View Full Version : Forced Induction
- Driving with no exhaust/downpipe
- 270 duration cam too much for Nitrous?
- ATS carbon clutch and LSD, anyone?
- O/T Oil pres. gauge on a SR20DET
- autometer a/f gauge
- b16a2 or ls/vtec
- "spiky" a/f
- 3 broke pistons!!!
- What kind of BOV does AROSPEED use??
- Exh. Turbo Manifold poll VOTE HERE***
- Anyone with expereince or opinion of the nitrous express Ntercooler
- Biting the bullet for an install. How bad will it hurt?
- California people and smog...
- h23 question.
- some ?'s about headwork and fi engines
- What kinda power are you guys making with Full Races T3/T67?
- best sleeves for nitrous, turbo
- NEED HELP: Turbo kit recommendation
- What shop to use in MD, DC, Nova area??
- Help me decide
- how much boost can a stock gsr block with forged internals handle
- Meng/Spark/OBX/etc Manifold Tech:
- Charge Pipe??
- pics of tial wg
- Turbo for a GSR on a LS?
- Fluctuating RPM problem
- anyone running the spark/obx-r/ebay mani that hasn't crapped out yet?
- b16a2 turbo
- someone, guess my CR.
- Does anyone have a hookup on RC injectors?
- What size is the Greddy Type 31 intercooler??
- WBo2 Narrow band o2 sim-------where should I tap on the harness?
- I want your input
- sleeve posting/pinning?
- chipped ecu---do you need to disconnect the battery when you change chips or swap out the ecu?
- Pics of My new motor and turbo setup.
- Who is copying who?
- Flywheel with boost?
- Anyone talk to Blake recently? :S
- boost leak question
- uberdata-------cel-------can't pull code--------revlimit at ~3500
- more boost or high comp
- Just measured my "83mm" bore GE block
- what should i expect with this setup......(hp ,tq,1/4 mi...)
- HELP!! My wastegate is so annoying!
- What size injectors?
- I'm going to sleeve my ZC block in a couple of months...need some options...
- need tuning advice. just got a wideband and safc (B16T)
- motec adl
- scoop on the poop
- Injector tech
- starting turbo for first time... smoke???
- sleeving the block
- Turbo LS? and Stock LSD?
- where to get an ECU chipped???
- Max power with built B16a motor, hondata S200 and 450cc injectors??
- Looking For Colorado Uberdata Users
- raising the compression
- Anyone have or know about JRSC 90-93 LS?
- tial wastegate?
- T3/T04e Vs SC61
- Direct port Nozzle system for B16 Help????
- screen as a filter for turbo????
- help needed: idling problems with my b18c
- For the guys using a rubber hose and clamps for oil return...
- Boosted Si in the works
- How much does it cost to fix stripped head bolts?
- Tech Tip : Oil feed for gauges, sensors, turbochargers and head swaps...
- What is piston slap?
- Max Rev BOV question
- My Turbo Prelude on eBay
- Tuning MRL 2 injector controller?
- How much Headwork should be done??
- a few ? about b18a turbo
- WTKA: Nitrous and High Compression
- dsm 450cc injector pintle cap GONE... wtf
- GSR turbo setups please (stock internals)
- Turbo Specs??
- Turbo Kit Question
- what does too small exhaust feel like?
- what is the ignition of choice from those that turbo charged?
- what and hwere to get a great air filter??
- Sizing the right turbo for my b17a.
- nitrous users!...help me out
- Joined the 11 second club... video inside!
- What T3/T4 comes with the non-vtec d16 drag3 kit? searched and no luck
- where to mount nos and purge switch?
- Just finished turbo setup on B16
- which turbo is better
- What all do I need to tune Hondata?
- lovefab
- Honda Connecting Rods Crower or Eagle?
- for people with ls turbo
- hesitation problem
- Who's had turbo on their daily driven car the longest?
- n20 for my all motor setup???
- wat is going wrong.. rpm wont get pass 6K without jerking
- Pistons
- skunk2 d series intake mani
- what type of flywheel to use on a turbo car with 500+ wheel hp?
- 1.5/1.6 SOHC Turbo guys...I need help setting timing!
- sleving block what compresion pistons?
- Will tial 35mm springs work in 38mm wg's?
- Endyn's famous supercharger (His EF civic) **video**
- I think i found my jrsc problem
- What Size turbo for 2.0 gsr?
- Anyone with a boosted b16 pulling 125 traps? more or less
- Boost Noobie
- We Changed Our Name, Moved, and are Giving Away $1,000
- is this normal while doing a compression test?
- 550cc injectors
- What's everyones opinion on REV Valves?
- What can be done about torque steer?
- oil line leaks!!!
- what max hp on on inline pro mani. log..
- Custom Turbo Setup
- question of Boost+cams. Im running a b16 with dragIII and 7psi, Gains from b18c5 cams?
- Our phone number has changed...our new retail location is now open!!!
- Video of a sick ass dyno vid for new civic Si....check it out
- difference in log style and full legth tube turbo manifolds
- Clocking the Turbo (oil feed to close??)
- WTF is this and how do i get it out of here??(turbo civic)
- Good ADVANCED book for FI?
- nitrous installation instructions
- Headgasket Question.....(Not how to Install)
- Opinions on drag3 manifold?
- knock sensor question
- New Greddy SOHC Turbo kit for 96-00 Ex
- Most whp made????????
- Darton sleeved block with sunk sleeves. can it be FIXED??????
- Charge piping
- Maxrev & Inlinepro
- Driving Style: N/A vs. FI
- What size injectors for 430whp
- O2 sensor wiring ?
- How do you run no gasket on a tial??
- VTC presents: The sequal no one was waiting for! (56k = oWn3D)
- BOV question
- master power super turbo
- Bay Area JRSC installers
- Thoughts on APEXi Super AVC-R Boost Controller
- silicone tubing question
- Injector Question About a Boosted H22
- Turbo For 7th Gen?
- AEM Tuning in Portland?
- Profec E-01
- Better than the new Uberdata?
- ngk spark plugs for d16z6 turbo
- Greddy kit on the RSX-S: Fast?
- buget buildup, 2004 grassroots
- b16a Sleeves
- $2500 1/8 drag crx
- Getting CEL for Map sensor with Missinglink @ 4.5 psi....??
- wtf is the difference between open deck and closed deck
- Where to get the 4 bolt turbo flange?
- best no2 kit for h22
- ? on skunk2 I.M for ls turbo
- kinda off topic but ..
- Intercooler needed immediatly?
- internal wastegate
- greddy 15g flange question
- what do you think of this TURBO
- boosting automatic? is it worth it...
- Apexi PFC users
- i need some advice for timing
- ls turbo...what spark plugs wire to use?
- full race kit install
- boost on stock gsr
- Innovative Wideband
- Calculate Engine Size in Cubic Inches and CC's
- Those of you with mid 200whp B16's...
- Need Help Rebuilding H22A Block
- leave timing stock for ls turbo????
- are 94 gsr injectors saturated or peak and hold (cant remember)???
- Turbo size
- Downpipe
- what brand of injectors would you guys recommend?
- Any opinions/info on Competition Cams?
- My Winter Project (56k warn!)
- what will happen if i just install the msd sci box....
- turbo ls motor...do i need msd ignition???
- Attn Profec A users
- Greddy Kit on LS w/out Intercooler dyno numbers??
- Catch Can: VERY CONFUSED!!!
- install for d16y8 turbo
- fmic piping and jdm foglights for 5th gen prelude
- tell me what my turbo can do
- no intercooler needed??
- ecu question???
- my experience being scammed by rOby
- Your Opinion: best turbo LS cams?
- turbo installation
- Look what the man in the brown truck brought me!!!
- upgrded ignition needed for nitrous
- what is the ideal compression ratio for boost???
- Fully Built B20 TURBO motor
- for those with blown headgaskets and no overheat prob
- AVCR ?
- test pipe problems!!!
- Turbo gew-rews....Question on Precision SC44 Turbo.....
- DSM bov fluttering question, FYI:I'm the king of searchs but still have a Q?
- Is it worth upgrading to a D16Y8 intake manifold?
- Hondata Tuning for Western Colorado.
- HELP: Problems Tech edge 1.5 , the red light doesnt come on. My value are inside.
- Rebuilt turbo leaking because of -4an oil feed?
- ATTN CA, OR, WA guys TUNING SESSIONS!!
- AVCR Help!
- need a turbo rebuilt. where to go?
- thinnest boost gauge?
- B20 TURBO!?
- L1H1 wideband O sensor with no harness, just wires. Does it require a resiter or such?
- ford mustang injectors?
- Trying to keep the motor safe.
- Noob wanting to tune own car.
- Install?
- anybody with 180 whp N/A and 250whp with nitrous?
- N20 Problems on the Dyno...
- would this work to control my WG?
- does anyone think that sfp turbo kit is worth 3999.99 for a d series built.
- ZC turbo hondata or Zdyne?
- SOHC turbo onto GSR?
- Jackson Racing Power card
- Big problem with my motor mounts. Need help, (kinda long).
- Greddy blue Box Question w/ my seyup ?
- The great supercharger vs turbo thread - post questions and info here!
- vortec fmu trick, does it work? pls help
- turbo and A/C???
- intercooler piping
- 475,673* Preludes built from 97-01
- DID SEARCH!!!! please post b-20 turbo ls-turbo......
- safc install help
- Not getting any Boost.... maybe 1psi at 4grand
- hondata question
- What are the best turbo plugs to use
- Car isn't starting.
- how much $$$?
- Turbo b18C Help
- Need a response ASAP
- Nitrous bottle valve
- USPS CAME! =)
- Anyone using EF-1 Cams and valve train for Turbo Apps
- GSR with greddy turbo-pics
- MILES VS TURBO?
- garrett gt30 turbo hp potential and my setup
- spoon n1 exhaust and turbo?
- pics of my car
- Duc's EJ6 on the dyno VIDEO...
- Are there any rod alternatives(stronger) for a D15b(USDM) LX Motor?
