View Full Version : Forced Induction
- finally got my car boosted !
- greddy turbo help im new!!!
- turbo from 86 merkur xrti4
- Upping the boost waht do I need?(SOHC)
- Need b16a blocked sleeved in VA?
- Fuel Spark Management Question
- A/F Ratio In/Out of Boost
- caspers knock gauge. anyone with a p28 using one?
- turbo smart wastegate and tial spring?
- started tuning with hondata tonight.
- max performance of a super 60?
- Project Punisher - UPDATE! Bottom-end's finished
- well shes all finished now
- Anyone have pics of 99-00 Turbo EM1 with HKS Titanium Turbo Muffler???
- xs-power.com>? Newb needs Help also.
- Edlebrock Turbo kit on a 1999 d16y8
- NOT a ssac mani... any good?
- Cryofusion
- bigger injector? or sleeves first?
- Should i use ARP headstuds with 1bar of boost?
- Turbo ?
- Oil Bypassing Turbo Seals?
- will TOMEI injectors work in a honda/acura
- Z10 catch can fitting
- thick hg's
- need some help with timing
- Uberdata guys. Check out my basemap. Whatcha think?
- vtec not engaging
- DFW, where is a good tranny rebuilding shop?
- Just Ordered an AIR Manifold from Endyn
- Uberdata 1.66 or 1.7?
- precesion t3/04 or Turbonetics T3?
- White smoke on a rebuilt turbo?!
- Turbo-Edit info...
- Inline Pro Manifold
- Which piston? (not the usual piston questions...)
- TURBO OR NO?
- my setup is something wrong or is it just me?
- Turbo Drivetrain
- GReddy Downpipe Interchangibility?
- RC440 big enough?
- were can i find the gauge plate for console???
- best cams for turbo???
- what kind of HP/TQ gains have u seen with a bigger TB?
- Why wouldnt the 92-95 greddy kit bolt on a 96-98 civic
- Anyone with LS Turbo and Crower 402, 402T cams post here!
- can someone take a look at my .bin file?
- Dump tube broke off (!!?!?!?!?!)
- how does an fmu work
- need help, already searched
- breaking up and bogging in boost???
- Does z10 make a barbed fitting for use w/ their Breather plugs instead of the 12ANx28mm?
- people with sheet metal manifolds- help
- Plan to run nx wet kit.
- Dry nitrous kit and p28 ecu open loop
- Nitrous and Propane
- 20-25 psi with aem fpr(stock rail mount)?
- pics of some new projects at Full Race
- Car run's but idles really rough and doesn't want to accel.
- b16a2 turbo
- WTF is wrong with my idle? Video inside.
- supercharger w/bov
- Majestic Turbo, any good
- Intercooling position
- Need big help for tuning power fc
- b20 vtec turbo build
- How to connect charge piping?
- anyone have a wiring diagram for a blue box for an integra ls obdII?
- 363 whp H22 turbo dyno plots
- turbo installed but not getting boost
- Apexi Turbo Upgrade Options
- here is ou setup - what do you think
- oil fitting for T3... need a source
- Turbo D15b2
- Greddy questions for Civic Si
- Help me out on a fuel management options.
- dumptube vs. routing it to dp, power diffference?
- Stock RADIATORS?
- What Radiator for a DA?
- Dynoed the hatch
- Video from a Bi-Bettle
- is this a good turbo for a d series sohc engine?
- Turbonetics D16Y7 turbo Kit
- calling all bluebox and blackbox users
- How Much Boost Thrown at Benson's
- UBERDATA question..
- supercharging a crx
- sleeved b18b my goal 400whp ! turbo??sc61,60-1....any idea!!
- what the hell should i do!? please help out.
- Too small of a housing ??? ---------- t3/t4
- Hondata S200B CEL_7
- Car Wont Keep Idle...
- what do i need from summit for catch can?
- Optimum turbo for......
- oil and water-cooled turbo question
- EFI101 Schedule
- Motor mounts?????
- Fill Nitrous Bottle Question
- Whats your REV?
- 10.8 compression LS... safe to turbo?
- PLX Wideband o2......
- p28 ecu on dx motor and uberdata question.....
- EGT probe... how far into the pipe should it be?
- Oil Pump Failure
- looking for different set up
- AHHHH Freakin ATP gt series t3t4 drop in turbo !
- turbo flanges... dsm t25/14b vs garrett t25/t28
- New JRSC setup
- Wastgete question....
- Cams
- Really trying to find a tight crx preferably w/ solid painted bumpers!!!!!!!
- max hp possible w/ a tdo4 on a sohc
- Will a eclipse T25 work fine on my B18b??
- AEM EMS and GM boost solenoid... How to hook up wiring???
- P75 ECU on a boosted B16A2 motor?
- manifold+downpipe suppliers links
- Disconnect the PCV valve..is this a good idea for a heavily boosted motor
- Newbie to hondata iam lost someone help me out
- vafc hack on 99 gsr
- Crazy Tapping Issue Please help
- Undercover Intercooler
- Apexi power fc question
- y8 manifold, is it good for 400 + whp >>
- Can I Get The Garret GT32 In A 5 Bolt Exhuast Housing?
- Drag Install, a/c & radiator fan ?
- Pre turbo kit installation?
- Injector wiring question.(Quick disconnect adapter plugs for different styles)
- H22 H22A clutchmaster's stage 5 clutch kit new! unused! prelude
- ATTN Zex Users... Need to know what size tap to use...
- checkit outtttttttttttttttttttttttt
- Most power w/ skunk2 Intake Manifold
- Can turbocharging INCREASE fuel efficiency?
- WHAT SLEEVES TO GO WITH
- where to get fuel for nitrous?
- OBD2a to OBD1 conversion, now throwing Code 14(IACV)....help
- questions about greddy blue box for DOHCS
- Here is my Dyno, Comments please
- Need suggestions concerning newly purchased turbo
- Spraying v6 accord AUTO!?!?
- Anyone ever install a Blitz FATT turbo timer?? please help.
- research question on turbos and hp
- difference between a built b16 block and a built b18c block?
- D16Z6 turbo kit on a B18C
- How good are these intake manifold ?? Take a look...
- Please give input on this setup?
- del sol with home made turbo kit what kind of power?
- bad idle and black smoke
- how is my setup? please help==> LS (b18b)
- turbo for prelude.
- your comments about ls/vtec turbo
- b18b and b18c turbo?? Again!!, sorry just had to ask.
- 500hp stock sleeved B16 Dyno
- DIY piping/ oil feed lines.
- 3" exhaust for a prelude type sh
- gas miliage on a fmu
- hack and 450cc injector help...
- will i loose power going to a skunk 2 IM???
- Building a fuel system
- BauleyCivic Gets a Hard Lesson in SOHC Head Lifting (No 56K)
- Blue Box Question (Ive Searched)
- where to purchase tial bov springs.
- what HP range are 440 good up to,in b series?
- What fuel pump to use??
- Info on this turbo. Anyone using one? t25/t28 .49 AR .89 EX.
- Damn: T3/GT40s (GT35r) On complete backorder...
- EK Civic piping measurments
- My first tune + dyno sheet
- TurboEdit users...i need help!
- Need Assistance installing/fitting Seimen Injectors
- boost/timing
- D16 Turbo for 200+whp
- any stock widebands??
- HOW TIGHT SHOULD THE ALT TO CHARGER JRSC BELT BE?
- Help with exhaust setup
- Installed ITR manifold, IAT question
- D Series Ninjas! Attempt #3. Mission: Don't blow head gasket
- Up the Boost?
- What does an open dumptube sound like?
- 14b turbo on BLOX Mani?
- what is the rule of thumb for agjustong cam gears? i have gsr's.
- rods... pistons... all?
- cams with nitrous ?
- which oil feed line can i use?
- Oil in turbo
- Engine Analyzer Pro or Dynosim software - Anyone ever try these?
- Do I have everything i need for turbo timer install?
- Precision turbo GT32: GT3251e or GT3255e?
- Does the Tial BOV have a boost assist feature like the GReddy Type S?
- Common turbo flaws??
- Stock LS Turbo Question
- oil pump gear question.
- couple questions on my setup
- comp cams new turbo cams?
- do i need a missing link or check valves
- greddy box's wiring (d14a4)
- 300hp clutch for 00si
- Turbo Setup - suggestions?
- NGK Users - BCP or BKR?
- diameter
- Temperature
- any high shot sprayers ?? 100+
- VTEC STOPPED WORKING ALREADY SEARCHED HELP!!!
- does Greddy turbo kit support AC?
- T3 super 60 Turbo for B16, Tooo Small??????
- CEL will not go out!!!!
- how to determine stock sleeves from ductile iron?
- obx turbo manifold
- quick injector clip question
- greddy type s bov onto 1g dsm flange
- air / water IC setup in a daily driver... opinions?
- I made it to the 400whp club!....but now....
- What turbo for my Evo 6?
- ssautochrome gets my thumbs down
- 60 trim S type wheel in a super 60 t3 housing. Is this a bad idea ???
- Wideband rental?? Portland Oregon....
- what kind of turbo to go with my b20b
- --- .63 ar housing on a .48 wheel ??? anybody tried this? ------
- How much spray ?
- H22A turbo manifold
- Is anyone using this turbo GT35/40R ball bearing
- Uberdata...burner...chips...ECU
- F22B turbo, Suggestions?
- NEW IGNITION SETUP
- b18a
- [POLL] do I beat on it enough? How often do you see full b00st??
- LS turbo setup, what do you think?
- flange for downpipe on a 14b tdo5h eclipe turbo
- How are you running your downpipe/thermal 3 inch exhaust?
- SFP manifolds.... any good?
- Fuel Sumps??
- Total Seal Gapless Rings .
- Compressor and Turbine Size Sheet..
- auto ecu???
- DSM 450 O-ring seals
- FS: pistons, manifold, injectors, mbc, MORE >>
- ACT organic street disc, are they ok for high HP application ???
- FINALLY!!!... The AEM UEGO Wideband display for AEM UEGO SENSORs users
- how do you read a turbine map? whats that line mean?
- In the words of Homer....DOH!
- Failed emmission in NJ today. A few questions.
- walbro: reg 255 or high pressure 255
- Does anyone use a skunk2 intake manifold on a d16z6 in a 92-95 honda Civic Shell
- uberdata timing question
- Turbo end / shaft play specs
- Emissions Testing in MD
- Whats safe to boost?
- anyone know what the hell this is?!
- Pistion rings shot...time to build
- How safe is it to go without a tune? turbo d16y8
- Garrett T3/T4 turbo needed
