View Full Version : Forced Induction
- Vertical Intercooler and piping for 700whp
- 91 civic dx d16z6 turbo detonation at 6k
- Using Stock Cam Gears w/ skunk 2 stage 2 camshafts that is turbocharged.. Good idea?
- Afr at High Cam engagement.
- Help Deciding Turbo for 700hp
- Modifying Old School: Can DSM Injectors in an F23A1 engine? If so, where do I start?
- How reliable is the stock block with turbo
- Troubleshooting: B18C1 turbo w/ Loaded Demon2 Basemap is not firing properly
- Troubleshooting: Fuel Pressure drop to 20psi from 50psi using FuelLab FPR. Ideas?
- ef k series turbo kit? + advice needed
- Calling TheShodan and other Turbo drain line experts! Pictures inside
- AZ_CIVIC'S Direct Port Nitrous Setup
- B16 TD05HR build thread - until I set it on fire...
- Suggestions needed: B-series Clutch for street strip use at 400whp
- Questions for those Running Water/methanol injection on their B-series.
- 800whp+ Turbo K24 - Fuel Options [Methanol/Race/E85]
- Do I need internals for 300hp
- B20B Turbo Smoking, Low Compression Test numbers
- Switch inlet/outlet on fuel rail
- 2000 civic ex 1.6l coupe swap question and issues
- Troubleshooting: No Start issues 2000 Civic EX B18B1 Turbo retrofit
- Crankcase vacuum pump..More efficient, or no?
- Troubleshooting : Timing, timing, timing...And more timing issues on the crank pulley
- 9 inch fans for cooling
- Oil Splatter all over driver hoods, motor mounts, driver shock tower
- 3amBeeS and his tuning of a stock F22c Turbo in an E30 BMW
- Scotty Doesn't Know's - LS-Turbo Dyno Results
- Timing going nuts, EG Turbo k24 bucking HARD down low
- B16 piston/ b18 block compression For FI search question
- Any Engine Coolant Temperature suggestions, tips, tricks, etc?
- Which ARP Head stud part # needed for a a6/y8 mini me turbo build?
- Open Junction IAT Mod
- Transfer Hondata s300 map to Crome?
- I need a lot of guidance selecting a turbo.
- HELP My Civic 96
- WG vacuum source - Manifold or compressor housing?
- Need input about reason of failure - cracked cylinder walls
- EBAY GT35-2 turbo feed line leaking from turbo through threads of restrictor and out.
- Assistance needed: Turbonetics cast wheel turbo Identification
- Troubleshooting: Coolant out of radiator cap
- Troubleshooting: Overheating issue @212* - B18C turbo
- Troubleshooting : B16A Surging idle despite normal checks of TPS, IACV, FITV, etc.
- Garrett T04 60-1 Rear Housing swap
- Who does custom fuel lines? B&R Fittings?
- What turbo should i go to next?
- d16y8 + hx35, what do you guys think?
- Need ideas: Air dam mounts near the intercooler.
- Intercooler mounting ideas
- Weird overboost issue
- Assistance needed: Andrew Dasilva has a Boost Spike Issue
- Troubleshooting: Not enough voltage to injectors causing intermittent startup
- Ricer EJ6: Is there a way to build a K24A2 using budget internal components?DISCUSS !
- Troubleshooting: LS Turbocharger injector Deadtime / Running issues.
- civic_ek_b18a1's Search for 300whp. Is that possible?
- B16 engine rebuild estimate for turbocharged use
- DIY Flex Fuel Sensor/Ethanol Content Anaylzer for ~$20-100 (don't need Zeitronix)
- B-series manifold for Evo9 Turbo?
- Boost creep when vtec engages
- Boosted H22 voltage dropping at WOT
- GTX3071R gen2 which a/r turbine housing
- Troubleshooting: Oil in eBay Compressor housing & why
- OEM appearing kit availability for 11.0:1 Australian DC2R
- Injector size recommendations for certain power levels & fuel used
- B18c1 weird noise at 2-2500 rpm
- B16 turbo engine troubleshooting: No positive boost pressure.
- 93Grayeg Simple ITR Turbo Build Thread!
- Is oil pressure or fuel pressure gauges inside the vehicle that important?
- Mishimoto Half or Full Rad for Boosted GSR
- Multiple Product Inquiries: Levi Johnson Needs help choosing turbo and cams
- Buying clutch and flywheel tomorrow, will I regret my choice?
- Product list inquiry: What components are needed to run E85 pump fuel?
- Thoughts/Advice On My Turbo GSR Build Plan?
- Stud kits for intake manifold and turbo manifold to block?
- B-series "Top-Mounted" 3" Down Pipe Turbo Engine Setups. Show me what you got!
- Would you guys go E85 even if you could make enough power with 93?
- Shodan's catch can setup on a LS motor...Questions
- Sealed catch can setup for turbo b16
- Hks ssqv bov problems
- Would you guys choose a different head gasket than this for boosted setup?
- B20 Engine Supercharger: General Questions (in Turkish)
- A Look at the New Turbonetics C15 TNX turbos
- Camshaft Choices - 500whp LS-V
- Product Inquiry: AI4-XTSD for 300-400whp
- Product Inquiry: Using VP Coolant. Is this a good option to use?
- Product Recommendations needed: B18 High Z Injectors 500cc-1000cc
- T3 or T4 flange? image is attached
- How to tell if bov is leaking boost
- Speed Factory Drag race Radiator setup using a 4" downpipe. Overheat issues??
- Spal 12" fan shroud for a 1/2 size Koyo?
- AZ_CIVIC's Rear Mounted Radiator custom fabrication setup
- Head studs install questions
- Joeyzbg 10.5:1CR B16A2 with 400-420WHP 93 octane possibilities?
- Troubleshooting:Turbonetics turbo CHRA oil leakage issue
- MHI turbochargers - Compressor housing interchanges. What's available?
- Garrett T3 60-1 .70/ .63ar bent compressor wheel
- Which AR? K20a2 gtx3076r quick spool
- Assistance needed: Stock Turbo LS/VTEC mutiple Idle issues with codes
- Intake Manifold Recommendations
- Recommendations needed: Available 2000 F23A1 turbocharger retrofit options?
- What clutch recommendation for B-series turbo engine making 300ft-lbs of torque?
- Troubleshooting: Tapped Compressor cover as vacuum source, but no readings. why?
- MaxSpeedRods Turbo Drain Line Kit photos. *Product FeedBack*
- Is there a place in GTA (Canada) area that can Rebuild PTEs?
- thugsbryan Finally takes the B16A to the dynamometer. *some tech involved*
- Project B18C4 using the KKK K27 Turbocharger retrofit: Possibilities? Suggestions?
- B16a cylinder head port... Does this look ok, and will it make a difference?
- Creep w/Prayoonto AWD/FWD manifold..
- 800 Hp Integra turbos?
- D16Z6 Turbocharger Oil Pressure Verification Question
- Turbo K24A1 - Misfiring at the track
- Will a turbo setup work with my high compression build?
- Troubleshooting: Oil Pressure fluctuation issue
- Can anyone answer this simple LSVtec question?
- Turbo D16Y7 questions.
- Is it possible to make 300whp using a B16a with gsr head? YES!
- P72 head, anything stand out with it?
- Turbosmart hypergate45 wastegate spring suggestions
- Wideband AFR reading above steering wheel? I'm trying to find best option
- Using an eBay exhaust manifold. What turbo housing configuration from eBay works?
- Electrical Problems in Boost?
- Turbo choice for stock LS? Critique me
- Tyrantsold13R Feedback request: B20b turbo retrofit. Is it worth it?
- Turbo Coolant Return Question.
- Inquiry: Intercooler size/type recommendations for 500whp H22 build
- What exhaust should Chev run for his lsvtec turbo?
- Assistance needed: X series boost gauge finding a vacuum source.
- Is there a place to buy valve covers setup for breathers?
- Built 8.8:1 CR K24A1 What's the Power Limit and why?
- opinions needed:Fiat X19 B16 turbo exhaust manifold pre-fabbed optione
- Opinions needed: Turbine Housing Size for PTE 6466 using a K24A2 Engine 800whp.
- Difference between mini ram and ramhorn turbo height placement?
- Troubleshooting: High boost cut issues S2000. Ignition,solenoid, or software?
- Product inquiry feedback:Borg Warner SXE257 line
- Edelbrock Throttle Body for 1.8L on B16A2?
- Nates Civic. A build thread/resurrection.
- Probability of Compatibility of an A/C Cast manifold with a PLM v-band downpipe.
- Product Inquiry Request Opinions about this Pro Series "Oil Catch" Can?
- Toat13's Waking Up My 400hp Integra Dreams
- piggy96’s EM1 build
- What turbos DON'T fit with the tubular log manifolds and the Inline Pro manifolds?
- Is there any fuel pump NOT underperforming lately due to Chinese Manuf. Processes?
- So why does everyone go with aftermarket fuel rails?
- Product feedback inquiry: Turbosmart Oil Pressure Regulator (OPR)
- 4” downpipe question
- phirewire's 99 GSR Turbo Restoral build thread
- Product feedback advice: Courtney Lewis F20B turbocharger options for 500whp
- Grannyscivic is looking for project advice for a Turbo B20BVTEC
- Best location for flat shift switch
- Turbo k series sand rail - take a look
- 1000+ hp K-series engine cams.. what are people using?
- Purchasing a turbo ef..Wise decision, or nah?
- clutch for F22B DOHC 370 Nm torque
- AEBS vs. Skunk2 Pro vs. Skunk2 Ultra Street Intake Manifold
- GT28RS on factory stock B18B? 300whp?
- Large Brian Crower cams with a log manifold. Is this a good idea?
- IC core for a Prelude JRSC
- Piston Ring Gap For Turbo Build?
- ARP Rod Bolt Question?
- Turbo civic ek cold misfire issues
- Troubleshooting: Boost pressure drop during VTEC engagement - B-series Engine
- Intake valves have oil on them?
- Product Feedback: Oil cap vent/oil separator...Thoughts?
- Spoolyboi's dream k24 turbo setup build... What camshaft is needed for 350kw?
- Wheres_francis 600whp "wanna-start-a-build-but-don't-know-what's-needed" thread
- B-series Inquiry - Optimal operating temperature?
- Troubleshooting: Experiencing Boost creep. How can I solve this?
- Blow Off Valve: Do the flange type and location of the valve matter
- DC2 Integra Turbo A/C clearance
- Turbo oil feed location. Can I use the VTEC solenoid location?
- Product Feedback question: Brian Crower "stage 2" turbo cams B18B1
- Boost drop 19psi at 4400 deadline 10psi
- Ignition Breakup on Dyno @26psi
- Is my Vacuum/Wastegate setup okay?
- Product Feedback: K24 turbo & Drag Cartel 004 Camshafts for 800whp. Worth it?
- Looking for opinions before ordering (B16B turbo)
- montanacivic's D16z6 400hp build. What are the cylinder head limitations?
- B16A2 With Oldskool greddy Turbokit Drain Routing Help?
- Nitrous build. Do I need valves for 150 shot?
- Battery Choice - Boosted B Series
- B16a 450 hp on pump 93?
- CRV AWD B20/VTEC Stock engine turbo upgrade to 400whp. What direction to go with?
- B18c /82mm/ Darton Sleeve/ Pro 1 cams/ 6266 turbo/ 1.00a/r Divided hsg. Thoughts?
- Spanky’s 650+hp GSR build
- Troubleshooting: Accord turbo F-Series cannot rev past 5000rpms
- B18 Block/Crank + b16 Rods ? Need Input
- Product feedback request about PLM RAMHORN turbo manifold ac/ps compatible. Thoughts?
- Sniffbooger's post-divorce economy car repair thread
- Getting Car dropped off Next week
- What are the more robust pistion and rods combo for boosted B/D/K/H series engines?
- Circuit track air to water S2k
- User Feedback & Opinions: Comp CT4 Journal Bearing 6262 vs. The Competition
- Golden Eagle Head Gasket Orientation. Numbers should be facing up.
- What cams are these? ITR or B16???
- Main caps are m.i.a.
- Boosteddb8's EG Sedan Turbo drag Build thread
- G-Series Turbos w/B-Series engines(G25-550 / G25-660)
- Wideband o2 or not?
- random misfire error code on high speed low rpm
- LS/VTEC (B18C1/B18B1) hybrid. Can this take turbocharging to about 300whp? Answer-Yes
- Need some advice on preparing for a Kraftwerks Engine Build.
- Troubleshooting: Spark keeps blowing out
- Question: How are YOU shifting gears on your turbo Honda? Is there a "right" way?
- Turbosmart new Butterfly wastegate and other new E-gates
- cxracing wastegate vacuum to brake boost downpipe loud sound
- CIVICSI1999's B16A2 turbo build
- mynameisjustin and here is my CRX B18C1 GT2871R Build Thread
- Matteggy's theory on using "Longer Rods" for turbocharging. Good idea, or No?
- Need new crank, OEM, Eagle or brian Crower?
- 400hp goal for lsvtec turbo
- Internal Gated GT28 on Cast Log?
- Boostin again. z6 Greddy kit questions.
- nategbc attempts to Turbocharge a d16z6 engine. Not sure where to start
- Awesome Deal: 3 3/4" Apexi Catback - cheap!!
- boostedsohc95 Troubleshooting Tuning issue: D16Z6 is Running "rich"
- Where to find PTE V-band inlet Turbine housing for my 6266 JB?
- Boost Hunter: Hunting for the 500whp "budget" Build - Advice needed
- Comparing the K20C Turbocharged and K20A NA Engines
- acl race oil pump bad?
- Fuel setup help?
- D16z6 Engine health for turbo
- Nutz4vette's Speedfactory b series a/c ramhorn - Can't use a radiator
- S2T2 on gsr turbo?
- What is the "BEST" BOV for 1000+whp?
- Ryan Blair's 400-450who part build recommendation list. Ideas?
- Vaccum Line Help!
- Built d16 for 1 million horsepower. what transmission should I use?
- New GTX3071R Gen2 weird sound
- IAT sensor location
- What could be causing this boost pressure drop??
- Spaceturtle917's Stock D16Y7 Saab t25 turbo build
- turbo integra
- What bearings to use for a daily driven B18C turbo
- Would you trust a ecoplug (magnet drain plug) to hold your oil in under power?
- Horrible creep w/sidewinder tial MVR. 6266 k24/20
- B20v high compression turbo?
- Ratt731 needs Help with choosing a turbocharger for B18B 450whp on 93 octane
- skunk 2 tuner stage 2 tuner cams turbo?
- Lsvtec build thread first timer kingdee’s. Questions and input thread!
- Using moresso oil pan with turbo does this line look okay?
- Valve Spring Max Lift and Camshaft Lift Question
- Mishimoto Oil cooler Install issue
- Oil recommendations for D16 Forged internal engine w/ ACL bearings.
- d16z6 vitara stock sleeve gt3582
- Unknown turbo manifold????
- JCraven94 turbo newbie here. D16y8 boosted on a budget
- Troubleshooting: VTEC attempts to engage
- Fuel presure drops 5psi/hunting idle. turbo k24 DC4
- TPS Issue. Harmonic Issue? Voltage drop at WOT
- Jacob Clement's Building his first F- series turbo Honda..Let's get it started.
- Nippon Racing/YCP Pistons for boost? Power rating claims and discussion
