b16a2 turbo have 2 hoses need info on them
I have 2 hoses that i have blocked off kinda cheaply. One is the pcv valve hose off the intake manifold and i have the tube running from the pcv valve running to the ground.
The other is the extra smaller coolant hose running from the thermostat housing.
I need to figure out someway to clean these hoses up and make my bay look alittle nicer thanks for the help
DO IT ON ALL FOURS
Re: b16a2 turbo have 2 hoses need info on them
What the..........
Either go buy some neoprene caps, pull out the nipples and put plugs in them / weld them shut, or route the lines where the are supposed to go.
Well i wasnt 100 pct sure that i would want the oil feeding back into the intake manifold from the pcv valve. And as for the coolant line i cant find a thermostat housing without that line
Who is Mr Robot?
What kind of setup do you have and what kind of power are you making? I doubt just having the line off the PCV pointed at the ground is capable of reducing crankcase pressure.
At the minimum you should get a water separator used on air compressors and run the outlet line to the intake/filter off your turbo. This will prevent you from sucking the oil vapors back into the engine ( as long as you remember to empty it regularly) and the constant suction at the compressor inlet will help minimize crankcase pressure.
citanest
01-14-2002 10:26 PM
