View Full Version : Forced Induction
- FOR ANYONE GOING HONDATA!!!! talk to UBERTEG at Blawar on AIM!!!!
- No Spark with SpeedPro
- Where to get clutch accessories?
- making own turbo piping
- detonating after turbo UNinstall
- Building GS-R Head for turbo...any ideas?
- Code 15 !!!!!
- AEM wb and hondata
- How to install 3 bar map sensor?
- Calling all sc SI's (need info:power, times,etc.)
- turbo kit or custom turbo kit
- Head separating from block
- Five Bar Map Sensor
- boost gauge not at 0 psi ??
- b20b turbo dyno tunning help
- confused about hack.
- HELP! cylinder full of gas!
- A little bit about everything, boosting wannabe.
- bad o2 sensor??????
- Just hit 1500 miles, and the turbo goes on on the 14th!!!!
- what should i use for fuel managment?
- camshaft - design, selection, theory etc...can anyone recommend some good reading ?
- losing fuel pressure!!! somebody help..
- Greddy d16 sohc turbo problems
- Mini me turbo?
- what are your times w/nos in a sohc vtec?
- external wastegate installation question......
- T4/60-1 on B18C5
- Fist Mods
- how much rebuilding to rebuilding kits actually do???
- bearing tolerances, line honing, and sleeved block
- FI Experts! New way to supply oil to your turbo theory. Want your opinion!
- ebay turbo mani? looks legit help me decide?
- OBD-I ECU
- how do you tune for nitrous??150-200 shot direct port
- Spoon Ventuli Plate and NITROUS !!
- What rings to use on Weisco pistons stock good???
- nos,turbo,supercharger? which is better??
- what does purge do
- Liquid to air, ic, diagram needed
- Most affordable standalone for OBD2?
- Turbo too big?
- I'm going to Cali to see my buddy damon....
- turbo sohc recipe
- Revhard 2C kit, discontinued?
- Wanting to buy built b18c or b16a block
- Turbo is badass!
- Curious question about BOVs..
- How long have you been turbo'ed?
- Autometer Boost/Vacuum Gauge Hookup on JRSC
- max boost with this setup (new car im buying)
- integra turbo recomendations (fuel setup)
- JRSC VTEC Engagement Point
- Im nearing the end of my turbo setup and need a clutch now.........
- Brake boost hose - Tee fitting size?
- 2.0L B18b LS-T
- calling GREDDY SOHC turbo guys...
- t3/to4b question
- Please Tell me if this is possible for h22a?
- 857hp 537lb trq from RAPTOR race car!! John Brown and Pacific Performance
- GReddy E-Mange on a CRX
- Engine Rebuild Question
- Need Help with wastegate !!!
- help t25 zc not boosting
- which gives more power...jrsc or greddy turbo kit?
- B16 Turbo guys..plz post your dyno sheet
- anyone get 550s from viren? are these 550 injectors?
- Running on 2 cylinders??? tried almost everything?? WTF!!
- PRECISION SC54
- D16 turbo mani options???
- VAFC + Greddy black box
- FMU/Missing Link/SAFC questions
- Problems with JRSC installed on my Type R
- Anyone with BIG intercoolers that didnt cut there stock bumpers? (integras)
- Replacement for Displacement?
- ALL GReddy 30% Off -- JE Pistons 495 a set -- Fourth of July Sale!
- SOme ugly Pics
- blow off valve installation
- GReddy Turbo'd Si...dyno inside...
- Caught theifs in the act of stealing my ride.
- 2000 accord ex turbo
- Open Downpipe, Is their any advantage or disadvantage to this besides the kick as sound?
- stage III vs. stage V 60-1 for my 2.4L prelude... that much of a difference?
- what is the phone # for SGT
- stock c motor on Nitrous?
- How much power?
- Custom Turbo Kit
- S-AFC2 ???'s
- Anyone ever spin a bearing from running to rich?
- Does anyone know if this really works??......
- NY Emissions
- what air filter to use????
- turbo manifold suggestions?
- Compression test question
- 97+ Greddy Tubo on a 95 H22
- overboosting question
- Blow Off Valve Adjustment?????
- Boosting Problem...Please Help!!!
- wrong oil pan kills my turbo
- is your BOV open/slightly open OR close during idle?
- is my greddy profec b complete? here are pics
- Not Honda but still FI, hehehe...
- what psi max for eagle rods? and can stock gsr sleeves hold up to 18psi??
- b18b @8psi vs. h22a4@11psi?
- Help with tial wg install
- blown turbo seal... what now?
- 99-00 turbo civic si people, middle of install and i need some ideas
- ... gsr skunk2 intake manifold question... (throttle cable routing)
- TurboXS Type H34 Blow off Valve
- Need to pass smog check in CA, anyone???
- How would i set this up? Fuel Hack
- code 14 is pissing me off
- Says im boosting .5 psi ahah help me
- blow off valve location.....
- max power from a 50 state legal greddy kit?
- Can I use the VAFC to tune the stock injectors w/ the blue box?
- Cheapest non-autometer boost gauge?
- turboing on 10:1 compression ratio... safe????
- What do I need to hook up my A/F gauge (noob question)
- MICROTECH STAND ALONE???
- Tapping noises from head
- Anyone run 3" piping into an ITR muffler?
- 94 GSR IN A 94 CIVIC HB WITH A VORTECH CHARGER WITH VAFC HACK
- Anyone have a base map for a boosted H22 for Uberchip?
- where to smog in the south bay
- Best turbo set-up for b16
- sc61 69 trim vs the 76 trim plz help
- Drag 4 kit and no fuel management.....questions.
- OBX AKA Ebay equal length Manifold Q...
- My pics are here
- whats your pick for a B18B1?
- Amazing twin turbo dyno...
- sc61 to4e cover vs to4s cover
- I need help.what should I do?
- TODA Spec D's + NOS??????
- Manifold Question...
- Pass emissions with drag gen III?
- is a t3 strong enough for a b16?
- 92-95 greddy turbo into 98 dx
- JDM Civic TypeRCams good for Turbo or better stock
- these a/f ratios sound right?
- WHOA!!! does this sound like a good deal to you all???
- Can anyone recognize this turbo?(56K beware)
- Greddy turbo kit cheaper than $1430/shipped?
- LS turbo in eg
- Ran Again at the track!! (SOHC TURBO)
- Uberdata is GRRRRRRRRREAT!
- would I benefit from an better ignition system?
- d16z6 turbo setup
- ACT Xtreme clutch people
- JG Block and heat issues
- running turbo setup without hondata?
- Hit rev-limiter last night while boosting-- any damage?
- Will JRSC for a GSR fit an LS
- What do you guys do to the bumper support to make the fmic fit?
- *sohc turbo guru's I need help on buying the right setup
- What do I have to do to make my LS a 2.0?
- vacuum question
- Torque topic how about weight!
- Greddy turbo kit prelude...dyno inside!! (56k beware)
- Hondata tunning
- Msd ingniton ???
- Spark plug cables..
- my turbo blew up
- Drag manifold A/C Friendly???
- RSX Greddy Turbo Kit+BOV+Timer=$2650 shipped!!
- No V-TEC HELP!!
- Clutch?????????? NEED HELP
- supercharge ls/vtec???
- adjustable fmu
- horse power rant
- JUN cams and N20
- GReddy blue box question
- will the d-series manifolds bolt to b series head
- turbo manifold
- importbuilders 2.0L GSR block
- making a turbo kit???
- At what boost does an 8 heat range become necessary?
- Thinking of revamping my fuel setup let me know what you think
- Update on Blake (uberteg) and all that follows
- Any good custom turbo shops in mid-atlantic area?
- Smokin b16?
- Home Depot clear braided hose kinked and collapsed!!
- turbo seals?
- pseudosilvia = shady
- simple question... plz answer....
- SAFC....extra wires?
- Need ideas for IC piping on EF/ED
- B&M FPR with the AFC hack? Is it going to be a problem?
- Custom intercooler piping and Down pipe.
- How long have your motor lasted you with turbo?
- Everyone thinks i'm going to blow my motor.....
- YAY! I got hondata! YAY!
- new turbo install......little bit of smoke, is this ok
- How to remove a/c system on Turbo Si?
- H22 or K20a2???
- My rod bolts were loose?
- Hey some good news for a change!
- Too small of an intercooler =??
- Turbonetics T-Series/ T-76
- How would you cut your bumper out for the IC??
- DSM 450cc injectors ???...
- Manual boost controller vs. Profec B - What advantages do EBC's have?
- did a compression test today
- 2.0L Stroker kit for JRSC GSR?
- big bang backfire
- New toy (EBC)
- My motor is WWWHHHAAAAATTTT?!?!?!?!?
- my clutch
- turbo or all motor
- ITR Intake Manifold gains
- 2 step colder plugs for 95 GSR?'s
- Is this a good Kit???
- Dump tube ?
- wastegate w/ boost controller
- Starion Intercooler Specs?
- Problems Adjusting SMC
- what tranny to use on a boosted gsr crx.... pls help
- my plans
- Eagle Rod Help Quick
- Skunk cams in a Turbo setup
- Liquid to Air Intercooler
- Has anyone run Web turbo cams in an H22?
- new VW setup, short runner intake pics!!!!
- Anyone running Clutchmasters stage 5?
- MSD injectors dont fit!
- Help a turbo brother out! :linked:
- Safe PSI
- Who's got a hondata that runs smoothly w/o any hesitation?
- Air Fuel Gauge suddenlys goes from 9.0 to 13.5 with the greddy blue box????
- damn, clutch net stage 2, still holding!
- Do I need a gasket between a turbo and a downpipe?
- Buying a lightened CRV crank pulley to raise boost on JRSC
- mounting T3/T4 canadian style w/ inline pro mani
- turnin boost down/ installing turbo....
- SOHC Turbo questions....... help please
- Thermal Exhaust
- Blown Leitner & Bush block - pics inside
- More boost from JRSC?
- Where do you find AFFORDABLE silicone couplings and clamps???
- WTS or Trade JRSC for B18B Integra LS
- Piston material
- Online Stores where I can buy.....
- H22a missing link
- MIDNIGHT PERFORMANCE DYNO DAY AND BBQ
- Whats the deal Drop Shop?????
- Building LS for Boost, Detailed Recommendations?
- BOV which work better???
- b18b/16g DSM turbo
- Fields SFC-VTEC hack?!
