View Full Version : Forced Induction
- Supercharging Honda Ridgeline.......
- Stock internals or rebuild? Clearification for my setup!
- jrsc questions
- Turbo D16Y8
- wire hookup on walbro??
- Greddy turbo kit for integra LS..will it work on my D16z6?
- OBX Turbo Manifold !!!!!!
- evo VII turbo sizing?
- GT35r GSR Pump Gas tune (dyno chart)
- swedish turbo
- Head Bolt Question
- Thinking of dynoing my ek hatch tonight 10psi
- Performance Axles
- cooant temp getting hot only on the highway????
- Intercooler sizes, looking for something 23 X 6ish X 3, help me find what I need.
- Walbro fuel pump.
- 10.2:1 to 9:1 difference
- H-T help me choose!! Garrett T3/T04E or Precision SC50
- Nitrous (nos) set-up
- ls boost help
- Sry for lazy question, but how much does it cost to turbo on average. Probley doing a B18b1 or B18c1
- 48mm turbosmart WG, who can make topmount manifold for it.
- low or high imp
- Differences between a internally wg'ted turbo and externally wg'ted turbo
- Top fuel turbo kits UNITE
- Those of you running LC-1 New logworks update w/datalogging!!!
- FS: INNOVATE LC1 WIDEBAND 02/CONTROLLER
- integra intercooler piping
- FS: STAND ALONE MANAGEMENT.....MUST GO!
- where to buy Black Steel braided Hoses??
- Need help with plastigauge results...
- Just bought some turbo parts, have a few questions.
- new to the honda/turbo scene. some help
- studdering
- Performace Cat?
- can you reuse a headgasket?
- rods info
- turbo setup
- nitrous help
- right oil restrictor for Garrett Blowzilla turbo?
- is this tru you can put B16 pistons in a sohc vtec
- Turbo GSR dyno - Thanks Redzone Performance
- **FINISHED TURBO RAN INTO PROBLEMS**
- FMIC mounting help....
- Where did u get yours for your build?
- JRSC Throttle Cable MacGyver
- DIY Turbo manifold for D-series
- ? about IM and TB on Ls Turbo
- where to buy t-bolts and couplers in so cal?
- GT4294 What .AR do you guys recommend...
- turbo silince
- Starting troubles----1999 GSR turbo
- need help ASAP, IACV question??????
- Ebay turbo kit
- My Setup- input appreciated
- Turbo suggestions for Integra
- Chiped ecu gives me Trouble Code 21??
- datalogging cable question
- Tail 38mm 1/2 stock spring max psi?
- Which 4 bolt V band conversion flange?
- i need an intercooler that fits an LS....
- Action clutch... which one do I have?
- Turbo breaks in 5 min...!!
- New to this thing called FI...
- quick b16b turbo questions
- sfp manifold
- backyard
- GT4294 or GT4202
- need help with crx
- 12.00 AFR idle after driving??
- d15b-t.. loss in power.. why??
- clutch for bolt on wrx...
- Slow boost build below 4,000 RPM on Accord SOHC
- does flywheel bolts have to b installed like head studs??exedy twin disc?
- downpipe too restrictive?
- running stock o2 sensor on my b16a turbo ?
- Checking my bore: Is this gauge ok?
- what vtec head fit on a d15b7 block?
- hondata tuning in utah?
- high flow cat removal.
- EP1 275whp HELP
- Turbo suggestions for B16A3?
- Thermotec wrap Good or bad Idea??
- can i make 300whp on this setup?
- overheating after driving 30-45min
- spooling issues??
- need lil help in doing oil line
- For my turbo plumbing, vaccum line, slicone line, stainless line
- Dont click this link!!!!!
- Rods choice
- Anyone know what size D.P is in the Turbonetics kit?
- would anyone use this intercooler ebay special for Boosted Single Cam with Hondata??
- stainless log manifold turning purple...is this normal?
- Greddy 18g turbo flanges which work? let's get this straight for once...:)
- Big HP k series show what you got!!
- where to get a TiAL BOV flange?
- Pic Request- Greddy, drag, revhard ect manifold with hotside on pass side installed
- 10:5:1 to much for boost?
- ARP main studs, good idea for my build?
- Anyone have the new SSQV yet?
- greddy t04 good kit for d16z6?
- CRX LS Turbo Manifold
- Deckers 2JZ 240sx
- MSPi/TDF Turbo S2k Pics and Vids
- Quick picture comparison T51R KAI vs. GT47R-80
- F20B internals?
- Turbo Kit Fabrication and Tuning Video
- Pistons and rods for an ITR motor?
- oil pressure gauge question
- Saab turbo into civic need input!?!?!?!?!?!?
- Stupid question...but ill ask anyway
- Does PSI=WHP?
- Can i still save my piping?
- map defensor..?
- oil return and oil feed
- Turbo b20... Block guard?
- Greddy profect B type II boost controller help PSI
- Supercharger drain battery?
- is my catch can finally connected correctly?
- F220 on rsx?
- JE piston wrist pin locks...what should they be?
- Garrett Turbo help?
- gt4088r, afi, stock k20a2 :)
- 3" Exhaust / Turbo install Woes
- determining oil pan tap?
- gt35r coolant line pics
- head gasket question?
- b16 allmotor
- Who has the best prices for Precision SC61??
- Evo 3 manifold on a d16
- helpful info for the lazy
- a/r 50 vs a/r 60 on a 56trim turbo
- d16z6 aftermarket cam ?
- Missfireing at full boost.
- can anyone tune a greddy blue box? change from dc2 to a sohc?
- engine management/tuning for automatic tranny
- B16 Turbo
- Only looking to push 10-16psi....
- Compressor map for master power turbo???
- SSautochrome downpipe flange, question
- I need help with my timing marks!!!!
- super rich for no reason.
- CRX running way too rich since turbo install
- exhaust flex
- swapping turbos question
- anyone boost one of the newer accords?
- turbo sounds like a supercharger..
- any one running a GT3582R Twin Scroll... numbers? graphs?
- does anyone drive a front passenger side exhaust on the street?
- slimfan install
- HELP I REALLY DONT KNOW WHAT IT CAN BE SMOKE!
- B17 ?'s
- B17 ?'s
- help! crank oil seal gone, anything to do with turbo?
- t25 turbo on d16a6
- Plans for Spring build
- Redshift Motorsports Supercharger
- B16 Turbo thread?
- Need HELP!!
- Cold Idle issues, I searched like mad, can't figure it out. PLEASE HELP!
- b16 with ctr guts on boost
- Qs about small turbos
- supercharger on my na?
- Fuel problem, need opinions
- edlebrock turbo kit?
- looking for a quality FPR...
- nitrous tuning questions.....
- sandwich plate question
- Tuning
- Removing Intercooler Paint? and keep the nice finish
- oil restrictor, what size orfice for garrett t3/t4 (360* thrust bearing)?
- hooking up s300 launch control switch
- Building a LS or LS/VTEC for Boost, Which is better?
- P72 OIL PAN
- plastic boost gauge hose got kinked.. still usable?
- spark plug question.
- Very Noob question
- Need help with FJO Injector Driver install on a H22
- quick question
- got turbo for set-up
- Working Pressure?
- is obx intake mani any good for boost?
- APEXI VAFC2 II?
- my new engine for my turbo ITR
- Condition of my bearings
- Spark blow out??
- Are these JE pistons usable? *BIG PIC*
- how to clean a used turbo?
- ok guy what head gaskit do i use now that i have my turbo oh sohc lol
- Facts about Rotrex
- help with walbro 255hp
- 2JZ??? RX7
- Q for engine builders stock valve max whp...??
- Who has the best pricing on CP Pistons?
- b18b1 "turbo question"
- OK need help...I have NO idea what is going on with the car now...
- problem
- gsr turbo question
- do you think i can make 650whp w/ this setup
- Max bore for stock gsr sleeve?
- ERROR: File larger than selected chip. Load Failed. - Message when trying to burn chip
- Need help, tuner really did a number on me this time :( 266whp/13psi/sc61
- downpipe hitting motor mount
- Anyone here use Supertech pistons
- Finally got my car dynoed right.
- does water cooled mean its ball bearing
- Experience with Airesearch Turbo
- jrsc problem
- stock ignition power output??
- advice on what kind of boost and oil pressure gauge to buy?
- what to do???
- New sleeved block smoking like crazy!!
- Automatic radiator transmission lines to cool turbocharger??
- Read my plugs, please
- JRSC & Cams
- Gauge Question
- t3/t04e
- what head gasket are you LsVtec-Turbo guys using?????
- Quick question about turbo gsr and drag piping?
- oil cooler core mounted to back of FMIC?
- turbosmart ultra-gate
- Turbonetics 62-1 for b16a ??
- Swoosh or Blitz
- b18b1 Turbo and Nitrous?
- SARD Trigger EBC help?
- Vacuum block question.
- keeping turbo cars cool when sittin at track all day and like 90* out
- Need a quieter exhaust: supercharged 2jz-ge
- Anyone using a TCS clutch sold by EMS with boost!
- ***Custom Turbo***
- a turbo question
- Grade my catch cans(with pics)
- ssqu BOV sputtering?
- anyone use a t3/t4 turbo on a d16y7 motor?
- GT4067 no longer is made.. now what ?
- Greddy Turbo Timer
- intake question
- Official B16 Boost Thread
- how big of TB for 500+ whp?
- How to adjust hks bov??
- gt35r 1.06ar, please help, need a housing, precision says it dosent exist!!
- Coolant boils under boost.
- ? about Tial 50 MM bov's....
- car dyno'd
- Looking for Nightrider-gsr for greedy carb exempt tags
- when i need to use Forged Crankshaft (Lightweight)???
- ~anybody running this manifold on there sohc
- i need someone to tune my car....
- Need your advice.
- T3/T4 60 Trim .60/.63 AR on B16?
