View Full Version : Forced Induction
- How MUCH HP
- PICS OF MY GT40 T/4 CRX
- Mazworx V1 Turbo Cams?
- Turbo ideas?
- Car finished and fired up... but stalling at high and low speeds?
- please help need tuner in orlando/kissimmee are
- cool trick for downpipe bolts you cant get tight.
- intake manifold pnp?
- VID: Ran my Turbo 99' Si tonight....160K stock engine, 10psi... 7.6@89mph in 1/8!
- anyone heard of SPI motorsports gauges??
- tial wg spring
- Hondata S300
- help turbo kit
- 3" integra exhaust
- to turbo or not?
- wich turbo for my built h22?
- turbo sizing comparisons
- Downpipe & wideband AFR's
- mini log mani any good?
- HONDA CIVIC D16Z6
- Boost issues, help needed
- b series in eg
- HowTo: DIY Exhaust Coating
- turbo?
- What Ignition system and components for B18B on 20 psi?
- Fuel Pressure question?????
- video of some az turboed cars
- Which is best T3 turbo for D16z6 and where to buy it?
- Were to get 2"-2 1/4" Alum pipe with alum bend like this
- Check Out My Turbo Setup!
- SAFC2 HELP PLEASE
- RC 440 injectors question...
- rev hard manifold?
- rev hard manifold
- can i run my LS vtec with the stock LS pistons?
- Boost stock B18C
- BOV????? where can i get it???
- Put together one good car - NOT Honda
- Lightweight flywheel or not
- getting more power out of my setup
- what mitsu eclipse oem TD05H trim turbo do I have??
- Tuning Options...jdm H22+Auto Tranny+Nitrous
- 17's on 400 whp SI??
- New Setup Thought yall might like
- Anyone notice a difference in their gas since the ethanol change?
- Help needed from Argentina...
- b16 build help!!!
- h23 turbo question
- Compression Test: Wet & Dry acceptable variance
- i need help picking a clutch for my lude
- Anybody know how to PROPERLY turbo an Ls vtec??
- PLS NEED EXPERT+EXPERIENCED OPINION B18C3 SPOON TYPE R BLOCK DARTON SLEEVES,82MM BORE,ARIAS 10.4:1 P
- Lookin for cams for an LS drag car
- Question on Edelbrock turbo kit for b16a
- did I buy the wrong flange?
- Retarding timing
- question about my ross pistons help
- Bad Idle problem
- Urgent: need ideas fast.
- Ballbearing Vs. Non Ballbearing?
- question about turbo and missing links
- new ENDYNE intake manifold vs FR intake manifold?
- need help finding dave from superT
- 300 whp possible for an ls?
- Microtech vs. AEM EMS
- How good will my stock b16a2 fuel rail work???
- HOW MANY PEOPLE
- What compression would i have with ....
- Ramhorn Help@!
- need help on which vacuum line to to which for my profec b spec on boost controller
- Way short of my 700 HP goal. Lots of pics
- Feed Back on Plans
- 16G killer turbo in B16A, how would this perform?
- T3 turbo suggestion for D16z6
- Freshly built motor leaking?? Help
- SOHC fuel mods
- What went wrong with this turbo? T4T67
- boosted f22 pics
- Turbo?!
- del sol si's with nitrous
- Want opinions on fuel setup (searched)
- FMU help?!
- Turbo feed line question
- DIY d-series manifold?
- losing boost
- 75 shot on stock B16
- Manifold fitting in a CRX? Turbo OBD0?
- what to tune with?
- Itr Cams??
- Ethanol additive vs MTBE? Does it change A/F ratio?
- Another shirt idea that I need your help on :) .......
- turbo B20b
- Project Boosted EF: The Journey to 400+ whp (warning: lots of pics)
- Why does HT dislike SRP pistons?
- my full-race manifold is cracked?
- Where to buy HF manifold adapter for T25???
- Need LSD help. whats one to buy????
- Question about Compression numbers
- Peakboost Kit Horsepower
- RC Injectors....simple yes or no question
- traction, everything is done already?
- Fully built B20 Vtec
- Max power from a little TD04 Mitsu Snail?
- need info...
- piston rings
- 2005 sentra question
- looking for street tuner in orlando kissimmee area
- Limits of SRP shelf pistons
- Ok, when will it stop...
- embarassed to ask this, but: couplers?
- Tunner questions look at this map for a sec
- Oil pickup to pan clearance, anyone know?
- Arrogant Tuners !!!!
- Injector question....RC550s
- What range of HP should I expect to have?
- Neptune experts, i need your help!
- d16 t3/t4 turbo position question.
- Hondata vs NepTune vs Chrome
- What muffler to go with my new 3" exhaust?
- Boosted the DA today, 56k grab some lube
- quick E-manage qustion
- Open Downpipe Pictures
- Traction Bar settings
- 91 Octane - A/F ratio question!!!
- My S300 is on crack
- Anyone wants to get tuned by Jeff Evans this Friday April 28
- blew the y7 at 14psi updated pics
- helpme with my turbo ls
- 4 of 5 bolts on downpipe?
- Does JRSC have oil in it?
- Temporary heater hose as return line from turbo
- Opinions of Central Florida Turbo? (good and bad wanted)
- Boost conrtoller?
- hks bov
- Are my seals blown?
- Estimates before i hit the dyno.......3 weeks and counting
- No more High Boost with turboxs DS MBC, what do i check first??!!??
- Full Race GT3567r
- before d16 turbo...
- SOHC dies, a new powerplant emerges
- slim fan
- Rocket Motorsport cams
- kinda of OT, but look whats comming from those Germans!!!!
- How good is my turbo setup? hp numbers anyone??
- 91 ef si hatch, jdm d15b vtec, boosting and need opinions...
- 230 whp list.
- 230WHP TO MUCH TO ASK FOR 130K SOHC TURBO?
- More JSRC questions-fpr with fmu?-timing stuff?
- will vitaras work in a sohc zc
- This Downpipe OK?
- Fuel pressure pulsating
- Researched and just wanna see what you all think on this setup...
- ls turbo help
- HELP! turbo and a/c
- Draining Nitrous Help
- Oil feed fitting broke inside theblock? Need some advice
- Ignition for Nitrous Setup 75 shot! Also Which Plugs
- ***Oil Drain Question***
- oil jets.....please help
- Oil pump........
- fuel queston
- PYR Racing? Phone Number?
- Edelbrock IM & Greddy turbo kit
- will a broken knock sensor disable VTEC?
- H22 turbo advice, need help choosing a size.
- need a base map
- obd1 injectors>obd0 engine
- AC Fan
- Whats safe on this kind of setup???
- Im loosing power leaking boost "need help fast please"
- anyone running a 4" Exhaust on street driven cars?
- type r pics
- Keep a/c with a hy35 manifold thoughts
- What NGK plugs to use for nitrous setup?
- I know this is a little vague but could someone help me find a certain thread
- Which turbo??
- afc AND uberdata???
- forged internals
- 2000 civic hatch ex turbo???????
- T25 Manifold
- car idling up and down
- 68mm BDL
- Just a little tip for you s300 guys running the MSD 3 bars...
- MASE TUNING coming to Cali in May!!!!
- Boostin EM1
- QUICK ???? ON PISTONS AND....
- ***************Built motor won't start?*******************
- New AFC NEO question(s).
- IHI RHF5 turbo Shaft play?
- compressor surging Help me out here. *searched*
- turbo decisons/queastions
- is it bad to hot tank a sleeved block???
- how many POUNDS
- What should i use
- MSD 1000cc injector problem w/ Victor X mani
- Turbos for sale, can I post them here?
- good summer coolant/water mixture?
- garret truck turbo
- a/c issues with turbo, who is running turbo/ac?
- what kind of turbo is this?
- garrett turbo kit
- High EGT at Low RPM
- mustang dyno vs dynojet
- Cheap Manuel boost controller?
- Stock ecu to transport boosted car?
- TiAL 44mm Wastegate Valve
- building a jdmd15b
- CC-FAB Chuck Norris Mani mounted (pics)
- Quick oil line question
- what should i expect hp wise????????
- Slow to Create Vacuum
- New to Supercharging
- boost controller
- cheapest way possible if there is any
- Where to buy built/sleeved bottom-end B16
- Gt40r oil feed
- blow off ask
- GREEN stuff break pads questions.
- ssautocrome kits
- i'm searched. have different question for d16 turbo choice.
- block guard or sleeved block
- Manual Boost Controller Usage
- Need MSD Help ASAP Having MAJOR PROBLEMS PLEASE HELP!!!!!
- Anyone ever used this gauge to help monitor Intake temp?
- Okay who wants to guess what this tranny problem is??????
- Question regarding larger TB
- Anyone running stock exhaust?
- blitz sbc-i colour boost controller
- Any constructive ideas wanted!!
- GReddy 15G Kit w/ Emanage + D16y7 Questions......
- boosted f22
- type R tranny with LS final gear.
- traction bars worth it?
- Basemap problem or chipped ecu problem? Help needed asap!
- Coming soon 450hp K20a2 in a ep3 hatch street car!!!!!!!
- hondata 2 step vs msd 2 step?
- t25 vs t3
- getting the most noise out of my bov
- Where to get reinforced vacuum lines?
- uberdata datalogging.. problems
- my sohc turbo times
- leaking boost
- can anyone please verify if this blue box #USDC2-F40T05 is for which car? thanks
- is 85 shot safe on mostly stock LS ?
- Jonny race car intercoolers???
- Any one see this before 3.47 Final drive?
- was wondering if anyone wanted to trade my turbo cams for ctr cams???
- Honda Challenge
- Good Golden Eagle Dealers who accept paypal?
- AT what HP should the motor be sleeved?
