View Full Version : Forced Induction
- what does it mean if white smoke comes out of exhaust rarely? like only 3 times..
- Hi TurboR616
- Pics of my turbo teg (8 months)
- Anyone with a '00+ GS-R and a JRSC?
- What diameter charge piping?
- OT: UPS sucks ASS big time!!!!
- What kind of intercooler comes with Rev-Hard stage2?
- Turbo and A/C issues
- oil line for turbo
- Just found this while browsing around...
- HKS Type 1 Turbo Timer?
- just got my turbo R dynoed
- BEN from Importparts
- Guages....which ones and which brands?
- NEED SUGGESTIONS FOR SLICKS
- Which is better for turbo, 18lb or 14 lb flywheel?
- Does code 22 cause a limp mode in the ecu?
- how to convert torque
- Battle of the Imports in VA
- update on my motor... what do you think now..???
- INLINEFOUR you have e-mail from me...
- Hesistation @ 4k-5k rpm
- BAR to Psi conversion??
- can someone tell me more about 360 degrees thrust bearing?
- friggin' avc-r...does anyone know hot to tune this thingy?
- am I able to boost lower than 9psi when my wastegate is set @ 9psi?
- oil pressure switch
- Overcoming VTEC on a turbo
- Has anyone ever rebuilt a turbo?
- Detonation and other noises
- fmax turbo trim for b18b
- Please tell me what is going on with my motor!!! Help Pleeeeease
- which gauges?
- Best mounting locations for boost controller, timer, etc?
- Hondata
- Sinking feeling...help me out!
- Turbo kit for 99 Civic Si
- Pics--At home head porting, and some of ma snail project.....
- a/c and turbo`
- Blitz SBC i-D vs. Apex-i AVC-R
- tags are expired, getting personalized tags need suggestions....
- All ProDrive questions answered here..
- gasket for drag kit
- White Smoke out of my BOV & Exhaust ? HELP!!
- what t/bs are you guys running (high hp)
- Anyone know the FAX # for Zdyne?
- compression fitting at boost gauge
- turbo specks?
- runaway throttle?!
- 440cc fuel injectors...Lucas vs RC
- Suggestions please
- anyone use a garett t-25?
- O.T but I heard that Lisa Kubo's car is for sale?
- stock fuel pump with 440cc injectors?
- Can anyone have any info on the Power FC
- Colder Sparkplugs
- Twin turbo, possible?
- Ls block with greddy kit on a si ? is it good idea?
- What parts for custom turbo
- does PRODRIVE have a website?
- First turbo
- F-max turbo kits, which is the best anti-detonation method?
- Electronics install
- Fuel Pressure Regualtor crapping out?
- Teardown pics...
- GReddy GSR Owners: ECU wiring diagram?
- Dont ever let ProjectD2-Jeff and 00SilverLS in your car...
- oil gauge...electronic one or not?
- web sites
- Is it ok to mix pump and race gas?
- Has anyone ever dynoed >320 hp with a 60mm exhaust...
- i think this is all i need to complete my set up and maybe hit 400+ hp
- best tranny
- OT: My Downpipe fell off!!! (my 2,030 mile in two day roadtrip story (long))
- Real turbo gurus, I talked to FMax and this is the setup they recommended, what do you think?
- Fuel pressure regulator????
- High HP guys- which oil pump?
- What should i watch out for when using ZEX???
- Drag's website
- Oil pressure question?
- rubo Exhaust question!!!everyone look in here
- Max boost
- leaky head gasket?/ new turbo setup
- on the air/fuel gauge what wire on the o2 senser to hook up to
- greddy kit down pipe
- bad injector?
- Fuel Pump
- How much to drop in pistons and rods?
- hi flow cat for 3 inch exhaust
- A/C, Turbo on a 1991 CRX si
- Better Fuel pump and/or fuel injectors
- TURBO REBUILDs
- Where can I get some Slicks?
- FMU PIC... how is it tuned?
- 442ci Quad-turbo 10000RPM race engine technical article
- Manifold suggestions...
- Does any used fuel injector work?
- anyone know cheap dyno in socali?
- Fuel Pump...Inline or intank?
- Greddy turbo question
- Which brand and weight oil do you guys use in your turbo'd honda's?
- pump gas
- Best price for Je pistons and eagle rods?
- If I had a Motec PLM.....
- what to do please help
- How do you dyno?
- Drag kit install
- Recomondation on guages for JRSC
- Best Price on Rev Hard Mani
- Crane Valve Train
- XS engineering?????
- Strait up turbo poll.
- F-in vtec code is pissin me off, need help please
- Need some help on my T25
- whats the deal with apexi safc?
- Does anybody have a gsr oil pan for sale?
- Does a turbo really silence your exhaust note?
- Help identify FMU
- Does a EuroR intake manifold help a turbo setup?
- Drag turbo questions
- HPC or jet-hot for turbo manifold and turbo
- any one have a turbo kit vacuum line chart
- Best Turbo Cams (quick ???)
- kinda OT: but help..brake rotor bolts...?
- MAP sensor malfunction? Help!
- Hi flow cat
- Rspec Turbo timer
- vacuum at idle and in gear.
- buildup
- Need full exhaust for turbo setup. Whats good and QUIET!
- Bogging?!? Help!
- DRAG 3 gaskets
- quiet muffler for a turbo teg?
- 3rd motor mount insert advice
- Would kind of power and times would I get w/ the Drag3 from the groupbuy?
- is it worth it to do forced on a 5th gen prelude
- i took apart one turbo piping and oil film in it
- holley pump?
- Best turbo setup for H22A4?
- Check valves to fool the ECU
- Best Valvetrain for turbo/NA GSR??
- Dp, Test Pipe, Cat
- Question about Importparts Drag kit
- Ls/Vtec Turbo??? Possible??
- Forced induction and engine strain
- drag 3 kit "black box" questions.
- where to get a missing link
- Need to find a hole to put vacumm lines through firewall
- Which is better for turbo applications, huge TB or ported intake manifold??
- Big question, gotta know!!
- fuel pump?
- 1 Civic Sedan and $4000, what's the best thing to do?
- toooooooooooooooo slow
- Dyno tuning? AEBS or Dynamic Autosports?
- im bored! so whose got the fastest turbo honda on here?
- hey guys, got a question for yous
- running forced induction safely
- no fun installing fp gauge on jrsc'd h22a : warning, pics.
- When is the fuel pump supposed to turn on???
- I need advice on a userd T3 turbo
- New Jersey: Whats the deal w/ turbos and legality?
- Hits 9 PSI, stays there for a few seconds, then boost starts dropping?
- best way to hook up a cat to a turbo/3" exhaust?
- Need Help with Potential Setup
- Those slim radiator fans.........
- Inline Fuel Pump
- This is what I want out of my car, what do you recommend?
- Some new pics....
- Rumor! Apex i 3" turbo exhuast
- Boost spiking on JRSC??!??
- NGK Plugs in my GSR w/zex?
- When frustration sets in....
- Revved LS to 8k+ rpms what did I screw up?
- Spraying the intercooler black/gunmetal. Ineffective?
- Oil Pan Torque Specs?
- what turbo?
- Turbo install help?????
- Should I thermal wrap downpipe or intercooler piping???
- J&S Sensitivity?
- Turbo b16 in a 6th gen hatchback
- anyone had ever use a k26 turbo?
- ??? fmu and high pressure fuel pump comparisons to additional injectors
- who have had problems with total seal rings
- im looking for opinions and prices
- someone please help me decide on boost controllers
- VAC LINES
- Whats require trimin, removin stuff etc install Drag III kit???
- MAP sensor? relocate it with standalone (HALTECH)?
- anyone ever seen one of these before?
- Turbo Manifold on a 1991 CRX si
- Anyone willing to publish one of the kit turbo install manuals?
- i installed my new fuel pump
- The correct term for NITROUS OXIDE
- I updated my Page..check it out..!!
- AVC-R Tuning
- ok let me know if this is all
- FREE Importparts.com Stickers!!!
- vafc and JR map Conv.
- 9psi Woes
- anyone selling a missing link?
- EGT Probe
- Rich/ Lean Issues on a FI LS
- TURBO REBUILD
- Need some help - turbo/fuel/ignition/overheating...
- sohc drag gen 3 intercooler piping
- check engine light. i think it is 90
- Exhuast/Downpipe Size Help~
- Best ECU replacement?
- Hondata Problems (please help!)
- Turbonetics Turbos
- Calling It Quits ...
- Quirks of the Drag kit? Want to keep it real when it comes to installation...
- pressure flex question
- how many miles do it take to break a fresh built motor in
- How come some cars you can hear the turbo/blow off valves at LOW RPM?
- muffler on wastegate dumptube
- High compression on a FI motor (drag motor)
- what disk shoudl I use with the vortech?
- EBC suggestions?
- Introduction
- If you are interested in a DRAG III kit for your type R, check this out!
- Upgrade to ball bearing?
- THERMAL QUESTION!!!! need help quick!
- can anyone help me w/ this?
- please give me a new member a worm welcome and with that I already have a question :-)
- Teflon Tape or Paste?
- Hesitaion Problem at 35oo rpm's
- what size injectors are the stock 91 ls use?
- Anyone's Autometer A/F Gauge break?
- Electronic Boost Controllers and turbo spool up time?
- FPR: SX or SARD??
- Too early to go Turbo??
- Ball Bearing turbo discussion
- Is a new ECU required when upgrading fuel injectors and pump?
- Maximum boost on a bone stock 1991 CRX si motor?
- deltagate wastegate w/ 9 psi spring
- Running Lean...Are there warning signs when you boost is getting too high?
- Need help passing NJ inspection with turbo
- intercooler efficiency, which one?
- 310s?!!
- LSD
- boosting 10psi on B18C1
- Is upgraded intank fuel pump needed if purchasing an inline fuel pump?
- DRAG 3 vs. Revhard
- What is a good 3" muffler to use?
- Houston meet up/dyno tune....
- map check valve problem
- Do the greddy kits run lean?
- lots of oil out of breather
- ls turbo questions
