View Full Version : Forced Induction
- E85 Powered S2k buily by ISP Racing - Owners DD
- I'd like to boost..
- This a Bad Sensor?????????
- What throttle body Should I go with for my turbo crx????
- E85 Question?
- Vtec Problem
- Wastegate ? and high boost ?
- Mini-Me Turbo!
- What is the best turbo book out there?
- First turbo, coolant line question.
- what kind of ets and traps
- hotside vs coldside???
- 900hp goal! help me reach it! what turbo??
- Reuse headgasket just tq it down never ran it
- Will a p72 Gs-r oil pan fit on a b16?
- fuel pump/tank fitting?
- high comp boost?
- questions about pcv/ catch can set up
- differences between z6 crank and y8 crank
- gt3076r rated
- will these fit
- another problem
- my boosted b18c1
- oem honda head gasket? or aftermarket(cometic,etc.)?
- i need help with my injectors
- is handata gear boost hard to program?
- b20 sleeves
- how many bars do i need in my map?
- How much boost ? ? ?
- My sohc turbo build
- whats the differences between the new ITR jackson racing supercharger to the others.
- boost on stock fuel
- RDX Turbo question
- gt series turbos
- Do I need a catch can?
- Cant make full boost!!!
- best fuel for turbo honda ?
- Stock block 10psi 438whp!
- gsr motor with LS crank
- s2000 gt3076r turbo water line need help
- Boosting 96 integra (need help with ecu)
- IS HIGH HP AXELS REALLY NEEDED FOR 600WHP
- Walbro 255 problems!!
- Turbo / Radiator Clearance
- twinscroll manifold?
- B16a2 Sleeved Block question
- turbo kit??
- water lines for turbo
- Please help ID this turbo
- 2000 Turbo GSR Project (lots of pictures)
- to aebs or magnus... that's the question
- tillton flow control valve?
- HELP! Picking out cams for a boosted set up!
- Possible loss in power
- greddy e-manage ultimate FOR SALE
- Forged Performance top mount manifold
- super t70 turbo
- 3 bar map, goin bad?
- Can someone recommend some injectors for us?? D16Y8 and B18B
- Running lean (pic inside)
- Manifold and other questions
- Oil pressure sensor install...
- 600 hp goal
- e85 hard to convert
- b20vtec t70 boost cut
- will this downpipe work for me...plz hel
- i've searched, cannot find the info on oil catch cans...
- Indentification Help
- NEED HELP....
- Oil return problem
- Basic Question from a 2003 V6 Accord owner
- Removing the Charge Pipe?
- -10 feed, -6 return? acceptable E85
- violent shake when boosting!!
- 310cc injectors??
- Car not started after fuel injector install, please help!
- The "fabled" hf manifold for DIY turbo kits...questions
- which turbo is this
- benson sleeve...?? How can you tell??
- spoolin a-spec
- Greddy Turbo Timer Help
- gsr cams whats their power range
- need help with turbo sizing. specs inside
- turbo internal wastegate issue.
- Boost Controller quick question
- E01 , true boost , AVCR , EBOOST2 , PROFEC B , blitz ???
- Stock LS-T build help!!!
- how the heck do you put these damn walbro pumps in lol?
- what do you think about this manifold?
- stock b18 map sensor
- Inline Pro to Equal Length?
- whats a good turbo brand?
- dyno numbers; stock d16z6 50 trim 10psi 246whp/223wtq
- what kind of cams are these?
- GT30R topmount setup, where to buy an oil line kit
- Blown Turbo or what.....?
- B20 Sleeves Help..
- Intercooler size change: Will result in lag?
- neep help on choosing a FMU for turbo LS
- B20v turbo GE sandwich kit leaking oil HELP!!
- Turbo GSR questions, turbo, intake mani.
- Bottom End/Balancing question
- thermostat or not??
- best source for bov vaccuum line...
- Starting a fire......B20VTEC + nitrous
- what size is the shaft on a gt30r turbo?
- 14b on a B18c1
- t5 turbo
- will this manifold work for me...
- internal wg vs. external wg
- about turbonetics
- Wastegate spring trouble
- Greddy or Peakboost?
- Overheating mysteries
- tial 35mm gate too small??
- Oil Cooler Hose Size
- catch can size?
- Identifying Rod Bearing color codes
- How will this Turbo do? *Searched*
- New engine break in with synthetic oil.. Bad??
- Manifold question
- Stock internals "holding" together?
- ACL Race Bearings
- does anti surge turbo housing make less power then reg. housing?
- Need Help Identifying Garrett turbo
- "Honda motors can't take boost!" says hater
- oil weight for turbo setup..."searched"
- Help Picking out good turbo cams.
- has anyone got a 6765 dynograph
- b20 vtec block or lsv block for boost which one
- i have a JRSC on my integra b18b question
- Stock H22 head
- Boost Fluctutates
- Turbo questions?! What should I do?
- stock LS VTEC how much psi?
- max power stock b18c head
- which turbo for 300whp on stock gsr?
- Ebay turbo rebuild kits?
- tuners help!!! engine falls on its face WOT...
- i've searched everywhere for an hf manifold...
- after math of mis shift
- where can i get intercooler piping for gsr manifold
- Does this seem right
- silly question by a noob
- what size injectors to use?
- A Few Turbo Questions
- GT37R versus GT3788R
- how much can i get out of pump gas
- 1600cc or id1000 goal 650hp on e85?
- Check engine light under boost
- wanna boost a b18b
- compression #'s for built engines?
- stage 1 blox cams JRSC??? THAT WORK?
- piston ring gap
- Where do 3 bar maps come from?
- how do i run vacum lines to my synapse wastegate and synapse BOV?
- BRAND NEW B18C1 ISSUE!!
- New to Honda-FI,
- what turbo to get for my setup
- down size to a t4
- t4 twin scroll, best turbo for the street
- Are any of these holset turbo's good for my d16z6 400+whp build?
- B16 turbo not starting
- flutter issue
- ITR cam overlap with turbo
- Will a Cut-Out regain all power lost from restrictive Exhaust?
- New winter beater project: Turbo CR-V
- benson block and copper head gasket ?
- just picked up a block, need experts opinion
- Individual throttle bodies for turbo?
- Camshalf for turbo GS-R...
- Advice Needed: Turbine blades damaged. Will it boost?
- which lightweight flywheel
- slight in-out shaft play, time for rebuild?
- what makes turbo hondas w/3 inch exhausts so loud? lets talk mufflers.
- Mindblowing 1000hp b-serie
- scarred the wall, bigger pistons, retune?
- NEED SOME HELP
- 550+ hp engine mounts?
- schwitzer s200g turbo experience
- skunk2 cam???
- what ya think..(est 1/4mile time)
- b18b whp tolerance...
- *****THE OFFICIAL LS-VTEC TURBO THREAD*****
- twin bosch fuel pumps
- AR Performance Turbo ITR 630whp@26psi E85
- how much is safe???
- 3 Inch Exhausts W/ Muffler only
- is this worth Synapse Motorsport Fuel Sump Kit
- built gsr turbo quest
- AUTOMETER OIL PRESS. T FITTING...HELP!!!!
- Setting timing on Tall Deck DART block????
- Cometic HG w/ARP studs, How much boost?
- High Boost Catch Can Breather Box Situation
- What are some ac/ps compatible turbo kits?
- Which MAP sensor; Or bypass
- swappin head before boost..
- using oil filter adaptor 2 feed turbo!!!!
- vaccuum lines..question
- ls-vtec....turbo.....buddy club spec 4's...yay or nay?
- My First SOHC Build, need input
- need help with vacuum lines
- Type r compression good to boost
- aem wideband reading
- turbonetics turbo 60-1 ??
- Good Turbo for a/c
- 400 whp turbo???
- GSR-ITR cam swap
- No boost?? Help?
- Whats going on????
- IMW-Tuned: 2008 FA5, K24, TD Autowerkes mani, GT35R, tuned on FlashPro
- ls/vtec help help
- want 2 turbo my b20
- Skunk2 Pro2 with boost! Opinions...
- Turbo'ed D15B7, Major Issues
- Pivot Super Baby Auto timer question
- turbo crx now wont start
- catch can problem
- PTE billet 6765 vs Garrett gt4088
- Which turbo and how much horsepower do I need?
- AEM EMS gurus please help, sync issues galore!
- B18b turbo wont idle....
- What clutch to use on turbo sohc zc build??
- sucked up a rock
- what all is needed to build a boosted b20b vtec??
- no brake and no blow off??? help!!
- b20vtec turbo question.
- unofficially the first auto turbo honda in south africa
- turbo build questions: fuel pump and engine management
- gt35 turbo??
- how to tell feed/drain flange sizes
- **PLEASE***Callin All Experienced Engine Builders for Input - VTEC TURBO Applications
- hondata and non functional temp gauge
- S400 Ebay Find Question?
- B18c Turbo Build Questions
- looking to turbo my single slammer
- PLX M300 GEN 1 Harness Question
- idling and running like poop, low rpm, struggles to keep going.
- twin pump for pump and race gas
- The Bottle.
- Nitrous with chipped p28
- anyone using hondata s300 on an f23?
- b18c turbo build. whats turbo should i start with?
- pte6262 vs bws366
- horsepower question?
- Has anyone used treadstone kits
- ls/vtec tubro help!!
- turbo timing
- Need help to identify rods
- what kinda track time should i expect
