View Full Version : Forced Induction
- dsm injector wiring?
- Overheating with high boost?
- Might be dumb, but would it be possible to turbo a 50cc??
- fianlly done with turbo set-up
- Crower 404s on turbo LS
- how big is a sc61? i mean physically vs hx35w
- need help on a sleeved block.
- LS B18B into Del Sol
- Catback/muffler recommendation
- OOOHHHHH $HIT!!!!!!!!!!!!!!!! (the video) 634+ whp del sol
- JRSC on an LS (b18b1)
- turbo gsr overheating
- switching from a precision sc50 to a gt28rs, will everything fit?
- is this downpipe on good or loose?
- ACT clutch
- Blox turbo manifold clearance issues?
- OT: Will a Walbro fuel pump for a Miata fit a 92-00 civic?
- Tilted turbo, this ok?
- what sleeves are these?
- B20VTEC TURBO QUESTION
- air fuel question??
- need help with turbo.
- Oil Pressure Problem with a -3AN feed and -10AN drain
- Shop in AZ/NV
- B18a block, oil temp sender in oil galley plugs ok to remove??
- vband clamp
- Fuel Problem (I think)
- greddy blue box
- Idle Problems and Boging Down
- Idle Issues Help Me!!
- Gasket for Downpipe
- Just recieved some Spoolin Performance products and more!!!! Pics soon Couple of questions
- T25 Exhaust housing clocking
- 3" exhaust piping sufficient for turbo?
- Electronic related problem.... very strange.
- Intercooler piping
- 92 eg boosting HELP E-manage
- ams evo dyno
- Skunk2 Cam Gears - In reference to a problem from the past.
- Difference between FullRace Turbokits
- Have you gone from No cat to Hi flow cat?
- TIAL 38mm WG size difference between big and small springs?
- turbo setup
- who can make the best sleeved block?
- Old school pinned block?
- DRAG Intercooler
- b16 turbo
- 3 bar map?...
- Flowmasters 40 series on a B16 Turbo
- I wish I wouldn't have driven w/ an open downpipe ;)
- Ignition breaks up when car is shaken
- missing link?
- Introducing a new sales/technical expert at Fast-Turbo.com, Tommyten !
- Bogart drag-on fly wheels require extended wheel studs?
- D-Series Turbo Manifold Quality
- will my b20 fail? please help!
- Vitara pistons setups...SIGN UP HERE
- fuel problem
- hp #'s?
- HKS
- How do you have your MBC hooked up with your external wastegate?
- inlinepro mani
- when i should be reading boost?
- Blow-off sound at 0 psi
- air/fuel ratio wiring
- Emanage and UEGO question???
- horsepower problems (lean, power, heat)
- K-series - 2140cc: 89mm x 86mm short block
- Anyone know what intake manifold this is?
- smoke coming out valve cover nipple after some freeway pulls
- Drag Turbo
- boost: On high Mileage Engine???? please read...
- MAX boost level for blockguarded b16a
- arp tq spec. boosted gsr motor
- O2 sensor
- Uberdata maps, interpolation?
- greddy bovs; Type S vs. Type RS what is the diff?
- boostin a b18b and have ???
- Gas tank drain plug? Drag racers and circuit racers welcome...
- Opinion on this turbo kit
- Who tunes the Greddy E-Manage in the Northeast?
- boosted b20/vtec overheating while highway driving
- stock ls/vtec turbo
- Looking for charge pipes and intercooler, looking to not go over $400.
- Overheating while under boost..help please
- Greddy E-manage Support tool serial number?
- how are my plugs???
- GSR 00 SI Axles The same?
- How do you determine the diameter of I/C piping?
- intake manifold
- Anyone interested in Tuning session in Tennesse area ? nashville, knoxville ?
- I need ideas for new T-Shirt design...
- DESTROKING, theoretical question inside! EGG-HEADS inquire within!
- fuel pressure suggestions
- Evaluate this setup please...
- fuel pump?
- Compressor Housing vacuum help??
- what turbo kit should i use for a stock motor? and how safe is it?
- Max Power on 93 (experts needed)
- SC61 ON A STOCK LS BOTTOM END WITH A BUILT LS HEAD
- Just got back from dyno
- Apex turbo timer + Alarm?
- suzuki vitara g16 pistons
- Keep getting an error code...not sure which
- turbo placement?
- "What spring do I need for my Tial BOV?" - FINALLY ANSWERED!!
- built b16 or a gsr boosted
- flex pipe = super sound absorber?!? helpp
- BOOSTED Integra RS questions...
- please check out my set up ...
- Dyno Vid-- 480whp Honda, 441whp Honda, 408tq Neon
- XS POWER.. good or bad?
- Downpipe for ssac manifold
- should i put on the mbc or no b4 i go tune...
- HELP....stupid newbie question
- Rev Hard or/vs Drag
- turbogsr and emissions
- radiator
- misfire cylinder #2 after JRSC uninstall
- TURBOING H22 NEED TO BE RESLEEVED??
- cannot feel vtec
- PSI vs MAP voltage
- Dual-Sequential Chargers
- car dies help
- what kind of downpipe should i do?
- WB O2 reading too lean on open DP?
- manifold gasket?
- Fast Idle Thermal Valve--Hondata
- Why does my VSS appear to be non-linear?
- ALIGN HONE - think your next block or race block wont benefit or need it during the the sleeving pro
- startup problems!!!!!!!
- A/C Compatible
- All you smart honda guys PLEASE HELP HELP!!!!!!!!!!!
- installing stock injectors?
- How to tune timing with EGT
- Aquatrax map sensor
- Oil sandwich plate question
- Step Retard for each psi range?
- supercharger psi
- greddy 18g turbo kit question
- Aebs closed down
- Differents between t4/67 and gt40/67
- b20 vtec needs a rebuild... what pistons? can I find some stock that will work?
- steel braided line really needed?
- Better spool with boost controller
- Trouble spooling a 60 trim t3 turbine?
- i'm horny for nitrous
- I need to see how people are using their dump tubes?
- recomendation of good sr20det tech forums?
- high hp guys, what valves do you run?
- 3bar map sensor
- tepid1's topmount turbo pics. No 56k**
- Greddy Kit
- 99 si Greddy turbo
- please help identify turbo....
- Blitz SBC ID boost controller over 25 psi!
- what is this for? ARP crank balancer bolt
- Quasiturbine Engine
- Wideband
- B16 oil pan on an LS motor?
- hondata or uberdata?????????
- Clicking noise from Boost controller
- Boosted D16z6 with Blockgaurd....
- Turbo question?(Please Help!!)
- JRSC.. what would cause no boost?
- 3" downpipe on 2.5" 4 bolt exhaust flange?? pics please!!
- Need Help with 5th gen H22 turbo
- accord/prelude stock fuel pressure...
- Turbo+WAES+NOS - Possible?
- Anyone using an ERL manifold?
- What to build for Turbo 20-25psi?
- Where do you guys install your water temperature sensor ( Autometer one )
- Neukin Issues?
- Pressure in the head!?!?!?
- help w/ RC 550 injector install
- Q's on jrsc stock GSR
- what is your biggest shot on stock sleeves?
- where can I find this flange?
- noob questions about nos
- D-Series manifolds
- Missing/breaking up-ignition related
- td04h oil line fitting size 'searched'
- oil pressure gauge, quick question
- Electronic boost controller w/ a data port pics (my project)
- LS/VTEC Turbo questions
- D15B turbo Help
- td04/Accord
- 02 sensor question
- searched, BLOX Exh. mani V. Inline Pro
- Internal VS. External wastegates.
- Stock B16, drag kit tuned by jeff evans
- anyone running turbo ls please read!
- Pistons
- How come I don't see many people using Tial 46mm WGs
- Need help from electronics pros on here look inside
- would a stock exhaust damage a turbo in any way?
- Where to get T-bolt clamps by Thursday evening this week??
- No oil getting to turbo
- Look What was on my bed when i got home!!!
- My injectors are maxing out, what should I do?
- Startup rough idle, ok after 30 seconds
- No dumptube for now. how safe?
- Tranny Oil
- NEw intake maifold gains
- LS/Vtec with JRSC... Questions.
- GT15 turbine flange
- ...Car failed Emissions for the 3rd time...I'm thinking about giving up.
- Compression test results...
- Which Cometic Gasket?
- My stuff came today!!!
- Air Research M10 Turbocharger?????
- Help me choose an Intake Manifold for my setup.
- Mechanical boost gage accuracy?
- Velocity Performance Full-Race Top Mount Set Up
- Which flange??
- Specs on this turbo???
- What headgasket.....
- Just one more to Mase's list....
- need stainless weld-in injector bosses
- Need Answer quick guys "blox turbo cams"
- problem with new turbo
- tight fit??? help
- Help me trouble shoot idle problem on turbo D
- Your experiences/opinions on block filler? Have many people used it?
- What compression should a LS/Vtec motor have??
- Help.....Trying to choose proper TB size for turbo application.
- header question
- how much power can you get out of a stock wrx turbo?
- aluminized vs. aluminum?
- SC34, which one is better for B18C6 Engine?
- EGT installation help, please.
- Not Honda related, but my Supra got some work to her this weekend.
- Turned up the boost yesterday...OMFG!!!!
- For all my Turboed Sohc Friends!
- GT35R versus SC61 Before/After (Plots, graphs, data)
- turbo suggestions.... need for show not go...
- compression ratio, how come is that........
- WASHINGTON -> Motor Assembly
- Tuning - 1.8L to 2L
- uberdata or crome tuning
- Does anyone here have info on the Ignitor bypass with an MSD Ignition?
- Need new tune to turn up the boost?
- Precision injector question
- new tune..... PAYN TECH
- turbo sohc...run like shit..need help..
- Can I install a turbo kit and not boost?
- CSF Radiator?
- TO4B 60-1, 3 or 4 in. downpipe/exhaust?
- ways to brace ss autochrome manifold?
- n00b questions...can someone clairify?
