...anyone have a pic??
- Sohc Turbo,good&kinda bad
- Uh oh, a b18bturbo imposter. BEWARE
- M45 and Timing?
- are the log style manifolds any good?
- need some very technical information on a turbo
- Look what I just got...
- TNT (aka Turbo Nitrous Tuning)
- HELP! Strange Loud noise...
- b16 with sohc greddy turbo kit? what are the possibility
- drag gen III e.t.'s
- ** ITR Turbo Help **
- what is the max boost that i can put through a TD05H-18G turbo?
- Victor X or skunk 2 for Ls-Vtec turbo set up
- How many of you guys running B20VTEC Turbo + more then 14 PSI on stock sleeves?
- backyard turbo pipng....can this be done?!?!?!?!
- How safe am I w/ my setup?
- o2 sensor help!
- high egt's running rich?
- Timing with my turbo? Please Help!
- Help! Drag 3 GSR running crappy ET's.
- question about gauges
- Quick question about Oil pressure/temp gauges.
- GReddy Type-S BOV @ 6psi...
- How will this react?
- What is the most whp output on a t3/t4b turbo you've seen on a H22A?
- HAL Fuels?
- OMG, I know where the lost paradies is!
- Bolting the turbo the the manifold question...
- wheel hop at low rpms....why!!!?
- **Best Intake Manifold for Turbo?**
- My fuel lines: pics
- front mount intercooler question.
- Where do you guys order your Cometic head gaskets? Need to find a good price.
- help???
- heres the symptoms, please help me name the cause
- FMU Disks? which is which
- What kind of tools do you use?
- online directions/write up from greddy T kit install?
- Injector duty cycle
- Oil return help??
- My compression numbers, am I good to turbo it?
- Rc injectors
- 87 octane in my tank what should i do
- Im
- oil feed adapter?
- I need I/C piping in Dallas area
- PLEASE post your online SHOP here
- Anyone running AEBS Sleeves?
- 17" w/ BF Good. Drag Radial or 16" w/ Nitto Drag Radial? Help! No flames either =)
- Anyone know where to cross reference a Honda part number.....
- Mazda 626 gt turbo injectors good or no?
- LS/Turbo beginner help please!
- Initial dyno results on my setup.
- hondata problem
- I did not know what shot peening was, so i found this
- 608 horsepower on stock sleeves.........................
- damn this sucks, what is this supposed to mean?
- Are these DSS Stage 3 Axles?
- Ross Racing Pistons - FI app GROUP BUY
- where are all my supercharged b18b's?
- ls rods + stock d16 pistons
- IAT gauge?? Usefull, or useless??
- When does your car hit peak boost?
- Removing f-ed up bolts??? and other rants...
- Need help for track tonight...
- Anyone been to Alamo Autosports in Arlington, TX?
- Engine Bay Heat Problems!!!
- V-AFC settings for 370's, 6:1 FMU, and 14 psi?
- i need some professional bckyard turbo help!!!(littl long)
- avc-r help!
- fuel pump intank or external?
- What exactly makes nitrous work?
- Is it possable or worth it to upgrade my current turbo.
- Zdyne Users Need help with 2 bar MAP sensor........
- How important is egt gauge?
- What do you use to keep your engine temps down?
- Who here has cracked their stock sleeves?
- exhaust smoke
- Clutchmasters Stage 1
- :| tell me what you think..(engine damage?)
- Moving the Actuator on a TD05-18g
- Does anyone use the Clutchnet Stage 3 clutch. How is it?
- car stalls when slowing down
- just bumped the boost up
- Is this a good or bad turbo for an LS
- Running way to rich I think.
- Is anyone hear boosting an ls/vtec?
- APEXi SOHC turbo guys
- B18A/turbo smoking?
- pple with greddy sohcs
- hondata question
- Feel VTEC With Turbo?
- what size belt to use with endyn stepper pulley?
- how did you install your pod
- Anyone need a intercooler?? I'm selling mine! Greddy Type 24
- how to hook up Blitz DTT turbo timer??
- Best DP size for GSR with Greddy kit?
- Garrett Turbo Prices
- what the heck, electric turbo charger????
- Group buy on garett turbos.
- 3 or 2.75 inch piping on gsr 8 psi max boost ?
- how tightly screwed do the oil fittings have to be?
- ***NEED HELP ASAP! need valve adjustment specs for SKUNK2 cams!***
- Thinking about putting my stock muffler on my car. Thoughts? Power loss?
- Resistor Box...
- Turbo ITR's...Where is your timing set at?
- Ethanol safe for FI??
- my recent trip tp Jg (pics)
- integra gsr jr supercharger advice
- rebuild
- Arp Head Studs
- gapping @20 psi and plug quetion
- 02 Simulator
- Missing Link MAP Bypass...do i need this????
- Bent Valves????? Setup & Dyno Sheet Included
- anyone have "mini" backfires?
- Full-Race equal length A/C compatible manifold... (Richard/Slowcivic's manifold)
- CEL question
- What is the best single fogger wet (75 shot) nitrous system out there?
- chip for turbo car on e bay???
- J&s ultra safeguard
- Possibly considering maybe going turbo... sometime
- Turbo-Performance Prelude Manifold and 3" dp...
- How do manufacturers sell kits without a BOV?
- what parts do i need to make a fitting fit on the oil pan? dont want to weld it on!
- IC Piping, Greddy Sohc help please
- fuel rail Q
- Need IC info
- VAFC on greddy blue box
- profec b boost source....turbo or manifold
- To keep my Blitz TT or not?????
- WTF...this has me Totally stumped! Check it out.
- OT: Lookin for Good Shop to get Turbo Install
- Fuel Pressure Guages? Hardware store work?
- Homemade 'Teg Turbo Kit
- Have you guys seen this...?
- Boost the H23 or H22....?
- Turbo Stuff For Sale
- Mechanical or electrical Nitrous gauge?
- can someone tell me what this is?
- Need Garrett 4bolt t3 exhaust flange.
- Eagle Rods Group Buy
- Nitrous backfire now car runs like ass...help
- LS Crank in B18C...
- My rant about Moroso Oil Pans
- Turbo Performance products...
- turbo on 98 ex
- Damn HKS! Can someone hook me up?
- groupbuy: oil line kits
- Turbo ITR on its way to Boost!
- Which Injectors............
- Redecking a block..when is it necessary?
- break in procedure
- Guess what.....I'M FINALLY BOOSTED!
- Turbo on an Automatic
- 91 GS Integra/turbo needs asistance idling/ please help
- Re-drove this morning
- Drag or Custom Turbo Kit?
- Stock injectors cc on 2000 civic ?
- Need cheap inline fuel pump...
- What are the specs for this turbo? Please help ya'll
- How long does it usualy take to cool down...
- help Viren....
- Nitrous express question- help please
- Smoke help???
