View Full Version : Forced Induction
- help with jrsc
- Head gasket for Turbo setup
- anybody see the cars on the new SCC ???
- Check out my compressor map plots
- 210 too hot for a turbo b18b?
- once again, cams with jrsc (a different take)
- Somone know where I can get turbo stuff ?!
- 440cc injectors on a turbo h23
- 300 whp /w JRSC
- Blow off valves
- Would you recommend this BOV for turbo
- Paying a shop for install...or doing it myself?
- manual boost controller worth it?
- Greddy kit for 300 whp or 300+ on this setup or in general
- what is the best ignition for turbos.... MSD6AL?, MSD6BTM?, CRANE, Jacobson ignition
- ls motor in a eg with drag gen 3 kit
- Greddy Turvo Kit:
- GROUP BUY on HonData ECU upgrades
- can I run greddy turbo with Zex nos kit?
- oil on spark plug...
- MAP Sensor
- welding manifold....
- cheapest price on fuel rails....
- high pressure radiator cap questions..real quick...
- DRAG Type R Turbo Trim?
- does a t3 super 60 good for a D16A6,what exhaust maninfold can i get for it
- will a drag gen 3 for a b16 fit onto a b18
- Exhaust gas inside intercooler ????
- Questions about a Turbo for my R...
- super turbo? and another question
- Street Legal Drags
- whats the break in for greddy turbo???
- downpipe for greddy kit gsr???
- Haltech E6K Install Article
- Can i lower compression by just using a thicker headgasket?
- Looking for Hondata tuners in Virginia Beach area
- Drag III on 01 GSR Help
- CAR STOLEN!!!!
- Fuel Pressure Regulator
- stupid question, how to use turbo timer?
- I need the right Part number for the Bosch inline fuel pump....
- NEED HELP QUICK.. I desperately need to find a turbo kit for my 99 accord ex coupe (4cyl)
- question about injectors in greddy kit...
- how big of a w-g should i get.
- Tial Wastegates: Spring Q's
- Slicks.......
- how do u read plugs???
- turbo oil line..
- Hondata Group Buy - ending 8/20/2001
- Cracked manifold...Help!
- Toluene as octane boost?
- Will this setup be good enough.
- Could some help me figure out why my car dont run?
- Experiences with / Information about Golden Eagle Sleeves?
- PLEEEEASE help...so sad. I think I blew my motor help quick!!
- Who has the best prices on turbos?
- is greddy si turbo already carb legal?
- new end tanks for a greddy intercooler
- NOS Purge Kit Install
- if i dont break 13's i am going to be pissed!
- OEM alarm and turbo timers....can it be done??
- Questions for Turbo Teg and Civic oweners
- Where can I get a 2.5 Test Pipe for an OBDII Integra?
- Can you run 5psi on the Drag kit ?
- My hooptie....pics....
- what kind of ACT kit do you need for greedy turbo on gsr and how much is install?
- Stock Headgasket Q's
- OT: New exhaust law in California is signed
- where can I find this part?
- new autometer gauges for turbo
- TYPE R (TURBO)
- Info on SDS system?
- JRSC, water injection, 11.5:cr, spec b cams...
- Type R Cams with JRSC???
- 1\4 mile times with turbo
- Turbo Sizing t3/t4B
- is this time good?
- SRS Light on LS/Turbo Hatch??????
- 13.5 Supercharged Integra?
- injector size for turbo gsr & fuel pump
- Contemplating going open loop, how much louder is it/power?
- best t3/t04 turbo kit
- 7psi limit???? f******
- Another turbo mafia weekend.... i hate turbo's....
- my story at CMI/Summit Racing IDRC event
- physical mod to fit DSM injectors...
- blockgaurd...STR or RACE ENG.?
- what size intercooler?
- t3/to4 custom setup or 18G greddy kit
- SDS system?
- fuel regulator problem
- anyone know at what degress celcius does a...
- anyone put a a/fr in a 6th gen?
- ENDYN STEPPER PULLEY (8psi)
- So simple question for anyone FI...
- Almost there...
- So Cal. Legal Street Racing Sept. 8-9th
- been a while, need advice on a new Radiator...
- for those with greddy turbo..
- Where to get a down pipe made in Orange County?
- Hondata Tuners in NJ/NY
- how do u guys wire up your inline fuel pump
- Greddy TURBO KIT: NEED TO KNOW ASAP!!!!!!!!!!!!!!!
- Dyno results
- turbo for stock b20z engine
- Braided oil return line and Missing Link???
- is 2100 installed for used greddy turbo a good deal?
- I have too much boost! How can I lower the boost? Still have boost creep.
- New build smoking badly?
- Question from Neebie Looking into the Dark Side
- Best Turbo kit for D16z6 (Opinions Needed)
- turbo pistons
- any place in socali that installs turbos cheap?
- greddy turbo kits
- i gained more power!
- Installed my staion I/C, how's it look??
- to build a B18B or B18C? that is the question
- Swap Dilemma
- what size turbo?
- Turbo Guru's help!
- Connecting a voltmeter to the O2 sensor
- Group buy for J&S Safeguard...we need 10 people!!
- How much more power if I were to get a test Pipe?
- problem with my Type S BOV
- boost gauge problems?
- Wastegate vac. hose size? Spool up time?
- Some dumb questions from a newbie to FI...
- Reputable Shops for Engine Swapping (Bay Area)
- how to check if my skunk2 gears are whack?
- good enuff?
- blewup the car...new plans
- flange for dp --> cat
- Selling my 2000 Celica GT-S and getting a 94' LS (to turbo), have gotten some advice but need more
- I think I'm screwed...help (long)
- timing confusion... anyone an expert?
- Injectors Questions?
- OT: honda-tech a pornsite!
- Is there any HONDA mechanics in here? ? ? ?
- what size slicks????
- where in LA/long beach area I can get oil pan welded
- cam gears REALLY off? help tuners.
- which OBDI ecu do a get to go with my hondata when i get it ????
- Asking the pro's?
- Golden Eagle 84.5mm sleeve Groupbuy - $575
- Anyone run zdyne?
- my car is up on ebay.
- Clutch Reccomendation.........
- I NEED A MANIFOLD!!!!
- HONDATA USERS/GURU's
- Attn: Hondata GroupBuy
- NOS setup
- Altenator/speed sensor
- turbo install instructions
- HONDA GURUS only please!
- can someone with a Helm manual please help me out?
- Anothe set of compression #'s.
- Sticky BOV?
- my compression tests
- Help with the tial!!!!!!
- Turbo grief.....
- Jinxproof!
- Turbo Sputter
- Strange EGT readings
- Top Fuel Turbo Kit?
- Smoke and oil coming out my breather...Help!
- Boost Spiking! Need help ASAP going to DYNO TOMMOROW AAAHHHH!
- Tell me something about this 60-1 Turbo
- Sequential turbos? Turbo ride quality? general...(I've searched)
- Best Turbo for H22??????
- Attn: Hitech mani owners
- Would anyone be interested in a DRAG turbo kit group buy?
- motors starting to smoke....need ideas
- Proper turbo sizing for a B20 motor?
- Best cams for Supercharger?
- Back and better than ever!!!
- what do you guys do to stay at stock timing for all you turbo guys
- stock b16 manifold?
- Weird Silence
- CRX Compression numbers
- CF hood for turbo??
- Can anyone decipher Garret s/n's? What turbo is this?
- How do I do the bike pump test for the wastegate?
- I think my engine went boom...!
- ARP head stud kit for an LSVTEC...?
- the low down on water/air IC's.....
- Will the greddy TD05-18G turbo out spool and power the T3 turbo ?
- question about Apex'i boost gauge..pls look..
- what exhaust is recommended with a turbo set up??? 3"???
- what's the difference between electrical and mechanical boost gauge ?
- I need exhaust housings. help
- IPS Racing...
- N20 motor questions
- i heard a constant tapping sound today...what can it be?
- Some pics of the 3" downpipe.
- Can some one host some pics for me?
- boost gauge question?
- jrsc help
- Holley fuel pumps are Walboro???
- turboR616, sgT - i heard the "beast" blew up @maple grove. what happened????
- will a t3 super 60 fit the drag manifold AND downpipe?
- Head gaskets
- GReddy Turbo Si Setup!!
- Overheating... process of elimination...
- T3/T4 hybrid turbo?
- need a turbo kit HELP!!!!!
- Radiator Woes
- 84mm pistons
- Test
- Update on cracked #4
- Turbo choice---please help gurus, genious', know-it-alls (Turbomafia? Arturbo?)
- $6,000 for turbo set up........help me out yall
- PSI -> Bar
- rc 550cc injectors or blitz 550 cc injectors??
- buiding an h22a the right way?
- Thermo wrap?
- Check Engine light - code 67
- my Civic VTi turbo.. comments please!
- Just installed DRAG turbo and have some questions...
- profec-B vs. AVC-R
- Bensons?
- Need opinions for buildup of my car.
- JE compression ratio
- best price on drag or revhard kit?
- fmu question...
- Compressor Maps
- 99 Honda Accord Ex Coupe (4cyl) Superchargers
- Compressor map for hybrid turbo?
- St00pid is at it again with his in car video. But its not a Honda.
- Special Thanks to Thunder Fabrications(Tony) and ARTurbo!
- air fuel is this rite?
- Anybody need a vortech 6:1 disc?
- How do you tell if an injector locked up?
- Anyone using the hytech turbo manifold?
- J&S Safeguard Install on OBD0
- Input on my possible new setup.
- ZC Revhard Turbo Manifold
- Opinions of Greddy turbo kit of Civic Si
- v-afc tuning
- What Nitrous kit should i purchase?
- anyone have a lightweight flywheel w/ turbo? like?/dislike?
- should i dyno before turbo?
- Polishing Intercoolers
- fuzzy logic boost controllers!!
- anyone in here use the starion/conquest intercooler?
- Pics of my car. hope ya guys like
- test
- high pressue fuel pump
- Bay Area People
- pic of top half of motor
- Looking for stock air intake box (upper box, and filter)
