View Full Version : Forced Induction
- Using Boost Controller Kit On Power FC ?
- Does this D series turbo kit sound like a good deal?
- internal wastegate
- obd2 resistor box wiring...
- Fact or Fiction ... VTEC-t
- Has anyone heard of pfabrications.com
- Anyone turbo'd in Cali, help me out please.
- Help... Can I use a 75mm head gasket on a 75.5mm bore?!
- add me
- Best Honda/Acura motor for Boost ???
- oil lines..
- Intermittent knocking at idle and light throttle...
- 5/8" brass barbed fittings big enough for oil drain?
- Problem: Full Race Manifold Flange Hitting Block
- turbo oil feed and drain flange
- Should I have problems boosting 20psi on a 9lb deltagate spring with electronic boost controller
- Idle is bouncing and dies when i give it gas.. what to do
- turbo fittings needed!!!
- help with turbo setup
- 175-200whp D16A6 Questions.
- piston and rod install
- FYI: GT3582R's now in stock
- WATCH OUT BUYING PARTS FROM SKUNK2GOTOGUY
- Boost Gauge not reading accurately!!!
- DSM 450cc injectors question
- nissan silvia BB turbo question
- Lost 2 of 4 bolts from my InlinePro exhaust manifold...
- anybody use a turbo blanket when track racing?
- Cylinder Head Flow Test Results.. . OMG!
- gt35r coolant line pics
- type R cams and jrsc?
- Search is DOwn. NEED Help with 3 Bar Map wiring in a Ek hatch
- NO BOOST! i mean ZERO
- which tuning program to use?
- anyone running a pusher and puller fan?
- Thermostats available for the D series.
- Turbo b20b with drag kit- what turbo? block shaving required?
- Post JRSC W/M inj setups!!
- meaby the FI forum can shed some light
- intercooler fins
- hf manifold with dsm 14b turbo a/c compatible?
- Noob Turbo Question
- Civic radiator in integra gs-r
- 220 wiring question
- calculation from inHg to mbar or psi
- Fueling Options
- S2000 Supercharger upgrade?
- Help me with Cooling my hatch!!
- Help, Boosting issues!
- dumptube?????
- Walbro 255 pump not priming- Main relay, or pump?
- b16a and JRSC need install help
- greddy users!! how do you hold 10-11psi??
- JRSC / b18c1 ?
- Can oil return bung be aluminum, or need steel??
- boost dropping in high rpm???
- running turbo but not piped ???
- turbo xs
- fs 99%complete turbocahrge setup (92-92civic)and complete jrsc setup fpr single cam
- saturated vs peak and hold injectors
- d15z1 ???/
- Boosted D16A1
- Put in a new short block and now my car won't start, WTF?
- D16Y8 Oil pan options??
- does this make sense?
- supertech valve springs with crower cams?
- oil leak help!!1
- Which turbo
- Intercooler options for keeping fogs on coupe..
- Any Assistance With The OBX Intake Manifold...
- ugr manifold
- drag turbo question
- A lil help for noob boosting a b16
- which turbo????
- jg sleeved block???
- Want stock again
- is this a good deal to start my GSR-T?
- 4k idle PLEASE HELP!!!!
- I solved my overheating issue.
- how much whp can 6th gen cv axles/half shafts take?
- B18c1 turbo a/r 0.63 or a/r 0.82 hotside
- does anyone have a nissan manual for a timing chain?
- turbo blowin oil out exhaust?
- callin all crx w/ jdm frontend intercooled turbo kits and reliability questions also
- can I run ITR valve spring on skunk2 Pro1 and pro2 cams?
- super t3 45trim
- used turbo
- vacuum set-up (pump)
- Did a search...quick questions do these make any difference?
- car want build boost...
- Which oil Viscosity in my situation?
- L15A internals
- gsr turbo help
- B16a2 turbo sizing question - Sell it or keep it?
- Chipping a p28 to use secondaries?
- which rod?
- External w/gate with 5 lb spring. Boosting 17psi with elec b/controller. Should I turn w/gate adj.sc
- best set up for a turbo gsr
- sohc boost
- slow spool on 50 trim y????
- ls? gsr?
- B16 New turbo vtec Problems
- PCV smell, should i run a catch can?
- ---> oil sandwich adaptors
- need sugesstion for turbo cams.....
- Cracked a sleeve.. UGH
- Noob Question on FPR ?
- Realistic for my goals?
- anyone have a ebay fake tial bov?
- catalytic convertor question
- shad at accuracy automotive vs. inline pro
- lookin to turbo my 2004 s2000
- 14b turbo flange the same as the evo 8 flange??
- just fired up my b18b turbo Oil and Break leaks help!
- crome and launch control?
- turbo install kit
- How much boost is too much?
- Is it possible
- Accord/Prelude front mount question...
- Is a Drag downpipe power steering friendly?
- 1 gsr camshaft & 1type r camshaft
- if i had a cracked piston...
- Turbo f22 Help!!
- Noob Question Boost Adjustmen
- LS Supercharged issue (I WANT VTEC)
- New Bottom End
- AEM EMS help chaning coil drivers
- need help identifying turbo
- Why did this happen?!?!?!?! Cam / Rockers destroyed :(
- I was bored so I decided to post pic of the new motor build
- Remote mounted turbo setup question...
- type r cams install
- BDL fuel pressure regulator?
- i figured out my starting problem, weird
- high idle problem, help me out
- New Setup, Stock B16 57 Trim @ 14psi
- Moates 2Timer Operation Questions using uberdata.
- ramhorn that retains ps and a/c?
- Traction?
- AVCR wiring help - RPM or Injector signal?
- ls vtec build for nitrous (need opinions)
- my top mount comming along!!!
- Ruber hoses for turbo
- Fresh Motor compression (prior to rings seating)?
- Laminova cores on eBay
- pics of my new triple disc
- d16y8 turbo?
- Quick question on my turbo setup "SOHC" :)
- Motor completely floods on deaccel in higer rpms
- 1.64 liter d16y7 help me choose a turbo
- STC GT3255b and SLS shorty: Stock block GSR going to the dyno...
- Difference between motorola map sensors?
- Skunk 2 Manifold
- D15B7??
- Intercooler Experts...opinions on spearco IC (26 x 8 x 3.5)
- Lost/broke my Autometer boost gauge hose...Any alternatives, a fix?
- h22 turbo
- will my turbo make 400-450whp?
- H22 turbo setup
- I chipped my CP piston ring, Can i use a JE one instead?
- boosted sohc
- Latest dyno runs from the Civic turbo
- need some help for my EVO friend please
- oil sending unit oil feed line issue
- quick question
- Surface oxidation on exhaust manifold.....ok to get ceramic coated?
- ZEX Plugs vs. NGKs
- Will a GT3076R fit on a Spoolin (Spoolin-type) log mani?
- Need Help, 2G DSM T25 Turbo Bolt Sizes?
- edelbrock victor x dimensions?
- What will Happen????
- full-race
- Need help with turbo selection for civic
- turbonetics.. anybody have experience with them???
- Thermo Valve ???
- spark plugs for 400-500 hp
- OEM Spark Plug Wires
- Throttle Postion Sensor?? HELP!
- Dual Wastegates WTF?!
- JRSC Install, My mechanic screwed me over, so now i need help
- first time kit install several issues **searched**
- Should I raise fuel pressure 5 psi for nitrous?????????????????
- EVO 560cc what PSI?
- Not feeling boost
- a few turbo questions..
- ...B18B motor rebuild Question...
- spark plugs are making me angry...
- which retainer best? titanum, aluminum or steel
- Electric cooling fan and radiator question.
- Oil feed line for turbo leaking... any ideas?
- why is my timing always jumping?
- Cable to Hydro Drag 3 Turbo B18C1 CRX...Air Filter Options?
- Direct Port Nitrous Questions
- walbro pump max horse?
- anyone h2b turbo? results?
- FS: AEM EMS @@!!!!!!!!!!
- turbo my 97 dx whats needed????
- TEXAS EMISSION NEED HELP
- Lookin for some heat/header wraped setups..want pics
- low comp pistons are making me pissed
- H22a prelude Top mount options...
- ls/vtec turbo w/ ITR valvetrain, how aggressive cam can I go?
- Need Engine Builder
- alaniz built head... boost ?
- which manifold ramhorn or topmount?
- Broken stud in exhaust housing
- Chipped p06, car won't start anymore. Solid CEL
- Going Jdm H22a Turbo, I think
- Building The B16 Need Some Imput!!!
- car breaking up after shift!?
- F.S PRECISION SC61 INLINE PRO SS MANIFOLD 38MM DELGATE
- spoolin ramhorn with valve cover fittings ?
- pg7 tuning options
- Turbo cams vs: N/A cams
- will t3/4 oil lines fit 18g ?
- anyone using skunk2 pro1's?
- Problems fitting precision 440cc injectors ?
- Boost Controller Help.
- k i made a dumb mistake and i feel stupid for it, but hear me out and help me!
- t3/t4 oil feed fitting
- GSR: 1.8->2.0 Questions
- GE oil squirter plug offs ????
- boosted 400hp and im all over the road!
- China Intercoolers
- h23 turbo ?
- civic si turbo with aem ems wont start again!!!
- 95 civic vtech with greddy turbo running lean
- B16A turbo vs. B16A nitrous
- dyno numbers?
- p0108 yes searched, yes i went through the flow chart. reading 30in/hg car off.
- where to put velocity stack
- lsv dowel pin question
- TiAL GT42 SS housing vs Standard Cast Piece
- NEED HELP!! OBD1 DOHC ZC??
- STOCK D16Y7 NOS
- sr20DE or Sr20DET For Turbo SEARCHED
- BOV"S
- Can rubber connectors be used?
- need help on buying a turbo ???
- crome tuned
- spark plugs for turbo
- Ls turbo won't hit full boost in 1st gear....turbo to big?
- C&R Radiator Cap replacement? Overheating.
- Is a built (not sleeved) 8.5cr b16 block be more reliable for a daily driver?
- dry ice on intercooler
- Tial Housings
- jrsc kit/where to buy?
- 50 trim or 57 trim
- B-series ramhorn manifold setup!! Lets see them
- o2 sensor question
