View Full Version : Forced Induction
- Plx m500
- Need Your HELP!!!! (Nitrous Express Kit)
- I dont know what this means HELP
- Spark plug gap and Injectors
- compilation video of racing i made
- turbo b18a with egr
- What model ATI dampers for 500+ whp
- Tuning The Turbo? A Few Q?
- Air/Fuel ratio
- Modify Stock MAP Sensor DIY?
- rising fuel pressure under boost?
- Help please! pics
- Vtec Crossover Tuning
- General Turbo build question.
- Electric supercharger?
- Biggest Turbo youd use on the street for a sleeved 2.0
- nitrous jets
- hondata/omni 4bar sensor work with s100?
- help a turbo noob out.......
- hp goals to much?
- Turbo Set-up Value?
- PLX DM-5 & SM-AFR Wideband
- B18C block girdle on B16A2?
- T-25 turbo
- civic si turbo
- Valves? Ferrea vs Omni?
- SFI dampers and a Slicks Questions on EK
- Loud Turbo? BOV not working?
- Polished crank ACL bearings
- Beginners Turbo question for z6
- D16 main studs?
- water injection+JRSC = lower IATs?
- Turbo LS
- Semi-Built B16 setups
- high compresion turbo
- spool and power differences between a t3 gt35r and a t4 gt35r?
- Explain Boost By Gear
- Help: Tial's Backordered I need Product (Anyone have stock??)
- identify this apex IHI turbo!
- help identify this turbo
- Oil Catch Can?
- NEED HELP! how low should the drain be on the oil pan?
- hks turbo time not working on 94 gsr
- GOING TURBO ON MY BONE STOCK B18B THIS IS WHAT I HAVE WHAT YOUS THINK ILL DO
- B-vtec Turbo guys using GSR/ITR/CTR cams what's the best Aftermarket Springs/Retainers
- Need help picking turbo.under 66.5mm
- Another turbo Integra Gsr Misfire question/comment
- skunk2 pro1 stage 1
- any one run JG valve springs and retainers on there car?
- b20v turbo???
- How important a dumptube really is
- Tuning a turbo 06 civic si does anyone know?
- any places still sell JRSC pulleys for SOHC?
- pin outs on AEM for the nitrous control function ???
- vortech
- Turbo charger help?
- Post Your b16 stock internals setup
- Hondata s200 with boost option questions
- Where can I get a cheap Top Mount Manifold?
- d15b7 injectors..
- I know its been covered.....but whats a good horsepower on stock LS sleeves?
- SMIC piping in an EG
- Turbo Manifold question.
- hondata s300 + boost control solenoid or mbc
- PR3 or PW0 tuning for turbo crx/b16 prodject
- t3 60-1 help
- turbo system install in b16a rev problem
- Squirrel Performance turbo map calculator
- H22 turbo setup (good or bad?)
- turbo decision opinions.. 35R
- Oil feed and return setup on SOHC
- PSI vs CFM
- 3 bar map sensor installed in stock map sensor, modifying stock sensor
- s2 tuner series valve springs
- nitrous guru's. fuel source info
- what size wastegate???
- s366
- what does everyone think about jackson racing's supercharger for b16
- godspeed wastegate
- ARP thread chasing taps for head studs
- Starting fresh Fully Built LS turbo
- would it be ok to tap my pan at the shorter area of the pan??
- SPA Top Mount Cast Manifold in a CRX?
- wastegate options
- Help with Crome! Car will not start after its warm.
- D16z6 with evo T
- Made 300+ whp on TUrbo D16..... OIL PUMP question on y8 bottom end
- ls-v turbo bearing clearance question
- got tuned last night...boost would stay steedy need help...
- Mounting AEM fuel rail on Edelbrock manifold?
- 9:5.1 comp.ratio ??
- B20 SWAP
- a few turbo questions. (GSR SWAP in EG, would like to keep a/c)
- best affordable ebc
- Garrett Turbo on a stock b-series on 11psi? Yes/No?
- TQ VS HP
- the new setup
- BLow Off Valve Spring
- Boosted the LS now slight tapping in head?
- Datalog/wideband
- Axles Axles Axles, What do you use?
- loose bolts after clocking turbo-seal issue/question
- IC piping and Exhaust Piping for CRX
- Electric Supercharger ???
- AEM EMS/S300 questions
- RS machine pistons + Eagle Rods?
- Did I just mess up? please help
- Tunning CHIPPED P28 or AEM EMS
- Engine mangement?
- Greddy help
- Tuner help. Can't get ahold of one.
- 1999 D16y8 JRSC
- Anyone know the information for theese turbos?
- Open down pipe
- Sohc Turbo Block d16a6 vs. d16y7/y8
- Turbonetics 60-1
- Precision turbo...........
- Samco for Civic 92-95 160hp
- Can I delete the IACV with AEM EMS
- Could slightly overfilling with oil cause smoking, and It damage anything
- turbo dohc zc mock up (pics)
- i knowI need a T4 manifold... where to get?
- Greddy Intercooler, Identify it please
- Need help with NOS direct port wiring...SEARCHED
- b20 block
- Possible?
- turbo seal? or not?
- Dual wastegates = better boost control on high boost set-up's?
- Idle problem on JDM D15b (Greddy Boosted) Searched already with no result!!!!!
- Strange oil burning problem and compression numbers
- OIL Leak Please help need some opinions**
- sc34 is it right for me
- i have a few questions look inside
- I need pictures of full race IC mounted
- K series turbo, need your input
- resistor pack needed with 1000cc injectors?
- check out my parts list
- installing a turbo kit on a 88 CRX with b16a swap questions
- ct26 turbo on t3/t4 manifold
- oil cooler size ?
- OGURA Racing Clutch... any good for DD????
- What canister you guys running for your turboback exhaust system???
- Stock PCV system
- where to buy jrsc stock replacment belts?
- Which 15 inch Wheel would fit over Wilwood 12.19 Big Brake kit with Dynalite Pro Calipers
- Boost controller not working?!
- Smoking problem B18b-T
- dyno sarus rex
- ls-t vs built ls vtec
- external wastegate question.
- Should I port this PEAKBOOST manifold
- Disable ELD function in CROME
- 600 hp precision intercooler on crx
- Any got t3/gt40 blowzilla Numbers.
- Need your input on replacement IAT packaging
- F22A oil catch can setup, which ports to block off?
- Top Notch's EG - St00pified - Runs 9s in San Antonio
- b118c1 butterfly gasket
- "super 60" center section??
- Have some twin disc questions, repairable?
- J&S Questions
- Race Axles!????????
- ls Vtec turbo?
- Desruction B18B Blown Up.
- ls vtec head bolt question
- trans question? HELP!!!!!!!!!!!!!!!!!!!!!!!!
- Do I need to order special O-rings to run with a Edelbrock manifold?
- Blow Off Valve Problems
- take a look any thing stand out? cooling problems and 195 180 190 190 compression
- turbo kit, or peice by peice
- coolant soaked spark plug in cylinder #2 only?
- Map Sensor? Please help!!
- gsr with 5lbs 236 hp 170 torque,,, GOOD or NOT?
- Need Help Using an SC4427E Turbo keeping A/C
- Turbo Accord: BOV not opening(i think) but car runs great
- MBC what kind are u guys useing??
- need some help with arp head studs
- b16 crank in a b18a?
- Anybody know what company made this conversion harness?
- Sequential Turbo Setup on ONE Big Turbo??
- The greatness of Honda engines!
- Anyone try this boost controller yet?
- d series tubokit opinion?
- JRSC and CAI vs ICE Box
- LS Vtec turbo question
- Sleeved B16.. stroke? searched but confused a bit
- Quick Question, SC34
- b16 turbo injectors help !!!!
- gas question?
- Turbo Y8 - 2-way PCV Catchcan Setup - 1 question.
- Intermitten Blue Smoke
- Where to buy a NEW smic?
- Best turbo for 350-375
- Basemap Question.
- ebay intercooler
- 10.6.1 comp?
- Dpfi to Mpfi - obd1 B16A won't stay running please help!!
- sleeving a block? yes, but what's the best bore size 4 turbo???
- Thanks to Xenocron (non Honda)
- worth changing ?
- intercooler question
- BKR7E-11 vs. BKR7E turbo
- Peakboost topmount in a DA..?
- Need help/suggestions coolant leak under 8psi boost
- pics plz
- act HC4-XTR4 clutch slippin at only 14-15 psi?? sohc ....
- Sniper Nitrous?
- Choosing the right turbo for h22 setup?
- Enter The World Of The 96 EK 4DR
- details on this turbo please
- Dyno From my H22 Hatch Nitrous
- So I froze my motor....need advice/ideas
- First Post My JRSC B20vtec
- Turbo setup without an intercooler?
- Do I need to bore out the wastegate hole on my manifold?
- Car sounds like an air horn under boost
- .....fpr for victor x.......
- dedicated nitrous fuel system build????
- A/C with your D?
- back to boost!!!
- Bullseye Power's Florida trip!!!!
- Victim of the infamous 1-2-3-2 shift..... :(
- Adjusted valves but still a bit tappy. 550 injectors & Wiseco pistons?
- head porting really help with jrsc setup?
- need help?
- Question about Greddy Turbo's
- my boosted ej1 new too the site
- highest tq???? highest hp with a/c???
- question about BOV brand.
- 600hp B16a Motor Build...Question?
- My D16 Build Thread *Pictures*
- Need help on turbo build!!
- Hondata Nitrous wiring question
- Is this ignition system good for 800+WHP?
- Found more stuff melted under my hood.......
- d16 turbo setup ?
- check out these bearings
- n00bie h22 eagle rod question
- Ebay intercooler vs Precision intercooler
- ls vtec pistons
- anyone know where can i download crome 1.2? 1.98?
- Hondata S300 boostcontrole
- got my used JRSC today...
- 99, fog lights
- Been out of the scene for a while, need help with Tuning Software
- Exhaust Wheel Stages
- will a ACT heavy duty pp hold 400whp
- Anyone experience thrust bearing wear due to too stiff a pressure plate???
- car was tuned and went to track and have major issues.. help
