View Full Version : Forced Induction
- Another PCV Question
- which way for Airflow FAL radiator Fan?
- egt in middle of manifold?
- Where to Buy Thermal 3in TURBO Exhaust???
- Cheapest yet most powerful D16Y8/Z6 turbo kit.
- Help! need conversion table zeitronix wb with hondata
- Turbo Rebuild Complete Torque Specs Here!
- Solution to my D-series headlift problem...
- Price for turbo kit install
- Tapping IM best plan for Vac source?
- which pistons for nitrous
- back from dyno JRSC ouch!!
- greddy 15g downpipe options??????
- N2O on a 11:1 stock bottom end tuned for all motor....will a 65 shot be safe?
- Walbro/aftermarket fuel pump connections: did you solder or crimp?
- is a EBC really better than an MBC?
- NEED HELP FROM JRSC GUYS! ASAP
- MAP sensor problem..HELP!!
- D16y8 300WHP on pump gas
- w00t!!! just won a ZEX kit on ebay!
- What size Wheels/Slicks for me? Please help...
- Built 2.0 GSR GT40 etc, setup & dyno
- SOHC dyno z6 with 10 psi Vid inside
- SOHC turbo Project-BAAD idle with RC 440's and Walbro 255
- ** need safc "before start-up" intructions quick! **
- compression ratios for shelf wiseco pistons?
- Just home from Dyno.
- i searched didn't help i got vac problems help...........
- Does 4-wire o2 sensor work? Or do i need 5 wire for tech edge wideband?
- HOW can i know if i need a FPR ??
- Need directions or pics on drag3 piping on crx
- a quick yes or no question
- EGT gauge with JRSC...??
- Help w/ Motorla 2.5 bar Map sensor
- Need help understanding piston choice etc
- waste gate question
- Smoke from tubo... white / blue.
- Loosing a little oil, endyn breather smoking a little...
- Thick white smoke comming out my exhaust...HELP
- What's up with this sputtering??
- I need to know where to get oil feed and return lines and a downpipe
- What to expect from a T3/T4
- Greddy internal gate actuator...is there anything that fits??
- boosted d16z6 advice!!!!!!!!!!!!!!!!not b18 b16 h22 d16y8 gsr civic jdm rota
- JRC johnny race car intercoolers....too good to be true??
- Turbo SOHC set up?
- turbo
- Fried Drivers for injector #1 on P72 ecu. Any fixes?
- i cant find someone to rebuild my starion td05 12a turbo can someone help me
- gsr pistons in b16
- What fuel psi are you running?
- Fluidyne , KOYO or C&R?
- Greddy 15G V. 19T
- pvc out now smoke
- what kind of downpipe is this?
- 3 " down pipe for inline pro manifold
- crx...ls motor jackson racing / vortech
- First timeslips, what do you think (b18c1 13 psi dc2)
- Rust on Wastegate
- best crome tuner in SOCAL???????
- Anyone running a DART block?...my motors screwed!!
- intercooler piping help
- What is a "bar of boost"???
- Turbo fasteners
- dumb question....anyone ever 2 step while moving????
- Need Help Have Pictures Motor Assembly
- D16 Turbo with NA intake manifold??
- How to identify fuel pump? Walbro 255?
- can a turbo blow/burn oil without actually having blown seals or shaft play?
- stainless vs. cast
- prevent boost spike
- After Warm Up... Very Hard Top & Bottom Rad Hoses ?
- Is it bad to run the wb o2 sensor in the downpipe for tuning? o2 sensor questions
- hks evc5 questions?
- royal purple oil???
- Crushed Nylon Boost Wire
- Gm map sensor wiring??? Already searched..
- what is the power range of t3/t04e 54 trim...63 ar
- Greddy Profec B solenoid
- vaccume source
- need tuner in north Dakota for hondata
- built motor Greddy 18g users, what psi are you running and what exhaust and dp?
- Greddy Emanage
- Which Turbo Setup for Jdm Gsr?
- BEST INFO I EVER READ
- If i get a gm 3 bar map sensor how do i wire it up and will i have any reliablity problems?
- What are the torque specs of a b18c1 with a b16 head with arps?
- Greddy 18g controlling flapper
- Rust on Manifold
- NA P&P .012 milled head for boost???
- kink in the oil return
- Base Map for the E-manage for 6th Gen Accord
- No boost
- Boosted CRX project in DFW
- Correct Intercooler Piping?
- Intercooler Test Fit
- Attn 'crome' users..
- Loss of Boost
- 3" exhaust Thermal R&D or KTELLER Kit
- relocation time... where do I put my washer fluid bottle??
- What compresson for h22a turbo build?
- Q: WHERE DID THIS TURBO COME FROM?
- What Would You Techs Reccomend???
- what kind of numbers will i get with this setup?
- How can I identify DSM 450ccs from the 390ccs? Also color wise?
- efficiency of v trim turbo on h22????????
- Supercharger and 9.3:1 Compression Motor ?
- temporary charge piping
- where to download uberdata version 1.66
- uberdata help!
- Stock B18 turbo
- Help on choosing injectors!!!
- can I Relocate IAT on BLOX manifold?
- sleeves need to be bored/honed??
- Adding a 5th injector....
- wat r good turbo cams
- gt17 turbo...
- need help asap! no boost or very little boost
- DIY bottle heater?
- JUST SOME TURBO PICS
- I need some time off
- high flow cat question
- fmu adjustability?
- turbo specs for b18b
- SRT-4 TUNES IT SELF
- Vtec and oil pressure problem. Please help!!
- Part Throttle boost bad ?
- precision 880cc injectors
- anyone having problems breaking Crower vtecs cams.
- Rare Dyno Vehicles
- boost drop
- Which motor to use for d block 10psi?
- Installing head
- Nology coil causing radio static?
- Fuel Delivery problem
- EXOSPEED
- How to wire in-tank fuel pump
- If you're running IM assisted crankase ventilation, check out my revised setup:
- AEM EMS for *2004* S2000????.........help
- black plugs
- ATTN: LS-turbo, 10 psi, on 450's, with uberdata, can you email me your map?
- diameter of pipe that a srock dsm blow off valve is attached to?
- 10.9:1 compression, 100hp nitrous shot, hondata, which injectors??
- NEED OPINIONS: What Rods to use?
- Turbo size question!!! All opinions welcome
- wideband pics needed
- My Shitheap keeps burning out Rotor Arms!
- b20 turbo... 220hp n 204 tq
- Super 60 T3 (Ford Supercoupe)...stage 1 exhaust?
- compression test
- spraying N20 thru sohc stage 2 all motor cam safe?
- Favorite soch turbo vid??
- slim line fan?
- dsm blow off valve
- High Mileage + Stock Sleeves + Boost
- Detonation Problems at Idle and Full Throttle HELP!
- Stock B16 turbo
- additional parts to drag/fmax turbo kit
- RC Injector Question?
- Maximum amount of horsepower stock sleeves can handle?
- Will a H22a engine run fine on 100LL aviation fuel ?
- Overheating Problems Still, NEED HELP!!!
- What collector gasket to use with Kamikaze header
- just got a 91 ls motor
- Injectors w/ boost?
- Need help on 350z any takers?
- j pipe?
- whats the difference between tuning Turbo compared to N/A?
- turbo exhaust question
- missing link ques
- WTB: 450cc blue tops...injectors. *SOCAL*
- Can somebody give me a measurement of a t3 turbo flange?
- Piston Ring Question.........
- Which would you choose?
- intercooler that will fill eg front bumper?
- DSM's flooding engine on startup...
- Dyno'd the turbo del sol today (dyno sheets inside)
- 16g EVO turbo, specs anyone ???
- Which turbo you think work good with F22C
- My turbo is bigger then yours!
- log style turbo manifold
- which engine to use
- automatic fuel management
- just want to make sure i am doing this right . . .
- boosted my car and now burning oil
- what would it take to get my car to 350hp?
- dyno #'s
- quick spark plug question
- Video Inside - Question too
- Converting form stock to floating wrist pins
- how much boost safley
- hks evc on lock mode help
- cybernationmotorsports.com stage one turbo kit
- Nitrous Solenoids...
- how much psi on a engine with blockguard
- no more all nos car!
- Need Help w/ hks evc
- turbo piggyback and stock MAP woes....
- Turbo HP?
- HKS SSQV BOV... good or bad for h22 @ 8psi?
- Keep my IC or go bigger?
- In progress EJ1 H22 boost :)
- gasket for dp?
- selecting manifold not a lot of room need help please
- boosting D-17
- Jrsc belts researched and revised!!!
- Hope this will work
- weird idle/ vac problem... some what long.
- T88
- Helper bracket, Think this will work?
- Injector question...
- LINK: Rim choice vs Turbo
- Cold air intake for turbo inlet
- what radiator to run with gsr turbo setup?
- RC 750 saturated injectors - Does your car pop at idle? Any tuning issues?
- Torque Specs on Cusco/Geiken Super Single Pressure Plate
- limits of stock 1g B16a rods
- Need Help with boost controller
- Turboing EX
- Misfire CEL 74 Help!!!!
- Installing Oil Pressure sending fitting
- Oil Pan Gasket Leak
- Help with GSR Turbo!! 10 psi too high??
- How high of a boost can I go with 450cc and deltagate wastegate??
- questions on turbo setup to get 300whp.
- Any good numbers running chrome/phereable tuning?
- What flywheel to get for Turbo?
- Wideband with new external wastegate?
- Weird boost creep on road, but not on track !?!?
- help need 2 bypass map
- i want to turbo my 95 integra Gs-R. What do i need to buy?
- question about injector sizes
- turbo spooling... car not moving???
- how much boost can a stock gsr motor take??
- Forced Induction woes
- Which plugs and gap size
- looking for turbo
- Who has installed an Ultimate Racing turbo kit (S2K) ...need quick help.
- Help with Nitrous set-up
- Checklist for engine rebuild to handle turbo
- Trouble w/Greddy Profec E-01
- 7 PSI/ Timing
- Did I overpay for this turbo?
- Crankcase pressure
- walbro 255 quik question
- Fast & Furious BOV??
- this use to be a B16..
- Water Injection w/ Intercooler
- Importparts.com - Employment Opportunities!!!
- Can I put a GSR head on my SOHC Civix DX turbo project
