View Full Version : Forced Induction
- Wanna help me build my turbo kit???
- Leakdown question... Is 12% all that bad?
- Plugs for turbo LS
- polishing my parts....
- ... street tires for boosted applications...
- Ecu ?
- My car is backfiring I think how can i fix it
- just installed a FPR, whats the deal with this POS?!?
- Question about blown headgasket?
- how strong are b rings?
- D16Z6 JRSC'ed 6psi w/VAFC
- Internal Wastegate Actuator
- 700 mile compression check, should I worry ?
- Timing
- My new Project Has just Started!!
- msd 6al question...
- help please
- valve cover vent spitting oil?
- 309 whp stock b18c1 at 8lbs
- Engine Rebuilt and I think im burning oil
- I just Shat myself again
- t25 question
- Getting new car....which guages most necessary?
- Lovefab wastegate elbow
- msd external coil cap?
- for the pros
- D16y8
- I/C Hose Coupling and Vaccum/Boost hose questions..
- my friends b20vtec clank like a diesel is it normal.
- 9 psi on stock motor?
- What NGK plugs for Nitrous in GSR?
- fuel concentration problem on a gsr
- Turbo help
- where do you gap your plugs?
- WHAT Starter is this guys!! I know you guys will know :) Help me out here.
- finally done with install...*pics* *LOTS OF IT*
- how much boost can I run? B18C1
- does the greddy turbo kit charge pipe have a bov??
- difference between T3 and T3/T4 .60A/R comp housing?
- New Version 1.0 Software for AEM Engine Management System
- boosted sohc vtec crossover???
- Turbo surging....?....
- The time has come......help me decide!!
- Max Boost Levels for Crower Econo Billet & Eagle I-Beam Rods
- 450 injectors
- junkyard diesel turbos
- its that time inspection time
- any good FI catbacks besides R and D's 3 inch exhaust,,for a 94 SI with LS motor,and t3/t4 turbo??
- interesting comparison
- boosted sohc dyno results... decent..?
- just got a hondata... which boost controller?
- confused aobut something with precision
- whats a good turbo for a 92 integra
- How much HP can a stock block handle
- qwik question: Eclipse Generations
- ProAutoDevices M-200 Wideband Oxygen Sensor Controller
- Zex hook up
- 350 chevy in a ford focus? RWD?!?! SUPERCHARGED?!
- i am going to the track need input on psi?
- About to install a Hondata s200, have 2 littles question about ditching the FMU and timing
- Ignition timing on S200
- Head gasket question....
- Sputtering is driving me CRAZY!!!!!!!!!!!!!!!!!!!!!!
- 3 inch exh on turbo motor? worth doing asap?
- Going for turbo Rebuild Question of CR for Pistons?
- cam overlap(type R cams)
- Wiring diagram?
- I need to know the power of a srtaight T3 from a saab.......before i buy this turbo.
- Rod Bearing Help
- Injector question
- Installed Hondata Chip and GM 3 bar... Need help
- Plans might be changing....M3
- Undecided: t3t4e 60 trim/.63 ar or t3 60-1 w/ .63 ar??
- JRSC and the "powerband"
- Anyone have the Profec Spec 2 yet?
- Detonating at high rpms big time!!!
- Help with oil feed and return lines
- turbo manifold with AC
- Switched back to stock IM now the car won't start
- Where in Atlanta are you
- 100$ boostchip ?? whree?? uberteg ? heello?
- HKS SSBOV question
- Do I need a gasket for the dumptube?
- DRAG 4, 5th gen Accord in the works.. LOTSA PICS 56K warn.
- saf help
- Ignition
- SMC 500 problems
- big shot of nitrous
- will this clutch hold?
- Help on homemade manifold / downpipe
- Autometer Air/Fuel Gauge Help.
- After Turbo Rebuild (Pics, 56K.. sorry)
- Are 2nd gen DSM BOVs any good?
- for boosting....... JDM ITR?? or GSR???
- N-tercooler
- ACL Bearings good?
- Valves Tapping ? (newbie question)
- just got a wrx....turbo seems laggy
- Oil to use for Rebuild (already searched!!)
- what causes differentials to break????
- quick fuel setup question for all the turbo owners.
- Rod question
- GReddy tuners in Central VA?
- Part # for 255lph walbro intank?
- Which boost gauge to go with?
- Getting ACT clutch - XACT StreetLite flywheel worth it or no?
- need to buy b16 arp head bolts immediately! who has them?
- Intercooler size?
- Another Full Race/60-1 turbo set up with dyno and pics.
- Turbo+Carb Cleaner??????????????
- The turbo prelude problems continue!!!!!!
- What is THIS?
- how much nitrous can stock b16 handle?
- sleeving an LS?
- JSRC 6psi?
- Steps to Removing Turbo, Manifold, and Downpipe???
- SOHC turbo, need help with afc settings?
- I am out!!
- Accord With DSM SETUP
- help with hooking up zex n20 kit for my civic dx
- t3 saab turbo
- Where can I find a Apexi Timer manual
- what size should your oil sending line be?
- What is a EGT gauge?
- Rev hard stage 2c
- Er... did I tighted my Fire ring gasket too hard?
- Want to run from 6.5 to 8psi. Best course of action?
- Whats missing from this picture?
- hondata vs. tranny swap
- where to get a t3 oil drain FLANGE today!
- looking for thread about extra hanger for kamikaze header
- S-AFC install issues - help please
- LS Valvetrain???
- blue print of a turbo?
- hypo rev hard
- turbo head gasket and c/r
- E-manage vs. Hondata...opinions/experience needed...
- Can a crank really warp if you lay it on its side?
- Turbo Intake Filter piping diameter
- - What is Spearco's website address? -
- The difference between ball bearing, and a normal turbo?
- Big turbo guys whats your spool time....
- Who has had an Engine built by Endyn? Want experiences with them.
- what turbo specs for a B16a2 Civic Si?
- Nitrous for a stock B16 or B18c1
- Hondata on a PM6 ECU???
- Anyone know if this will fit?
- What is the biggest vacuum line diameter I can run on stock b18b mani w/o modding it
- Probe Turbo?
- Is this a good deal?
- Is This Pinging or Knocking.
- Garett GT30 discontinued?
- Turbo
- What is a B18C5 worth??
- Turbo Install PICS and a lil Help!!!
- my boost ex runs like crap help me plz.. also 1/4 time..
- Turbo Priming
- JRSC'd guys :::::READ:::::about the coating on the blades...
- Need some clear pics of JRSC....
- Blank Fuel rails, whos heard of them?
- PowerCore Catalytic Converter Pass MD Inspections?????
- crower valves?
- need help..Brand new GE block with used je pistons...
- Best Header for a GSR w/ JRSC??? I've done my research!!
- What do you Think about a 1.8T 2003 Turbo on a GSR B18c1 !
- Grand Prix GTP's.....?
- What Else Do I Need To Support My Turbo Kit
- what air filter for ek with ls/vtec jrsc?
- I thirst for knowledge!! Explain compressor maps
- radiator??.any pics of boosted crx's pls help..
- Pistons/Rods questions
- Wastegate touching Mugen JDM hood, need help...
- L1H1 O2 sensors available at autozone for order.....
- bore over the b18 for turbo or leave it at 18??
- SLAMMED SOL........ Look.
- Valvetrain for LSVTEC
- D16Y8 + Greddy@10 PSI ???
- Okay, okay, so Precision Turbo is the dope, but...
- oil in the intake side... should i worry?
- welding pipes
- My turbo setup plan: Needs approval!
- What does it take to get a Precision Turbo to work with the Drag III kit?
- vafc hack and profec b
- Anyone tried selling their turbo honda?
- 2mm head gasket?
- a/f 96 gsr
- sc44 60trim whp max ?
- Dyno results - GSR - Drag Gen 3 9 PSI
- Log vs Others
- Best Hondata tuner Knox,Tn.
- know if a Is a fmu and fuel regulator the same thing?
- Headwork with turbo
- Anybody seen camp1320 ?(aka. Tom Cho)
- 100 octane at the pump... worth it?
- Got my block back! Pics - and a couple Q's....
- Rust on Manifold
- 300hp on a d16y8
- Idle fluctuates at standstill/ IAC valve help?
- My dyno results(graph & pics)
- White smoke from exhaust and valve cover breather...
- Just wondering what i would run?
- JRsC not spining.....
- Going to start my car for the first time tonight. Have a few questions.
- Not Boosting and tons of White smoke
- Throttle body selection for LS turbo
- Experts! how much power will i get with my set up?
- I took everyone's advice ===> LOOK<====
- Looking for a Specific 3 Bolt Downipipe Flange?? (pic inside)
- my sohc turbo d15 .. spit a piston
- HELP with Fmax kit
- aftermarket cam seal for SOHC?
- Intercooler Size
- CRX 1991 1.6 litre, 120bhp --- any kits?
- Jrsc Power
- Turbo Question
- Greddy kit@stock boost -> intank or inline pump?
- Chances of actually keeping my a/c
- nitrous express Volkswagon VR6 Golf
- Turbo questions- PLEASE LOOK!
- Accel DFI, anyone know?
- D16A6 turbo or mini me turbo?
- if any one needs a palm pilot for WB datalogging?
- which clutch
- anyone with S100...question..
- What would make more whp?
- New Setup......Higher compression.......QUESTION
- Anyone ever have problems with KS Motorsports?
- wanna see the austrian turbo ITR owning all of them? -- TRACK VID
- question for tuners
- Post Videos Here
- Best way to "T" a boost gauge?
- UberChip Dyno Results Inside!
- Anyone here have any experience with probe pistons?
- What boost controller are you running?
- 2k miles on motor...150psi across...should i boost and forget?!?!
- Getting tuned this weekend and I'm worried about snapping my Axles....
- What would you pay for this?
- PWR water to air kit now in stock
- what rpm should i launch at ?? pls help...
- max rev and 60-1
- Someone please explain the whole map sensor deal...
- how much power will i gain?
- ... diy vortech recalibration... is it possible?... anyone done this before?...
- What are your best ET's on pump gas
- Downsides to "closed loop" wastegate?
- Where to get a Hondata system installed/tuned
- Buddy Club Racing Spec Comp Treatment
- Mig welder needed in nova!
- Looking for old FI Dyno post comparing precision 60-1 and Turbonetics/Garrett 60-1
- Boosted LS VTEC??
