View Full Version : Forced Induction
- Do i need to change my dp flange?
- Vented catch can smell
- ITR setup ?'s B18C5
- Teflon Paste for Nitrous gauge.
- clutch and flywheel?!?!
- Wiseco pistons for a D16A6?
- Which turbo do I need to make 250 whp for 12 PSI or under?
- oil and spark plug question for turbo
- Car feeling wobbly at 140- 155 mph????
- Stage 1 clutch not good enough for forced induced?
- need help...turbo project..thanks
- T3/TO4E 50 trim out of efficiency????
- some updqates on the set-up...
- What turbo to run?ON a built motor..?
- strange fuel/injector/ignition/ecu problem???
- want to trade my t4 for your t3/t4
- VF-34 (05 subaru turbo) Questions
- where is the best place 2 order a swap from
- did a search but had no luck
- turbo exhaust
- looking for h22 "official turbo h22 numbers"
- What EMS for nitrous?
- 300 goal..which turbo?
- anyone use these pumps?
- Is a retune needed??
- electronic or manual dual stage boost controller...???
- 500whp and pump gas
- This is probably a stupid question...Internal/external wastegates
- gt3076r?
- Supercharger set-ups with LHT intercooler Chime In!
- how much boost can stock heads handle?
- How to tune obd0?
- how much power can a d16z6 hold?
- can i remove this?
- noob stroker/turbo question
- tuning ???
- Quick ??? about PCV's and Turbos.
- installing 2.5 bar map sensor
- **Opinion** Turbonetics Evolution Wastegate
- Replacing Stock Rodbolts?
- Inducer question gt4294
- how safe is this.
- S2000 Turbo- Currently Comptech Supercharged
- Help with endyne breather for my turbo kit
- Lightweight flywheel with supercharger?
- RC Injector Seals Wanted!
- I searched I need info on good rods and pistons.
- switching to ram horn, how much gain?
- Anyone ever use an aftercooler for a supercharger on a turbo set-up?
- variable turbo
- Please help me inspect my spare block
- Hotter weather, harder to start turbo GSR
- clearance issues with built motor??
- video for anyone bored
- boring a b16A block?
- hoping for 275-300
- swap vs turbo
- boosted d16 with nitrous questions
- Eagle stroker kit on gsr with boost?
- where are your guages??? Pics please
- Estimated cost to push ~300whp out of a k20a3?
- easiest way to calculate turbine inlet pressure???
- Is it me? My RC injectors dont fit onto my OBD1 clips?
- f23 turbo keep the car obdII or convert to obdI
- maxxed out 57 trim....
- any hondata tuners or other in wisconsin
- B18B T3/T04E 57 trim .48 AR??
- GRM Ultimate Track Car Challenge
- new pistons and rings require a hone?
- Quick Question about Precision Injectors.
- help me find what flange this is!
- MSD pro-billet distributor,worth the money on turbo build?
- How many hp gain per # of boost? Safe boost level for a stock B18?
- Clutch (600HP)
- Innovate LC-1 wiring Diagram
- So why does everyone hate MSD?
- excuse my EXTREME noobie ignorance ...
- Best cams for turbo b16a?
- Decked blocc/shaved head = automatic cam retard ??
- maybe jumping on the bandwagon
- anybody using these ebay rods?
- looking for a deal on a turbo xs dual stage mbc
- CP Pistons: My story
- whos running a gt4088
- need help on installing a aeromotive A1000 fuel pump
- Nikasil lining/piston material
- I need some advice
- Question about compression ratios between gsr and b16 heads in turbo built block
- lsvtecturbo , let me know your opinion on my setup i want.
- Hondata S300 w/Aem Boost Solenoid
- Hondata datalogging key?
- H23 block using H22 Mahle Gold Series Pistons
- please help with idle problem after turbo timer install!!
- Where to find a spring for insider rad. hose to prevent collapsing?
- tial wastegate noise?!?
- flex section in downpipe
- need help turbo kit!!!!
- help me LAG my turbo!!!!
- what size bolts?
- Painting A Turbo Manifold
- New clutch question
- BLITZ SSBC INSTRUCTIONS
- tuning with s300 and turbo
- what kind of turbo down pipe?
- fresh built motor buring major oil...
- fuel pump wire?
- e85 winter and summer blends question?
- INTERCOOLER HELP!!!!!
- stock injectors
- Precision GT35r water lines????
- Injector "dead time"
- switching to a .75* per psi retard safe?
- SC S2k we just finished !!!
- new to honda turbo few questions
- Timing Question for the well educated?
- Supercharged s2000 question. . .
- satisfying the ricer within.....help me choose a BOV
- Project fukenricen 2.2T finally done
- To 2.0 or 2.2L Need Advice on Setup
- Gt3076R
- CR-V WITH BOOST
- cc-fab manifolds?
- 30 psi ignition timing
- Turbo kit help maybe some questions too..
- correct size hex key for tial wastegate bolts
- Does the kteller 2.5" downpipe for 15g kits work w/18g kits?
- Correct Injector Size
- Hondata Tuner Around??
- quick question.
- I NEED HELP
- help on my next setup
- Boost creep with Turbosmart MBC
- head gasket question
- best route for street/drag set up
- head gasket question (searched :(.......)
- head gasket question, searched :(...........)
- da turbo pics
- Universal Muffler Question
- Hks Turbo timer
- What's the best budget T3 turbo manifold?
- D series torque steer?
- Best fuel controller?
- oil squirter??
- EVERYONE LOOK AT THIS> stock LS 9psi 11.9@119!!!!
- Pics Of breather Kit setups
- lets talk -6an return line to stock tank
- Oil temp/press question
- b16 block guard
- S-ITC install in a B18a...!! NON V-TEC
- jackson racing supercharger issue: experts chime in please!
- deatschwerks
- Snapped t-belt replaced no power
- What gas to use?!?!?!?!? (90 integra boosted)
- blaast performance turbos???
- garrett ball bearing service program
- how about this for an idea
- H22A1 and H22A4 pistons interchangeable ?
- All motor 85m
- How Do I Get A Higher RED LINE????????????????
- Walbro In-tank vs. Inline question (surge tank application) ?
- HELP! Need phone number for VS Racing!
- GReddy Emanage????
- walbro 255hp and oem fuel lines from tank how much will it handle
- Piecing together your own kit...?
- Want to verify this turbo and need some help.
- Adding A/C to a 99/00 SI with a turbonetics blower
- going fi questions..
- CT tuning????
- gtk worth the extra$$?
- BSPT to 4AN adapter from mcmaster
- Loss of boost pressure. HKS GT-RS turbo. What's going on?
- Strong Gas Fumes in Cabin
- Nitrous H22
- AFC Required? What's the risk
- New turbo manifold for B-series
- OEM 84mm Headgasket
- b16a or gsr cams for boost?
- Turbo Opertaing Oil Pressure
- Need Opinions on Mani: Tuner Toys...
- Fuel line question, what's the advantage of SS lines?
- MY LS TURBO SETUP
- oil pressure - only reaching 50 psi at wot
- How does a MBC work?
- When your clutch slips, does it smell?
- New record- 442whp/323tq on the Vitara's!
- better injector
- its decided, im using oval piping on my down pipe and b-pipe
- New to F/I, couple of questions
- Recirculated BOVs / blow off valves and my sleeper setup plans.
- e85 or c16?
- Cam Comparison as well as new pump gas numbers...
- Downpipes.
- Sleeved blocks.
- turbonetics or garrett t3/to4e 57trim
- 84.5 mm sleeves and 84.5mm combustion chambers what compression??
- finally got some pulls onthe street at 25 psi vid :)
- B20B with a T28 at 14psi???
- H23 Turbo setup? can any1 help me?
- Whats will stock sleeves handle to a turbo built motor???
- Gear dependent boost, only way to achieve this is via a boost controller? (Apexi AVC-R)
- i have a question
- turbo and bov vacuum question
- big cams plus maybe nitrous
- Help Needed with Fuel Pressure Regulator, Fuel Pump & Fuel injector choices?
- Noob question (i searched); Do I need a weld on flange for the HKS SSQV?
- Can i hit 280whp and is it even worth it to do so?
- finally going forced induced but need suggestions(yes a noob to this?)
- 82mm safe for boost?
- Quick question; Tial Wastegate 38mm what spring to run?
- SSAC wastegate failure?
- Will car run correctly after part out?
- BOV setup HELP!!!! Vacuum source???
- Backdoor Intercooler Setups.. Post them up!!
- Head!?
- Turbo + colder plugs
- expeced numbers?
- superchargers: vortec vs. jackson racing
- searched and search and searched, AFC hack
- thinking of a new setup
- Anyone ever buy piping from these guys?...
- Turbo teg wont start after putting gas in it?!?!
- port match intake manifold?
- ek wont rev past 4500rpm when i floor it?????
- My Custom Gauge Cluster
- will a gsr .bin work with an ls vtec? or what shuold i use as a base?
- PLX R-500 R-300 ? Tuning question
- Boost creep Problem!
- Anyone using polyurethane tubing & quick push fittings?? Wastegate, Vac Lines??
- Top Mount Turbo..?
- another turbo question...
- 15psi of Booste into an engine?????
- sc61 question for all you pros out there.
- want to know whats a beter motor to boost
- Sean, Louisville, KY
- Compressor outlet and piping clearance problem
- help my car wont go anywhere drivetrain problem pls help
- What 4 bolt flange do i need?
- whats the fuel psi that i should be running?
- Clutch and Flywheel choice, cheapo XTD (ebay special) or $600 Brand Name?
- Ross Racing pistons
- BOV
- 342hp/308tq Stock Ls Dyno
- TURBO MADNESS!!!
- How many ditched the PS fluid cooler?
- question, i searched, dont rip me appart
- questions, and i searched
- ATS LSD USERS?
- simple question, help gain power or lose it?
- Oil on a spark plug
- FMU???????
