View Full Version : Forced Induction
- got some new stock sleeve dyno numbers from Vance's SOHC Turbo today.....
- Changed cap and rotor and now car hesitates in first
- prelude after turbo install problems!
- Rich and no power
- So I blew up the turbo B18C5...ouch!
- My Turbo Teg @ the track *VIDEO*
- does turbo really quiet down straight pipe to turbo muffler?
- summit racing thrush muffler
- post ur EG coupe boosted
- Blown seals maybe help??
- oil feed line to long?
- 7lb fidanza flywheel
- Any Reviews on Old-school Technology PT67?
- Info regarding buying a block
- d16 jrsc 10psi how tune my ecu?
- DSM Turbo Question
- tial wg question
- oil catch can install question
- quick vacuum question
- turbo xs rfl bov not opening
- MY 08 BUILD THREAD
- Looking for a write up
- help setting up apexi avcr
- T3 T67 HO spool versus a GT4088
- where to buy this kind of thermoshields
- saab t3 turbo DP question
- vacc source prob
- Weird boost gauge problem
- is it okay turboing 100kmiles on gsr?
- the best gauges alive!
- Ramhorn manifolds...Where in the powerband will you see the most gain?
- Sleeving Nightmare
- main cap!
- turbo integra b18c5 burning alot of oil not sure why really need help
- ecu question
- Dyno: B20/VTEC - 15psi - Stock Head / Stock Block - Pump Gas
- will hondata work on my p30 or do i have to get p28?
- can pressure plates be resurfaced?
- greddy 15g return line kit?
- NEED HELP!!! WILL REV HARD MANIFOLD WORK WITH T3/T4 TURBO
- Injectors, plug and go???
- 400hp lsT
- GT4088r
- Calculating effective compression ratios
- Turbo I.D. Help
- Sleeves locally made?
- whats better??????
- weird smoking situation?
- DSM BOV?
- 12in resonator on turbo car
- Lets talk exhaust housings.
- ATTN Anyone who tunes or mods honda/acuras or used crome/uberdata neptune etc
- looking for a flywheel
- T1 tuned 465.9 whp
- Thick Head Gaskets
- compression
- Anyone bought a ebay turbo just for parts?
- Greddy 18g oil drain flange
- TURBO KIT FOR SALE CHECK IT OUT
- Installing Oil Pressure Gauge Quick Question
- turbo vs supercharger install?
- Opinions on My GSR Shopping List?
- stock ls/vtec good for 300whp+7500rpms?
- LudeSRV's DOHC ZC turbo build
- sleeves cracked on dyno
- Comp ratio???gsr crank-b20 block?
- turbonetics and their warranty
- Best 500whp turbo for a 3.2L inline-6...
- wastegate hitting my ac condenser!
- Want to boost my accord
- Honda FIT turbo questions/discussion
- Post up your AVID Mounts H22 in EG
- how much boost is safe on d16 witha .040 head gasket stock internal
- Colder Spark Plugs????
- need a QUICK answer, How do i weld on my tial flange on my aluminum pipe?
- Top mount + A/C compatible??
- dyno results on my new to me 30r setup
- Somebody break oil catch cans down in simple terms, please!
- BOV lagality question.
- water cooled turbo question
- LA Sleeves...who's using them these days?
- all spark plugs were gapped diff sizes. help!!!
- NEED HELP WITH MINI ME
- driving my car and engine is HOT..
- SS AutoChrome / XS Power contact info - if you need it
- B18C supercharger direction of rotation?
- h22 turbo questions
- B16a rebuilt :AEM?
- Ku engineering version 2 intake manifold
- p28 virgin or no??
- Apexi VAFC at 15-20psi?
- Mandrel bent piping question (VA Beach specifc)
- Turbo Question
- Tunner In northern CT area?
- Nuekin Ramhorn vs Fullrace RamHorn
- is it ok to boost a stock h22 block as long as its no more then 7psi
- windshield wiper bottle
- GTR Turbo water lines
- boost b18b or b18c?
- i need some help with peakboost topmount
- d16 head gasket
- Who has delt with Blueridge motorsports?
- Tial 38mm Wastegate, short dump tube
- injectors sizeing
- Question after question i know =[
- crowler 404s in turbo ls?
- A newb welding question on my turbo installation
- SLS Mini Ram SOHC Users: Please HELP!
- My setups potential hp?
- F22B (DOHC) cylinder thickness in relation to B18B??
- Boosted K Series, Post them up
- Done some researh heres what I come up with.
- Question on map sensor
- SSQV Blow off valve - old style flange
- vitara pistons..?
- full race intercooler piping...
- Garrett Gt2871r or GT2860rs on B18c1...
- do i need cams or not???
- turbonetics turbo
- gsr questions
- How much do following OEM parts cost?
- Hondata S300 used?
- hp to low. input please
- are the xs turbo kits any good?
- 1000cc injectors flowing at 900cc?
- new boost, how do i know if my turbo car is running/tuned properly?
- New Setup T4 Twin Scroll K20a
- hf mani on a dohc? other ?'s
- Neptune versus ECtune....Is it possible to do a comparison of these apples? Blundar, Xenocron?
- can i mixmatch rings and pistons from diff companies??
- Profec B spec 2 problem with hi boost??
- 880 injectors
- aem map sensor & Hondata s200
- Is this turbo too big?
- Ultimate B-series Turbo Touring
- K-pro guru help! Knocking
- Precision SC61 rebuild questions
- stock gsr on boost reliability??
- 5w-40?? best oil for daily driven turbo hondas?
- darton sleeves 84 Cp pistons 84???
- car start but wont stay running
- Dynojet: WB O2 Replacement?
- nitrous substituting more boost?
- Will Any Piping fit?
- XTD Clutches are the peds pinned or glued? cant remember,
- Boosting an f22?
- Missing bad in boost and higher RPMs
- Rod Knock In Built LS/VTEC Engine Builders HELP
- gsr internals in ls?
- Newb turbo questions please help
- If I am considering a Garrett T3 Super 60, what else do you guys recommend?
- Need Insight on Stock boost Type R (Engine failure)
- Comptech or ARC intake...?
- Cometic Head Gasket Thickness for B16 Turbo Setup?
- Sup all, new, and have some questions on turbo'ing an f22!
- built h22 motor, making noise at 2000 rpm ? need some opinions please.
- Supercharge or Turbo
- SC61 on a h22. questions.
- Slevee Question
- 2.5bar motorola map scalar
- skunk 2 pro ones cams valve clearance
- fuel line sizing???
- Quick A/f wire question
- turbo gsr vacuum line??
- precision sc34 feedback!
- spark plug question for boost
- LS Rev Hard t3/t04 turbo kit opinions
- Boosted 03 Accord
- New to boost. Turbo question(s)
- v band
- 2.5 inch DP and 3 inch exhaust
- Duel Rad setup
- wierd problem with built b20vtec
- drive stock turbo with virgin p28?
- B16 turbo housing
- Single Cam Turbo Build
- Dyno: b series 42r spfwd car
- Any insite on this matter would be helpful. (turbo build)
- turbo oil feed line HELP!
- How much fuel psi running in stock turbo b18c?
- Project Teal 93 coupe
- Does anyone here have used or tried a Carbonetics twin disc carbon clutch?
- second guessing my turbo setup...
- BONE STOCK B18C1 WITH T3/T4 TURBO a.r 84 hotside and a.r 50 coldside HITTING 440 + HP
- Car is smoking only under decelration...WHY?
- Biggest T28 Turbo?
- TD05 manifold
- sc61 oil pressure
- how much power will my 14b make?
- Use this turbo or no?
- 3" Vibrant catback
- Anybody know a Racing Store that Finance?
- car cutting out while getting on it
- mini-me turbo hondata, conversion, suffering from analysis paralysis
- Finally Finished & Dyno'd My Built CRX [VIDEO]
- engine cutting out between 5-7k rpm WTF?
- JRSC missing alt bracket what should I do??????????
- How much on a B16??
- Which alternator for H22 swapped 93 hatch?
- 3" downpipe for Edelbrock turbo kit.
- Borg-Warner & F-R topmount=Hood no close?
- smoking catch can?
- Post up your turbo B16 and feedback on the smallblock.
- what kind of power do you think I will put out? Supercharger
- RS machine pistons??
- where to get bosch 044
- turbo D16 which size throttle body and which intake mani?
- In need of AEM Stand alone basic map. s2000
- datalogging on turbo edit....
- Oil grade for turbo
- Help! My turbo GSR sounds like a WRX
- new s300 and flooding bad! on basemap
- wastegate too close to turbine housing
- My 4DR Boozt Build Project (still in progress,sigh...)
- Boosted The DA today...
- PLX m300 Wideband Install issue!!!!!
- HELP Blew my 612hp motor the day after I got it tuned.
- my turbo needs help
- Final Tial Question :)
- garrett t3/t04e to revhard manifold problem
- ta da!!!!! dohc zc turbo
- What made this happen????????
- stock fuel filter bad?
- Tial 38 vs. Tial 44
- DC Area Mega Meet and Skyline Drive Cruise Oct 28th
- post pics of nitous frogger kit
- tuner toy rods any good??
- Bore out throttle body??
- Serious problem with tuner toys rods
- How often do you have to tune?
- couple tranny/differential questions
- stock dx..w/ t25 Turbo set up???? help
- anyone here rocking a sard bov?
- help please
- who makes the map sensor with a factory plug?
- wideband o2 placement
- New CPs...are the valve reliefs thick enough?
- JRSC OR GREDDY KIT
- QUESTION ABOUT INSTALLING TURBO KIT INTO GSR
- all brands of bearings to tight, help please
- CFT's Gift for Cancer patient looking for turbo Advice ***VIDEO***
- timing sound rite?
- Choosing an EBC
- alright guys questions about turbos
- Testing a Blowoff Valve?
- dynoed b18b teg...low results?
- Bushing Turbochargers.
- A few questions on choosing a turbo for my setup.....
- What do i need to boost?
- Anyone with a Jackson Racing intake know if it oiled or dry?
