View Full Version : Forced Induction
- Got hondata want to convert to uberdata
- 3 inch Downpipe for a drag gen 3 turbo kit
- fan stopped
- Lag on 18g as you increase boost?
- good machine shop in dallas texas
- 3" downpipe turbo si loud or no?
- My JRSC Setup: Would an AEM Fuel Rail And FPR Help?
- Ok so i got this LS and..........
- Zex Turbo Plugs ANY good?
- Got a problem with my 1988 CRX Hf b20z supercharged 6MPG on the hiway HELP?
- Nitrous in my 94 Si, on a budget.
- * TiAl WG * what psi ?
- 3 Inch Downpipe For Greddy Turbo Kit?
- who can make me a downpipe?
- adapter plate help!!
- noob question high flow cat (searched)
- turbocharging a d16y7
- my list so far?
- Looking for a machine shop in the bay area.
- best shorty SOHC mani for around $300?
- Nippon Low Compression Turbo 75mm Pistons?
- uberdata tune help.
- Engine builders in central florida???? HELP PLEASE!
- Nitrous into turbo bad idea?
- A/R and turbo suggestions for my motor
- charge pipe vaccumm nipple???
- Video Turbo Crv snowplow
- Looking for a Great tuner Somewhere within driving distance (around 2 hours) of KY
- not running any o2 sensor?
- what do i need?
- Heater Controls Hondata and P30
- Head Bolts Question?
- Can your ECU do this?
- where can i find...
- Peak and Hold or Saturated injectors for boost.
- NX Ntercooler Trick?
- Turboedit on PW0 ecu with 380hp
- carburetor fuel manage :P
- turbo kits 101....help with b20 turbo setup.
- ls vtec turbo or just ls turbo?
- Bypass rev Limit?
- Where do you guys install your oil cooler???
- dsm injectors
- torbo housing
- couple turbo questions
- Where to buy turbo blankets?
- FMU and/or? bigger injectors
- Is It Possible???
- Running rich....but not running rich?
- Best way to break in a FI motor??
- Compatibility of Turbo/Tranny?
- VTEC engagement ?? 5000rpm or when the turbo begin to spool up ?
- How much would this engine work cost?
- fuel pump question..stock......
- How much power on a stock LS head/intake mani.......????
- NOS dry kit on built b16
- Victor X or BBK SSI im ?? which one
- Bay Area people!
- Buying brand new center section, instead of turbo rebuild off of ebay...
- pics of ic piping and exhaust with custom cut-out 56k dunno
- D16Z6 Turbo
- Turbo b18b
- Greddy type rs with drag turbo kit
- New Distributor, Now Real Lean?!?
- Should a bov be sealed at 0psi? (atmos. press)
- B20 Vtec Turbo
- jdm itr boost
- So Whats Up With This 4" Down Pipe Craze?
- v-afc + e-manage
- where to buy a rebuild kit for a garrett turbo?
- msd cap + coil + 6al = engine codes?
- post times of b18b turbo here....on stock internals
- Safc 1 and Safc 2 , same harness?
- Greddy Turbo vs other turbo brands
- p28 and CEL help?
- arghs, boost problems..
- GReddy Full Auto Turbo Timer question...
- uberdata nokia datalogging cable work with other datalogging apps?
- at a loss for words... help please
- Stewart Warner Gauges
- Ride Revolution for Hondata tuning?
- P28 A02 vs P28 A51
- Best piston bore size for turbo
- Please Help Turbo Adapter Plate
- Can I use a stock AEM SRI with a JRSC??
- Do I need an adjustable cam gear for SOHC?
- Zeitronix Wideband questions..
- EG with teg radiator... can i still boost?
- wtb: wastegate block off plate for drag mani
- Anyone have gear dependent boost with a Profec B?
- Mishimoto Intercooler?
- Just some pics cauase i was bored
- y8 turbo in a ek coupe
- Anybody re-use ARP headstuds?
- Mase/Precision Visit to New Orleans, LA 2-2/6 Anyone interested in a tune?
- IC piping, same for B and D series?
- B16 TURBO OR LS TURBO?
- OT: Fastest snow plow on the east coast
- weight difference between mild-steel and aluminum intercooler piping?
- flange question
- Wheel isnt spinning as it should?
- What specs should I get my ecu chipped at?
- Press Release: HKS RSX Type S Turbo Kit and Intercooler now available!!
- oil presure guage problem
- F22 Boosting.
- Neeh Help??? TD40H-15G or T3/T4 ?????
- my car is smoling
- MOTOR ?
- oil feed line: to "T" or not.....?
- Turbo Brace (correctly)
- Velocity Performance S2K Project
- MSD PRORGAMMABLE TURBO LAUNCH CONTROLLER
- how to get a 18g greddy kit on a d16y8
- what is the lionk again?
- Question on oil pan and fitting.
- low compresion valves
- stock sleeves
- how can you tell if a turbo is new or re-built??????
- diff between s100 and s200?
- VDO dash bezel? Better than ill fitting autometer?
- Traction problems!!!!
- boost issues...higher gear...more boost...
- ?need information about Phantom Grip LSD Conversion Kits
- Core pics of the garret core? AKA the Precision intercooler.
- *** Where To Get Cheapest AN Fittings Online? ***
- water cooled td04????
- aem ems problem
- torn between JRC and Precision IC
- Tial wastegates and leaded fuel?
- I swear, Everytime I get the car running right something else happens!------->
- changing bulbs in defi d-gauge??
- SONNY KING OF THE STREETS!!!!!
- Help on building turbo kit...need opinions...
- High boost and a 35mm wastegate, FATAL?
- my turbo si vs. zo6 corvette vid
- can i change colors on boost gauges?
- jrsc vs vortech
- Most efficient way to setup e-cutout?
- how to lengthen the life of my boosted honda
- DSM flange???
- This turbo seem ok???
- whats the deal with the tial bov's spring?
- Map sensor vac source?
- i need a diagram
- Is a tdo5h a 14b,16g,18g turbo?
- Intercooler piping on 00 GSR
- Johnnyracecar backdoor intercoolers!
- What magnaflow Muffler for turbo civic? SEARCHED!!
- h beam eagle rods
- 03 SRT-4 injectors with a afc hack
- DIY Techedge 2A0 Rev4 not working on Palm
- gauges to mach stock cluster (98 GSR)??
- sc61 gasket
- A couple of turbo h22 oil questions.
- anyone tried mr. gasket?
- building engine in cold weather ? >>
- 400hp on the street movie inside !!!!!!!
- any idea what lsd this is?
- Are there any Turbo Kits besides Greddy that are CARB legal?
- o2 sensor questions
- Spark Racing Rods
- Add more boost
- has anyone tested the "NEW" OBX manifold yet?
- t3/t67 vs gt35r
- Do I need head studs?
- Reasons WHY the Prelude B20A and B21A cranks are "Weak"?
- Yeah, go ss autochrome!!!!
- Car will not even begin to turn over with Hondata
- Dart Block Boring and Honing
- where can i get a highspeed water solenoid valve for Water injection?
- Sprung -VS- UnSprung Clutch Differences? Act 6 Puck
- How do the Rotors of this Jackson Racing Supercharger look to you?
- Which turbo exhaust?
- I know it's not a toyota site but a friend has a MKIII supra and needs upgrade.
- Help me on my way...
- 500 whp block
- Just bought a 93 integra GS. Want to get 200WHP super cheap and reliable....
- Is this Tial wg a 38mm?
- DSM 4g63 injector size
- Wastegate question
- My custom intake makes my bov sound different...vid
- turbo + cam stock block?
- nitrous help!!
- wastegate question?
- injector seals
- How much boost and how high could we rev on this setup?
- help! d16z6 in an ef runnin obd1/hondata ecu.. cant go past 4 k!!
- urget h22 Question
- greddy turbo timer music
- Painting FMIC?
- New GT3071 Turbo- car undrivable?
- help with my first track only setup
- Full-race goods
- HONDATA
- TSI EXTREME TURBO KIT B16A
- Part numbers for oil fittings?
- T-25's just received
- Poor mans type r or full gsr, ls, b16 for my 700 hp build
- turbo/b18b built up
- Code 61 WTF
- Latest Nissan dyno graph
- Porting the Greddy internal WG flapper...do I have it right?
- Best Turbo Intake manifold for best midrange ?
- GT35R @ 3psi, good idea?
- DIY exhaust gasket......what can i use?
- best sparkplugs for fi
- What do you guys think about this Daily Driver boost setup? D15 POWA!
- dart block prices?
- What turbo for 500+ whp on a EJ20?
- Hondata.....Breaking up in high rpm
- another NA guy just turned to boost
- Help o2 sensor placement
- precision turbo... swap out a small with a bigger? Straight fit?
- uberdata datalogging cable question
- what numbers to expect, LS-VT
- Cracked block...Oil pressure sender unit
- Equal Length Manifold?
- Hondata Peep.....Rom Editor V3.6 Available!
- d-series turbo
- What made you decide....to sleeve or not to sleeve?
- Full Race Exhaust Manifold?
- afc hack
- charge piping for d16 300whp ?'s
- stupid question time! Yaaay --Turbo to mani, WG to mani gasket Questions...
- oxygen
- turbo rods
- running 12's
- Hondata V 3.6 (beta) Native 5bar Support ! plus more Nitrous Control
- Can i make 300 whp with my motor and turbo?
- What Size Intake-JRSC
- price on a semi-built d-series
- b16a1 turbo help
- Made a custom intake for my turbo :)
- Testing Waters, EFI 101 New Orleans, LA
- Electronic Boost Controller in the works... should be finished soon
- dsm injectors
- Anyone ever buy from turbocalculator.com?
- what flange for a sc61
- Went to the dyno the other day
- could i have f*cked something up?
- greddy turbo timer i bought used not working right
- RC injectors not spraying fuel.. saturated on obd0 car.. HELP!!
- Timing on a long stroke engine.
- how to start building for a turbo
- IC piping and Traction Bar fitment Questions
- leaking oil !! help!!
- Ben Strader {EFIGUY} asks for your help
- Where all does a quaife lsd have quaife markings?
- need zex directions
- diy removeable cam gear cover
