View Full Version : Forced Induction
- oil feed line length
- Skunk2 IM on boosted LS?
- hondata s200 boost basemap
- ODD QUESTION. Has anyone ever pulled anything with their Turbocharged car?
- Anyone have supercharger soundclips or videos?
- fuel management help
- Which injectors for my Boosted B16?
- 9 inch intercooler too tall for DC Integra? 94-97 Front end: Pics!!!
- ecu question
- what b series haed makes the most power boosted?
- Need some opinions on turbo manifolds
- do i have a vacuum leak?
- compression ratio help
- Help with my 300whp build! ..
- resistor box
- Help, Car running rich after turbo install
- Relevence of Displacement
- nitrous refill?
- head gasket blow off
- blowing smoke supercharged GSR
- ****Strange Problem..........Help Diagnose!!!***
- Bigger turbo give more HP at same PSI as a smaller turbo?
- Is this a modified exhaust housing?
- greddy turbo kit questions
- go with act xtreme PP w/6puck or action 2MS 6 puck sprung???
- Just grabbed a 8-series greddy tuebokit, engine management help needed,Ineed your opinions...
- do you guys run gas with ethenol?
- Type R differential
- 3 year old turbo (New) "GT30R"
- Any downfall to gapping a spark plug too tight?
- What change would i have (Ex manifold)
- Using a chipped ecu from n/a car on a turbo car cant i reprogram it with chrome or somthing for bo
- B20 crank pulley on a ITR with JRSC
- y8 head on d16y7?
- New to site, here's my project
- Need Help!
- Profec E01 remote control?
- crazy smoke randomly? what the hell?
- Will i need a slim fan??
- I dropped my injector on the ground.
- What twin disk clutch should I get?
- Any had experience with these H-beam rods before??
- Just some pics of my accord project
- is this injector usable? (dsm blue tops.)
- How much do you pay for Machining?
- Any cheap Dyno Days or good deals in the bay?
- Pyro/EGT Gauge? Necessary?? What do YOU think?
- T3/T4'ing my H23, couple questions
- So I welded my wastegate arm to my actuator canister lol.
- slight hesitation before revving
- Post your Oil Line setups...
- t04e downpipe bolts
- which wastegate spring fits sscrap's wastegate?
- ecu?
- 1000cc obd2 injectors?
- Another Washington Vitara setup, 300+
- Newly Boosted Accord
- good turbo?
- best place to pick up extra V band clamps that wont make me broke?
- Recommend place to buy exhaust parts-flanges/piping etc.....
- OBD2 LS crankcase Ventalation, catch can...Help!
- Drag turbo kit?
- external wastegate
- external wg
- got a CEL after hondata s200b instal
- Lovefab H22 Mani Clearance Problems Need Opinions???
- Conversation I had with SSAC
- vac lines needed?
- Who all makes a top mount a/c compatible b series manifold?
- College guys GSR turbo build.
- boosted sohc 2nd time rod bearing smashed help!
- B16 .... turbo vs supercharger..need help picking a set up
- random check engine
- v band
- knifedged crankshaft
- Keeping Underhood temperatures down?
- LS-VTec Turbo Dynoed tonight...
- apexi auto timer
- New engine
- turbo to stock
- Precision 1000cc with NOS Noszels direct port question, please look..Pics.
- Wiring question msd 7al2 (I know you think it's not FI related but)...
- hack on the AFC will it work on mine?
- alright 2 more questions, please don't flame me. Stock fuel pump and specs on something...
- b16 turbo or supercharged?????????
- how hot do turbo manifolds get?
- Cams
- Wrapping exhaust ?
- prelude on boost fuel cut?
- OBD2-OBD1 questions
- accuracy of the narroband sensor
- Wastegate Size!!!
- TCS clutch kit feedback
- New Build Suggestions. 350+whp
- Heat Wrap 1inch or 2 inch?
- What size wastegate? b18c1 t3/04 .57 8PSI?
- Edelbrock manifold/Drag intercooler - won't fit - help?
- Two Inline summit fuel filters?? enough flow for me? sumped
- turbo k-series dc2
- Excessive crankcase pressure... on a good motor?
- Valvetrain
- Turbo Setup for a daily
- Using Nitrous with a WOT switch and RPM acivation switch! HELP NEEDED!
- Injector question....
- b18c1 block
- B20 vtec turbo size question...
- internal wastegate
- turbo lagging
- edel. vic.x 2nd throttle sensor?
- Dyno In RI...Tuners/People Want Tuning Check This Out!!!
- .5 BAR = how much boost in psi?
- t-25 on d17
- ARP rod bolt stretch
- smoke out of exaust??
- OVERHEATING (weird)
- boost and spray
- Prelude turbo initial expected problems
- IC piping question for all you guys who know a lotmore thanme, aka 99% of you...
- dmh ecutout owners- how are your cutout motors holding up??
- anyone seen a 06 lx coupe turbo kit?
- Ignition for a boosted d16...
- Sweet... My Filter ate my Turbo
- Installing boost gauge on GSR w/JRSC
- OBD2 how to keep the ecu from seeing boost with vafc
- Wastegate question - 38mm tial
- ecu
- What kind of fan do you guys run?
- Idle Bleed Screw for Edelbrock 65mm Throttle Body
- Need a how to on SOHC catch cans : Post what ya got
- Help, need engine clarification and limits
- Valve lash specs... with crower cams.
- HELP ME OUT WITH MY BOTTLE SET-UP
- K24 - More power needed.
- does a catchcan need a breather/vacuum source???
- is there any company's that offer any tuning solutions to the new drive by wire hondas
- Im gonna heat wrap my downpipe.... question..
- Back in th
- Supercharged D16
- Block Guard?? yes or no??
- what oil you turbo guys running any recommendations
- BOV before the Intercooler?
- Where to buy catch can filter(Endyn Style)..?????
- waste gate dump tube?
- Stock Suspension 12 second Daily Driven Coupes
- How much hp can this intercooler support?
- boost control
- Shorter geared trans+forced induction.
- FMR vs. Iorn Sleeves 2.2 liter questions w/ boost in mind
- single cam turbo?
- T3-T67 Turbo from fullrace
- intercooler for JRSC setups
- how often do you need a fresh tune?
- tiny metal shavings in oil.. damage my turbo?
- Thoughts on GT37 for SPFwd?
- t3/60-1 hp potential?
- need a filter to fit my turbo
- WHOO HOO!! Finally 44mm wastegates on ebay!
- anybody have pics of peakboost 4inch exhaust?
- Tuning
- Greddy SOHC turbo kit instructions??
- stealth
- oil sensor.. oil feed line.. to block..
- LS boost build
- safe to boost a b16a2? <============================
- Problem after turbo install, cannon diagnose CEL
- Fuel Pressure Regulator
- some random work at the shop
- internal wastegate and external waste gate
- turbo advice for this dummy
- planning on 400+hp question.
- What do you guys think of this VDUB?
- Question on Boosting a B16 First Gen
- can you guys name the setup that made this graph?
- 90 civic hatch, semi built LS, 300+ whp dyno graph
- Ineeda' find a 3 bolt downpipe thats 2.5" piping.... B series too, where the hell?
- where did i get a boost pulley for a JRSC
- Data logging question
- Cams for high boost applications???
- intercooler too big...what happens
- Need help...turbo EM1 problem...
- rebuild a turbo!!!
- All of a sudden runs like ass - HELP
- Defi D-Guage Owners
- Crazy Oil Pressure Readings == Bad Sender??
- Can my motor handle 100 shot???
- Where to mount FMU?
- Help!! What Turbo Is this???
- running into walls with my shortblock build up, opinions?
- B20 or B18 for turbo??
- HELP - GT4088R turbine wheel failure in first race!!
- please help....... would you.................?
- Opinions on Cranks
- Exhaust sheild surround.
- ADAFDLKJFSK!!!!!! wtf No Boost AFTER Turbo Rebuild
- Link to Boosted 93 Hatch For Sale with spare built motor
- GT28RS with T3 Flange
- help with my set up
- ill send u $5 paypal if u can tell me How To install GREDDY TURBO TIMER step by step ? *searched* Pl
- quick qustion on tuning
- Replacing turbo seals? Questions..
- eagle crankshaft in b18 block? thrust washer or bearing problems?
- What causes misfiring/bucking at low load in s200b?
- Quick Question
- H23 block questions
- anyone running wrx turbo on d16?? what boost should i run?
- Boosted Gas Mileage Thread.
- What effects will Higher Octane fuel make to your current tune?
- detonation = not good
- hard time finding a small radiator
- vtec lsd in an LS tranny??????
- Dyno results: D16Z6 Topmount 57trim @ 28psi Neptune --> 441whp 333tq
- 3" exhaust ?
- What Size Turbo Is This(Pics)
- 99-00 Civic SI Vortech supercharger onto a b16 hatch
- nitrous retard feature for stock ecu
- Car running awfull, im running out of ideas...
- Cracked Dump Tube Question
- 2.5 Bar Install - Car Wont Idle/Run *NEED HELP*
- T3 --> T25 Adaptor Flange Adapter
- ?? about top to bottom flow intercooler?
- Aeromotive 12602 fuel filter same as sx performance 41102 filter?
- b16b stock
- Silicone with BOV flanges?
- Question about S300
- Oxygen Sensor Simulator
- Opinions on advisibility of running straight methanol.
- new to d series
- Which manifold style to choose?
- Garrett GT40 vs. GT40R
- Got my 92 Accord Turbo running strong, vid inside
- best turbo pistons that create no piston slap what ones do u choose
- Hondata S300 installation, yes i searched
- OBD1 Convervion Injector ?
- what size spring in your tial bov?
- is your radiator hose hard to squeeze when at normal temps
- Tubo Kit Opinon?
- post if you have your fan constantly on
- Synapse FPR on Victor-X manifold
- WHISTLING?? good bad???
- Did a compression test.... what is the problem for my numbers?
- Jackson Racing Parts List
- BOV Decision
- When is a 4" DP needed
- what size wastegate with 60-1?
- leaky turbocharger?? whats up with that??
- Considering Tuning it myself?
- "" SC61 Owners Chime In ""
- Injector size issue
- will a DSM O2 senser work in a honda?
