View Full Version : Forced Induction
- best headgasket for d16?
- Ok to run Fluidyne Radiator w/out Fans?
- **who tunes Greddy E-Manage in SO CAL???
- B20 BEARINGS FALLING APART =-(
- new SPS forged pistion oil smoke
- 350whp turbo? Need advice.
- garrett t3 off of a sabb
- Car died, won't start, can't seem to find the problem...
- What bends do I need to do my FMIC piping?
- why conservative and not aggressive air fuel ratios?
- Those with turbo's Super close to the block, see any overheating issues>
- SOHC: ARP 2000 rod bolt torque specs in D16A6
- b18b1 turbo finished and dynoed, but unsatisfy (pics)
- 98 LX Accord looking to turbo
- D series stock sleeves good for???
- a/f gauge install
- d16y7 - best turbo kit for safe boost?
- boost on my t3 int wastegate is only getting to 3 psi?? need help
- full race traction bars 98-02 accords
- 833 whp 549 ft pounds Daily Driven...Tuned by MASE
- B16 INJECTOR QUESTION
- radiator - overheating situation
- turbo timer install questions
- Vegas Tuners? Anyone else wanna setup a tune day??
- import power house turbo manifold?....
- Holsted HX25W decent?
- Does anyone know where to buy..
- Vacuum line questions
- Golden Eagle Intake Manifold Fittings!!
- Who can tap downpipe bolt holes on the turbo?
- BLOWN TURBO QUESTIONS
- t66 ball bearing turbo question.
- Turbo Rebuild @ home, whats involved?
- i need an apexi safc2 basemap for my integra
- best ecu for the job?
- Check out the pics of our Turbo Prelude Anti Reversion manifold and L/A intercooler
- Weird Problem with fuel consumption. Help me troubleshoot.
- will a stock p28 work with a gm 3 bar
- Check out this crazy AntiReversion 2JZ manifold my buddy built
- Fab works
- Turbo manifold for a h series?
- Timing for LS/VTEC w/9:1 CR
- turbosmart boost controllers yay nay, lets hear what you say
- timing belt cover easy to remove during dyno tuning?
- Major boost spike
- Vafc,450 injectors and 255 walbro at 10psi???
- gsr or ls tranny
- best oil to use for ls turbo
- Who has methanol injection "Snow Performance" on a JRSC set-up ?
- lookin' for bay area tuners...
- DYNO numbers are in: B16a CRX (STOCK) with SC61
- *NEGITIVE BOOST PRESSURE w/ GReddy e-01*(?) is this normal<<<im nOob srry
- Oil Consumption problems
- Block Is Dark/Dirty
- stock piston durability (autocross)
- Should i retard my timing??
- what is the best muffer for a turbo Integra
- 550WHP on stock ports and valves???
- Wastegates question
- where do they sell ngks
- EP3 LEAK coming from oil feed line to turbo
- where to get AEM regulator vacuum fitting???? damn help!
- What is the compressor outlet size on a garrett t3/t4?
- Best Hondata tuners in Az or NM. Searched,but too old topics.
- AEM Fuel pressure regulator key??
- Dilemma: B16a turbo guys, tell me your timing if you ar at 6psi please.
- msd help please!
- Trying to find Stock Timing map for 99 Si b16a engine
- 90-93 Integra Intercooler Setup Pics
- How much do you think a JRSC 2000 GSR with 78,000k running 9psi worth?
- zeitronix wideband questions... just got done datalogging
- street imports turbo manifold
- Block gurad......
- Megan Turbo Muffler Review
- HELP with uberdata...
- Another Block Guard ?......
- Questionable throttle body connection on non-honda swap, input wanted, pics included
- SR20DET T25 turbo w/ Garrett .48 exhaust housing?
- Equal Length manifolds?
- b16 99-00 si JRSC on an ITR?
- how to clean turbo
- Fab-Works manifolds?
- Greddy Profec Spec-S
- I have a problem, please help !
- Top fuel JDM piggy back info need
- To Vtec or Not to Vtec
- VAFC QUESTION
- uberdata and timing?
- How important are Camshafts on our Turbo Cars ???
- full race prostreet manifold with C/F hood. heat bad?
- Crower Rods Max Power?
- chromed ecu
- pinging sound
- looking for Bolt on FPR for B16 fuel rail....
- JRSC bogging! fuel tuning?
- Cant break 300 whp......WTF!?!?
- Nitrous bottle pressure
- Reliability (Turbo newbies read this)
- Why does Turbos have lower torque at lowend then NA?
- Anyone bought a turbo from turbocalculater.com before?
- How much for a tune?
- Compression numbers - how do they look
- BOV question
- Boiling Brake Fluid???
- Lost oil pressure at 1/2 track, what to check
- greddy 2mm head gasket
- AEM EMS CDI1 vs CDI2
- Who's still using SMC (zip) products?
- ALLMOTOR< FI
- turbo wheel is tight after attempted clocking. please help
- WASTEGATE HELP URGENT (VACUM LINES*?)
- I'm confused.....
- need some FMU questions answered.
- Stupid question prolly but here goes : Why an LS crank ina b18c?
- Turbo Project Nearing completion, opinions, advice, pointers, all welcome
- battery offset for 700cc siemens injectors for aem...anyone know???
- sfp turbo manifold
- Do my plugs look ok?
- tial spring question.......
- h22a oil pan tapping...
- Ostrich help
- h23 turbo questions
- Videos from the shop today.
- DIY oil restrictor. Cost = $3
- turbo kits with ac
- Rebuild, with just the center piece, is it that easy?
- fs tial 38mm
- AEM EMS: Idles fine, stalls out when clutch goes in
- Built b18c1, turbo, uberdata and damn CEL's.
- Custom Turbo progress.....
- Hondata question...
- K-series: supercharged vs. turbocharged
- apexi question
- Quality difference between rc 440 injectors and dsm 450 injectors?
- gsr cams vs usdm type r cams
- AEM EMS Boost Control w. GM Boost Solenoid Discussion.
- bolts from turbomanifold are breaking - what can i do?
- FMU and p28 boggin help
- radiator choice with proam top mount
- What do you guys think of this Header with JRSC?????
- Effiency of a EVO VIII 16g on b16?
- stripped Bolts
- gapping
- installation for drag 3
- full-race manifold in crx with plastic hood? need advice for space and heat!
- Turbo xs mounting???...where to mount the thing?
- Narrowband O2 sensor
- Greddy profec b spec I vs spec II
- got a problem
- Boost breaks up!!!
- Coolant Leak Between Head and Block
- POST RACING/DYNO VIDEOS OF YOUR CAR PLEASE.
- how do i upload pictures
- Turboed B16 Compression results in!
- just when i thought uberdata was starting to suck......
- Will a missing link from a GSR fit on a SOHC VTEC civic motor?
- Are my main bearing clearances too big? (w/ ACL's) What oil viscosity to use?
- SOHC Y8 BOOST
- Setting up Blitz SBC id boost controller...
- dyno day with GReddy and uberdata
- Exhaust effect to a/f ratio........
- Check your setup
- What motor mounts?
- The "new" steel Moroso oil pan has been out for a while. Who's using it, and what do you think?
- you may or not know me, please read
- Garrett T3 Turbo
- car leaning out....
- d16z6 arp headstud torque spec?
- turbo?
- Turboed my civic now I need help asap!
- Who has NOT cut block webbing?
- need more power
- Questions for the guys with H22 turbos?
- can the heat make my car feel sluggish(slower than usual)?
- Can you run a stock fpr with and turn down the fuel pressure with the aem ems?
- peak boost turbo kit on b18b
- ? clocking turbo, tried heating and hitting with mallot any other suggestions
- 300whp stock LS motor - 15psi
- REAL E/M For a OBD-II Automatic Integra !??!?!
- Building my turbo set up, a few questions!!
- comp test question
- How to clean out the inside of intercooler?
- plx m300 and uberdata datalogging.
- 4 door Thermal Exhaust on 2 door integra......
- RB25DET into 1973 240
- D16Z6...turbo or super???
- will my auto be ok???
- just ordered a frontmount
- fuel rail problem...
- Evasive Motorsports can a suck a fat d!@K!!!!!!!!!!!!!!
- Finally My Hondata S300 powered ls/vtec (519whp & 409trq @ 16psi)
- lets talk about piggy back's and safc's and all that crap
- ef sleeper
- why do my rpm's increase when im in neutral???
- Is my socketed P06 converted to P28 specs? *PICS*
- Saab T3 O2 Housing
- which sc61
- What's wrong with my Greddy Profec B?
- quick question about a used turbo.
- What kind of Injectors for jackson racing supercharger gsr setup
- A different sparkplug q???
- Remote IACV?
- Valvetrain Upgrade (Rocket Stage 1)
- Problems with intake manifold interfering with ls/vtec oil feed line
- Problems fitting oil presure sending unit using GE Oil Sandwich Plate
- 3.5" Upper Charge Pipe??
- GM 3bar vs. Autometer boost gauge...
- GReddy Profec Type S boost controller clarification
- b20vtec timing
- oil cooler installation getting ready for turbo (install pics)
- which kit??
- wategate top port- possible to use on MBC ?
- Boost controller vacuum lines
- DSport Full Race turbo Hatch?
- Threading Turbo Inlet
- overflow in resevoir tank under load
- Valvoline Turbo Fleet
- GT35R Built VR6!!
- map wire 4.6v? help
- 8psi blow off valves
- has any body ever used tranny oil cooler lines for turbo oil feed lines
- T28 oil feed line
- best possible quiet exhaust for turbo
- did i blow my turbo seals on my turbo already?(sc63)
- My dyno results
- GT35R Do I need a restrictor?
- 3in CAT to 60mm ??
- Full Race B-series GT Stage I, High Boost (plots & comparisons)
- Mesh screen or air filter. Power loss, gain??? What are your opinions.
- Has anyone crack a SOHC sleeve?
- help between 2 p28chipped...
- another full-race dyno 488whp
- overheating in hot weather
- Anyone else having problems with T3/67 ?
- hondata code 14 no map
- 4 Months in the making and im 95% Done!!!...
- which turbo
- Can I change compressor wheel w/o overhauling the turbo?
- Hondata/Uberdata users: Is your ECU install "clean" after tuning?
- BMC Log w/ Tial wg
- Are Equal length exhaust mani A/C friendly?
- IM gasket. OEM .vs. other brands / headgasket which one is the best for high hp?
- Driveability with a twin disc?
- FINALLY GOT IT RUNNING ... now for help tunning the 1000cc injectors...
- Can I tell Garrett turbo wheel trim without taking off housing?
- CP piston rings - file to fit?
- did hondata screw you over on shippind? they did to me
- Engine Knocking... was boosted
- TWIN TURBO B18C ???
- how low can a manual boost controller go?
