View Full Version : Forced Induction
- quick question:Are Talon injectors the same as...
- Does this guy and car look familiar?
- Sound of your car with turbo and Thermal 3"
- ITR LSD...how strong is it?
- show your dyno plot
- i've had my turbo in ~1 week now....
- Drag Radials
- need advice on setup
- up grade my turbo
- car alarm with built in turbo timer functions...
- Boosted Tranny.....
- anybody with a lighten flywheel that has turbo???
- DOES ANYONE KNOW HOW A HONDA COMPUTER WORKS?
- HKS dump tube needed
- 98 GSR turbo or 98 LS/vtech turbo
- ENDYN
- Anyone have Spearco air-water intercooler?
- WHAT ARE THESE CODES ANYBODY?
- Been boostin for over 1000 miles now....how do my plugs look?
- Another fine car bites the dust.....
- Prelude Turbo...need help
- what are the limits of Endyne Rollerwave pistons?
- custom turbo exhaust?? need advice...
- A few problems I hope you can help with...
- Car's Hesitant
- f-max and hondata
- turbo timers and alarms
- 2g DSM injectors (zdyne boostite seals)
- what are good cams to run w/ this setup for more hp
- Fuel Setup problem?
- sohc boosted owners! spark plug question
- stock ignition?
- Can I use low CR GSR pistons in an LS?
- JR supercharger-need help
- Adjusting the fuel pressure with my setup.
- FI Build up. What to think about.
- Interested?????
- b20b or b20z??
- OK, I've got a Z-Dyne ECU, and 550CC injectors for a DSM from Venom... Should I be using a resistor
- To those who think Turbo + Vtec = No good...answer me this
- Pictures from my build up
- Good info about injectors ( by sonny van hook)
- I have done it
- things i should have added when i did my rebuild????
- Anyone need a Profec B remote?
- if you have a drag III for sohc and swap to B series, can u use the turbo by changing the manifold o
- Downpipe ????
- question and comment
- f-max downpipe hole
- ATTN: those with 84.5 mm sleeves
- NEW JOB FOR ME (turbo related)!!
- Turbo acts weird
- built LS vs. built GSR
- For all you guys who want the turbo sound wthout the feel!!!!
- spark plug gap on turbo teg
- Looking for good Turbo Books
- Brand new TURBOS ??? Mitsubishi 360CFM
- DSM Injectors for Hondas?
- price to start initial turbo project
- REVHARD TURBO KIT NOTHIN BUT CHECK ENGINE LITES HELP?
- Goodbye Homemade Turbo Setup.. New Setup (PICS)
- Help changing oil feed line, pressure reducer, T's off of the block, etc
- B20/vtec with 10lbs of boost?
- Oil return line, I made a mistake..
- diff between squential and normal BOV's???
- ANY Turbo G2 Tegs ??????????
- how much did the L/S Tranny help your quater mile time on a b16/drag3 setup
- where do buy brass T for oil feed line for turbo
- Fuel pressure weird w/setup, little boggy then feels like ass. PLEASE help
- turbo with cams....
- What turbo you running?
- Where to Buy Aluminum Piping...
- What for better traction?
- Wanna go custom, quick question?
- Can I hancle 310cc injectors?
- Slow settling idle.....normal?
- Pre-turbo tune up
- Inline pump ?
- muffler shop maid 3" exhaust?
- carsound cat question...
- Hi-Tech Turbo kit... I've heard rumours
- Zex Nitrous Kit Questions...
- ACT clutch question: on B18C5 with 100shot NOS
- need some clarification (Licsense plate ideas)
- Charge Pipe Diameters?? which size is reccomended?
- DRAG III kit question
- pilot bearing removal
- tial wastegate spring color codes
- Trying to save some money, I came up with good idea.
- turbocharger or a supercharger on a 96 del sol b18c1 or b18c5
- Hondata stage 1B???
- KKK K26 is this a good turbo?
- FS: 88-89 Integra ECU
- **TURBO WITH STOCK AUTO B16 CAMS?**
- ZC Boost Question
- What is Turbosmarts web address?
- my SFP turbo manifold for the h22a plus extras
- off topic, but not really, funny though :)
- Turbo and smog test
- Advice on motor build-up ?
- Help me out with some pics....
- Oh man......spun a bearing!!
- bypassed coolant lines... what about the 3 wire plug?
- Where can I find good Iron Sleeves for my JE Pistons?
- New Drag III intercooler piping, manifold, and deltagate
- Fans again
- Drag III on D16Z6
- 92 hb ls turbo temp ?????
- What do cam gears do to increase/decrease detonation?
- SOHC turbo drivers?
- how long did it take to save up for your turbos?
- WTB: HKS Wastegate
- Golden Eagle Groupbuy
- fuel pressure at idle
- Who runs a 60-1 on a ls (likes/dislikes)?
- Compression Test on my 97 GSR
- ZC Compression maxxxxxx..... HELP
- Since some peeps know him on this board .. I'm still being ripped off
- any of you guys selling a missing map link ?
- Nissan Skyline Turbo AWD on Ebay!
- looking for a how-to make a BC web site
- compression question?
- Bosch Injectors
- I think i've been scammed. help please?
- Anyone want my FAL fans?
- some IMPORTANT questions to DRAG III users
- Best Trans for a Gsr with Turbo?
- To tune my car... what do I need?
- vacuum at idle
- Will 60-1 turbo clear AC on teg?
- 2001 GSR W/ DC 4/2/1 Header & Type R Exhaust... Good for JRSC?
- 40 over pistons too big?
- break in a must?
- vented Imoto hood need pins?
- Check out these BIG ASS Turbos on this Skyline motor
- Vortech FMU broken?
- How tough to pull off 13.0's??
- did search and conflicting answers on breaking in engine with boost
- better sounding exhaust
- fmu diaphram
- I have done everything to ensure I dont boost spike, but im still spiking..
- Need Help picking out a clutch!!
- FS: New T3/T4E Turbo and Drag lll Downpipe
- Anyone Turboed hondas from the bay are go to CMI on 1/13/02?
- I was interested in JG Engine Dynamics, but now...
- DSM injectors in a GSR manifold..
- inline fuel pump better or worse????
- Change my turbo?
- what kind of hp can i expect from a dragII on 91 rs/ls
- how hard is it to switch the psi levels? everyone talks about running this psi and that psi, is ther
- quick ?,whats the thread size of the oil feed port on my t3/t4?
- help running really rich
- Why does my boost level rise slowly at WOT?
- im getting turbo...what should i be doing for mods?
- lap-top program for power fc
- turbo (2) - 5th gear/reverse (0)
- Trading something unique for something more unique......
- Anyone have a spare high press. inline fuel pump?
- lsturbo +gsr oil pump?
- Tial wastegate help..
- DIY Boost control...
- Vtec modification for turbocharged cars... worth it? >Tech<
- Im getting my AEM EMS tomorrow!
- Idle with 370cc injectors?
- polished ports on my head
- Drag I/C Piping
- automatic + turbo anyone?
- Engine runs rough at Idle, Possibly the Ambient Air Temp sensor placement? HELP??
- from exp 90-93 turbo tegs, what kit is best for the application? and what ones have you guys used.
- very wierd problem running lean
- steam cleaning engine
- 92-95 Prelude Custom Turbo Manifold
- High temp paint
- damn good turbo question
- Fmax Turbo Kit
- CRX turbo kit-custom made and need advice please....
- tdo5-14b
- DRaG3 turbo kit..FMU, fuel pump and boost gauge check..
- Suspension Set-ups
- JE pistons, what cr specs are out there?
- Is this normal..?
- Question on HKS Racing BOV (0ld type)
- # of injectors?
- installing new injectors need help please.
- drag III b20
- Need help on major decision for the car please!
- Few questions after working on my f-max all weekend
- What kind of turbos do Volvos come with?
- 550cc...how much boost is good for?
- O2 bung for OBD1 "test pipe"
- Anybody need a Profec B?
- Anyone in/near Marietta, GA?
- which radiator?
- more help with power fc
- ANYONE USING CROWER 401s? Please give me opinions on this setup<------------
- Driveshaft noises
- Greddy Kit on B18b
- Downpipe
- b20 turbo
- what is the turbo kit FFgeoff selling equal too?
- Finally in, some more newbie questions
- Hondata with boost installation: Do you have to remove all check valves?
- quick question....
- 3" custom piping in MD/VA/DC area anyone?????
- drag3+greddy evo+stock cat or Drag3+testpipe+greddy evo????
- 2002 Tokyo Auto Salon
- sohc vortech sc?
- friends new motor for his e 320
- what kind of rods should i get?
- Turbo/Supercharge my SOHC?
- Assuming I want a sleeved block....
- wtb TURBO PARTS! whatcha got ?
- is there a turbo for an acura tl or cl?
- Jackson racing Supercharger for all you delsol or Civic Si owners!
- Liquid to air intercoolers??
- Attn. LS crower cam users
- new to the world of turbos
- FMU for a 2000 DX
- A/C & Turbo
- Is there any pressure coming from the oil return line in the turbo?
- WTB: IG DSM BOV
- Where to get stonger sleeves?
- Critique and Criticize my setup PLEASE!
- f-max manifold fitment problems
- Hamsters vs. Ferrits for my gsr.
- Nitrous techs? Head work or bottom end work...
- supercharger ot turbo.......................wich way to go
- Headgasket vs. pistons and rods...
- New injectors and fmu recalibrate.
- greddy blue box ques
- Max Rev manifold + fans.. ??
- Boost gauge?
- Max Rev turbo kits
- What fuel?
- car doesnt boost anymore
- New Times...dissapointed
- What car should I buy now?
- 7.5psi in 2nd and 3rd, but 9psi in first.. why?
- hks racing bov quetion
- Can I replace an OEM relay w/ a normal Bosch relay?
- Black smoke when downshifting
- greddy TT Blue wire hookup....help please
- What beside this do I need for 300whp on ITR
- Car is in tuner hands now.
- Drag Gen II on stock D16Z6
- FS: Tial 40mm and bov
- Pro/Con of BOV mounted BEFORE or AFTER IC....
- 81mm vs 83mm
- What race gas do you use?
- info:swap injectors 450 blue dsm 1gen for zcturbo?
