View Full Version : Forced Induction
- Misfire on cylinder 1 and 2? but car doesnt feel like its misfiring...??? HELP!!!
- for all of you pro's
- broke bolt in my exhaust housing help!!!
- built b18c losing oil, help !
- Emanage Ultimate
- SOHC turbo / NA B16
- What Model Weldon Fuel Pump Recomended For 1000hp
- has anyone see this manifold before?
- What spark plugs to use on turbo H22
- where can i send my injectors to be cleaned and flow tested
- Where to get Hondata IM gasket?
- Greddy E-O1 Boost controller
- Pico Style Injectors...
- cheap ebay turbo?
- fuel sumps
- help identifying this turbo?
- Questions Regarding A Low Boost Build
- PIC REQUEST! SEARCHED!!
- if i was a tial wastegate what size would this bolt be?
- Help on NGK spark plug
- E manage questions. Car doesnt start with ignition harness plugged in.
- It's Crunch Time and There Are A Few Q's Left
- Issue with My b16 cylinder head. Need some advice please!!!!
- Intercooler Question
- max psi on 8.7spring tial wategate?
- Greddy Profec e-01 Electronic Boost Controller
- Turbo, Wastegate and BOV question
- is this a possible fuel leak
- Wiseco Pistons 9:1?
- Are Pyrometer (EGT) Stingers universal?
- Your homemade turbo kit
- Wastgate as a BOV-pic
- victorX vs skunk2 for turbo app??
- Boosting- What gauges would work?
- high flow cat? bad or good with boost
- HOW MUCH PSI OR WHP CAN STOCK GSR INJECTORS HANDLE
- How much whp before you need headstuds?
- Thicker headgaskit with more boost
- Tappet clearance for Turbo setups
- Ls-T (TD05H 16G) Question.
- couldnt find the fi video thread so here it is gsr turbo
- skunk2 IM stuck, fitment issue
- Oil leak from where? +pics *n00b warning* :D
- Getting ready to buy a GT35R, Shroud or no Shroud??
- is it really this easy??
- how many pounds can i run on this set up safely
- I dont know what to get???
- how do eagle rods get oil???
- Cost to have a turbo kit installed
- b16 turbo(blown turbo rings) change the block and back to NA it wont run straight at 0 timing help
- RPM dependant boost control...which EBC is best.
- civic oil line kit
- What compression to run?
- How are these valves looking??? 56k Warning
- Manley H vs. Eagle H
- boost D16y8
- Smoke from under hood (Built/Boosted LS/VTEC)
- are 440cc injectors enough for 280-310whp ???
- tuning help
- How light a flywheel should i use?
- nitrous on stock block b16
- NEED HELP!! H22A TURBO BUILD UP!!
- Worth it to you?
- injector question
- looking for a tuner in louisiana!!!!
- Built Smart(car) 125mph
- GSR vs B20
- D16z6 Parts
- LS Crank and GSR block...WHY & HOW?
- a simple question for you experts out there. will the ef work if i just bolt on the turbo without...
- Just a little K24/K20A Turbo EK!!
- Running a intake manifold spacer, have a a question...
- the right sectionWeld in a block gaurd a good idea?
- any manifolds that DON'T require cutting your block!!!!!
- ahhh help?!
- DAMN!! Sucked in mesh screen and bent fins on GT35R.
- which clutch is good for 700hp?
- lightweight flywheel?
- D-series Ebay cast manifold
- All dsm flanges the same?
- d16z6 Help
- Help with a d16z6
- GSR TURBO HELP!!!
- Help on Greddy Profec B
- Spark Plug gap/plug for 500whp
- How well do traction straps work. Need opinions.
- Jackson Racing Supercharger Issue - Scratching Noise past ~ 6k RPM
- TURBO QUESTION!
- ge headgaskets on boost
- Radiator Scoop?
- bfg- drag radials question
- t4 to t3 adpater plate
- turbo turbo
- new turbo build up...
- engine management???
- Opinion on which turbo to go with on a B18c
- Rebuilding D15B7 Motor
- K20a2 Turbo Limits?
- Tuning price question
- quick question about mahle forged pistsons.
- hp limits on laskey race engine?
- Do I need to upgrade my fuel pump
- What turbo manifold/turbo unit/intercooler is good fro B16A CIVIC EK4?
- Supercharger question....
- strange sputtering at full throttle and high rpm??
- is there any good crome pro tuners in miami???
- how high are you revving on your oem retainers?
- Anyone running a GT40R on a stock bore/stroke B16?
- Are stock b-series blocks OK for a turbo build?
- Why no Darton MID sleeves for B20?
- Need 0.25bar tial spring
- Fuel pump reliabilty??
- Aeromotive A1000 vs A1000-6? Walbro 255lph w/Aeromotive FPR? Golden Eagle Rail? What size injectors?
- t3 60 trim vs. t3 super 60?
- tuned the turbo ITR yesterday
- B20/vtec turbo?????
- **463hp D16Y8**
- NITROUS beginner, WET vs. DRY for B18B
- turbo accesories
- Sleeve prices and suggestions please!
- hks ebc- pressure is higher than the setting
- looking for traction. Wider wheel in front ok?
- D16Z6 stock block, 15G turbo, 1BAR - tuned by me :)
- help with turbo vacuum lines
- HMT kit w/ td04 13c turbo on a GSR
- how much lag with a no name t3t4 To4E turbo?
- gt35R OR full-race GT3567R
- head work
- whats the biggest honda TPS throttle body?
- Thoughts on this setup
- Piston size?
- best intercooler for my application?
- Dual Bosst Level Using Tial Wastegate....?
- Delta Regrind?
- NITROUS HELP PLEASE!
- TRACTION!! Which Tires Are The BEST For The STREET
- 3" Exhaust or a E cutout
- <ambient crank case breather = HP
- ? about Full Race kits.
- Breaking in motor with a turbo kit.
- All MOTOR or BOOST
- noob turbo question
- will anyone be interested in a turbo ready gsr?
- DSM 450's or stock + fmu
- GSR 84mm Sleeved Block/Engine. WITH crank. Golden Eagle
- spoolin log turbo manifold?
- fluttering coming from BOV or WG???? is it even possible to be coming from a WG?
- $25 Turbonetics/HKS Manual Boost Controller
- Suggestions on my K24/K20 Setup
- turbo timer and EBC needed for turbo install???
- GM 3 bar map
- LHT Civic K20 Turbo auto to manual
- turbo ls headwork
- What air filter to use on an fi setup??
- LS TURBO VTEC DYNO RESULTS
- 500whp Ls/vtec, Block-gridle? Is it a requirement?
- b20z TURBO YES Or NO
- Best Boost Controller....Need your opinion!
- What should be my vacum reading
- ATTN: Peakboost/Phoenix Turbo
- Design for Homemade Catch Can/ Breather
- Advantages/Disadvantages of boost+AT
- how to retard timing 10*
- Here is the reason I like my JRSC setup vs a turbo....
- Any thing anybody would add to my build??
- question about dart block??
- Im a Automotive Technician for GoodYears, Anyone' Show Me forced Ind. Preludes
- How Much Boost.....................................
- To Recirculate or not Recirculate?? That is the question.
- anybody heard of pfabrications
- What kind of injectors do I have?
- what wireset do you have?
- How's my Vacumm? What is everyone else getting?
- H22A Piston Swap
- who is not using a iacv?
- Stay all motor or turbo it at the raceway for shows?!?!?Is it worth it
- Suddenly Lost Fuel Pressure- trouble shooting help??
- SAFC?? what do you all think
- does anyone know what car this turbo came from?
- BLOX MAP sensor bypass question
- Help, is my motor done!
- oil restrictor- yes or no?
- b16a3 turbo build up
- **Precision Fuel Injectors GOOD OR BAD**
- turbo manifold
- Turbo oil feed line?
- FAQ: How to nicely install RC440cc injectors on D16Z6
- LS pistons in B18C1 block???
- is an FMU worth it?
- rear bumper keeps getting black ??
- Vitara Pistons - The Bad
- replacing actuator and arm on td05 turbo
- going to run nitrous with my turbo , how to seal the fitting in charge pipe?
- lost my zdyne master disc , anywhere to get it again ?
- Sleeved block just showed up, PICS
- cometic head gasket on a d16z6 bore?
- Safe boostin
- Throttle Body advice
- what kind of gasket for turbo exhaust manifold???
- should i buy this turbo?
- Zex Nitrous Kit
- another nitrous question
- The thread that nobody wants to think about. How much do you have in your B setup?
- Help with a CEL code: P1128
- GT35R-2.5 discharge VS 3"discharge
- this T3 too small for stock B18b1?
- GSR IAT on a Si engine harness
- am i gonna be able to keep ac?
- is dyno tuning really necessary?
- will it be good for me to upgrade my cams
- How much spray can it hold Stock?
- Thoughts on this setup.
- clocking the turbo
- a good ring gapping tool?
- Plugs fouling in weeks, horrible idle, stalling.
- Pic Request: Aeromotive FPR, JG intake manifold mounting pics...
- Peaking out too soon and high duty cycle
- Think C&R radiators are the best? I'm not impressed
- Does the H22's composite cylinder walls make it very boost unfriendly?
- 3" V-band users....solution for leaks found.
- Noob Question
- magnus motorsports intake manifold users?
- New turbo leaking
- queston on hondata s200
- can I get a decent civic radiator sized intercooler?
- how many stock LS's are using a sc61?
- Anyone is able to help with this one...
- Converting wet kit to direct port?
- Garrett turbo spec question.
- jackson racing supercharger for less than $1900?
- GT35R, Use the built in restrictor, or buy one from ATPturbo
- b18c1 Garrett GT3076r or GT35R! Check out my set up!
- how can i make my k20a turbo
- external tial wastegate on greddy manifold
- ATP Turbo Restrictor Install
- EM1 Intercooler/Foglight questions...
- dc headers
- Injectors are out
- SC61 respool, who has problems
- PIC Request : BIG turbo setups (twin wastegates/GT4088r/GT4094r)
- turbo question
- O2 Sensor placement with an E-Cutout; before or after?
- GADGETS
- T3/t4 turbo 50 a/r vs 70a/r compressor someone explain the flow difference please.
- Anyone know the inner diameter of -6AN or -8AN braided hose?
- Removing Cat, need to re-tune?
- can a 91 honda accord lx F22a1 engine handle boost?
- Sleeving Companies:ERL vs. GE vs. RS
- d15 turbo experience-anyone:what to expect
- Someone, Explain the Resleeving, and boring process PLS
