View Full Version : Forced Induction
- will a universal hKS SS BOV fir a grag 3 kit
- zdyne???
- some overheating issues
- need help choosing turbo
- Can't figure out why check engine lights keeps coming on
- Which size exhaust piping?
- 10:1 compression in my ITR. Can i run on 93 octane? (ive searched)
- What fuel pump do I use??
- Tips on broken off bolts in my turbo????
- can anyone explain to me about how to rotate turbo housings ?
- is a boost controler needed if I have an external wastegate?
- Low compression numbers = fixable?
- Hondata quirk..
- reading posts, now confused - SC61 & SC63 - need specs and advice
- Help installing Apexi turbo timer.
- Greddy Turbo Question
- Which tranny would be better for me ?
- Anyone heard of HKS new FCON ?
- low boost hesitation with v-afc hack?
- help.....overheating!!
- JRSCed GSR with nitrous...440s or 550s??
- how do you install a turbo timer
- question about silicone connectors
- hondata tunning?
- which injectors for 300whp B18C1
- Should I run a Greddy SP Exhaust?
- Please tell me someone has tried this!!!!!!
- FMIC and turbo B18C in CRX, first pix
- Turbo Newbie, possibly entering the dark side...
- OT: Someone bought into the electric turbo idea
- throttle body
- Driving with Turbo
- Best Hondata Tuner in the Bay Area
- Help!!!!
- Need opinions on t3/t4e turbo for 450hp
- OBD2 to OBD1 harness and EMS
- Problem w/ tach after turbo install
- what compression would this yield
- D16 turbo manifold
- 95 GSR cams on 00' Si
- who here runs a T3 super60 ??
- HONDATA...idling problem?
- GT35R turbo
- SOHC TURBO OR DOHC
- Alum. or steel BOV mount flange?
- MAXREV or DRAG??
- turbo gsr vafc hack question
- turbo on b18b1...setting timing?
- Anyone Know exact size of a T3/T04E 50 trim .48 housing?
- Greddy turbo b16 crx?
- turbo kit for sale
- Problems installing a water temp gauge...
- Alright last question for the night. Can I switch exhaust housing's on my T3 turbo?
- :: $15 manual boost controller from apolloracing.com :: anyone using this ::
- 2.5inch dp worth it for ac, or 3inch?
- Hondata Vs AEM
- OIL cooler w/ rad
- Intercooler Piping Size, how much does it matter?
- Forged pistons
- fuel rail question H22a1 what side do I splice the fmu on?
- Greddy E-Manage
- Can i use brass fittings on a turbo???
- where to place oil cooler
- how long should a BOV blow off ?
- Is JB weld a safe alternative to regular weld?? Com'on how many have used it? :)
- How do I tell what trim the wheel is???
- :: eg - b18c1 - drag manifold - t3/60-1 - gsr radiator :: fitment problems??? ::
- gasket between mani and turbo
- Trouble diagnosing babbitt looking material in oil
- which pistons will yield 9.5-10.0 on ls/vtec turbo?
- Hondata problem, need some help...
- how do you clean your fmic?
- manifold questions??!! PLEASE HELP
- Can't get the BOV to change sound.....
- Just b00sted the R. Few problems. Need help
- Just installed Revhard Stage 2 kit. Have a couple questions? Help please.
- FS: Bosch Fuel Pump and Deltagate
- spark plug question
- After Market Fuel Pump Install
- afc hack q
- IAC keeps going bad!?!?
- whip the dead horse... fmu poll
- Anyone know what manifold this is?
- 75lb injectors, good for 6 - 8 psi?
- Is this a good price for rods/pistons???
- injector question
- how much psi is a blockgaurd good for?
- possible to up the boost without a controller??
- Who makes affordable 1000cc injectors?
- Vouch for Import-Palace?
- Crazy smoking at idle...
- making a down pipe
- Places in So Cal that rebuild turbos...
- too big of injectors?
- bah, venting some anger... !@#!#$
- Question about knife-edge crank & boost
- about jc whitney mandrel pipes
- IC in/out angles?
- My race car is for sale
- OT: i need a shipping company, motor freight
- D-series Sohc.........42/.48 or.......48/.60 help me out
- need help with 91 ls integra turbo setup
- D16z6....Drag manifold or custom HX..power difference
- Exhaust question
- wastegate tubing question
- Is it possible to rotate the AEM FPR?
- IC piping size
- Limit of SOHC VTEC sleeves?
- MAXREV TURBO kit owners CHECK IN HERE....
- Thought I'd show my setup since it leaving home next week
- dyno tuning in OHIO?
- Dry Nos Kit #5122
- Greddy E-manage numbers
- fuel system pressurization gone bad?
- can i run itr piping w/ turbo?
- How long did it take to piece together your turbo kit? Poll
- TURBO gurus: can you guys change my n/a list to a turbo list for a b18b
- Went to track last nite.. any suggestions?
- D16Z6 A'PEXi turbo kit still in production?
- maxrev people, show me your oil return
- equal length manifold
- T4
- new setup ?
- Turbo kit price
- all honda resistor boxes the same?
- stuff breaking from having turbo
- Good price on clutch/flywheel kit. Also are indigo flywheels good?
- highest WHP on stock ignition
- dyno report: tested aquamist water injection
- Maxrev turbo!!
- Can anyone help me with my injectors?
- turbocharged b18b..question
- JRSC people, help me out...Who (besides Endyn) mods these superchargers???
- JRSC on B18B (LS)
- 3inch mandrel bent piping...
- Recommended Air-to-Fuel ratio?
- car stinks while in boost??? and spits out gray smoke at WOT
- tanabe G medallion or greddy evo for my integra turbo??
- Apexi N1 or Mugen Twin Loop for turbo GSR.
- what would you do with 4500
- what's this turbo missing?
- Mitsubishi TE04H manifold
- Got my pwr today
- No Spark
- What causes this?
- What BOV, GReddy Type-R or Tial ???
- this one is for the engine builders & boost gurus
- Fellow HT members...Need some good will advice
- Changing/Modifying charge pipe
- Air intake temp sensor
- why do turbo kits face the turbo the crappy way???
- my new intercooler mounted.
- Block Posting or Black Guard?
- RS SLEEVES??
- 1st clean passes...opiions please...
- ZC Turbo Problems
- Motor problems after ZEX install
- Welding Golden Eagle sleeves.......????????
- Tranny problem
- AEM adujustable fuel pressure regulator, what would cause a rise in pressure
- weakest turbo b16 ever
- pics of my new turbo manifold
- bad idle...... vaccumm problem?
- siemen deka injector help
- What is so bad about pressure drop?
- New 3" exhaust and now boost is screwed!
- what do we think about the fp-30 turbo?
- Colorado Natives... Mase is taking another road trip
- Fluctuation in boost gauge....?
- Will it 99-00 Greddy SI turbo kit fit a 96 gsr?
- Where do you guys usually buy your BRASS BARB FITTINGS, locally?
- intercooler comparisons
- starting problems with a new bat and alt
- :: kinda ot : any reputable shops in the mobile, al area? ::
- new style DSS stg2 and coilovers installed
- injector question
- Street/dragstrip car, which T3/60-1?
- CEL on w/ low compression pistons
- look at my nice custom made 3" dp
- intercooler piping
- :: throttle body question - h22/h23 vs b18c1 - differences ::
- Crazy Stock d15 turbo setups.
- GE Block, cometic gasket = oil seepage?
- Hondata or unichip?
- any T3 b18b's out there?
- Catch Can: Off vacuum distribution log???
- Is 7 lbs Safe?
- Prob been discussed before, but whats everyones thouhts on intake manifolds.
- anyone pick up the August super street?
- what is the weakest point in B series motors respectively?
- Rename KS Motorsports and win $100 Credit
- Yet another possible oil feel location.
- Is there any way to make a turbo more efficent at lower RPM's?
- Gas millage and tunning..
- Valve springs A6 or Z6 what the difference
- -3an to small for t3/t4?
- GE sleeves or AEBS sleeves which one would you choose!
- boost problems
- looking for a good repatable shop in the southeast, SC, NC, Ga
- Newb i need help on my t25 setup
- Dyno Numbers
- Question about Asmoil, who uses it in their turbo? Is it worth the price?
- hondata 4b
- apex turbo kit for B18C?
- Maxrev Turbo
- Hondata Map Sensor?
- anyone have the AEM 30-2112 3.5bar MAP in stock???
- how to run oil and water lines for a t3/t4
- MSD 3 bar map sensor or GM 3 bar map?
- AEM UEGO WBO2 KIT?
- Hondata datalogging help
- What would YOU do ?
- hondata??? why?
- Help! Idle Problem, Car revs from 700-1500 nonstop
- 99-00 Civic Si w/ Greddy 18g turbo using a B18C1 bottom???
- turbo questions..no flames please
- 10psi o.k. for stock b16?
- saturated vs peak hold
- dyno charts please
- hp numbers on stock turbo b16
- Cleaning a Turbo!
- best Header with Jackson supercharger
- good place to buy turbo manifolds
- block sleeving and block gaurds...
- SC63 came in today...
- Importbuilders.com
- tial wastegate springs????? which is best???
- How much oil do you burn .
- Wasting my time?
- what's the coolest sounding BOV?
- HELP PLEASE!! Need directions hooking up a XS Dual Stage MBC
- vafc hack ?'s
- sandwich adapters and oil return line
- whats the highest recomended?
- anyone got MSD plug wires
- place to get complete oil lines
- Attn: smart people. Why is my car doing this?
- what turbo manifold for d17a2?
- turboing my 92 integra
- Just wanted to post up old Dyno Chart using UberChip
- Anyone Tyrus ICs on a 90-91 CRX
- RC 440cc or 550cc injectors?
- help me, i think my clutch is reaching its end!
- pls. give advice on which o2 sensor to get
- horrible results at dyno...something's definitely wrong!
- B Series Exhaust Flange
- opinions on turbo setup needed..........
- Newbie wanting to supercharge a 98 integra gs-r
- Clutch + flywheel.
- best bang 4 your buck bov?
