View Full Version : Forced Induction
- Selling everything from my monster turbo build up! Alot of stuff here!
- I'm bored on a Saturday night, so I made this...
- Buying a head from Auto Salvage, do I need to have it resurfaced?!?
- please help me get my car running before monday
- I want to do a Turbo Ls in a Crx, and I want to use a smaller stock turbo to get alot of low end tq.
- B18C exhaust manifold gasket same as B16A?
- Turbo Timer
- Projected 1/4 Times?
- Will a turbo kit from a Civic SI bolt onto an Integra LS?
- Missing link...is this a good one? does it matter?
- MSD Boost Retard Controller Needed!
- 60-1 with .82 a/r housing on a 2 liter Ls/vtec and MAXREV manifold.
- Custom 3" DP and Exhaust DONE!!!
- clocking the middle of the turbo???
- TERRRRRBOOOOWWWWW completed, pics inside..and a few Q's...
- What downpipe?
- i need to know if i can use this fmu....hurry! 20 min!
- Mike P's injector cleaning service
- What is Blowby?..
- headgasket...
- My turbo ......maybe for sell
- ram air time....
- is the stainless steel tubular revhard manifold a street driven manifold?
- Doing engine build-up, need company information please.
- clutch disks
- DRAG kit has been ordered =), which exhaust to buy?
- ls swap
- help with oil connections on the turbo itself, already searched.
- How's the blitz twin solenoid boost controller?
- Turbo Gs-R
- apexi turbo timer ?
- Backfire after clutch install
- she starts..................
- what injectors fit
- Wideband #'s
- i need a oil return line
- o2 sensor a/f ratio and o2 voltage
- Question about turbo exhaust blade a/r
- 1/4 mile time question
- POS Boost gauge?
- how do i clock my turbo when its all rusted?
- Where can I pick up a D16Y8 head?
- JRSC problem
- Why the hell am I running so rich?
- turbo and emissions question
- Rebuild D16Y8 or do a Swap?
- Blitz BOV For Trade!
- Where do I plug in the check valves (MAP Sensor)
- OK; Can I use the black box I have or NOT (ZC)
- couple of turbo questions
- ATCO IDRC this weekend.....
- Engine Tuning and 15psi
- need turbo install help
- how much?
- Detination Problems!
- drag vs greddy part 2
- Fuel system
- My birthday presents came in today!!!!!!
- What octane gas??
- urgent: eagle rod fitiment issue
- NEED HELP, I'm Blowing oil at idle but as soon as the car goes under load its fine, It doesn't blow
- vortech supercharged itr?
- who makes 350cc-370cc injectors that will fit?
- Need Help w/ Black Box wiring..I only have 4 wires not 5...
- Autometer AF gauge acting weird
- analog s-afc work with '99 integra gs?
- has anyone put a turbo on a type r
- AEM EMS $1100 Brand New
- where to buy some strong axles?
- Safe boost to run with 9:1 and stock fuel and ignition?
- OE Cams for turbo b16
- Do I need to replace the crank/rod bearings with my engine rebuild?
- Just got back from dyno... :(
- i was wondering if anyone has used the greddy piggy back fmu in there car
- a couple really easy questions
- Checked my ROD bearing clearances with ACL bearings...
- Blow Off Valve Location....Where to put to make it the loudest?
- Funny new product...
- greddy turbo stuff for sale if anyone is interested
- complexity of wideband o2?
- Pressure loss....cracked IC?
- Turbo Parts needed?
- Anybody vouch for Turbointegra??
- ... voltmeter as an a/f ratio gauge - need voltage ranges
- bolts and studs
- itr valvetrain..HELP
- Drag Gen 3 Turbo Kit.
- about 1st gen B16?
- LSVT now, change back to LS ??? What to do ?
- Dynojet datafile conversion.....
- greddy sohc turbo kit in GSR
- look at this cute lil guy......anyone running one of these?
- feul setups when uping the boost from 6 to 9 psi on a jrsc
- Anything to do the tranny to beef it up? 3rd Grinds =P
- Sohc Greddy turbo dyno?
- NEEDED: someone in NY to tune a Zdyne turbo built b16a
- Some DRAG questions....
- Forced induction
- fuel cell vent questions
- OT: just bought me a Tahoe
- what can be my problem here?
- proper way to install a blockguard?
- car stop pulling after 7000rpm
- fuel filter maintenance and brands
- Rebuilding Turbo
- direct port nitrous setup question
- B18B1 + SOHC Greddy kit + DSM IC + more... read
- Where to get TD04 exhaust flange?
- Guess the 1/4, win a prizzise!
- LS rods in a d16 turbo?
- interested in a nice turbo????
- snappin axles?
- LS or GSR for boost?
- who makes a good equal length trubo manifold??!
- Will pay if you help me with my afc problem? Need help bad!!!
- I put in my HondaSaver Clutch today !!!
- fmu and vafc question...
- Good place to buy Garrett 4-bolt ex. housing flanges?
- misc info...
- cutting drag3 piping for jg intake manifold
- Boost Controller
- sohc people @ what rpm do you hit full boost and with what turbo ?
- Missing 2 main caps to my GE block
- Daily Driver Turbos
- v-afc hack????????
- How much boost for 12's?
- anyone with aem ems need info
- import builders "killer" turbo kit
- B-Series Turbo Parts list
- spark plug help?
- Whats the going price on a 91 GS turbo teg?
- turbo stuff
- Opinions on Greddy turbo kit for 99-00 Si?
- Crap, have a problem...
- Selling the car...again.
- Hoserpower
- PowerFC knock indicator/way to test knock sensor?
- can i use this turbo?
- ... hondata base maps needed
- forcing a wastegate open?
- Greddy kit questions
- D-Series Custom Turbos
- i Decided to sell my turbo kit..
- Gasket material?
- Pre-Fab Intercooler Piping Kits.... What do YOU need ?
- This weeks low down specials.
- Water Sprayer???
- Which headgasket!!!??? I am fuk!!
- blown greddy td40h need help!
- What to do w/ breather hose on valve cover/intake?
- hks EVC
- Standalone (AEM EMS)
- Would you fellas recommend that I buy a BTM or the like? PORNO NOT INSIDE!!
- anyon
- Has anyone ever done this?
- 9 or 10 psi too much on stock internal LS integra?
- Buying used turbo's
- need some vafc help
- Full-Race turbo kit (and a pic of maxrev IC)
- turbonetics racegate 42mm WG same as tial 40mm?
- nos plate kit
- bore size
- **catch can?? is it neccesary?**
- how does the GT30 turbo compare to the t3/t4 turbo
- Who wants to sell me a used external wastegate?
- how the hell do i spin the compressor to a different position?
- Electronic vs Manual Boost Controllers
- basic manitance for nitrous??
- NEED HELP FAST...I keep on blowing the ecu eat ecu fuse
- boost question
- urgent! need pic of obd2 to odb1 conversion harness
- do i need an fpr....i'm confused
- turbo or nitrous...
- Turbo Newbie Q's: External Wastegate, Catch Can, boost controller....help
- need help tuning turbo sohc crx
- 1 psi=How much HP boost? And 1/4 times effected?
- HKS EBC question
- ZC turbo...how much boost???
- **TURBO 99 prelude need NGK part number for 1 step colder plugs
- turbo timer install help
- afc hack on 6psi
- i hate ss braided lines
- Long drives with ur turboD cars??
- Need help keeping boost but no power.
- New Toys...gettin close guys...
- North Central Florida Reputable Engine Rebuilders?
- Jackson super charger????
- kamikaze 4-1 header ?
- Atmel AT29c256 source
- Turbo Ettiquette 101 ... The essentials... 5 simple steps to success...
- Bad Axle?
- for those of you who converted an internal WG turbo to an external...
- VS racing 3inch cat/resonator replacements.
- fuel pump relay
- tial wg special
- turbo or supercharger??
- How do I know which injectors I have?
- Need Clutch opinions....
- help on turbo bogging and hesistation
- new 1/4 mile time for my 99 si
- For those of you experienced in the ways of the diesel.....
- REquest: T25 turbo template
- Best price
- 10 psi on 60-1...boy its fast!
- ECU Diagram needed!!
- titanium exhaust question
- Replacing head gasket on 00 SI . WHat kind to get?
- Newbie Question: turbo install
- turbo kits, and components for my 1999 GSR???
- OT: a game
- got a quick question here.
- putting my jrsc on sat ......
- Which ARP Studs to use with B16/B20 combo?
- what is wrong with my fuel????
- carb legal turbos
- Dyno Results on my 5th gen prelude
- Manual Boost Controller.....
- 60-1 Turbo users... Too big for my application?
- D-Series turbo guys...
- OT: Attn. all quick Hondas: come to this event!
- ----> how do i add 2 more injecotrs into my IC pipes and run a on/off switch on them.
- what do you guys recomend as far as a throttle body for a 2002 EX
- fixed the smoke!!!!
- 562whp, 300 tq... BETWEEN YOUR LEGS?!
- any je or wiesco gb's going on?
- avcr reading 80% throttle at full throttle, will this mess w/ anything?
- will this turbo fit
- Need afc hack help, bad. Good untill I get on it all the way.
- clocking the turbo
- VAFC question?
- Bar's Leaks and Golden Eagle Sleeves
- fuel injection
- Hey guys Who wants the new APEX JAPAN ONLY EL2 series guages
- Latest Package 3 Turbo is released. New and improved. 17 PSI
- hey need input on on fuel for 99 civic ex
- T4 62-1 vs XS T04X
- Intercooler piping install on an EF, plz help...
- What is the highest tq numbers you Have seen or Have out of a Turbo b16/b18c/b20Vtec
- Dropped my oil pan, help on placing return fitting... (ZC)
- who can get gt30s?
- stock oil pressure sensor
- charge pipe ?
- nopi drag race/ aug 17 results
- 1998-2001 LS Ecu P75 Ecu OBD1 or OBD2?
- Compression numbers on my turbo LS.
- Tenative Name Your Own Turbo Kit Pricing
- what size piping for low boost levels...5-7psi
- apexi BB turbo
- Can't do the compression test right ... ************
- ? regarding turbo piping.
