View Full Version : Forced Induction
- Prelude S/C problems, any shops in Austin?
- help with fuel problem help help help
- FULL-RACE.....or FAB-WORKS....or REV-HARD?????help
- How do you install a missing link and a FMU? Please help asap!
- Which head studs
- how much power am im goin to lose when i connect my 2.25 exhaust and stock cat?
- oil feeding question...
- saywbest honda engine??
- What to use to clean engine block?
- Domani (D16Z6) turbo troubles...
- Noob to D-series SOHC turbo, tips anyone??
- SOHC D16Y7 with Y8 head GT28R 9psi
- Will NEON SRT-4 injectors fit my b18c1??????
- PLX says "Rich" when out of the car
- Turbo d16 or b16-T
- What turbo comes stock on a Grand National
- SPAL/Fal fan choice...
- oil in charge pipes - new turbo?
- Most Hp from a 2.0L 4 cyclinder
- More problems, ignition timing all over the place...HELP
- FR Prostreet non-AC vs. AC
- anyone with a compressor map for a precision sc63 turbo?
- difference between SC-3427E and SC-3431E
- Intake temperature
- ej1 14b 9psi minime, reppin the sohc
- CB7 Turbo Question
- 501whp GSR/Turbo Tuned by Raceline
- S2k Turbo owners - what are my options for a EMS?
- Clutch for a Turbo D14 ??
- Radiator Fans
- manifold?
- What causes sleeve failure?
- Switching over to Synthetic, a few questions about using it with a freshly built engine/turbo.
- where to make return line?
- need some advice
- Looking to buy a GReddy kit for my 96 hatch, questions within.
- Difference between 40mm and 44mm wastegate?
- spark blowout at high boost??
- Rev Hard Tubular manifold and A/C????????
- Detailed write up.... HOW TO DO A Coil On Plug CONVERSION
- cams in a jrsc'd integra ls question
- WTB: Darton sleeves
- Need help choosing
- Had the prelude back on the dyno tonight more demons giving it issues
- motor mount inserts or bad axles...
- Looking for the bearings in this pulley (pics)
- Precision Turbo Exploded Views
- traction frustrations
- Oil dipstick melted... Any suggestions?
- GT40R Bushing turbos -- Affordable and Available
- A series turbo - need some help
- anyone running big cams in thier sohc?
- need help, car is acting up
- PCV conclusion after months of H-T reading.
- Valvetrain Opinions: Springs and Retainers
- anyone using a nissan t3 60/63 ?
- What do you guys think of True2Form? (Columbus Ohio)
- T25 on B20z
- help with quick problem
- blew headgasket (vid inside)
- who can chip my ecu for a basemap?
- Where to buy? Weld in cage....
- Which dealer would you guys recommend?
- what would make boost drop then hit full boost then drop then hit full boost but only sometimes?
- manifold for split housing turbo
- 92 honda accord with 2.2l SOHC non vtec turbo ?'s
- Smoking ???
- turbo D idle problem
- PLEASE HELP---WAT IS BEST OIL FOR MY B16 TURBO???
- Garret housings VS Precision housings
- AFC wiering on an EK!
- Ideal exhaust size for Supercharger
- ITR Turbo + Hondata = whirring noise!
- wideband/02 wiring question...
- vafc problems heeeellppp
- wierd ticking noise...
- Im A Jackass! blown ignition?
- Delphi and RC engineering fuel injectors
- Oil drain in shallow side, problems
- so my stock block itr hit 20psi yesterday..... AT IDLE?! wtfz0rZ!?
- Wierd BOV location
- Vortech s/c , broken belt
- Will a OBD2 DOHC Civic Blue box work on a 98 GSR
- p1106 Baro Code
- Hey Turrrbo experts... is this worth it?
- Coil on plug w/ Hondata S300
- 450dsm injectors and 255>how far can I go??
- New internals
- oil return line location?
- Who carries M&W products?
- Anyone else going to the Miami Hondata seminar?
- 3/16 SS oil line, need restrictor?
- Mobil 5W30 oil... good shit
- h22 supercharger in eg, will it work?
- CIVICFLNUM1 PLEASE CONTACT ME!!!
- Vacumm@Idle. What are you guys getting?
- what kind of turbo is this?
- Autronic SM4
- Engine fires while cranking only
- Sohc jackson racing supercharger question???
- how to properly break in new motor + clutch?
- import vs domestic?????
- who uses a little nitrous with boost?
- BKR7E or R5671A-8 for a 350whp B16a
- SOHCs with cams, springs etc...what do you idle at...
- need ecu help quick
- Dynoed the turbo h22a....terrible results
- Will an APEXi AVC-R turn on if you just wire power and ground?
- Nissan Garrett T25 turbo oil feed fitting size??
- manifold, and dumptube
- My 400whp D-series BOOM... carnage pics
- Turbo selection ?
- installing turbo need help
- Stock GSR, 12lbs? good/bad?
- intake temperature gauge vs air temp gauge???
- 515whp RSX Stock motor!!!! st00pid tuned
- What compression ratio do B20 Vtec 9:1 pistons have in a B16 Block??
- noob fuel injector question.
- boost but no power...........
- (searched) 300whp hatch competition clutch SUXXX!! What next??
- Stock internals GSR suggestions
- Vortech belt change? *HELP*
- Problem to shift, what would help please take a look...
- High-power engines: ignition?
- Check out our precision SC61 from race day :(
- need to lower compression ratio?
- Check out my turbo civic. 56k... best get a magazine and a cup -o- joe
- aluminum funnel ram?
- Turbo'd Jeep...
- Wideband & Uberdata
- Blown head gasket- Should I lower the compression when I replace it?
- INSTALL: ARP Extended studs; How to?
- Oil filter: which one to get?
- Aftermarket Intank Fuel Pumps that are not loud?
- 12.9 second b16, are you hitting fifth gear?
- Stock D16Y8 + Greddy kit = 12.2 on BFG DR's!
- What oil to run?
- my new manifold
- does anyone know where-downpipe?
- TYPE R TWIN TURBO.... lawn mower
- advantage of blow off valve on the intercooler
- What should I do?
- turbonetics manifold problem
- Fab-works and Peakboost
- what size wastegate to use?
- turbo integra prob
- Exhaust leak? okay?
- Recomended Engine Builder (central Texas)
- Wanna have block Sleeved, whos the best??
- oil return fittings leaking- fix or replace?
- turbo questions plz help
- what tranny for my fully built Ls-Turbo set up with JG built head
- Over heating and Fuel pressure
- are these dsm 450's ? (need help asap)
- Coating tech thread!
- Any Honda engine builders(in-house) near Deming,Nm?
- help!
- help settle a debate opinions needed
- Greddy Blue Box Need Help Civic on GSR
- weak/faint spark, car won't start
- 11.318 @ 116mph 1/4 mile on 8psi... can this be true? Fab-works will tell
- I overheat while in boost
- my d series 300 whp dyno
- JRSC w/ Uberdata vs. JRSC-High Boost w/Hondata - also, essential gauges?
- turbo setup for 99 si?
- Hooking Stainless lines to bov/wastegate/boost controller...
- Blowing into throttle with JRSC?
- Spark Plugs.. Will running platinum plugs make.....
- 403whp / 280 Torque @ 20 psi Stock Block (No Sleeves) GSR
- Blown motor and new engine build
- Is anyone running the new Greddy 18G kit w. E-Manage?
- when was NepTune first brought into the picture?
- Broken bolt in turbo housing experience?
- what size injectors to run b16??
- 3Bar?
- Need help idenifying this KKK turbo.
- Is my compression 2 Low On my built motor ?
- Solved my cooling nightmare + i'm a jackass
- Tuners In the Northwest????
- Turbonetics Turbo Kit????
- PLX m300 install.... open downpipe sensor placement?
- is 2.5 motorola map sens compartible with s300
- head gasket problem
- can't decide which trim turbine .63 or .76
- My Crome / Uberdata / TurboEdit / Neptune 'Tuner' ECU - DIY Write-Up
- Small Hole On Manifold
- LSD Question
- BOV brand *link inside
- boost problem need help
- Cant find How to Socket P28 for Hondata
- safe boost on mod engine
- Buying a used turbo
- Anyone with SwainTech Coatings?
- give me some info on this bov (Skyline)
- why does an ebc go to the top port of a tial wg?
- H-series discussion
- Brake Boosting?
- Oil Line question???
- pwr half core?
- Anyone use Accel 300+ Ignition? Need GOOD ignition for H22.
- ls boosting 12 psi?
- thinking about getting an LS tranny for my b16 turbo now that im chaning the clutch??
- pros and cons of a trubo b20
- GT35R or GT3076R or...
- T25 Rebuild; Specific questions
- Where to get 3"to 4" reducer in Stainless Steel for downpipe?
- Manifold and Downpipe???
- boost & high compression
- Possible Comparison if you guys are interested?
- NGK 8 series plugs?
- anyone got jackson racing supercharger on a gsr??d
- Why EXACTLY does race gas make more power than pump?
- BMC Manifolds.
- BOV Sound Clips
- Turbo Specs from factory cars
- Reading Plugs correctly!
- where to buy high temperature bolts for turbos?
- Wideband mounting locations on 96-00 Civics?
- Suggestions on stopping oil leak at return flange?
- dont want to get scammed
- Open DP tuning
- HELP, 01 b20z in a 98 civic ex..... just need a lil help... thnx
- wet kit on skunk 2 intake
- Anybody got a pic of a civic 1/2 rad with an intercooler mounted next to it?
- What clutch do u recommend for 700+whp 500+wtq
- greddy manifold which turbos
- need help confirming this
- No Spark? Running out of Ideas
- Low PSI BOV - 4 PSI?
- Clutch slipping?
- check out my broken b16
- HELP ME PICK A NEW MANIFOLD!
- Help me identify this manifold!? And what to do with it...
- turbo and auto??
- Greddy GSR Turbo kit
- need help selecting cam
- need help with pipes
- turboedit ???
- whats the best way to seal a oil leak
- Nitrous Express Jetting Question
- Smoking kind of bad if revved and when slowing down
- AVCR problem
- how does my stock clutch and flywheel look after an hour of boost?
- RC 650cc inj. saturated battery offset for AEM..?
- gsr turbo
- help ID turbo parts
- Hondata, open loop or closed loop after tune, also check light with open
- need help lost boost
- t3 60 trim on a lsvtec?
- oil feed fitting ??
