- Drag 3 kit oil lines big enough for sc61?
- nitrous 3 stage controller,would this work?
- what is the difference between(RC injector question)
- 75 shot on stock b20 vtec
- Late xmas gift
- Maximum boost on what compression?
- Best turbo for my (D16A7 - SOHC 16v non-vtec) motor?
- My turbo install/setup
- Installed my Hallman ES MBC just a little while ago
- adding boost to p28 rom(crome)
- Brand new garret turbo...
- boosting a f22a1 stock interenals (for now) what setup
- Why have VX o2 sensor???
- New Jersey Tuning... HELP!!!
- turbine rust
- Compressor Covers = E vs S
- Junkyard turbo Justy build.
- Turbo Lag, and More...
- Ceramic Coating pistons and head
- Help with gauges!!
- Help with turbo flanges please!!!
- support bracket for turbo???
- C&R Rad came with 20psi cap...ok?
- Oil cooler
- what causes throttle body to go bad?
- anyone heard from ben@importparts in the past week????
- GIRDLE ????
- turbo ???'s
- CP Rings question
- Oil/Fuel lines?
- any turboed h22's using uberdata and what numbers or times have you made?
- Thanks A Lot Mase!!!!
- ZEX Nitrous plus sc61 and sleeved motor..
- can i use a missing link instead of the greddy box?
- What Should I Do ?????
- hks bov
- check out my vafc settings after wideband install
- lovefab manifold
- t3 t4 on b16
- Just did a compression check on my motor. How do these #'s sound?
- High-Altitude Street Tuning Q'S?
- new program for techedge wideband logging
- Turbo project shopping list!!...and some Q's
- Local Tuners
- WHAT IS THE OPTIMAL SIZE OF INJECTOR FOR MY SETUP!! PLEASE HELP!
- Please help! Car isn't going into boost! =\ =\
- Planning a turbo project
- dyno/street tuners - question about timing
- Greddy kits come with E-manage?
- internal wastegate possible to run open loop?
- Blowing Wastegate Gasket...Tial-Ok to use some liquid gasket?
- trr manifold
- any one use rubber hose for oil drain off turbo
- FInance?
- not FI related, but I need help!
- Car ran out of gas w/half a tank???
- what a bunch of WANKERS!?!
- traction bars and 3 inch downpipes. >>?
- AEBS Intake Manifold
- supercharger rebuild
- winter set back. need advice
- Better Results With Turbo or Supercharger
- best manifold coat?
- ls turbo people??
- greddy kit ok to use without intercooler?
- My experience with Precision Turbo and Engine
- poss. blown ring?
- FMIC pressure drop?
- can you up load my pics please????????????
- b18 block
- sr20det and smog
- which valves springs can handle up to 12500 rpm????
- looking for a used lovefab sst
- Sleeving
- Troubleshooting low boost... new wastegate?
- How much to rebuild a greddy turbo?
- check engine light won't go off...
- Valve overlap?
- Is this what causes detonation? and few other q's pertaining to detonation
- Clipped Turbo fins?
- silicone coupler question (fitment problem?)
- How can I tell if my MAP sensor has gone bad?
- Turbo CIvic spark plug gap? Already searched
- Looking for a Turbo Exhuast for my Integra LS
- Help! Stranded....
- Check out my oil return line (as if youve never seen one of these...)
- Is This Manifold Worth The Money
- Can a MAF kits be used for us imports????
- DSM 450cc + AFC Hack vs. FMU?!?
- help w/ 3" piping
- Greddy Turbo applications
- GSR Compression #'s
- new turbo install questions...
- MSD BTM question..
- my new d series turbo build....
- TurboXS Dual Stage Boost Controller Install Help...
- Just got an 04 Civic EX coupe...want to turbo it..have some questions...
- Again... timing!
- place to tune my car? bay area
- OT: Where do you guys pick up your magnaflow mufflers from?
- How heavy is the stock LS(B18a/b) ROD and PISTON??
- will 92-95 apexi n1 turbo catback fit my 98 dc2
- 1000 post! And my turbo setup inside
- Which turbo is right for me?
- Is there a AN/banjo fitting that can allow a SS line hooked up to the stock fuel filter?
- Turbo decisions?!?!
- Sleeve the b16
- JE 9.8:1 GSR pistons in a b16a2...is this guy right?
- turbo output
- Precision Injectors - where's the best place to buy ?
- holset ht60
- boosting
- stage 2 cams
- Anyone know where to buy very unusual sized bolts?
- NGK plugs
- Apexi AVCR
- How much drag when doing a valve adjustment?
- Ideal turbo specs for GSR turbo daily driver @8psi?
- The greddy profec e-01 or the apexi safc II ??????
- Rent Wideband 02's and other specialty tools
- is this safe? Downpipe questions...
- Quesion for anyone running liquid-to-air setup
- Manifold Design Question...
- anyone running 100 shot or over on a B18c while daily driver still?
- Need suggestions for $6-8K turbo setup
- WTB: external wastegate asap!!! and other items
- just got car tuned..... need help!!!
- b16a2 cams vs GSR cams
- I want to have 8.8:1 or so...
- Injectors Sat. or non Sat. whats the diff.?
- whats a good turbo sump?
- large injectors
- need help: torqued connecting rods = engine doesn't turn
- Who here Drives their Boosted car during the Winter?
- jrsc on a b16a?
- Three ?'s for ya guys
- Need help w/ gsr block setup...
- is it necessary to balanced engine parts ???
- Got bored, made a turbo heat sheild for precision turbos
- Exhaust for h23 turbo prelude
- project sohc turbo under 1000$ :wana go faster
- jdmjerks boosted b16 project.....
- 550cc mitsu injectors work w/hondata?
- Electric Supercharger Works?
- What is your turbo setup for your 6th gen Accord? "Searched"
- rod bolt stretch
- Clutchmasters carnage...
- Blue smoke / oil in spark plug cylinder / turbo seals? -- HELP!
- TD04L-19T ( newer volvo turbo ) turbine inlet question
- DSM 450cc injector install but a few questions....
- Poll: Build the D, or go B?
- volvo t5 turbo??? any good? please look!
- limitations of stock head (d16z6)
- Edelbrock Victor X users
- my dissapointing dyno numbers. b16a turbo
- need some rods for jrsc setup?!
- i have another problem please help
- How are GSR cams better for boost than Si'??
- Oil Temp.
- v-afc II settings???
- Which intake will make more power between GE or JG?
- can this engine be turboed? what to do to compensate for no o2 sensor?
- ? im use 92 octane gas and i run rich
- need help on IC piping size please
- external wastegate and standalone = wg spring question
- SOHC engines! Where can i find em?!
- WTB A Greddy Profec B Boost controller
- Anything new on the RevHard IM
- fmic and fmlp
- bad hesitation...can't figure it out...need help
- D series ARP head stud torque Q's
- silicone hose from atpturbo
- look at this manifold
- Sleaving
- ic pipes: aluminum or steel?
- JRSC Parts and Hondata?
- 20-50 synthetic on turbo apps???
- Which BOV? tial or greddy type R???
- collector style
- Thermostat..is it really beneficial?
- Yall know price on HONData S200 Boosted W/harness
- i need help with fuel on turbo crx
- wat goes here??? AEM FuEL RAIL question...
- fuel pressure regulator problem
- SIXTYdashONE <-- READ PLEASE!
- wastegate help
- swaybar + 3" exhaust = ???
- Gotta Problem!!!!!
- Did anyone miss our Batronix USB programmer or Innovate Wideband GB
- Supercharge or TurboCharge
- turbo DA Integras
- G2 Integra w/Turbo B16A
- replacing bearings
- Skunk 2 cams ?
- everyday driving with rc 550?
- "Hack" idea for those with hard starting and rough idle. Need input.
- rc 440 duty cycle
- Good turbo mufflers?
- Turbo oil supply line
- Turbo for my RB25DET............
- Pieces to make custom log style turbo manifold?
- Can It Be Done! Please Feedback me!
- hondata chipping nede help, car has code, cant read code idle like crap
- What wastegate on my 14b
- PCV catch can causes engine to smoke
- turbo kit
- What else can cause boost creep?
- Tuning?
- Diagnosed my probs further.made some progress,but leads to more Q's
- i need to temporarily plug an o2 bung...auto store item?
- oil return bung
- comments on my turbo setup would be great!
- College question....sorry off the topic of forced induction..but i have an explanation inside.
- ECU settings
- Willems Burner Revelation!!! Get offline to burn chips.
- nissan guy need honda guy experiance in picking an ecu
- is this intercooler any good?
- please post your precision intercooler pics!!
- obd0 o2 sensor placement ???
- Tampa Racing Track Day Photos
- b16 blueprint?
- Full-race turbo
- boost problems need help asap
- Is this possible.
- DRAG III Questions about Precision and Inline
- Cost efficent fuel management options?
- Hidden nitrous?
- anyone heard of www.city-speed.com
- Sohc with HMT track times
- MSD 3 bar map guys
- Help ASAP please
- possible change of plans
- Questions about turbo? Need some questions answered!!!
- More on that random turbo I found...
- new turbo set up just wanna see what you guys think
- wasup with the SMOKE COMING OUT ?? and OIL? where is it coming from??
- To sleeve or not to sleeve???
- AIC (additional Injector control) opinions??
- MSD Turbo Launch Controller
- comments on a b-2o turbo is it as good as an ls???????????????????///
- custom turbo setup ?!
- t3/t04b super v .63a/r and 54 trim how much boost?
- b16 turbo timeslips.................
- where to get inline resistor?
- Turbo website
- Electrochager from .....
- What kind of TURBO would you put in if you had a 1991 CR-X SI?
- Here's my setup - Any guesstimates on HP level?
- installed skunk2 manifold...now having problems
- BIG POWER b16s post #s here. Want to see whats possible out of the b16
