View Full Version : Forced Induction
- Should i sell my B18C5 turbo set-up and go NA K20 ?
- My boost timing
- d16z6 compatible exhaust manifold
- 190 LPH To big?? If So...Suggestions?
- Picking out my turbo
- Turbo Sizing
- Flywheel
- Missing 5th gear?
- question about boltons
- Hondata help
- pics of your inline fuel pump setup PLEASE!!
- Howmanybends(i've searched, need a quick answer)
- which turbo came in a DRAG 3 kit????
- MSD external ignition module questions
- Anybody here used/familiar with the MSD Digital 6 Plus ignition?(2-step limiter question)
- i blew my 00b16 block, tryin to find a way to clean new block
- air fuel-o2 sensor ?
- Closed loop and narrowband sim. question.
- Uberdata 1.8 DSM 450cc and leaning out at only 8PSI
- hks ss bov question for the f/i know it alls....
- frustrated Turbo gsr owner
- Is there anyway to scale zdyne to be above 7400 rpms?
- new setup is finally on!!!!!!!!!
- NRG Tech does it again (my car is finally done)
- turbo??? what do i have
- problems with muckman "style" SS WG line
- Revhard manifold question plz help?
- ssautochrome manifold on low boost? safe
- Heads Up for you guys my cars for sale
- best price on obx lsd shipped??
- Ls/vtec Turbo guys
- JE vs Arias
- Cruise Control Button wired for Boost or Nitrous?
- Drag GEN 2 Turbo kit .....??
- Greddy Type S Question
- difference between 92-95 and 96-00 civic kits?
- Running Lean = Higher Timing Running Rich = Lower Timing
- my boosted mini me
- Cheesefrog Civic Vs. Viper Video... I Need That Vid
- Nitrous preperations.
- 5 bolt-TO-V band flange.....where to buy
- full race k24/k20 ek turbo???
- should i do low comp pistons and rods to run 12 psi on gsr block with vafc
- looking to boost 10-15psi daily...b18 or b20 block?
- defi egt probe
- Oil Feed and Return lines setup on turbo...is this ok?? help needed. (pics inside)
- EFI101, my personal experience
- 450's STILL running way rich, help out
- Why MoTec, Haltech, AEM instead of Uberdata?
- Hard lines for Oil Feed???
- Turbonetics customer service sucks donkey balls!
- B16 + GT30R @ 10psi how much whp?
- GT SERIES water cooled turbo lines?Pics???Advice????
- Which GT series turbo for my goal????
- Injector question...
- bought my turbo, check it out!
- wastegayte creep
- Exploited Racing strikes again!!!
- Finally boosted again!!!
- $$ for blitz fatt x turbo timer instructions.
- Boosting with 310's
- AEM EMS Timing Question...
- new to turbos: need help!
- oil in turbo pipe....catch can help???
- Ls/vtec c/r
- Poll: Who built their kit opposed to who bouht there kit... SERACHED
- Anyone elses car NOT liking this cold as weather???
- What the hell does this CEL mean?
- Some questions with tuning zdyne
- Tied between the two... Hallman Pro RX or Turbosmart Boost Tee???
- anybody else get a code 13?
- :pics: do you think this oil drain line will work?
- return line question
- Longevity of a fully built motor.....
- HX30 or HX35?
- turbo goods.....
- HELP ME CHOOOOSEEEE - K26, 14b or ???
- Tial BOV Flutter
- Hondata auto/manual ecu question
- will my hondata s200 with ls ecu,be compatable with my new p72?
- Any one running a "One-Fab" Mani on a CRX?
- which honda has the biggest throttle body
- why do most people on here prefer a tubular manifold to something like the inline or drag manifold
- Oil line/Water line's Need some guidence.
- How much can 6AN fuel lines support?
- Inside splines on my action 2md stripped! How does this happen?
- Help ASAP. High RPM POP and falls on face, H22.
- B18 a/b or b18c for boosted
- ** Where can I buy a set of NGK 2 step colder Spark plus for my LST **
- Saab t3- d16z6 few q's tried search please look
- blue box or fmu?
- hondata for fi...obd 1 or obd 2??
- Places to buy....
- those with the LM-1 wideband? Logworks
- Do you think this intercooler will work good on my 500HP motor???
- Boostin my b16
- Is it normal?
- Greddy Profec B TYPE S??
- Might not be a Honda, but Dyno results from my gst 501whp
- ANYONE HAVE a gt28rs t3 housing with b16 ???
- Turbo problem...rattling noise...
- Hondata Logger?
- which is best sohc intake manifold?
- did a search and no luck with Turbo exhuast
- mobil 1 10w30
- TURBO Si? (turbo experts)
- Tapped Oil pan?
- In the garage building my motor and kind of 'stuck' : )
- bearing clearance advice..
- Does a JR Super Charger cause idle droop or any neg. problems on a GSR engine?
- Full Race Stage 4 turbo kit, OFF THE SHELF -- 712.5 WHP, 461.5 TQ
- Boost spiking on me like CRAZY...HELP!!!!!!!!
- What T04 has 8 blades?
- Fuel management for 1.6 SOHC OBD0...
- boost bleeding device, quasi missing link
- Tial and Full-Race products
- Complete-engineering turbo kit ?!?!?!
- 440ccm peak&hold injectors - where?
- D16/B16 Turbo
- Running with no IC Temporarily
- Hookin up a Turbonetics MBC
- New Sleeved block... its rusting!!!!!
- anywhere to get piping for turbo in TX
- Which H/G for over 1.5 CR drop ?
- 3 types of rev hard cast mani?
- pics of my 95 civic setup
- hmmm... which block?
- laminova intercooler?
- man... what's wrong? limp mode?
- how can timing blow headgaskets >>
- Compression on a LS/Vtec
- How To: Tell if you tranny has an LSD?
- what happened to crpturbos.com???
- Need help, i have a igniton or ecu failure problem!!!!!!!!!!!!!!Vortech SC 00Si
- turbo
- how to put pics on here?
- 50 lbs/min (640cfm)...------------------- which injectors?
- intake tube
- After Many Months Of Saving My Pennies & Dimes......
- Good direction with b18b and Nitrous?
- anyone in the bay area have an extra arp washer?
- 954rr 75mm forged pistons
- Need uberdata basemap
- turbo size question
- Will gt28r fit an Apexi manifold?
- Octane Booster? Good or Bad?
- LS VTEC turbo kit
- RSX/K20 turbo oil drain
- Clutch type or Helical LSD?
- My dyno vid.... check it out!!!
- b16 with gt28rs t3 housing.. .63 or .82 , search w/ no results
- DA i/c piping question???
- How much timing should i retard with a b18 14b?
- 1/4 mile times on b16, stock block
- obd0 - obd1
- t3 gt35r...
- garrett turbo question
- I've come to the conclusion that I'm F*cked
- a couple ??'s about the 14b
- does the DRAG kit come with injectors?
- SOHC VTEC HEAD LIFTING....
- Rebuilt motor won't fire in two cylinders....give me some ideas
- Starting my custom turbo!
- What do you think about this manifold?
- Turbo for 2000 civic
- recognizing a rebuilt turbo versus brand new?
- Do all supercgargers need blow off valve??
- what is the potental of a LS
- someone wanna help me out?
- Where to buy 550 peak and hold injectors + box
- can/should i keep my 5 zigen fireball catback with boosted d series???
- stainless steel vs aluminum for IC piping
- Can spark plug gap cause a "misfire?"
- Turbo engine break in
- SOHC Turbo
- bkr7e or bkr8e
- boost limit
- GT or SC or 60-1
- would this work?
- 5 bolt DP flange on sc61
- Anybody have an ACT clutch fail latley
- Question about the Garrett GT2871R
- ls/turbo
- Intercooler for 97 dx w/ ls/vtec
- 11.47 on drag radials d16a6 no nos
- learning about turbo sizes
- cleaning TIAL WG ? >>
- 38mm or 44mm BOV?
- WG and Turbo.......
- Thermal exhaust without a Cat, question
- how much did you spend on custom turbo kit VS drag, greddy, revhard, etc...
- SS AUTOCHROME MANIFOLD AND TURBO SETUPS??????
- D series - successful no head lifting....how did you TQ ur studs???
- The bottom end
- JRSC on b18 which fuel
- greddy blue box
- D-Series ARP Head studs question
- How To Make A Filter Fit My Turbo?!?
- do they make...?
- ECU that self tunes... putting tuners out of business????
- calling out integras (dc2) w/ equal length air conditioner compatible manifolds!!
- ef turbo
- Turbo Question
- Open exhaust Dyno
- BBK intake manifold anyone tryed it
- Wastegate Question
- Couple questions I have on my new turbo setup
- boost b16a2 or b18c1?
- Best Transmission For Turbo Car
- anyone got some free time to help me with an install? SE PA? maybe NJ, DE dudes?
- how well will this turbo work for me on my b18b?
- lightened flywheel on 400whp turbo car - yay o' nay?
- Help me pick the ideal turbo for my application....
- Intake arm???
- Oversize Valves
- Switching to Uber - JRSC MAP question
- bad cylinder? Compression question.
- Will a FMI fit with Stock EK foglights??
- whats the diff in 50 mm performance???
- What do u say... T3, T-25 or 14b.. turbo for a daily driven d series?
- can i turbo this motor?
- RANT: Greddy 52mm Water Temp Guage
- who had the best.....
- Tuning a 1993 VTEC PRELUDE TURBO
- manifold pressure/ velocity
- gt3071 good for stock b18b?
- 3-400 for the street 4-500 track, what plugs?
- What size piping do I need?
- Are Precision GT turbos really THAT much of an improvement over the SC series?
- Just a tea spoon of sugar (oil) makes the medicine (compression) go down (up).
- mild ls block build?
- dyno fuel problems
- ARP headbolts/headstuds
- Fuel Management and Nitrous?
- which open lugs for ARP studs????
- question about main & rod bearings building motor?
- Too Good to be true
- car smoking when at idle out exhaust.
- Percision Turbo Part Number Help
- vafc with check valves throws code at 12psi? map sensor
- JRSC setup
- 14b on jdm dohc good or no good
- Shipping nitrous kit question
- b16 head torque sequence and specs?
- TURBOO MANI ISSUES
- 880 or 1000cc injectors?
- what oil for b18b with drag kit?
- auto meter boost gauge ignition wire?
- Need help fast 8:5:1 Vs 9:3:1 HELP ME DESIDE!
- AEM wideband Sensor
