View Full Version : Forced Induction
- Open waste gate ????
- Open waste gate more power or not?
- Who makes a good intake kit with the piping and bends?
- JRSC for D16a6
- Loctite on P/P bolts or not?
- aem ems
- VTEC with turbo? pro's and con's does it work well, whos right??
- Blue Smoke, please help...i'm stumped
- jrsc install help
- did a search...how is a leakdown test down?
- differences between the greddy 20G and t3/t04e?
- Road Cruise.. 230km + speeds
- My turbo problems, long explanation, plz help
- Who makes a cheap electronic boost controller?
- Besides Summit, who carries the Blitz SSBC?
- How many of you are at or close to 400bhp street drivin
- Please help me make a decision
- Question, I went for a ride in a 5psi boosted b16 Hatch, How much psi till you feel a Slam you in th
- polishing the top of pistons
- What Gauges are important for SC?
- What are you turbo Bs launching at on slicks?
- How long will a turbo last
- Things you hate about being turbo ...
- Supercharger VS Turbocharger?? HELP!!
- help!! something wrong and dont know what
- any pictures of 3"thermal on 92-95 civic hb's?
- Cometic head gasket problems!
- need FMU help
- diffrences between supercharge/turbo fmus'?
- Custom B-Series Manifold Made From Stock Headers
- Just curious who is hitting 11's or 10's with an Open Deck? (D-series)
- Where to find pre-fab turbo/IC piping for CRX?
- Identification PLEASE!!!
- EMERGENCY!! need help with OBD2a to OBD1 harness ASAP
- My turbo is quiet. Anyone else's turbo is quiet?
- ran the 1/8th... 9.9@75mph... 2.496 60ft
- NO2 with an auto trans? What issues am I looking at?
- who here has had this mproblem w/their fmu???
- benefits of b20 over b18b
- **cheapest place to buy sparkplugs**
- I need a turbo kit 96gsr
- Supercharger
- JRSC on 00 Gsr
- sohc boosted vtec wows
- real quick question about AEM FPR.
- too rich at idle
- Intercooler Groupbuy
- Daily Driven Integra, need turbo, import builders or dag?
- What's missing from this turbo setup?
- can someone please give me some help on this
- How much boost can the sleeves take?
- Fabricating a Complete Ballistic GT Dual Ball Bearing Turbo Kit for the B18C - Anyone Intrested ?
- VAFC settings on a GSR
- v-afc & FMU
- thinking of going turbo...what exhaust?
- Need a time slip eval
- 90-93 Integra with Hondata
- Spark plug question
- Austin, TX Area: Good tuners?
- attn rocket: dislike of clutchnet?
- retart timing?
- 10.58@132
- DSM Injectors
- Please help me understand my track times.. thanks
- 12.1 @ 112 mph with JRSC, 11psi, liquid intercooler.
- machine shop in the bay area??
- bahh!!!! so got back from the track with the slicks...
- Nos. Any ideas
- Oil/water cooled T3/T4?
- What gauges are "necessary"?
- First time at track while boosted....need some input
- Is this a good buy?
- need tips on launching at track tomorrow... burnt clutch, 8-10psi, street tires, etc
- Metallic specks on piston.. detonation?
- Anybody using the Apexi Power FC??
- Someone with Vortech BOV: please confirm this!
- Topfuel turbo kit FMU
- How does the Thermal turbo exhaust sound???
- would this compensate the integrity of my manifold?
- Pics of Profec B box mount please.
- Boost gauge help
- I cant believe it!!!
- What is the biggest I/C that you can stuff on your crx?
- How do u find the correct bearing size, WHEN THE ORIGINAL PARTS ARE NOT IN THE BLOCK!!??
- those with Drag3 Turbo kit on 00 Gsr
- Does DRAG have an official web site??
- Recieved my Inline Pro exh manifold
- another turbo GB?
- synthetic oils
- Blew a coolant line and had a major overheat--consequences??
- Anyone got a picture of a aftermarket fuel rail on D16Y8
- FS: Old School HKS Blow Off Valve
- Greddy Profec B is awesome!
- AVC-R users..
- Anyone have pics for FMU install SOHC?
- Is this a scam?
- Some pics of my Turbo setup....
- holy fu*k.... 10psi is AWESOME!!!
- What's the power gain of upgrading your turbo?
- Terrible 1/4 mile time...
- turbo size question?
- largest t3/t04e
- woohoo! thanks geoff/maxrev
- does any air filter on a turbo work?
- will i be able to run 24x9.2x15 slicks....
- JRSC + Nitrous?
- **performance gaskets**
- Subaru turbo size.....
- DSM injector parts/pieces needed
- what is the bore of my stock sohc engine
- How much mods will I have to make?
- Zdyne
- how fast does a turbo die without oil?????
- supercharger question
- AFC hack
- any one with the skunk 2 IM
- Endyn Roller Wave Pistons for sale....
- What suspension set-up to get?
- Lakewood Radius Arms? Anyone have info on them?
- MSD adjsutable FMU?? 67$ ?
- I found some engine pics
- turbos in CA... what happens if you get caught?
- hondata help
- My BOV whistles after blowing off??
- **exhaust leak**
- what compression for turbo?
- Turbo timer wiring (been searched)
- greddy civic turbo TD04, came off what car? need gakset
- Ok, Hondata Lambda conversion thing
- help... where to install egt probe!
- Bustttt
- Help!!ASAP!! DRAG kit Fuel Pump terminal!!!
- Remember the FMIC JRSC SI?
- integra LS trubo setups
- OT: what shade of black should I paint my 4dr?
- should I stay at 9.0:1 or bump it up a bit?
- does this look complete too u... its a drag3 for gsr...
- Vortech supercharged b16?
- installed intank fuel pump (walbro)....have some questions
- bleeder-type boost controller bad?
- MSD 6A: makes beeping noises?
- Looking for input... what you build?
- JG/Edelbrock intake manifold and Hondata Heatshield install help~~~~~~ (please)
- would a TD05-18G fit on the greddy manifold made for TD40H-15G?
- OT: Do you keep parts in your cubicle at work?
- whats should the tops of my pistons look like??? on a turbo setup?
- Walbro fuel pump
- Greddy 720cc injectors......
- **Wastegate stuck open?!**
- Best Setup??
- how to control boost?
- Is enybody here runing the new AEM ecu?
- Turbo+type R cams good idea?
- How do you plug in the 2 bar MAP?
- What's the 'resistor pack' look like on a G2 integra????
- t4 in a gsr???
- What to use in blace of greddy box? Check valves?
- JG/Edelbrock intake manifold 4 a LS
- V6 super charger?
- b18 t25 exh. maifold.
- WTB:b18b turbo exh. manifold
- difference between G2 & G3 integra IC piping ?
- 97+ Prelude JRSC fit on 00 Gsr?
- putting a block on engine stand question
- is hondata a standalone?
- Golden Eagle Group Buy for Nor Cal people
- Dyno day....
- best rpm's to launch at
- piping size??
- t-25 water lines?
- chrome diped pistons?
- turbo difference
- Anyone interested in a turbo?
- FS: Brand new MAX REV Manifold for B-series
- New Turbo
- Etown people - need to find results
- power source for fuel pump
- need an obd1 civic dx non vtec ecu!
- Goin' Miami to Tampa, FL on Saturday (1 day) with a BRAND NEW MOTOR !
- Custom Turbo Kit
- Help. People in VA. I have 8 days left to do emissions
- How many psi until u actually feel quicker?
- ran my hatch again..RESULTS..
- JRSC Dilemma...
- should I run a 3" exhaust while I save for boost?
- Need help selecting a drag radial
- turbo ct26 for honda?
- Hate to do this guys...
- Which way is your BOV supposed to be pointed?
- Exhaust leak need some tips
- Air filter-boxes (heatshields) SHOW OFF
- oil coming from exh. ports. PCV?
- Installed the Z10 Bars
- does wiseco make a ..........
- MSD in-line fuel pump enough?
- Is this turbo RICE
- Is Sacramento Raceway the only track near the Bay Area?
- Ran my car for the FIRST time, boosted auto
- Quick ? about FMU
- Did you have to replace bearings when you replaced your rods/pistons?
- wa does this mean
- How to stop wheel hop in 2nd with a turbo car?
- LS or GSR?
- whats needed to run a B20 on a supercharger?
- missing link and still getting check engine???
- Turbo Prelude run 13.7@102!!!
- Opinions on my new kit please :)
- PLEASE - New product, need to determine tooling costs AFC+VAFC+AFC-R
- Q's on J&S Safeguard.
- Manifolds w/ HKS flange
- New Times
- JandE Pistons 9: for sale cheap
- 2 step with Turbo...
- Anyone know a website that.....
- Clutchnet Stage 2 installed. First Impressions Inside...
- Mishiftted: What did I do? (MP3 of tapping)
- for those that bought turbos from me...flanges
- APEXi Power-FC, any experience, suggestions?
- Thinking of Turbo/SC on B16a, need lots of information from u FI guys...
- Ls Turbo?
- half throttle, full boost question
- EGT readings
- DFI management
- Stock GSR oil cooler VS. front mounted oil cooler (please give me your thoughts)
- Can someone please help me with this...
- type s and type r blow off valves?
- fs 97 gsr + turbo and springs
- Attn: all LS turbos.....would you recommend?
- Maybe you know this, but DON'T use checkvalve for map sensor...at least not like this:
- what cause boost spike??
- Emergency Kit for the car: Opinions?
- anyone have probs with magnacor plug wire poping off?
- throttle body question. help
- sanding the sharp edges of pistons?
- are these the same internally?
- head gasket upgrade question
- first dyno pull
- finally got money for a hondata but there is no authorized dealer in pa, where to go?
- anyone running an msd btm
- help me decide... build up my current motor or a dohc one...
- Max boost on JRSC to run efficiently?
- Need turbo stuff? Intercoolers? BOV?
- What head gasket's are you running w/your turbo?
- honda greddy turbo,running too LEAN???
- burning oil
- Downpipe Bolt Size
- how much boos???
- You KNOW you're turbo if....
- str block guard
- FS: eclipse 450cc injectors.
