View Full Version : Forced Induction
- t3/67
- just now boostin my b16a
- GT30 too big on a b18c5?
- gapping for around 400whp
- turbonetics turbo kit
- spark plug gap for turbo d16a1
- super t70 turbo?
- D series rod that doesn't require notching block?
- injector size?
- T3 turbo. who has them
- Clutch/Tranny Noise on my turbo Si?
- Is this combination safe on a stock H22
- trying to understand Turbo Timing
- hks blow off valve question
- Piston undersize or block oversize?
- GT30R: Update #2 I can see the light
- 3 inch downpipe stock cat
- precision intercooler what to clean it with?
- Dynoed the new setup (Pics and Video)
- stock prelude motor on a diet of sc61 at 15psi.
- Tuning my B20 w/ Emanage
- Turbo for a fully built d16
- pauter vs. crower billets
- What WHP do most B20's Crack?
- In need of a GOOD ACCURATE RELIABLE boost gauge!!
- help with turbo specs
- anyone had any experiences from autologic in houston tx?
- nos solinoids question..
- Qwik Question... Is inline and FMU Good enough for itr?
- how many psi can u boost on a stock b16a?
- ssac turbos crap?
- Peak boost turbo kits???
- dsm injector caps
- Pauter vs eagle
- oil capacity
- OH SNAP!!! I F'D UP -Map Sensor Install-?
- can I use a oil/water cooled turbo with water cooling it?
- 99-00 civic si greddy turbo kit with intercooler. Which blow off vavle to buy????
- b20vtec sc 61 379whp 282 trq STONEY TUNED
- To boost or not to boost
- Installed my new Distro today...still missing... :(
- Manifold options!?
- Thoughts on GT30R over 60-1 hifi or GT35r For RSX-s
- Quick question on Garrett's GT turbos and Innovative's SH61 BB
- heat resistant tape?
- stupid questions on wastegates
- Speed junkies, need your help with smog
- WHAT WASTEGATES FOR A INLINEPRO T4 MANI?
- b20 vtec turbo... what head?
- LoveFab Mini Me and AC
- water/coolant for T25/T28 turbo....
- Wideband / Narrowband conections, use and settings with Hondata Urgent Help Needed
- Attn: LS-VTEC'ers... to girdle, or not to girdle?
- RPM Signal wire on ECU?
- Progressive Nitrous Controllers.... I Need help picking one
- I am New..What Turbo To Use ?!?!(teg ls body kit, rims, etc.)
- d15b8
- hondata question
- What are your opinions on this exhaust for a FI B16A?
- Calling all f22a1 boosters!
- 4 inch Dp, AC?
- Reputable Vortech Dealer in the US for Export?
- my cuziz turbo teg...
- jrsc hondata install help!!! Is this injector harness compatible with 99 my civic si? w/pix
- charge pipes
- Injector question
- B18a1 Turbo
- How much boost
- Edelbrock Kit Spiking
- Screw Type Supercharger On F22A??
- HELP!!!!! mandrel bent pipes from kteller.com what sizes to get
- So I dyno'd the GSR on race gas this weekend..........
- Anyone explain why 2 vac. lines are needed for EBC on Tial sport?
- which turbo for s2000
- Contacting Benson and anyone who went through benson
- Coating the bottom half of a Tial wastegate, is it possible, Pro's and Con's
- air intake temps....unclear.
- water temps , where are you guys sitting at?
- STUPID EASY AFR ?
- HELP ME OUT WITH MY TURBO SETUP..sc61
- Tuned by Tony1!! Pictures and Videos inside!
- 93 civic dx 160 000kms want turbo but is it worth it how to tell?
- ? about tuning jrsc for gsr
- bringing a car back to life after 1 year of sitting
- supercharger misfires
- error code 8 and 54
- Help me with my connections
- custom headgasket
- Ls/vtec JRSC, let me hear some opinions!!!!!!!!
- The B13 that could....
- Boosted2K's HOTROD (56K, go use the bathroom)
- difference between autometer "full sweep electric gauge" and "mechanical gauge"
- McMaster studs and nuts for DP part number?
- attention greddy profec A owners!
- B20 gaskets
- Boosting f22a1.
- Looking forward to boost or supercharge questions
- yes or no to this turbo kit
- whats best but affordable clutch kit flywheel combo
- 604WHP 373TQ
- manley turbo tuff rods hp rating????
- got a question on my setup
- spooling
- anyone withe DIY tubo ITB?
- question about waste gate
- yet another pcv/catch can question
- what turbo should i use?
- Limit on stock axles
- cheapest place to get stainless stell?
- Opinions on Zdyne Gold Super SECU?
- E-Cutout Response Time
- Video: Taking project EM1 out on the back roads (21MB video)
- d16 turbo trouble starting please help,
- Preparing engine for boost
- Qtec/e-cutout downpipe?!?! pics please
- Choice of turbo for B-series?
- From Japan with love
- only 6 psi? car is also holding back when it starts boosting
- b16 valve spring and retainers install
- Dart block / Turbo setup questions
- Maximum streetable power?
- Used piston rings??? SHould I USe them ?
- td04???
- greddy obd2 vtec blue box work on obd1 b18 non vtec?
- What is a good turbo to use on a D Series ?
- boost question
- Sohc SRP n Eagle Assembly. Direction Importance?
- HOW ARE scat rods.>????<
- Is anyone using the exospeed z6/y8 cam with turbo?
- need a definitive answer..
- No blower whine? WTF.
- 92-95 greddy kit INTO 96-00?
- My new D-series turbo set-up...
- apex turbo timer
- gasket size
- Dyno Not so good
- 3 bar sensor changes?
- BOV?
- Would I benefit subsantially from a bigger throttlebody?
- Fixed problem,Ditched FMU, Got AEM, 344hp at 9psi Pics and Graph Inside
- uberdata
- Piston ID Gurus. SOHC SRP's. Pics N Prescision Measurments HELP MEEEE
- JRSC at 17PSI with Nitrous 450+ HP?!?!? WTF?
- Maybe you guys can help me
- t3/t67 where can i get one made from my greddy t67
- I'm going to boost but something sounds like its shaking in the head--(VIDEO INSIDE)
- b18b 25psi safe?????????
- if you put a turbo with a max hp of 300 hp on a 300 hp car...
- JRSC Prelude tuned at DRT, NY -- Dyno
- Base distributor timing with hondata
- Would you get this fpr or aeromotive?
- Wiseco Pistons
- where do vacuum lines go on electronic boost controller?
- B16+Hondata S200B+550CC INJ+Tuning=?
- Retorquing ARP studs, Required or not?
- t3/to4e 50/63ar or sc50?
- HELP hondata gurus?
- are Fogger Nozzle's all the same??
- Those running 2.5"+ exhaust: Safe to remove gas tank heat shield?
- ge block girdle for ls-t
- can i put my dseries turbo on a b18b???
- Turbo XS DSBC not working....
- help with crankcase/valvecover ventilation problems (high HP-setup)
- Problem with turbo civic. CONFUSED
- Will Integra ic piping work on an EK
- Downpipe Creation from stock flange/bend *PICS*
- 6 to 8 psi turbo setup correct or missing something help please ? b16a1
- i-vtec I
- what type of thermostat for boost
- Mangled Exhaust Wheel /// Grinding Turbo's /// BLING! (seriously) **PICS**
- ic piping, 2.25 or 2.5?
- WTB: Vortech Race Blow Off Valve
- Question about Greddy Profec B2
- Cam timing?
- TURBO MASTERS I NEED YOUR HELP PLEASE!!!
- Vacuum question
- Headgasket wont seal arghhh
- MegaSquirt Revisited
- Tial Wastegate
- Just got boosted, car died need help
- Gauge/Wideband Gurus. Post Info/Links -Install Tips-
- Need help searched but I cant fin it
- Read my plug?
- T4 turbo
- Look at this housing
- prelude ringlands
- welding return oil fitting
- do i need datalogging?
- Any input on NOS nozzle injectors?
- Code 43, running rich? fuel pressure too high? Need ideas
- intercooler piping routing; 5th gen prelude.
- problems w/ greddy eo1 + emanage?
- looking for chipped pm6 for sale??? anyone got one?
- whats RPM's do you guys make Peak power??
- Open Downpipe. What Are The Noise Levels Like?
- need more detail on greddy 15g kit
- D17 cam to be released mid summer of 05
- Headgasket Upgrades For High Boost?
- autometer oil temp gauge
- which boost controller
- Those w/boost controllers: How do you switch from low boost to high boost?
- Anyone running 3.5" dp?
- Quick ignition hondata related question
- GM 3BAR MAP Question
- Boost and Hondata (What ignition setup are you running?)
- Edelbrock kit MBC
- fuel pump question
- does this sound like a good deal
- weird boost problem
- need help on choosing pistons and rods and sleeving company
- What's Your Base Timing???
- Wastegate banjo fittings?
- Wastegate Size
- Emanage help!
- hooking up my water, boost and oil pres. gauge...what do you guys think of these locations?
- a nitrous scooter racing a Trans AM *Video*
- Building a catch can... where do the hoses come from?
- i'm fucking confused!!!
- *VIDEOS*...post all vids if you have them in here!!!
- where to find a filter for a t3/t67 or any turbo 4" inlet for that matter!?!?
- Need re-tuning after taking msd off car?
- downpipe ? on turbo lude
- bad to run turbo with out intercooler?
- Max hp on drag intercooler?
- T3/T4 turbo or smaller?
- hondata D16 IM gasket....will it fit y8?
- DOHC ZC turbo setup?
- Best of (aka most informative) posts of 2004
- ignition problem!?!?
- VAFC 2 Tunning/Fuel Managment???
- Intake Mani and TB sizing???'s
- Cant help but think my intercooler is too small...
- Problems with GE vaccum manifold....
- need greddy blue box wiring diagram (sohc)
- Opinions on this type of setup?!?!?!?!
- blinking zex light
- Twin Turbo: parallel or series?
- Neptune tuned dohc ZC dyno w00t!
- Quick DRAG manifold question. (stud size and pitch)
- Inline Pro Manifold Wastegate fitment?
- vtec/turbo problem
- WHAT SHOULD A TURBONETICS 57 TRIM T3 TURBO COST?
- engineeee
- Zdyne?
- h22 turbo compression
- anyone have experiences with the vortech supercharger V-5 G-trim
- will 96-00 LS greddy kits fit 94-97?
- Quick question. Tial 40mm wastegate springs.
- Newb-Turbo questions-vtec/non-vtec
