View Full Version : Forced Induction
- My "New" turbo has some shaft play??
- Difference between Garrett GT and Garrett Diesel turbo?
- exedy clutch
- Problems with boosted Prelude
- Boost Gauge readings off
- Vtec dosent enguage all the time..
- hondata 3 step not working.
- the difference in dynos does leave alot of people misinformed....
- resistor box
- compression too low?
- how long do oil pumps last?
- deciding on using an external WG . . .
- 100oct pump or race gas for my set up
- Getting a little Confused?????
- cam advice
- head?
- ls rod bushing
- having some issues with my lovefab top mount
- Revving the b18b1 to 7500?
- CRAZY STORY FIXED FIXED LOL
- CRAZY STORY FIXED!!!! with pics
- Vitara piston and rods install Q's ***Clip iside***
- Using nitrous with out shortning my engine life?
- ct25 toyota turbo
- oil return ok
- A few projects at TD Autowerkes
- Help with Endyn breather kit install
- SC H22A in EG
- Carzy Story With pics crappy pistons hahaha
- Heat wrap for downpipe?
- Best injectors?
- My fuel system setup!!
- i need some turbo help first one installing
- sure fire!!!!
- headgasket troubles
- Turbo T3/T4 Installation Instructions
- DSM injectors question
- Problems with the BOV....HELP ASAP
- what wideband setup are people using for e85
- manual boost controller
- problems with the oil pumps
- SX fuel pump? is it as good as the A1000
- Max WHP on stock bottom end
- nitrous jet sizes *searched*
- I got these piston rings from hastings and i dont know which one is the top ring
- supercharger timing
- sleeving service
- is this turbo any good? Not xspower ebay
- Dialing in timing w/ cam gear on an block w/ pistons out of the bore?
- Difference between NGK BKR7E and NGK BKR7E-11 spark plugs
- oil bung
- My break-in procedure ... i know, just hear me out.
- HOW MUCH BOOST>>>>>>>>>>>>>>>>>>>>
- Running Air Conditioning with Recirculating waste gate on '01 GSR
- Cams....which are you using/what do you prefer?
- Coil and MSD cap damaged???
- VTEC crossover and turbocharged cars?
- Built JDM B16A T3/T04E Turbo.... What's a safe amount of boost and horsepower it can hold?
- Turbo for D16
- add pistons and rods: get a reliable 472 whp!
- NEED HELP ASAP!!!!!!!!!
- 450 whp LS-T Build
- Official Boosted EG Thread
- ob0-obd1
- single turbo
- b16a2 and d16z6 turbo setup and basemap?
- Pic request: Hot side IC piping on EG w/ ramhorn
- Moates flash and burn...really really hot and not working...?
- what bov is this?
- buying used pistons?
- Delta Fin Intercooler.. IS it better than Bar and plate?
- motor help
- electric turbo????
- ITR in. B16 ex cam thoughts.....
- Turbo size?
- what suspension are you running on your boosted car
- mx-6 mazda, mazda rx-7 injector fit hondas????
- CRX intercooler piping help
- need a socal shop to fabricate me a downpipe??
- venting solution?
- Searched need some quick advice
- turdblow + heat = spark plug pic inside
- plugs look good after hard pulls. any reason to go higher heat?
- small bolt eagle rods. who is still using them?
- Machinist/Engine Builder in WI??
- Requesting video clip Profec B Spec II Greddy Electric Boost Controller
- piston and rod recomandation
- Max WHP thru stock head?
- question about T3 and T3/T4 manifolds
- turbo with mileage
- I really need HELPPP with my SUPERCHARGER!!!
- Ok to use bolts from advance auto for turbo mani?
- adapter flange ffor 38->44mm wastegate... bad?
- NEED HELP ASAP (oil problems)
- d15b FI plugs
- Wastegate supply tube length (how far from manifold)
- TURBO QUESTION
- 2.5" dp and 3" catback
- gape plugs
- crome tuners, how can i fix flywheel drop??
- Manual boost controller
- odd question about cold start settings(aem), injectors and wiring resistor box (with diagrams).
- IC piping for ek with foglights??? HELP
- aftermarket IAC or running two honda IAC in parallel?
- Whats the horsepower rating on a precision sc61 turbo
- cams! GSR or Skunk2 stage2????
- New member trying to post in classifieds
- Will Wastegate Size hinder HP?
- this oil line return ok?
- 2inch charge pipe from cold side to ic
- heat rap??????????
- map ?
- Need Opinions
- ignition problem? or something else?
- SC installtion prices
- Need a d series turbo mani
- shops
- difference between cusco catch can and moroso catch can
- Coolant Blows out Overflow tank under boost! HELP!!!!
- Would this front mount flow badly?
- fuel pressure help.
- Supercharger Pulley Upgrade Help Needed
- who is am admin
- Replacing the diaphragm in an external wastegate...??
- anyone ever do something like this?
- Ice pack intercooler
- Divided Topmount ?
- can i shut the car off during the break in time???
- PLX M-250 Unit + Wideband Gauge or Innovate Motorsports Wideband "stand alone kit"
- Almost got Jacked last night
- low boost to high boost switch question
- my daily driver em1 b16a2 motor dyno graph
- Precision sc32 Turbo
- Oil Cooler Question: Spin-on adapter over oem oil cooler?
- System Fuel Pressure @ Fuel Rail
- integra type r turbo PROBLEM Can anyone help???
- Hey Need some Opinions on Clutchs
- exhaust issue
- RC injectors?
- installing nrg engine torque dampener on my ls vtec ek hatch ?
- t-25??
- Lovefab Minime Users- what air filter
- put turbo on now car wont start
- Skunk2 Camshafts for our Turbo S2000
- JRSC question ( Forging Engine , Heat Probelms )
- need help on building a turbocharged d15b2?
- To those with 3" DP, bolt question.
- Skunk2 Pro 2 on a turbo H22?
- Question regarding BB turbo coolant line
- Crome????
- Been away from boost for almost 2yrs... Think it's time.
- hondatas300 and gm3bar map problems.. gurus
- Setup question
- dohc vtec with td04 turbo out of a volvo
- New member 400hp sohc club !!!
- GSR Turbo build, need advice
- quick question bout taped oil pan
- Can anyone help me. ? about Darton MID sleeved GSR block leaking coolant into oil.
- Do I need some gaskets?
- Synapse BOV.. any feedback
- Car is still smoking... Turbo Woes.
- T28 oil feed line How long does it have to be?
- D16Z6 Rods!! Please HELP!
- Apexi IHI Turbo Question
- Endyn H22 Upgrade pulley
- gm boost solenoid/aen ens, vacuum direction on selonoid??
- what size oil line to get to replace stealthmode turbo inlet?
- what fuel pressure regulator ?
- A new try to Turbo my CRX. Need some Awnsers
- How many of you experimented with cam timing on vtec engines, and your results
- wheel hop?
- Catch can idea, ive searched, pics inside........
- b16a2 oil squirters question.
- Re-torquing ARP head studs.
- does the length of oil line matter?
- sleeper engine shots
- Exaust housing.
- new fuel pump or not/ tuneing
- Call me stupid.
- How would I know if my diff is toast/not working.
- Need Tuning in Chicago, '95 prelude turbo
- GT35 Set up
- high hp guys, what do you use for tranny fluid???
- changin my BOV
- BOOSting which?
- k24 weak?
- Compression and nitrous
- just a question about AEM a/f meter
- b20 most boost
- h23 or h22 buttom end(turbo build)
- Fully built head + bottom end, stock injectors, stock exhaust manifold/exhaust, can i run stock ecu?
- how much power
- Questions on S300
- Stupid question, dropped block any damage could have resulted?
- pcv little quick question Need help ASAp
- hmmm, boost for us backward UK folks
- msd btm
- Newbie turbo program question
- Guages.......?
- Help Finding a Video!!
- BOV's input
- what noises do turbos make when they are going out?
- smoke and oil out of breather filter? help
- It really works!!!!
- f20c sleeves vs. b series sleeves
- Site to buy a supercharger
- ls vtec turbo burning oil
- Engine Questions
- not making full boost..?
- vafc v-tec controller tuning for vafc hac turbo setup?
- act clutch squeal?
- b16/type-r head nitrous
- SPUN ROD BEARING???? What to hear for...
- fuel pump question
- 12mm fuel rail fitting
- sc63 users chime in
- 3000whp integra dyno!!
- dyno results of my peakboost civic 3-28-07 with videos
- oil drain flange bolt?
- Anyone use this Humphrey solenoid with the AEM EMS? For boost control.
- Question about using a externally wastegated T3 houseing on GT28r
- how much power/torque will this clutch hold?
- blew my motor tonight.. =[ peaceout turboo
- which is more tuffer gsr or ls tranny for 500 hp boost
- Any shops in San Diego that does tuning / dyno for 1st time turbo cars?
- LS CRANK INTO GSR BLOCK
- swap HELP!!!
- b16a turbo is makin silent fart !!! Need help asap
- Greddy 18g questions...
- need help - blowing ecu fuse
- Sleeved Blocks.
- oil dipstick
- BLOW off valve vacuum sources
- its safty to use Lightweight crank for 600hp?
- fuel lines???
- gsr turbo smoking.
- stock b18b
- weird starting problem/?
- Aftermarket throttle bodies
- Manley rods bolt torque
- which gasket?
- pic request Integra with large fontmount
- nuts and bolts for turbo? help please..
- arp head studs
- Direct Port VS Single Fogger
- Bearing Colors(Calling Jeff Evans)
- What would you do-H2B or SOHC TURBO????
- SOHC valve train and cams?
- best turbo manifold/exhaust gasket to use to prevent leaks?
- Wanting to turbo!
