View Full Version : Forced Induction
- o2 simulator
- LS Turbo Fuel Management
- 2"1/16 autometer gauge pillar...= what mm gauges?
- Fuel system questions?? I found a very helpful site on how to have excellent flow!
- APEXI IC
- Besides reliability, how much more POWER can be brought out w/ Hondata?
- When was the last time you cleaned your air filter?
- Boost Controller?
- OT: GSR Head
- Does anyone have flow charts for...
- minimum retard per lb. of boost on the msd btm?
- Q's on JRSC SOHC
- engine build up terms
- integra boost question
- AN banjo bolt for fuel filter
- Use stock FPR with hondata 3b??
- What else is NECESSARY?
- help with my turbo set up
- Pistons? Rods?
- WTB: tial 35mm wastegate
- would an inline fuel pump be quieter than an intank fuel pump
- boost controller and turbo timer
- OT: Another car running the T3/T4
- Drag Gen III kits?????
- What does piston slap sound like?
- Turbo and Long Trips?
- Anyone w/ a single cam turbo?
- hey guys, Can I use A supercharger with this setup...
- Help with Apexi auto turbo timer
- Oh yes! My kit arrived today :)
- some videos...
- where do you keep your nos bottle?
- where do i get has sports mounts?
- Bosch O2 Sensors??
- chew on this turbo setup for a D16Y8
- critique my new turbo setup
- NOS!!!!!!!!!!!!!!!!!!!!!!!
- JE pistons (84mm) and B20Z shotpeened and balanced rods
- CATALYTIC CONVERTER HELP.......QUICK PLEASE :)
- 6psi on a B20Z safe?
- MSD BTM, how much degree retard at 16psi?
- Panic!!! Please help-God, Artubo, Dustin, somone?
- Aeromotive regulator question?
- Question about EGT's
- REST IN PEACE B18C
- Turbo?'s
- Just pulled my head off to see the damage *!WARNING PICS!*
- I am officially boosted, pics inside
- How do you feel when your BOV goes off in font of someone? and....
- the "do-it-yourself" check valves....
- spraying a 00' SI
- running 16psi safely...
- question
- DRAG3 fuel pump question...
- Turbochargers.com is selling t3/t4 for like 450
- Turbo Cams???
- What is the highest h.p. number you have seen produced from a standard DRAG kit (t3/t4)???
- Turbo LS owners: please post your 1/4 mile times, thanks..
- JRSC or Drag 3
- Can I use a p-61(92-93 gsr ecu) for hondata?
- SHould i get MSD?
- LS tranny best for FI??
- Turbo in CiVic Si without LSD okay? For time being anyway.
- motor oil for break in
- for anyone with a MSD intank fuel pump or any intank pump, would like some feedback
- Greddy Kits
- question about the ZEX kit, please help
- Can you get an MF-2 by itself??
- IS anyone willing to share thier cam gear settings?
- damn broke my aem fpr....
- turbo specs?
- Upset, frustrated, and disappointed with my Hondata 2B
- coolant leak
- Zdyne-Who's got it?
- Nitrous = Forced Induction
- Went to the track today! im happy this time! =)
- Confused about which route to take??
- Anyone make a wet-plate nitrous system for the b16a?
- For those with RC 720cc injectors
- Did a search, What's the difference between a supercharger and turbo?
- Blitz Turbo Kit
- wheres the cheepest place to buy a tial wasgtegate?
- ECU wiring changed from 98 to 2000....anyone have 2000 wiring diagram?
- Psi with 270's
- p28 vtec solenoin A4 ecu pin-out prob...
- Please help - My FP guages are reading 100+ psi at idle
- Golden Eagle Mfg.
- Block gaurds?
- scramble boost settings
- Simple DRAG 3 Questions :)
- OT: argggg, Crower!!! :-(
- b18c1+zex =?
- Blow Off Valves????
- Most common problem when self-installing turbo kit?
- new wastegate spring needed w/ boost controller?
- Dire... update on the car since Art fixed it?
- D Series sleeved blocks
- Hondata w/ stock injectors pre-turbo
- Do You Regret Going Turbo?
- Where to find Pintle injector caps?
- NOS with JRSC 8lb?
- EGT Probes all the same?
- air research m10
- Hondata: adding datalogging, what has to be done?
- can a NOS nitrous bottle be placed on a Venom setup?
- 600cc high imp. rc inj. Attn Steve(hondata)
- Great NEWS!!
- good break in period for new pistons?
- drag manifold...
- Built Bottom End Costs
- autometer boost gauge, how accurate?
- I got a free turbo from a 91 eclipse.............
- Comments please: ClutchNet Stage3 clutchplate+pressure plate
- HELP!: Funny blipping sound on acceleration.
- A hole in the block of the RSX type-s(pics)
- Last chance for Golden Eagle Sleeving $585 !
- any one have a b18c short block for sale or trade for dyno time
- turbo not spooling!! wastegate stuck??
- Any one here boosting a ls/vtec??
- Stock sleeves and 1 bar?
- dyno today , bah =(
- crower 403's + turbo = ???
- Is an Talon DSM intercool sufficient?
- B18bturbo = nice guy
- dimensions of greddy 92-95 civic intercooler?
- How much does it cost to have a compression test done?
- Thermal wrap
- Specific question about to4b and to4e compressors
- To those who can CHOOSE their A/F Ratio?
- People w/built engine and hondata or other stand alone...(?)
- WTB: SOHC T3 Manifold
- Boost + Larger Displacment = ?
- Going to Bullish Racings shop tomorrow.....
- I love my turbo (even though I blow oil smoke every now and then)
- WHat does PS stands for?
- My Ludespeed turbo install
- Whit a JRSC at 9psi, what spark plugs I need?
- People with AVC-R!
- Stage 1 complete. Block broken down and ready for build up. (PICS inside)
- Fuel Management..suggestions?
- Anyone want to trade their HKS SS Bov for my Blitz Super Sound BOV?
- how long has ur honda been turbo'd
- whats the longest length of sec's you boosted on the highway?
- quaife install
- JRSC or All motor?
- hondata or ne aem system?
- Dustin, what kind of manifold is this?
- Questions about Mitsubishi 20G turbo in a Lude.
- Hey Guys quick ?
- Turbo Install Help..
- 12 psi??
- LS turbo...........more info
- Greddy Si turbo kit on a del sol vtec???
- Check out my compression #'s
- has anyone had their Darton sleeves crack or slip?
- need help converting BAR to PSI
- IMPORTANT! Technical! Does #1 cylinder blow the most? This may be why....
- Has anybody recieved their Turbo kit from Max Rev yet?
- Gotta check this out... N/A B.O.V.
- Drag 3 install problem/question
- running b18c1 GSR motor, whats better supercharging or turbo?
- Newbie here on forced induction..
- Which ECU to run in a 92 GSR with B18C1??? Please help
- How to hook up Aeromotive fuel regulator.
- 20G turbo-t3/t4
- Turbos anyone?
- muffler tip have liquids
- turbo groupbuy on GBC
- What do you guys think of this?
- too much stress on stock internals??
- Boost Controllers
- Performance of a supercharged b16 compared to supercharged performance of ls/vtec
- turbo timer
- My new turbo setup
- What is Thermals web address?
- compression and air/fuel ratio question
- NUFORMZ OR STR BLOCKGUARD....ASAP
- Clutch opinions for Turbo ZC
- Just rode in a Chevelle with a 454 big block!
- Need some suggestions for a good liquid fuel pressure gauge
- low idle after restart.
- NOS 80 shot (direct port)
- Timing
- JRSC at 9psi, what plugs?
- Just picked up a turbo
- Eaton in the JRSC for Acura Integra GSR
- immortal what are these?
- New Hondata user forum
- FS: DRAG3 B motor turbo manifold and more
- HondaLogger Easter Egg
- I gotta give it up to the GM guys on this one
- b16 or ITR tranny for turbo???
- well i took the plunge....rods, pistons, sleeves
- My untuned hondata/engine break in situation.. Your opinion please..
- Silncer for thermal 3in????
- need J&S Version 2 install help
- what are everyones thoughts on using DSM injectors?
- Sparkplug intervals..?
- anyone in the pa/nj area with golden eagle sleeves?
- The New Plan
- questions on NSX turbo
- ...waiting for my turbo......I´m down :(
- Camgear degrees..
- Turbo z6
- can we come up with the best solution for???
- 7-8 psi with stock injectors?? is it okay?
- Pics of Apex'i Turbo N1...
- greddy blue box + 450cc injectors
- nos on stock intake piping??
- how much fuel pressure would you think...
- fmax kits
- b18b turbo people
- what to expect out of this setup ??plz help
- help on general turbo info
- FS:rev hard turbo kit
- Profec B installation Help...
- heres a cheap turbo mod
- can anyone reccommend a good (cheap) multimeter to measure dc?
- WTF happened to FFGeoff's post about the manifolds????
- Pic of my Revhard ITR
- Fields non-vtec fuel controller
- TURBO LS Question
- Does anyone in Cent. Florida/Tampa have Hondata 4b?
- help need 95-99 gsr crank and block
- take off fuel pump/fpr w/ hondata?!?
- Is it okay to run a -3 feed line?
- Kit or No kit
- Here's the datalog
- My AEM EMS update...
- F22B2 Potential
- just ordered my turbo kit
- Turbo Subject. Please any info would help. How much can it take?
- Post pics of your engine
- Took My head off and I'm ready for Inline Pro!!!
- AVC-R duty cycle settings
- WG boost line: pre or post throttle plate ?
- Need help with fuel
- Would you gies put a Saab Turbo on a rex??
- turbo H22A4 cam timing
- Any one have a .42 intake on a ZC?
- skunk2 intake manifold
- Help, Car died!!
- FOR SALE: Turbonetics polished t3/t04b turbo.
- Does anyone make fuel rails that?
- eveyone seems to prefer b18b
- What coatings on manifold......
- Groupy Buy on Z10 Engineering products
- Can someone with the GReddy Remote Switching System help me?
- Plug cleaner for race plugs?
