View Full Version : Forced Induction
- Who has installed thier Action clutches??
- Who makes the best turbo manifold? revhard, max rev
- Turbo Techs Please help with b16a homemade turbo with hack project!!!!!!
- okay, new problem....need opinion and input....
- BOOSTIN' B16A.... SOME questions on inlinepro MANIFOLD.
- Building 220-250whp Type R
- Need help reading air fuel on dyno printout.
- What Turbo would you use Guys????
- I dynoed my car today.
- its bogging
- whats my A/R size on this thing
- Damn deer, guess I will never get into the turbo mafia now :-(
- What clutch can handle 350 whp and still be streetable?
- nitrous options?
- i think i found the phantom boost leak
- JRSC For sale!!!
- Can anyone vouch for iC Roger???
- installing a set of rods. tangs to the front or back of motor?
- built b16a/b18c head question
- OT: drag3 manifold for sale $275 + shipping
- To VTEC or Not to VTEC? That is the question at hand
- anyone hear from calgary alberta??????????
- Proper way to drain oil from turbo (discussion)
- A Little Confused
- Greddy Type S BOV Adjustment?
- Diet
- 328 whp 234 tq - 11 psi barely tuned
- What are Prelude injector sizes thru the years???
- What would you guys do? t04e or 60-1?
- Question about my setup and race gas
- Aluminum pipe
- Install complete--Have questions
- More fun radius arm talk
- Greddy Sohc OVERHEATING !!! HELP Please !!
- smc and timing
- Why is my fuel pressure so low?
- ihi vj-11 Mazda turbo any good for b16
- B20 Vtec
- Stupid black breather box on my 96, not on the 2000?? What gives?
- Looking for some sort of fuel management what is the AFC Hack?
- total noob question...
- B18A/B stock sleeve durability
- finally I have switched over to the darkside....
- Need pic of B-series SFP manifold with high temp coating... did search already
- SMC and JRSC questions..........
- nitrous qstn
- .57 trim a good size for a b18b?
- 7.45 @ 185mph
- OHIO guys...anyone wanna come? Putting my block in, then going racing (Saturday)
- anyone use an inline oil filter for oil feed line?
- b16a head built for turbocharged cars f/s
- Which Radiator
- Internal WG Flange
- fueling problem
- The new setup is finally done and i'm ready to open it up at Imports vs. Domestics next weekend at M
- Tial or Deltagate
- In a bit of a bind and can use some help!!
- Max boost on ZC on 93 Octane fuel?
- Anybody with Skunk2 Cam gears...
- help picking turbo on a b20a
- how much boost on a d16 rods?
- quick help with hondata and injectors
- Timing
- psi on stock internals
- Turbo Setup
- ... stock intercoolers... dsm smic, starion fmic... others???
- Trust my S-AFC or Autometer Boost Gauge????
- Hondata tuners in or around El Paso?
- AFC Hack Setup
- 450+whp.what air Fuel Ratio?
- Should I run Boost on my new set-up
- ? about sleeving
- Air Fuel Gauge not working properly *HELP*
- Stuck at 7psi of boost!
- How hard to get 300 hp form sigle cam Vtec?
- 400HP ZC.....Stock intake manifold?
- LSVTEC no drill Dowel pics (can be used on vtec heads/blocks also)
- people fully built need help please (piston slap)
- FS: Tial 35mm Wastgate, Greddy Type S BOV, Max-Rev Custom 3" Downpipe, Missing Link *Cheap*
- I need a straight answer!
- ... saab / audi turbos & starion fmic... where in the engine bay???
- spark plug gap?
- FMAX horror story
- revhard stage one...
- Since everyone here is quite smart....HELP!
- Installing NOS on a CRV?
- Help! bogs after i shift...
- unplugging map sensor
- My magnetic drain plug at work...
- tranny mods for d16 turbo
- What degree bends do I need for a custom exhaust?
- Bad O2 senor???
- Stand Alone Engine Management
- car doing something weird...help please...
- first thoughts on AEM automapping
- Oil cooler
- Cost of getting a td04h rebuilt? roughly how much?
- What gains if I switch to an MSD 6A box?
- Turboing my D16Z6 SOHC
- Turbo S2000 (PICS)
- Got my car dynoed this weekend
- OT: SMC for sale!!
- Walboro fuel pump problem?
- 2.5" downpipe -->> 3" cat : how does it work?
- vouch for egcivicturbo?
- I/C pipings (Civic Si, Del Sol, Integra)
- b series manifold?
- I want to put down 300whp
- Stand-alone for the CRX?? Calling Crx People and others!!
- Can you only buy Zdyne's from Zdyne?
- What is the part number for these plugs..
- Worth boosting a honda? Got regrets?
- Boost Gauge
- AVC-R is amazing!
- revard 2c... Complete?
- KA-Boom!!!
- .20 overbore, stock headgasket?
- Break in over..boosting again!
- how much boost? b18c1
- si ls tranny difference????
- does any company sell a compete engine build up kit?
- dirt cheap golden eagle 83mm block , crower rods and more only 900.00 brand new
- injector suggesstions?
- Which FMU calibration with rc 370's?
- 6 grand to spend
- getting a B20B re-sleeved.. where to go?
- Does anyone use GT series turbos?
- went to the track and got some shitty times agian.....
- Which ratio FMU to get?
- Balanced and micropolished crank (pics)
- manifold and downpipe gaskets
- GOT my GE SLEEVED BLOCK. Worried while buildin'it...
- More Auto Integra Turbo Track Times
- 3 bar map sensor with EFI PMS? HOW?
- WHEN should the ignition system be upgraded????
- turbo RPM gauge...check it out!
- Rev Hard...wow I didnt know such a big company could be so immature..
- Behavior of DSM 450cc Injectors without resistors.
- How much boost is safe on a stock JDM H22A?
- pics of my new engine bay,,,,,,what do you think?
- Hondata ??????
- 12's
- Turbo and Automatic
- New Auto ls turbo track times!
- Hondata Tuning???????
- Ethanol VS. Methanol
- the phantom boost leak
- Flared Sleeves?
- dsm tdo5 b16a with afc hack help
- 10 psi
- Tial HP (High Pressure) comments? Better then my standard 35mm?
- Eagle Stroker kit makes a B18 into a 1.93l anyone tried it?
- Boost controller questions
- I have a chance to get a Supra please buy my car for 10-11K now!
- what exhaust if everyone running?
- Rods and Pistons for d16z8
- My sister had one of her friend's visit... Domestics are better than Import types...
- Turbo recomendation!!!
- turbo gauges ???????????
- STR turbo intake manifold
- has anyone blown their engine @ 10psi or less w/correct fuel management?
- Calling all boost-aholics in columbus ohio region!!!!! Need help with turbo probs!
- NX maximizer or NOS progressive controller
- F-max turbo kits
- Cannot turn up the boost, Need everyone's input on this one, HELP!
- TechEdge Wideband O2 Sensor Available NOW at Partsbin.com!! Part # C5010-75044
- need help for turbo boost controller
- More detailed problem
- JRSC for B18c Wanted
- tubo for d16 00 civic
- lsvtec JRSC needs injectors.
- HKS bov gasket??????
- Friend gets his b18c1 block resleeved FREE
- sohc-vtec turbo question?
- car stalled out due to to much fuel.. please help!
- another sohc turbo, ideas on setup help
- for sale..down pipe and front mount IC..check it out
- n2o plate reduce air flow!?
- Bearing and Oil Clearance thread?? need link
- have some questions for the turbo peeps out here ???
- No oil to turbo, help please.
- clutchnet stage 2 experiences...........
- TD05-14B OPEN ATMOSPHERE internal wastegate
- Is it common for oil return lines to leak oil?
- Back from the TRACK again!!
- Hondata s200
- check out my turbo gsr civic
- What's the Difference Between BPT and BSPT?
- FS: Turbo intake piping, All earl's -3, -4, ,-6, -10 AN lines and fittings, cat, pistons, rods look
- ------> What do you guys think of the MOTEC M4 ECU??
- Problem with my Check Valves...!!!HELP!!!
- Need Help with blown Bov!!!
- Attention: XLR8 4U / Turbo Black Prelude in Rockville, MD
- Trim on a Greddy TD04h 4 SOHC kit?
- I am almost ready to go
- k26 too small?
- Water cooling - is it worth it??
- noob question about dump tube
- 13.7@104mph......What do you guys think??
- HP Intake Manifold
- Turbine Housing Stud Question
- LS/VTEC 4130 no drilling required fittings now availble! Also BSPT to NPT 316 SS
- quick bolt question
- Could someone please explain what CFM means?
- A Christmas List! What would you put on it?
- JG Edlebrock 65mm T/B and Victor X
- fuel leaking out bottom of vortech fmu????
- any ideas on loosen two nuts stuck on a studs ?
- 2nd turbo setup, quick question..
- any aem ems tuners in southern cali?
- How big can you bore a B18C1 to?
- 100 Shot of Nitrous on a D-Engine????????
- Damnit where to get this NGK plugs...
- Closed Deck or Open Deck?
- Darton or GE for sleeving?
- your opinion on running without a thermostat
- 30-1000 1 unit aem 30-1001- 2 units 30-1010 2units AEM COMPUTERS
- Simple question, oil pan weld on bung, steel or aluminum?
- wowsers gsr hits 297 on dyno 13psi
- Water cooling parts list
- ... best equal-length manifold
- Greddy blue box, good or bad?
- RevHard tubular
- f-max kits on a d16y8?
- ls turbo....what trim??
- EDM CRX SiR Turbo pics..........
- Anybody got the number for Cometic HG in West Palm Beach, FL????
- bleeding the fmu line
- where to get a n2o plate system for the h22?
- turbo motor, should i use plate or single nozzle n2o?
- where can i get a compressor map for this turbo?
- Crower Stage 3
- Resistor pack questions?
- Oil disappearing
- removal of one radiator fan for turbo clearance
- Jared, THANK YOU!!!!!
- Trade..Hondata p28 for AEM
- Has anyone dealt with Hondaswaper?
- Comptech Exhuast for FI, DC2????
- need urgent help ASAP....car won't start after installing MSD
- my car is gettin closer and closer to be finished pic UPDATE
- Anybody here mix in race gas w/ pump gas on a daily basis?
- AEM FPR + nitrous = broken internal diaphragm of AEM FPR?????
- Boosting now...but t25 spittin oil, to rebuild, or no?
- Greddy 18G DYNO!!! Yes, "Yet another Greddy Dyno"
- Pentium II with SPEEDPRO?
- EGT reading too high???
- Pics of my Turbo CRX
- any way to turn bost down to 0?
- zex 75 shot on my b16...did search
