Ls turbo
Old Sep 2, 2015 | 06:57 PM
nazmul94's Avatar
Default Ls turbo
what piston rod set up would be best for a
Old Sep 2, 2015 | 07:40 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Ls turbo
<p>I have a feeling you don't know the first thing about building engines...</p><p>How do you plan on installing new rods without removing the oil pan, or mains? &nbsp;Going to replace the rods without spec'ing out new rod bearings? &nbsp;How about the hone, which is necessary? &nbsp;Or spec'ing your P2W?</p><p>Don't oversimplify it, and don't halfass it. &nbsp;Do it right, or don't do it at all.</p>
Old Sep 2, 2015 | 07:42 PM
civic-steve-94's Avatar
I did something similar to that back when I was naive. You can't just drop pistons in, unless you can magically find pistons with the correct piston to wall gap. Too tight and you'll destroy either the piston or scare the cylinder wall to hell or both. Or it will be to loose and slap really loudly and smoke like hell, and have massive blow by. Boring is not that expensive.
Old Sep 2, 2015 | 07:43 PM
boosted94gsr's Avatar
I'm gonna be nice lol. This guy used Nippon cast Pistons and eagle rods and dropped them in with the engine in the car. I'm running the Nippon Pistons with stock rods and my motor holding up to a lot of abuse. You should probably read the FAQ at the top, a lot of good info there.
Old Sep 3, 2015 | 09:07 AM
diatibe24's Avatar
X2
joiv21
Jan 15, 2013 01:58 AM
kpjo4
Mar 11, 2010 07:56 PM
SiR99
Sep 1, 2006 09:17 PM
jakscivic
Jan 13, 2006 02:48 PM
B18B1DOHC
Sep 16, 2003 10:10 PM
