View Full Version : Forced Induction
- Hondata is taking away my licensed copy of RomEditor
- main caps... torque question
- quick cam gear question....
- bye turbo?...
- Aperture Style Wastegate
- Civic and del sol intercooler piping interchangeable?
- need advice on a stripped head stud!!
- re-using rings... already searched
- how can i check or tell if its really 550cc injectors???
- can a b18 with turbo fit in a CRX 88-91 shape?
- tuning after installing
- Extending WB O2 harness?
- Del Sol B16 turbo with a VAFC, few questions.
- my hks ssq bov can turn is that bad?
- at-home downpipe mock-up -- jb tack weld?
- Boosting my 7thgen
- Walbro 255lph, whats the fuel rail psi?
- tapping pan for oil return?
- how do u make a sohc apexi manifold fit a dohc motor?
- oil pan removal?
- CRAZY oil consumption..
- LM-1 innovation wideband???
- peak / hold vs. saturated injectors????
- Went to the dyno... HIGHLY IMPRESSED! Graph inside w/ questions...
- Why does the weird SH!T always happen to me?
- Where is the cheapest place to buy RC 440cc injectors and clips?
- Frustrated/impatient with upcoming setup...suggestions?
- where did the suspension post go?
- well no longer a honda man.
- Losing boost from wastegate?
- Oil Pickup - cleaning? Oil light flickers at idle somewhat
- tuning shops in md, va area....
- Question about someone setup, valve cover port.
- 2.1L turbo... :)
- Will My Car Run Ok With This Setup for emissions?
- question about moates burner
- Catch Can Info
- gsr w/ revhard stg.2
- pistons and rods question!
- Getting My Car Dynoed, Anything I Can Tune?
- Turbo Lag?
- Need 3" piping just dont know were to get it!
- Turbocharger or Supercharger
- My new exhaust setup - Comments please!
- Is this vac line OK for a bov?
- where i can get a full set of replacement gaskets for a d16z?
- boosted d series-1500 mile trip-awesome gas mileage
- cummins turbo diesel turbo?
- why is my coolent overflow tank always empty?
- Is it true fordged piston doents go with stock leaves
- The ssautochrome TURBO thread.
- How to keep the h22 secondary runners open all the time
- Supercharger or Turbo avalible?
- Ebay Serve a good plate!!! SST+downpipe
- need help finding a manifold
- Where can i rebuild my turbo?
- Greddy Turbo Kits?
- Brakes how to lock the rear
- Is this a "large" or "small" spring in my wastegate? See photo....
- help me plz
- turboedit in a pm6 and vss/eld sensors
- D15 Turbo????
- EMS experts please read! Cam sensor info
- which Boost headgasket to use?
- lean with closed throttle
- Fuel Management for Jackson Supercharger..
- T04 Outlet Gasket (4 Bolt)???? (gt series)
- anybody makin close to or 300ish on a t3 ?
- ls/vtec or turbo for a ls?
- Technical noob in need of help in rochester!!!
- bad rings= lose of oil and bad gas mileage?
- Vented hood to keep engine cooler....
- intercooler blocking Radiator problem
- Help me figure something out! (oil cooler)
- Ls/Vtec turbo?
- :( Help with code 13 - Barometric Pressure.
- critique my setup...
- Zex Install. Where do INTAKE n REGULATOR hoses go to. Fuel Jet?
- i think im leaking??? help
- REALLY CONFUSED ABOUT FMU
- The JRSC sold thru hasport.com? for the ef b16 swaps
- any one in the chicago area!
- GM Boost Controller Solenoid
- any idea why car hesitates when i hit 12 lbs of boost?
- turbo newb, need some help..
- anyone tried this wide band ?
- mitsu t25 12 pound wastegate?
- a custom CAI should get me atleast 8psi right?
- Is there a way (yes searched alot)
- CT26 and H22 and Civic.
- Which turbo? B20A (3g Prelude)
- My D16Z6 Setup...sound ok for homeade?
- going turbo next year need advise.
- external vs internal
- TIal wastegate putting dent in my hood help
- what turbo to run?
- Aucra 3.2TL Type-S Supercharger
- fmu+stock injectors is this safe?
- too much fuel or leaned out why did it blow?
- Gsr w/b16 tranny on nitrous?
- Nitrous on b18a1
- another oil question
- 50 trim installe don my 01 jetta 18t
- Oil Pressure
- AFC hack?
- name this engine.
- Need Help with Misfire?? Problem solvers...HELP!!!
- Boost creep, Detailed question with charts
- to everyone out there with IHI turbos, post your setups and #'s!
- Help with tuning! Can't find a place.
- help! need turbo
- Boost was fun while it lasted.
- check out this scam
- Tuning A/F when not in Boost
- my car idles low!! help
- hondata with datalogging and wideband???
- Injector clips for RC 550CC saturated...Are they needed??
- b181 with 170k
- Boosted Type R at HPDE: Running richer than tuned when hot?
- Nitrous guys- stuck solenoids?
- wideband/meter set up
- Help with selecting new turbo
- Dumptube to downpipe - what is your method of connecting them?
- help my car wont run!!!!!!!!!!!!!!!!!!!
- RevHard Manifold, missaligned bolts?
- what disc to use in fmu at 8-10 psi?
- Nitrous Jetting
- HELP!
- PLEASE SIGN THIS PETITION TO SAVE NHRA DRAGSTRIP "ENGLISHTOWN"!!!
- changed center section, now no boost.
- are forged pistons a must for nitrous ???????
- please critique: plugs and compression test #
- YOU guys are awesome!!
- 3" Full Titanium cat back?
- Greddy kit piping color??
- Help with tial springs?
- t3/t4 drag3 turbo in gsr
- oil lines
- Whch block will take more boost? B20 vs. b18
- Went to the track last night ( I think I broke it )
- Another "Not a Honda, but..." thread ;)
- Some Funky Things going on - D16Y8 Turbo Project
- Intake for turbo
- How will the weather affect boost?
- Greddy 15g gasket..what size?
- Burned chip - car wont rev past 2K?
- Is there a huge diff. between manifolds?
- Looking For a quiet exhaust setup......
- Overheating in town, not on highway
- Should I swap a JDM b16 and boost it?
- Boost gauge fluttering in upper RPM, why?
- where to buy B series header flanges
- where to get tial bov flange ?
- Headers and vtec controller for sale
- who can take my hondata bin and make it a uber bin
- How can I test my Tial BOV?
- PLEASE HELP! NO BOOST
- EGT Gauge Question
- We all lost a good friend tonight.(Hondahans)
- bored, pics of my diy earthing sys
- Anyone got InlinePro IC Piping&Precision Intercooler 600hp???
- Runnin a wet nitrous on Y8.....PLZ HELP!
- Fake Tial BOV ?
- does elavation and humidity effect your cars performance ( please read)
- HKS super AFR VS. VAFC II
- Injectors for turbo setup: Anyone use stock Honda ones on d16z6?
- Another Injector Question: Prelude 270cc or Stock Hondas?
- .63 or .48 either with stage III wheel
- Switched to OBDI - car limping?
- How many boosted hondas are running a/c problem free?
- Hondata injector question...
- Petition for Englishtown Raceway Park
- fuel injection setup for boosted d15a3?
- can wrong turbo clocking cause oil in turbine???
- question about tuning
- Back From the Dyno with the Built B16.........
- wanting to go turbo so please help
- Best way to stay emmision legal?
- GM and Chrysler MAP sensors
- Turbo Hondas are cool and all, but... 71psi ownz
- what should my b16a2 estimate times be???
- new turbo need help please!
- should he turbo his ek?
- Wastegate comparison
- Please, Everybody help me out with my turbocharged Civic
- conquest intercooler
- what should next mod be?
- need help with turbo options
- vband question... pretty big pic
- Ahh another nitrous question.. H22 . stock interal. 75shot?
- Quality of Thermal exhaust
- UBERDATA TUNER DIRECTORY
- msd 2 step launch control???
- B&M fpr with an fitting braided lines??? question
- Individuals
- Hondata 2 step, how does it help and good purchase?
- new motor but here a little knocking sound
- need some advice on a replacement fuel pump?
- Dont see many Apexi Kits anymore......
- I need help
- My Next Mod...
- check out my ghetto kit.
- How can I plug the oil feed hole on the block?
- precision turbo shafts
- "Uberdata" goof enough for 450hp+ setup?
- E-Cutout Power source.
- turbo set-ups for a d16y8
- Where can I buy a single ECU plug? OBDIIa 'B' - The one that isn't used stock on a '99 teg
- ???ssautochrome 38mm wastegate???
- help
- With 4500 USD how fast do you think i could make my b16 civic?
- Help with bearing clearances.
- I need AEM EMS for 99 GSR turbo!
- WBO2 for cheap
- no o2 with nitrous
- Car won't start after boost????
- Timing question?
- how do you guys have your charge pipes ran???????
- o2 and wideband sensor mounting locations
- NEW NOS KIT
- boost questions
- 3" flex pipe with 2.5"-3" flare custom only?
- Is this turbo spinning freely? --> Video
- Hondata Stage 3/Boost, J&S Safeguard, Autometer gauges, ect
- Does Vacuum tubing thickness matter?
- D series ninjas using CRX manifold *WASTEGATE Question*
- 60mm gauge in 52mm pod fitment
- Finally into the 12's next looking to break an 11'sec pass!
- Wanted to clarify my guage readings. Are these normal readings?
- Is piston #4 most prone to crack?
- remote mount fuel pressure regulator, or just buy new fuel rail?
- clogged pcv, oil seals, and oil leaks
- to run water lines or not?
- whats the minimun for 15psi
- reasonable price on used revhard kit?
- ball-bearing turbo rebuildable ??
- Most accurate boost gauge????
- mechanical fuel pump, not pumping? WTF....
- rc 310 injectors how much whp they good for?
- Full Interior CRX 1/4 TImes TC or SC
- No turnover
- Missing Link??
- WHO MAKES GOOD TURBO PISTONS??? PLZ HELP!!!
- Are there any performance gains when Jet hotting manifolds and turbo housings?
- Uberdata questions
- twin scroll turbo?
- g2 integra turbo questions
- n2o question
- NOS guys help me out
- turbo zc slower than it was as n/a
