View Full Version : Forced Induction
- question about my new setup
- dart built supercharged
- Look inside for what happens to abused 500whp Ford Lightning pistons!
- Happy with my D
- Where to find 6 bolt discharge flange?
- fellow Vermonters, where the dynos at?
- HELP! Why am I running lean at WOT... what do i do?
- Vortech supercharged Type R Problems help
- Hondata Blinking light .. hmmmm
- ls/vtec internals
- test fitment pics of my turbo on my block
- Critique my time...
- home made turbo kit
- turbo spools but no boost.
- DFW emissions
- www.turbocalculator.com
- CP Pistons ... how to install wristpin ?
- how much to turn down 310 rc's need help
- Help me please! Cometic Head Gaskets...
- WHY I AM I LEAKING OIL! PETA IS GOING TO KILL ME!
- URGENT: LOST THE CABLE BETWEEN HONDATA AND ECU. NEED PICTURES SO I CAN REMAKE ONE
- LS Vtec
- Show me pics of Water Cooled turbo hondas...
- DA6 turbo exhaust
- 3BAR and Hack
- Shes boosted.. my 91 EF Hatch
- magnacore resistance
- Greddy 18g internal wastegate?
- Colder plugs and missfiring.
- help: No CEL, starts won't run, strange idle before it stopped
- How do I take Tial wastegate apart?
- Tial hybrid wastegate 38/40mm?
- psi on a stock b16a
- Radiator Keeps cracking, 3rd one this past month (any ideas what could be the problem)
- How much power for stock clutch
- When disassembling and reassembling a motor what manuals or books can I use for reference.
- Garrett t3 60-1 opinions?
- Acura Integra Gauge location
- anyone seen this problem before?
- Numerous Q's about Turbo H23a1
- is 15W-50 synthetic safe to run in an turbo Honda?
- Car bucking at 6k...tuned ls/vtec with hondata stage 2b.......
- Hondata Issues???
- Stainless Steel and aluminum flanges...
- quick question please look!
- LS turbo - What tranny is best for setup?
- well just got back from the dyno now
- b20 sleeves?
- EGT going to 1500 what are some ways i can lower them a bit????
- will b16 pistons and rods fit on my b18a?
- Will this heat wrap work on DownPipe
- wet or dry nitrous???
- Adjusting the AEM fpr.
- Any good online prices for...
- Digital Wideband Gauge or Displays. Brands? Pics?
- JDM DOHC ZC in 89 Hatch back. Zex Kit - Dry or Wet? Whats Better?
- just went to the track... timeslips inside
- just showing off my new equal lenght mani...
- Is this a Little RED or BIG red tial 35mm spring
- 3 valve GM boost solenoid question
- d16z6 turbo questions?
- LSD in a LS tranny, worth it or not??
- Turbo LS/Vtec detonation in 4rth and 5th gear
- JRSC bogging + hesitating
- Toyota CT26 turbocharger on B18A...what manifold?
- NEED HELP FAST PLEASE!!!!!!!!!!!!!!!!!!!!!!!!
- Does Injen make a 3" intake?
- Turbo kit, pistons, rods, b16 head etc...
- Accord: I've got a manifold...what next?
- Adding PCV to your b20/vtec turbo car?
- Mounted the T4/SC61 and Mini-Me today...
- downpipe adapters
- Oil return?
- qiuck help me safc high low thrittle
- turbo timer
- Can't Decide...
- Turbo smart wastegate ultra gate question
- SAFE to run LEANER in the lower gears...
- How much is a compression tester?
- ATR SVO manifold, anyone?
- Un-identified CEL
- How to bore out injector seals?
- tuners check out my timing table.
- water wetter does it work?
- The greddy e-manage
- looking for someone with a Civic HB 92 with a b18b turbo set up to talk to.
- intercooler question
- What was your motive or drive to turbo your car???
- Turbo kit
- manifold sealant
- will this epron burner work
- Precision 880cc injectors
- Torn between the SC34 and SC61
- greddy vs. jackson racing
- Greddy Manifold Fits What turbo's
- ignition timing: depends on engine speed, manifold pressure,... and coolant temp?
- Quick V Band Question
- Built LS/Vtec Turbo back after rebuild.
- Stock tranny question
- bov sugesstions
- I am so happy for my friend!!
- b18 turbo Q
- Affordable tunning on a d series- SOCAL
- small turbo?
- ~BLOX turbo manifold- Giant pics 4 U~
- We forgot put on turbo and now car is broken!
- She's Alive Thanks to Absolute Pro-Formance
- ran into some trouble... Few questions
- can you swap sleeves from what block to another
- People who have Golden eagle Vac manifolds.
- Why does my turbo's keep blowing seals?
- Really loud whine
- Thoughts or recommendations
- Strange Idle Problem
- Going Turbo, need help with other things
- o2 Question
- Getting the turbo..now what?
- Intercooler piping
- SS autochrome mani any good??
- J&S Ultra Dip switch settings?
- Downpipe Fabricating Problems
- Crower Cams
- not a honda turbo kit but most of you are turbo experts. (remote-mounted kit)
- tuner shops near nashville
- Problems with Tranny.......
- OT but f.i. fosho... vw 1.8t aiming for 1000hp. :-p
- Any Socal Uberdata tuners that are willing to help me?
- self tuning dyno softwear
- Engine builders... How to get the oil filter thread out of the block????
- Putting motor back together with rebuilt head/ARPs - tips for re-installation?
- EX vetc turbo
- D-SERIES SAFC SETTINGS
- Pulling out timing and how much?
- What much is a Electronic Boost Controler worth?
- delsolb16a2 where is the fuelpump relay???
- water cooled turbo or not?
- safe whp?
- V-Tec Plus turbo question
- May I ask why you retard timing on a Turbo Engine
- 10 watt 10 ohm resisters wired into injector clips
- Obd1 conversion injector compatibilty?
- Burns Header Pics, some stuff we have laying around
- need help with some decisions before tunning...
- Dakota Digital Gauges???
- Tapping the 3rd runner for EGT
- Spy Pictures
- flange question???
- stock gsr axles... how much power can they take?
- TurboXS Standard and High Performance BC differences in spool times?
- How big is the Greddy 31v intercooler?
- ?'s about 450's and water cooled turbo
- what size exhaust
- people running 3 inch downpipes..how low are your cars?
- What size tial spring should i use?
- anyone heard of turbo leaking coolant into intake/exhaust?
- tons of white smoke, still......please help.
- Spark Plugs quick question
- gsr-t dyno sheet!
- vortech bov sound?
- Any of you guys using a pre-spooler for your Turbo's?
- Size Socket for AEBS headstuds?
- Where to buy studs?
- turbo my motor?
- piston & rod combination for Honda D series engine??
- turbo idle question vac
- h22a with 100 shot dyno
- Cryo Treatment
- boost question
- Optimal size turbo for Accord F22-LX head
- cheap "d" manifolds, worth it at all?
- cant get boost up
- Girlfriends H22 EK Hatch, almost done
- Read my plugs and some...
- Anyone Run Autolites?
- Sugest a FMIC
- B18B with boost, what hp could i expect
- Turbo 4 Civic 700 hp club!!!!!
- VTEC TURBO?
- what type WHP would i need for a full weight 95 DX hatch with a B18b to be good in the 11s ?
- Boost Problem
- willem burners
- No boost? Internal wastegate?
- Cost of H22a turbo swap
- D16A6 vs. D16z6 and air flow under boost
- Code 73-random misfire... Plugs? bent valves? Dist/Cap? It pulled just as hard as it usually does
- anyone use crinkle bend piping for a intercooler?
- How do you tell your oil pump is bad after disassembling it?
- ZEX Wet kit wiring on B18B HELP!
- turbo b16
- my car is not running correctly! can someone help me out!!??
- Why the bad lag?
- Walbro 255lph
- egt temperature
- Turboedit is there still support for this program?
- Anyone ever heard of MAster Power Turbo Chargers?
- Anyone interested in F.A.S.T/speed pro tuning in nor cal with Harv?
- Fouled Plug Question
- Help with intstalling a JR Boost Timming Controller..
- Del sol supercharged CR
- Is My T3 Turbo blowing out my SPARK from the spark plugs??
- Difference when checking oil level and blue smoke when taking off a gas
- Dumptube
- NEED SOME1 IN CENTRAL,PA TO STREET TUNE MY SAFC
- 12.3@119mph Help pls!
- JRSCed LS stalling problem....Please Help!!!!!
- Supercharger BOV... ??
- safc/pressure question
- good Timing under boost?
- Was it worth it?
- Vortech .vs. JR supercharger for Type R
- clutch suggestion 450whp h22
- hole in internal wastegate, fixable?
- Vafc hack car idles very high! help!! pictures too.
- Good tuner in Seattle WA?
- using a DSM manifold on a honda motor
- Innovate Motorsports Wideband.. what do you think about it?
- Water intercooler people, I got a question about water tempatures
- Greddy 18g wastegate take a shit?
- TIAL wastegate flange the same as a Deltagate?
- How much boost can a stock fuel pump handle?
- quick question about built motor
- H22A IAB plate removal questions.......
- vacuum questions?
- turbo manifold
- Big boosters please read.
- lets see some big number street cars
- Oil seeping from back of the block/hg?
- b16 swap in 95ex turbo kit
- turbo timer
- Boosting 5 pounds, when vtec engages its like...
- turbo problem please help!
- kteller 2.5 inch bolt up question
- atpturbo Anti-stall BOV
- ihi spool on a d14a2
- Turbo Problems
- need some help with ebc
- Dynojet wideband? and bogging/hessitating problem arising with Greddy Turbo Kit
- running oil cooler inline between oil feed and turbo.
- Is a turbo from a gas car and diesel car be the same?
- Weird occurance...has this happened to you before?
- Nitrous and water injection?
- is this turbo good or no?
- NX Express fogger nozzle location idea??
- power enterprize oil filter...im not believing the hype but.....
- Motor rebuilt for turbo and car heats up faster. Did search
- Anybody know about Holset's???
- NEED HELP GUYS!!! Fuel Problem HELP HELP HELP!!!
- Turbo d16z6 AUTO
- Blox Turbo Manifold! same design As Inline PRO!
- eagle rods are they good for 600 whp
