View Full Version : Forced Induction
- T3 from Volvo? What's the trim?
- Is it possible to pass emissions turboed?
- can i make 300+whp with a jrsc and nitrous?
- new ls/vtec -smoke from breather?
- EGT - Do i really need it ?
- Went to autozone to buy a 3 bar map sensor i need the part ##
- Another Oil Question, Should I Be Worried??
- Self-Learning EMS? Is there such a thing? Why not?
- What kind of turbo is this? (I've searched)
- PLUGS
- Crx Turbo radiator
- Greddy Type S BOV sound when i didnt even BOOST!
- help with b16b
- NGK 7's still fine for my 22-24lbs of boost?
- Hesitation at light throttle
- o2 Simulator Question
- Oil Line feed question
- Bad idea to turbo a high mileage D16?
- psi for the ls
- CHECK VALVES
- A/F Goes fat during shifting
- Got a victor x maniofld what did yurs come with ?? Mine isn't complete + any install woes?
- boost controller question
- Battery relocation.....
- Queston about clutch and flywheel for turbo D15b vtec.
- Anyone have JRC 8inch on EF??
- 9psi Integra on 15g turbo???
- Spark plugs for turbo setup
- GSR and LS Motor: IC Piping the same?
- intercooler mounting...
- 2 LS/VTEC questions
- Oli cooled only turbo - who drives one?! experiences
- LS Vtec turbo or LS turbo
- Best D-series Engine to turbo? Please Help!
- GLOWING RED!!!!!!!
- Wiring gauge power to dimmer?
- ls vtec turbo hold boost?
- turbo+ sti exhaust
- cleaning a turbo???
- d15b vtec engine
- Hondata support 1600cc injectors?
- E-Cutouts and O2 sensor placement on your Downpipe?
- boost question?
- Turbo 92 HB
- Wastegate flange welded onto hf manifold?
- What cams with Jackson?
- sleeving a k20...
- 14b Setup Pictures
- Ive come to a crossroads.. Turbo or Supercharged?
- Stock Injectors
- Question for the expert
- GT30R Retune
- Will this be good?
- question about b18b turbo
- Fueling problem...need an expert...turbocharged car.
- Lower Vacuum reading after new motor install.
- will a 2001 honda odysee handle 5-6 psi?
- !!!! MASE is coming to Minnesota!!!
- Question all...
- Mase-A-Pooloza Tuning Bash Episode 3 Return of the Stif Nor-cal and So-Cal (RESULTS)
- Nippon racing pistons? (D16z6)
- Tuners: What are the MINIMUM laptop system requirements to run Uberdata?
- LS turbo and engine rebuild Q's
- Can you tell me what type of turbo this is?
- Need San Jose Area tunner
- Exedy organic clutch kit with greddy turbo gsr
- Hondata & 5 bar map sensor
- turbo kit for a ek motor
- Any one tried Direct Hits?
- help!! coolant in oil.....
- Quick question about turbos and backpressure
- Helicoil/timecert
- what about this turbo manifold...?
- Tial WG Gasket Template
- missing link instead of 3 bar map sensor
- Lowering VTEC, going even lower
- is it possible to pass smog built, boosted, and on AEM EMS?
- 3 bar GM map sensor trouble
- Anyone use SRM Rods???
- DONT LIKE MY DIFF
- race gas timing on my sohc
- 38mm wastegate onto a 35mm flange?
- ?'s on ext wg
- Straight t3 on a b16a. (.48/ 60 trim) will it pull till redline?
- WTF is up with my Turbo?
- Best place to buy engine building parts.
- Turbo Honda + road racing = ???
- AEM EMS : Need help with accel fuel
- Turbo vtec issues
- Who lives in Miami FL that knows tuning the ECu b/c I have no clue.
- torque curves related to hp output, and turbo size.....(300whp+)?
- anyone in socal know how to tune with turbo edit?
- who's not running a flexpipe on your FI exhaust.?
- who sells civic turbo+fmic piping kits on HT?
- AEM Forums
- Greddy Profec B Spec 2, Boost goes back and forth between 5.5-6.5, what to adjust?
- will this turbo fit honda?
- Unberdata tuner near pittsburgh area?
- best way to install a BOV flange on IC piping?
- Clutch/LSD help please (Art, Tony, Jason, Stan, Brain, etc.)
- Off brand bov's
- B16 400-450WHP, what manifold type?
- sohc vs dohc
- built sohc?
- smaller turbo???
- SOHC Turbo People. What manifold are you using?
- LSturbo problems
- Greddy Turbo Timer Instructions in English???
- pcv routing? open pcv valve with out vacuum?
- timing
- let it sit for a while/ tap the gas and it puffs smoke
- Another Turbo Integra Done... Tuned By Church (Go away 56K)
- How to build a cheap turbo oil feed and return kit.
- Removed PCV, Now Poor Fuel Economy
- Is it time to upgrade the injectors?
- Opinions on building my engine for boost/turbo
- What clutch you guys recommend for turbo gsr's running on stock 7 psi???
- FPR-pressure not lowering
- air/fuel gauge installation over heating problem help!!!
- Where to get 4 inch to 3 inch transition pipe
- what manifold for EVO VIII 16g?
- Ls Turbo "trouble"
- pics of your turbo setup with ac
- SMS turbo
- OT but turbo related
- 2.5bar map sensor
- Boost gauge reacting slow?????????
- Catalytic Converter Help!!!
- Turbo smart dual stage boost controller, how is it?
- Turbo timer suggestions?
- Sizing TB.
- Running BOV stright out of Intercooler???????????????????????????
- Greddy's oil line questions?
- wesco pistons
- What size turbo??
- Random blown headgasket?? scratching my head. any idea's?
- EGT Gauge - Brand, fitting and placement questions.
- post uberdata install question?
- OK HONDATA Tuners What do i need to do my own tunning I have a stage 2BD
- is it stripped?
- Downpipe Dyno Charts - Power difference between SIZE
- ((((((((((((( I NEED WIRING DIAG FOR BLUE BOX FOR MY EK))))))))))))
- where to get Techedge 1.0 cable for O2 sensor??
- Dynoed yesterday, Stock B16 - 206whp / 167lb/ft @ 6.5psi
- ARP Headstuds for D16Z
- ? on wastegate clearance
- HELP...is this turbo kit any good???
- Installing OIL PSI Gauge. Hows this setup look?
- Please help need tuner in NY
- $hit on my radiator cap
- fuel with supercharger
- GT3767E anyone experice with these??
- volt/multimeter wideband question.
- street tuned finally!!! tune done by Trick Engineering in NH... great service!
- 3 inch electric SLIDING cutout question.
- h22 turbo manifold
- people with oem LSDs be careful out there
- JRSC vaccuum???? is this correct on the gauge????
- running boost on ITR block with GSR head
- what is a step or two colder than the ngk bkr7e-11 ??? p/n?
- Precision H Housing....?????
- whos running the turbosmart e-boost controller?
- Mase does UK!
- Turbo cams
- Stock LS Turbo vs Stock D series Turbo. What are differences other than Torque
- ls spark plugs
- Goodbye Weisco pistons....
- Spark plug gap?
- HELP - MD AREA - NEED TURBO TO MANI GASKET FOR T3/T4 TODAY!!!
- T3/T04E only oil cooled? any alternative?
- Dynomax VS. Magnaflow
- Best place to get a 3inch downpipe?
- Which Data Logging cable do you prefer?
- recirculatory valve????
- OČ Trim in boost!!! Tuners: Please Help!!!
- drag turbo is install
- dsm injectors
- Is this stuff needed for for a turbo GSR motor (B18c1)
- weird wg problem advice needed
- Pulling teeth....
- WG with Minime mani?
- What Boost can I hold with this setup?
- strange problem please look!!
- Just boosted integr and wants to tune
- OEM D series Pistons and rods for forced induction?
- D15B8 questions!!!
- Noob Question :)
- diffrent Hg to raise compression with a built motor?
- Wastegate vacuum line
- quick injector question for boost
- Stock B16 turbo (Searched)
- Why is it that some turbo kits out there don't require ECU changes?
- problem with sleathmode injectors
- Quick charge pipe and vacuum question
- black shit coming out from my exhaust??
- how would i run a 3"flexpipe?
- Additional evacuation port?? How about engine oil filler cap.. (Pics inside)
- 10 sec run
- Need help decidin which intercooler to go with!!!
- where to buy magnetic oil drain plug?
- How to quiet tanabe exhaust without using silencer tip?
- ppl with the magnetic oil drain plug
- Ls turbo
- Cam timing issue
- share with us picutre of your internal wastgate DP's
- please check out my longblock
- Question on timing and knock sensor
- Please help me pick out a set of rods and piston!!!
- quick question about neptune...and any EMS
- Another oil drain question....
- Intercooler mounting?
- Looking for Blairsville, PA Wyotechers
- One-Fab or Neukin top mount?
- Compression test #'s
- gt30R on a build h22?????
- 2nd gen integra turbo project????
- Trying to figure out if I would want to go the route of a turbo charger.
- Who runs 10psi or more on the stock D-series?
- Anyone dealt with tdc tuning?
- Problems w/ E-Manage/Profec E-01 and car...
- About ready to get started a JRSC install.
- What are the risks for building a turbo for a HS student?
- How "Plug-n-Play" is Greddy's E-Manage???
- T3/67 vs t3/67 H.O.
- looking for info on Ostrich
- anyone using a venom IM or similar box plenum?
- AC or No AC For you FI guys!
- D16z6 with greddy kit, running lean...need info
- Tony1 + NEPTUNE=571whp& 424trq
- blox gsr mani worth having for turbo setup?
- loud ticking...
- turbo?
- turbo ???
- inlinepro mani for h series?
- t3 turbo .60/.48 airesearc crack?
- Greddy Air/Fuel Warning gauge accurate?
- What should I do????
- orange spark plug?
- Need final help on build up, bullfrog head package and piston to cylinder wall clearance
- please look at my rod bearings ,
- Can someone explain how a diff wastegate spring makes a diff?
- Anyone have a boosted JDM GSR??
- zex box needed to be programed
- Built motor, Piston slap, random noises, blowby, paranoia ensues...
- Boost question
- Need filter for 4" turbo, uni-filter?
- comments/suggestions needed
- wastegate size?
- How Lean is Too Lean?
- Which pressure plate model is this? (ACT)
