View Full Version : Forced Induction
- So where can I order a brand new deltagate online?, (from a reputable store).
- wastegate question
- Your time on Turboed D16/D15????
- Damn pressure leaks...
- blowing out spark, how do you know
- question about header wrap
- Pics: JRSC rebuild
- HILARIOUS. Anyone that hasn't seen this Civic on ebay must check it out.
- A long wait (Full Race)
- DEFI D-Guage Boost Guage Question
- New Turbo On, A Few Questions
- dyno'd car, sheet not up yet.. it's fun. :)
- Another LS - GSR thread..
- Is this Blow by, If so why
- Who ever said b16's were useless? / Stock b16 / Precision sc63 / Full-Race / 11psi / Hatch / 12.4@11
- Drag mani...how many Hp??
- SOHC and DOHC Greddy blue box the same?
- this a good first step in custom kit? please give advice
- INTERCOOLERS - Bar and Plate VS. Tube and Fin
- do not read!
- What is the procedure for checking for turbo shaft play???
- help! code 13
- Is a High priced EMS Necessary
- Damn I Suck at Welding.... :( But I'm learning...
- I'm New. what does t3/t4 etc. mean
- fuel probs with h22/turbo(very intresting so read it)
- vacuum readings and compression test results inside -- please help critique
- need help with injectors
- Turbo mini me question??
- Can someone send me the Uberdata 800x600 version?
- a Friends EDM Fiesta turbo project
- To The SSAUTOCHROME B-series Manifolds Users
- who makes cheap turbo manifolds for dseries with custom flanges
- what kind of OIL??
- What do you think about this turbo and manifold
- Where in Port st lucie Florida would I Get race gas
- ? for you 500whp guy
- LSVtec? Turbo or not to turbo
- My Greddy Profec B spec 2 review
- facts about what really happens?
- Turbo Sizing and Hondata Tuners in the D/FW Area
- greddy manifold
- valve adjustment
- How are Crower rods numbered?
- 11.5:1 GSR... would you boost it ?
- is there anyone using a vortech super fmu with an aftermarket fpr
- Which Kit (once again)
- which precision turbo is this - pics inside
- Anyone want to socket my ecu ?
- Vafc QUestion
- Internals for b18b?
- Nos!!
- going turbo
- symptoms, help me figure out what is wrong
- HT Meet Angie!!!
- what should I gap my spark plugs to?
- How well is a welded cast manifold going to hold up
- put a filter on my BOV, now the oil from the k&n shit blasted everywhere?
- best clutch for 400whp?
- sputtering turbo integra
- Turbo NSX V-6 dropped in CRX
- Very Slow spooling T3. Opinions?????
- I need to tune my car.....where to go?
- What Turbo Kit?
- jackson racing fuel pump what injectors?
- Blow off valve for JRSC
- This is for us Turbo cars and to match up what we can demolish
- b16 w/m ls trans
- When can't you re-build a block?
- Which FPR do I need?
- Turbo LS project Q's??
- holy insanity at the track tonite... major issues omghi2u!!1 help!1
- greddy 92-95 civic turbo kit on 98 civic dx hatch (help)
- Safe to Go turbo on 100k miles on 95 gsr?!
- looks like Edelbrock copied me.. :|
- What kind of gains can you see w/o running a turbo filter (track use)
- accel wires with msd and turbo
- How does this sound for a SET-UP?
- NEED HELP WITH OIL RETURN!
- Turbo LS clutch
- ferrea valve train and boost??
- For people that use 60-1's and bigger
- B series tranny problem (snap ring)
- Can someone please answer my fuel management question?
- Who build the best sleeved block? - Post your stories, both good and bad
- where is the plug for the scanner located at
- Fixable manifold?
- HOSTED! dyno inside 56k beware!!
- Turbo CFM
- What cheap turbo can I use for now???? Mistu what?
- best turbo for d16a1 zc
- Sleeving opinions and GE block guard experience request
- compression test problems, please help
- tune shop in n.j.
- anyone record their A/F while running greddy blue box on sohc?
- Boost'n 2 Much **HELP**
- My photos from the Battle @ Joliet last weekend
- please help wierd sound in turbo block
- ecu q's
- PG7 or PM6 ecu better for turbo D15b2???
- Where can i buy this air filter?
- i think i messed sh*t up * sohc turbo *
- cryo treated
- how much boost can i run almost stock b16?
- 99.9% complete...Just waitin on my Full-Race IC...=)
- Difference between DSm injectors and rc injectors used on INtegra and Civic
- F-max kits--How good are they?
- hondata
- V-AFC vs S-AFC? -- AFC hack ?
- Need 4 inch filter
- Exhaust in NJ
- ::Went to Dyno last night 274.1whp & 213 tq @ 9-10psi ::stock motor::
- Stock for stock,which is the most reliable boosted b-series?
- oil coating je pistons
- swift-performance.com for intercooler piping
- Turbo spec help
- turbo exhaust manifold
- What to add to accompany 8 psi?
- Opinion on this turbo:
- Detonation or bad rattle not sure....help!
- semi stripped oil pressure hole!! what are my options
- Advanced wideband tuning question.
- What's the deal with Greddy and no 94-95 Turbo kit?
- Is this setup even necessary to tune?
- turbonetics 5 bolt housing is not same as garret 5 bolt? DAMN!
- does anyone here have the "G" sensor accessory for thier hondata????
- gazzilionth Hondata problem...
- Jim Fab Bars mounting question.
- Need some help getting ready for a track event
- Anyone in Western NY have Honda Engine Bearings?
- o2 sensor placement ?'s...
- what is the best electronic boost controller
- Full-Race AC compatible turbo kit (almost completed)
- 5the gear
- adjusting fuel pressure
- Anyone run an MSD inline fuel pump?
- need help what size injectors for my setup
- :: is it possible to use the jrsc water injection kit with turbo applications? ::
- i need an experts help please!!!
- cel...help!
- Help me pick a turbo plzz!
- Differing BOOST (spikes on dyno)*( steady on the street??)
- ls/vtec turbo in crx
- to post or blockgaurd
- What would I need to make this setup work?
- boost with stock internals
- What's your fuel pressure ???
- I think I'm going to give up...(somewhat OT/long)
- Engine flange for D serie to made a turbo manifold
- 440cc injectors to big?
- turbo problems please help
- Just ordered my LOVEFAB manifold!
- Fuel system question....
- should i bore my mani???????
- Suspension for Drag
- <Rod lengths, crank stroke, piston size, and sleeves?
- looking for advice for b18c hf CRX
- do acl bearings work with probe rods like they do with eagle?
- what are sheet metal intakes made of?
- 390cc dsm injectors/civic????????????
- Bad to run w/out O2 Sensor Plugged in?
- 550cc Fuel injectors question
- help with drag specs.
- New motor = back from machine shop... 20psi, here i come
- New Mickey Thompson 24.5x8x13 Slicks
- what injectors to use for 500whp??
- No cat = smelling exhaust a lot more
- Proper way to install block guard?
- CheapTurbo.com End of Summer T3/TO4E Special!
- BAR into PSI
- VERY Noob Question, but new to boost
- Does the whistling from the turbo come out of the intake filter?
- Turbo Maintenance
- injectors for sale
- ECU Fryed
- Need a turbo recommendation.
- Oil return flange.. questions..
- Leak coming from threads of Oil Pressure Sender.. help!
- dyno tuned (chart inside)
- boost gauge accuracy
- What 2 use to repair PLASTIC/abs for engine parts, jb weld??? crazy glue?
- Intercooler piping...
- what the highest WG spring for a 35mm tial?
- Question about engine build and sleeves
- How to tune off a/f gauge and VAFC
- ... kinda OT... any car shipping recommendations?...
- Help with synchros from 2 different trannies
- Some serious HP from Japan!
- strange wierd, cool down noise
- electronics for a turbo
- HELP!!! i need the advice of experienced engine builders...ring gap question..
- SEMINAR ATTENDEES PLEASE READ
- Back from the dyno GAYNESS
- ouch, this happend to my axle.
- Greddy EGT thread pitch
- 91->100 octane retune?
- b18c to 2.0
- hondata boost cut... ouch
- Garret GT28 on D16Y8....OPINIONS WANTED
- greddy turbo ep3 question
- zex kit for H23
- Fuel Pressure Q
- Exospeed problem =(
- rin gap install problem
- Intake air temp for 99si with boost.
- Bluish white smoke coming from tailpipe under boost..... Does "Restore" work?
- Smoke from breather from valve cover
- More accurate??
- Tuning Timing
- quick manifold question...
- ok to only get a boost gauge instead of boost/vac
- Nopi Nationals roll call: post pics
- such a thing as a quiet 3 inch exhaust?
- open deck VS closed deck
- For those of you who weld....
- 5000km, running real rich.. bad for motor?
- Anyone using a techedge 1.5 and AEM EMS?
- just did piston install, someone double check me!!
- help: Jackson Racing Pulley
- Where to buy wastegate spring at
- stripped the worst threads you could ever strip. doh! what do I do?
- aem cold air on jr supercharger?
- Vacuum line size? BOV, Wastegate, etc.
- DC2 GSR w/ turbo-overheating--radiator suggestions
- need a little help.
- Slightly OT: Takata harnesses,... where?
- cant boost more than 5 pounds? help!!
- Some Pics of New Big size Precision IC and Full-Race manifold...56k beware
- Is this blockguard ok for my D16?
- $1000 of coupon for Jackson RAcing Supercharger!
- map sensor necessary on 2001 civic?
- Scammer alert , does anyone know this engine bay?
- finally boosted tonight, but got some problems...
- Profec B Spec II setup help pls
- Need dyno number comparison on GSR-turbo at 11-12psi...
- will this setup be ok for a t3/t04 garrett turbo setup
- Aem ems, 3bar needed?
- ls/vtec turbo in crx....
- killed a probe gt
- VID--turboB20 vs. lt1 w/ 150shot
- Pre-Turbo Questions
- Arturbo is my hero...
- thinkign of turbo
- best bov?
- what exactly does building a turbo head do?
- Attn LS owners with Drag kits....Please post 1/4 times, dynocharts, etc.
- best tranny for turbo??(sohc)
- t4 manifold , t3 turbo how can i mate together???
- apexi BOV
- B16a, ZEX 75 shot.....looking for anti BOOM....
