ID725 install, B18B, which intake cushions should I use?
Brand new set of ID725cc injectors, installing in a bone stock B18B intake manifold/fuel rail.
Which intake manifold gaskets (cushions) did you keep? There is one thinner, and one thicker on the stock manifold where the injector pushes into the intake manifold boss.
I"m not talking about the o-rings on the injectors (for reference).
Thanks!!
Thanks!!
Re: ID725 install, B18B, which intake cushions should I use?
Whatever fits and seals the injector into the intake boss correctly. You can space the fuel rail accordingly after that.
