View Full Version : Forced Induction
- going tubo
- K series Project: RSX
- can anyone tell me the song in this Turbo hatch vid?
- uberdata 1.6 or 1.7?
- so i have a screen on my turbo and am worried about hydrolocking
- New center cartridge leaking oil.
- Angled couplers
- if you had given me a minute...
- happiness is...
- How much boost ??
- wtt 9psi spring for 5-7 psi spring... Deltagte.
- Switching injector clips to OBD1. Does wire polarity matter?
- Dyno video 500whp pump and 600whp on racing fuel
- Whats the highest boost you can get from a 60-1 turbo?
- Resister Box for RC750's
- 2.25" exhaust enough for my needs?
- Need information on fuel pumps and such
- 2.5in downpipew/2.5in exhaust or 2.5 downpipe w/3in exhaust?
- Uberdata with JRSC D16Z6
- comptech blower to spearco intercooler to throttle body
- JRSC/ HONDATA USERS!!! HELP!!!
- fuel question
- Nor cal Bayarea Be on the lookout for a red integra STOLEN
- Problems with Vtec In and Out hitting on my VAFC2.... HELP?!?!?!
- ignition timing?
- need help with int. wastegate...
- good condition clutch or no?
- fmu ? help please
- t25 on a d15 del sol
- Am I missing anything? quick turbo help
- Question about T3 turbo
- New manifold (56k no way)
- skunk manifold versus a stock b16 manifold
- Are these Cunningham rods??
- dsm eclipse turbo pistons in a f series block?
- Getting screwed by Complete Engineering/Aerokits after turbo installtion in DFW
- venom intake manifold
- quick question about boost gauge where do your vac. sit at?
- d16 turbo Q's sleeve or not, turbo size..
- what vacuum level does your turbo D series idle at?
- Help! about to order ic piping, is it good???
- what turbo for sohc automatic?
- Can anyone identify who sleeved this?
- im new
- FUNNNNNNNYYYYYYYYYYYYYY !!!!!!!!!!!!!!!!
- Blue smoke at high rpm , ls turbo???
- Build me a Turbo Kit Game
- Greddy Turbo on a 95' gsr
- Any thoughts on the HKS F-Con on an f22 engine
- Misfire ?
- I need HT advise to make my mind up
- help quick i need an fmu by sat
- Looking to get TURBO for my 98 GSR...what do you recommend?? Greddy or REVHARD?
- New engine break in
- AVC-R Boost by gear
- sc61 surge at high boost levels?
- building my h22
- Turbo Seals bad? or something else like drainline? :O
- stupid noob question i know, but....
- Help me identify this Atlanta, GA shop!?
- Subjective Opinions: Notec vs. Vtec for boosted daily driver - streetability, fun factor
- question: skunk2 cams for turbo?
- Please tell me autometer warranties this *huge pic*
- Polished stainless t04 drag race header
- b16 turbo
- Forced Induction Forum Inspired Me
- boost gauge size??
- Copper Exhaust Manifold Gasket
- My new setup (Sneak Peak)
- where to T for boost gauge
- whats more worth it, what would you do, pick one, etc.
- which turbo is better for a Ls vtec motor?
- 280-300WHP turbo goal: which engine? B16a or B18c(1)?
- gt30r users, any complaints etc?
- Hey all
- Common setups for 250-275 whp b18a/b's
- What Distributor is this???
- where to find parts for my greddy kit???
- Motor break-in problem...
- Hondata or Uberdata?
- Sleeved block o ring replacement?
- help for turbo indentification
- vortech fmu help quick
- fuel managment
- <-----------I need uberdata guidance---------->
- Need help finding t25 downpipe
- average asking prices for these turbo toys..greddy/hondata
- Electric super chargers????
- Turbo or Supercharger or nitrous
- hondata blue box question
- Alcohol injection....Inform me?
- What is needed to get to 275 whp with b18b?
- nitrous need help...
- super charger making sounds?
- Cracked b.o.v.
- my turbo is too big , LOL
- can anyone verify these CP pistons? D16Y8
- 400-450 WHP B16, what are the most common setups?
- fully tuned w/ bad Idle...help needed
- NEED HELP with turbo 5th gen
- can you clock a T3?
- Cam + compression choice for built LS on pump gas
- ?????----------- 57 trim or 50 trim --------?
- question on buying used greddy kit?
- exhaust question
- 250hp with this?
- home-made air/water ic!!!!
- Tuning Basics, Theory, and Applications
- finished turbo, need some help w/bugs
- anyone using 550cc injectors?
- cant find the topic about cast vs full race mani?
- Help!! oil and smoke from turbo downpipe
- DSM 450's Injector Clip Wiring
- better for boost b16a or b18c
- Questions Bout Turbo Setup?
- Some pics of the Turbo Kompressor Mini Cooper S we are building.
- DSM injector help!!!
- Final Word- SSAC wastegates are NOT Tial's
- Would a internal wastegate be fine
- Injector help...
- Exhaust smoking alot after warm up
- Clutch recomendations?
- Where do you get the electric exhaust cut out things?
- Where is the best place to get the Fluidampr?
- What kind of steel to use for flanges on a T3/T4 turbo setup?
- Making sure I don't miss anything swapping a motor from an integra to a dx coupe
- Will this HKS supercharger fit?
- biggest injectors Hondata can handle?
- Need Help!
- open and closed decks?
- what oil pump for high power B-series engine ?
- Emanage Question: Which Greddy turbo kit to order for hybrid OBD1 B16?
- oem Wideband 02 question
- turbo seemed to have blown. oil spewed all over the place
- any tuner in texas crom uberdata
- FMU Safety?
- DO U or CAN U BOOST AFTER a build???
- LS turbo
- Dodge Caravan turbo good for anything??
- washed rings?
- My Turbo LS
- nitous managment
- dsm 440 injectors
- Is this EBAY turbo package a good deal?
- How to read and engine? Detonation Timing AFR (Search Freindly)
- Changing Bov Sound, Why???
- my rc 750's will not fit
- Which would benefit my setup more?
- I could cry... Can anybody help my sick boosted Civic?
- B18 SUPERCHARGER QUESTIONS.........HELP!!!!!!!
- Turbo rebuild
- JRSC sound clips?
- turbo phyical size...
- Just finished install, have cel 16
- Uberdata chip burners? Which do you have? What do you think of these?
- bore and torque > related ??
- z6 pistons in y8 motor, same compression. ??
- Ls turbo fuel question i have uberdata
- what size of oil lines?
- Any Vortec Supercharger videos?
- yet another tranny problem..
- t3 baby
- STS turbo systems never seen this before.
- 3 Bar Map sensor problems *D-Series/Uberdata*
- couple of questions on vortec sc??
- Turbo hitting radiator...
- which turbo....
- Fastest spooling small turbocharger?
- Turbo question
- welding a straight pipe or or use a flex pipe???
- Which is Safter, 8psi on t3/t4 or 15psi on T3
- New Snap-On 3/4 Torque Wrench 16-86LBS.
- greddy turbo kit for 99-00 si
- proper way to tighten ARP studs? now I'm worried...
- 2.25" Intercooler/Turbo piping vs. 2.5"
- turbo shops says " 3'' DP/exhuast is pointless"
- Vortech FMU 12:1 / stock injectors VS Greddy SOHC Blue Box
- Do you need an oil filter relocator kit for an oil cooler?
- Where to get nice cheap new intercooler
- Anyone with a Tilton bearing kit??
- V-band assembly on my SC50 yes or no ?
- WALBRO 255LPH?low pressure? high pressure?
- need some opinions/advice on stripped tensioner bolt
- Tial Bov Sound Video Clip
- uberdata bin file for t3/t4 turbo
- are traction bars needed with slicks?
- Greddy Kit Manual
- I need Help with this Turbo discharge port
- Should I NOS it?
- Hey check out my old 500whp/333 ft-lb set up with an Maximum Performance Turbo Manifold
- my car is to slow
- WRX 13G to 14B compressor upgrade...
- My milkshake ain't that great.....
- newbie question
- budget boost, should i turbo my d or go ls turbo
- turbo size for '04 s2000
- Dipstick
- inline fuel pump suffiecient enough?
- Transmission question
- ls-t, what turbo?
- Going back to the track friday, Shooting for 12's! B20b turbo
- Hi Boost Blow-off valve
- Got rid of my old manifold
- Let's debate: Shift point vs. Powerband
- !! STOLEN TONIGHT < Need help in KC MO ASAP!!
- Unknown Piston brand...Any pistons with no stamp?
- Why do this BOV come with washer?
- Maritime Performance
- Do you think this head will sell well?B-series VTEC head with improved flow over OEM / bare core und
- HOW DO I ELIMINATE RESISTOR BOX. 91' CRX W/ B18A & 92' TEG LS ECU AND HONDATA S200
- Twin disk clutch problem already searched
- After turbo install
- sc61 with garrett housing?
- blow off valve
- manifold for turbo prelude
- Intercoolers from Speed imports
- Help me clarify this wiring chart. JRSC install..
- D-series guys, What manifold are you using?/ Best options
- Anyone using or have pictures of the Super-T manifold?
- forced inducted Ls/Vtec
- Can't open Uberdata 1.66...What program do I use??
- Zeitronix wideband install, and tuning
- t3 capable of 300whp?
- finally 11's, STOCK LS turbo
- DSM inj. not clicking? Need help starting car!!
- re-grind for y7? turbo, headwork
- Properly Motoe Break-In...
- what whp r u making with a t3 .63 60trim?
- what should I do/need to do to my GSR engine, so it safely handle more boost, etc.?
- LS pr0ject, yup another one...
- INLINEPRO for D series any word on it yet?
- AEM FPR
- h23a overheating after boosting
- HMT D16z6
- Honda Turbo Life Question
- turbo civic (flywheel
- profec A problem..?
- Greddy Wonders!
- any ROM burners for Uberdata in the 909/951?
- Turbo Question; Ls vs Gsr Transmission
- built ls/vtec redline question
- Greddy profec B questions
- clutch recommendation
- Endyn 81.5mm dome cc
- Cracked my Rad today ARRGH..
- ACCIDENTLY OVERTORQUED HSTUDS
- Precision Injectors
- JRSC help!
- Loose headstuds/blown hg---WWYD?
