View Full Version : Forced Induction
- Electric water pump w/ LHT JRSC
- Ej2 d16y3 mini_me turbo
- JR Supercharger Timing Q
- overheating b20b!!!!!!! HELP!!!
- h23 crank/h22 rods/custom pistons
- thoughts on using a distribution block
- ID 1000 w/ AEM Fuel Rail Question
- crx t4 turbo manifold plaese help
- Need input/opinions b16 build
- Spun bearing, resize rod or replace?
- questions on lsv turbo build
- Walbro 450 intank bosch 044 inline
- Twin Disc Street Driven Users Unite
- where is your bov at?
- Boosted B20v for 600-700 whp?
- blow off valve fitment
- Boosted stock b18c with 57 trim turbo
- Undecided with camshafts
- D17A2 Oil feed line
- Built DA LS turbo and EF B20V turbo
- Meth/water to reach over 600whp for daily
- Have fully built lsvtec type R set up flet top piston nos or spray?
- E85 conversion - flex fuel
- Turbo B20v won't restart after driving.
- will it fit??? cast iron and precision 6262
- JDM B18C Type R Build
- noob with noob questions
- B16a3 boost build
- Planning on turbo' my H22Z1
- What size wrap for Full-race ramhorn?
- Bosch Injector clips, jumper, pins..I have a question.
- S366 or s362 or other opinions
- Can anyone identify this turbo
- 3 5/8" to 4 " vband exhaust housing
- Jackson Racing Map Sensor Controller anything similar I can use?
- map sensor question
- I think I blew my engine.
- Bleeder valve for turbos
- B16A3 turbo set up help
- help with sleeper build..
- Going lean in boost problem (resolved)
- b18c1 Turbo Question (GO-AUTOWORKS)
- Spool up time on a 50 trim "stage III"?
- AMS-1000 boost per gear? gear position sensor
- JRSC kits: what happened to them??
- Nitrous Tranny B16 or LS???
- 5831 MFS oil in downpipe .065 restrictor
- Stock LS + ? = 200hp
- going for final tune.... suggestions?
- Water/Meth Fail Safe Transducer Hook Up need help :)
- ngk bkr8eix too cold?
- agressive cams on second B16 build?
- K series Gearset?
- Hondata Boost Solenoid + AEM gauges
- Skunk2 pro 2s cams on a turbo car
- converting rc clips to bosch ev14. Adapter ??
- first D16 build.. can you help me out?
- How do my plugs look
- what sleeves are these?
- going turbo b16
- most power from eagle rods w/ stock wrist pins on 93?
- spudder when vtec engages
- question and info about EGTs
- f22b with td04hl-16t
- AFR riching terrible
- oil catch can, is it really necessary?
- 04 Honda Civic Si-T
- HELP precision 6776 e OIL RESTRICTOR
- Em1 B16 JRSC idles bad and undrivable
- cold side piping for crx?
- boost on stock b20b questions
- What to look for in used Vtec head for turbo build?
- Pro1 Cams w/GE cam gears QUESTION???
- ERL SLEEVED BLOCK??
- what restrictor on rb25det turbo?
- To get hondata CPR, or not. Questions
- Converting 6266 journal bearing to ball bearing
- Keeping a simple LST
- turbo set up help
- need a turbo kit
- B20vtec dyno
- itr intake cam and gsr exhaust cam
- Block guard in lsv turbo setup
- identify this manifold flange style (pics)
- Oil in Compressor Housing, Smoking at idle.
- few bits left what to get
- honda-tech-user-built theoretical boost setup
- DDTECH Testing: FTW FUEL, Header, Nitrous
- Pr3 vs p30 intake mani
- SPEC stage 5
- -4 oil filter for a turbo feed
- recommended oil weight for sohc zc turbo civic
- LS VTEC TURBO
- Torque mounts effects?
- Clutch
- Head gasket
- High Comp Turbo Build
- leaning out problem once warmed up
- during build for FI found media blasting sand opinions?
- High Idle & Breaking up high rpm
- Valves and retainers
- Turbo B18B fresh rebuild. Burning smoke on deceleration.
- FTW GREEN fuel
- Question about going back to N/A from turbo...
- Tapering PSI
- Turbo too big to spool on Dyno?
- LS VTEC Boost build
- True Street 67mm Build
- Turboed h22a 99 prelude
- running hot
- Info on a Garrett 60 trim ar .63 / stage 3 turbine
- D16z6
- JDM D15B P2J Stock Block/D16Z6 Head w/T25 Love
- Ignition break up at 3k (aem v2, COP)
- Built LSV Identify Tick/Knock
- Turbo question help please.
- Turbo gsr problem(s)
- what size oil restrictor to Run t3 Garrett??
- k20 vs k24
- Rico892002 B series to K series turbo build
- TD05-18G vs. TD05-20G??
- Choppy Turbo Sound
- K20z1 turbo recommended upgrades on tired motor
- Methanol Pump Wiring Issue Devils Own
- Fuel question on dual 340s in tank
- damaged gsr block help
- FTW fuel red for turbo?
- First time turbocharger
- pressure source port on BW s362
- EF Intercooler help
- help on my turbo build, sleeved 2.0 gsr
- turbo integra air filter setup?
- What manifolds allow full radiators?
- JRSC and adjustable cam gears question
- Who DD's with aftermarket sleeves?
- Darton MID rubber o-ring
- Which cams are people using with nitrous?
- gsr 300-400 hp turbo goal. need help!
- Turbo oil return line
- who sells d series diy manifold kits?
- twin scroll with different wastegates
- Oil feed line help (oil pressure sensor)
- Can i simply "switch out" an exhaust housing, PT5858.
- t04s housing too big for gsr swapped crx with full-race ramhorn?
- turbo ideas
- Stuck between turbos.
- Looking to build my first b series
- Busted ringland?
- rich out of boost / lean under boost ... crome issue??
- 2000 integra gsr budget turbo build.
- VMS 70mm tb ?
- CARB Legal Kit
- Fuel Sending Unit Wire fried! Need help ASAP :)
- Will GT3071R be a dog on a stock LS motor?
- looking for cheap b series turbo kit no ebay
- Boosted d16y8
- D16y7 turbo
- Is this too thin for boost?
- 50 mm internals in 60 mm turbo?
- Thoughts on 3" downpipe clearance, Innovative clutch Kit
- Turbo d16y7
- supercharger pricing! need some insight please
- Ebay Turbo Kit...(yeah i know they're shit)
- Experienced opinions needed - B20v build
- stock b16a2 turbo advice
- 1200cc too big for pump gas?
- The Dyno as a Tool - 25hp from a vacuum line
- Fully Built Turbo Eg AWD Project
- ef catch can what's everyone running??
- Em1 b16a2 turbo options???
- What type of Head Gasket to use with Oring block
- Motor mounts: Best DAILY/STREET solution?
- running m50 fuel blend
- Good turbo for dd? Need experienced advice plz!!
- Turbo B18C5 or LS?
- Compression ratio, flat top
- Bosch knock sensor
- UP-PIPE BENEFITS?
- Boosted d16y7
- Bad 3 bar map sensor?
- need help identifying Garrett turbo ball bearing?
- turbo trouble
- turbo trouble
- battery kill switch
- Spoolin quick 4ac manifold
- Tempature raising in Sleeved motor, normal?
- is my turbo to big?
- Need help identifying this manifold and if you can still get it
- In tank fuel pump E85. What Fuel filter?
- Sheepey mini outlaw manifold questions.
- Suction from bov discharge when idling. Leak?
- LightningTeg's 600whp LS to LS-VTEC Build Legacy
- 750cc injectors at 80 - 85% is around what Hp?
- BOV rattles
- trying to be cheap - je's or wisecos instead of cp's
- srp forged pistons
- looking for some advice on Fuel Tank mods .. Fuel starvation at wot
- To crankcase breather setup or not to?
- which intake is better for turbo and nos venom or skunk 2
- Planning a Build...Not sure Which turbo to use
- GT 3076R on a 84mm LSVTEC
- IMW-Tuned: More supercharged fun, with chemical assistant (JRSC + Nitrous)
- Turbo Identification
- 1999 gsr future turbo build.
- Compression Ratio - Boost 101 (now heres a nice read)
- STOCK CLUTCH K20Z3
- Phearable.net Tuned Integra 530 whp on 93 octane
- cometic gasket now timing is off
- JRSC GSR header options
- What pistons for ~11.5:1CR turbo build?
- B20vtecvillian callout thread!! R&R ls rod bolts in
- t3 .48/.50 turbo
- Tial WG problem!
- How would this do for a quick spooling LS stock motor turbo?
- gsr head on ls block, is it even worth the work with a turbo?
- a question about ecu tuning.
- B18c1 supercharged build
- d16y8 map
- 4 years later, daily'd turbo EM1 went back to the dyno. Advice needed
- B20b swap into a 99 dx hatch????
- Possible seals blown?
- Budget 500whp build
- F23 Rebuild/Turbo Project
- B16 JRSC won't idle
- Going turbo need some help!
- crazy idle on turbo civic
- a few newb setup questions
- Instant Torque via Turbo?!?! Want to replace my JSRC.
- Turbo oil feed, t piece vs sandwich plate?
- B20V NA to Boost....
- Honda turbo experts questions
- H/F Engine considerations for boost. Looking to switch to DOHC.
- Boosted iab question
- Looking for a good street turbo for 600hp
- D16y8 stock engine with arp head studs questions thread!
- Turbo Coolant Lines, which fitting is this?
- EF sedan top mount manifold question
- Methanol/water vs Race gas
- Ls or GSR tranny
- Under 300$ turbo for d15 vtec
- Gsr block o-ring help
- Second clutch failed need some help..
- AEM Wideband sensor question
- Hood stack or normal exhaust
- Whose running e85?
- full size Radiator in turbo integra FIT?
- !!!Need help with my gsr turbo set up !!!!
- Built GSR with GTK-650 will it make over 550whp??
- Good D series oil pump comparison
- Y8 high compression turbo build idea *brainstorming inside*
