View Full Version : Forced Induction
- Planning to go turbo on my B16...
- Got my ENDYN/MOROSO catch can! Got 1 question..
- intercooler anodizing
- Edelbrock inlet size ?
- cft in orlando
- leaky BOV
- huge oil consumption problem...
- ls turbo fmu 10.1 or 8.1
- Would you sell your Turbo project for a TT Supra?
- Need a Tuner to Phone-Tune My Car
- oil feed
- Neptune RTP
- What else can i chip besides a P28?
- WHAT IS THE MOST POWER THAT EAGLE H-BEAM RODS CAN TAKE
- How to Tell If Line is -3 or -4
- QUICK QUESTION WHAT CLUTCH TO HOLD 450 TORQUE OTHER THAT YWIN DISC
- Turbos service manuals???!!
- AEM
- LS Turbo?
- Aem EMS
- 24x12x4 Intercooler? Anybody use these on DC2's?
- Integra radiator clearence issues
- turbo dumptube relocation suggestion.
- What do you guys do to prevent overheating?
- fully built gsr head complete crower valvetrain on boost? opinions
- intercooler
- Cylinder head chamber damage report
- RC P2LM-535 Injectors? Need help identifying these
- tilton clutch... no more splines on the disc
- Is this Ram Horn Manifold worth the purchase
- How do i clean injectors?
- T3/GT40 Turbo
- Need some help with Cyl 3
- 94 Integra ls Turbo plans... Need some help please
- HOW MUCH POWER CAN RC750cc MAKE
- bore match
- Turbo hatches
- stock b16 vs semi built b16 numbers on 8lbs...
- Greddy Boost Controllers
- 3bar map into crx intl question
- muffler question?
- Weird overheating issue while in boost
- Broken Internal Wastegate..
- Good place to get turbo rebuilt
- Boosted The Teg!
- pcv valve
- realistic hp and boost
- To whoever has a revhard kit... What oil line did the old revhard kits come with?
- Oil Drain Line Size
- real turbonetics turbo?
- new ignition set up= new tune?
- oil in LINE asks... leaky threads ...help
- stock 99 honda civic si w/ b16 turbo results 284whp & 191tq 12psi
- damn oil return
- Crower Customer Service - Amazingly...Bad
- Fuel Tuning Help. I'm close but stumped!
- Precision SC6152E VS. 6169E
- noobie boostin greddy.
- Buiding 2 boost motors..Crank question..
- Sleeved b16
- New motor build. What needs to be done to get it ready?
- need some help installing my turbo on my 91 civic...
- total timing on ls
- anybody ever used a garrett t3/t4 .58a/r on their b16?
- anyone running a b16 with a t25 eclipse turbo?
- spooled motorsports ?
- dyno tuning advice needed
- Cutting off horribly with any amount of throttle
- Did you tune it yourself or pay to have it tuned?
- spark plugs... too rich?
- JRSC issues...can permatex cause this?
- noobie lookin' 4 a good setup!
- Help me pick my parts for a Turbo d16a6
- tial BOV flange to GREDDY flange?
- pistons ?
- Secondary gsr butterfly w/boost
- how much power can 550's take
- what to build
- Can a block extension be removed?
- Help me pick a turbo for the mighty D16
- WA Tuners!
- fuel options for 03 civic (boosted)???
- h22a-1 ecu
- WTB- Driveshaft level 5 axles
- lsvtec/1.8L vtec people, whats your total timing at????
- Coolant Lines for BB Turbo
- Here are some wideband graphs from a crome generated ign/fuel map
- Does it make a difference which side is ground on injectors?
- rc 750cc too big?
- neetronics MAP sensor and crome
- TUNNING QUESTION FOR A JRSC GSR
- Turbo H22
- need turbo help...
- Engine Noise: Pistons or valvetrain?
- TARGET A/F At WOT and Crusing speeds
- Single Cam Crankcase Ventilation System
- Is this a good choice for my turbo?
- turbo rebuild kit...
- Question about Catch Can, confused on one small thing...
- Which Injectors To Get with DRAG kit? / Which walbro fuel pump, 190 or 255lph?
- Where? Who? has the Link for Full Race Pink Hatch vs RX7 Video
- How much power can u squeeze out with a turbo motor with a B18a/B head
- Vortech Supercharger on a B18C1/B18C5???
- Wiring a stock tach up to a MSD digital 6 box?
- F*$& NOW WHAT?
- Where to tap boost gauge on intake manifold?
- Full-Race B Series Intake Manifold
- wow!! this is funny but disturbing...
- My new 57trim SOHC setup w/vitara's- pics, dyno results.
- what kind of power band out of gt4088r
- B16 cometic head gasket, now cam timing is hard to set properly. HELP.
- piston rings
- oil return
- what do you think about this af plot?
- Resistor box question with 1000cc RC injectors
- Where do you head gasket reusers get your copper gasket spray?
- Cooling problems after "upgrades"...please help...searched
- question on axcel
- quick wastegate spring question.
- t3/t04e 50 trim .63 spool time (d16z6)?
- an idea how about an all dyno thread?
- help identify gaskets
- d16 head studs on d15?
- waste gates....
- T3 Super 60 Turbo .60/.48 or T3/T4 T04 A/R.50
- AEM FPR fitment
- Master Power Turbos??
- HKS SSQ Bov internal construction problem?
- this fuckin sucks!!
- Car wont idle
- thinking on runing na for a month until i get hondata
- does a turbonetics 60-1 fit drag mani and dp? 5 bolt
- 2" intercooler pipe??
- Blown flange gasket.....
- block sleeving
- has anyone slapped a blockguard in, and run it without extra machine work?
- New Titanium Coatings! PICS
- Going Boost On D series???
- Which VSS will work for my car?
- Internal wastegate question, and my New turbo!!
- Do i have to Retune in the WINTER?
- SRM Crankshaft anyone?
- Oil pressure still high with restrictor
- whats the max whp on any honda 4 cylinder........ever!!?
- i want to know how to instal turbo on h22
- More power?
- piston oil rings where to find them?
- what kind of bov is this
- Which turbo should I buy for a fully modded B16a1 engine. (gt28, gt35R, t3/t4, T-70)
- what timing should be set for greddy turbo?
- Need help asap
- Warm Start - Car Bogs n Shuts Off (TE ng55, gm 3 bar) WHY?
- what power can it take
- turbo gas question. what octane to pump
- what u guys think?
- is 235f BAD?
- My turbo setup...complete?
- recked my car...help me out BUY MY PARTS..
- Will 96-99 GReddy Kit work with 00 LS?
- tuned the b16t today
- where can i get a cca intercooler?
- need sugesstions on what to do with exhuast (from dp to exhust)
- sohc-t daily driver clutch recommendations?????
- Your thoughts on Crome Pro?
- Seriously WTF?
- Need Garage in my area to install engine/turbo?
- Drivability of Clutches
- Anti-lag, has anyone tried this
- New h22 turbo project. Advice?
- What you do when you are mad at your drag car
- For those that TUNE TURBOEDIT; EXTREME HELP NEEDED INSIDE
- ef turbo pics
- FI EXPERTS - ANY SUGGESTIONS?
- turbo question, from a n00b (please don't hate)
- HELP what is this?
- gear dependent boost controller
- Exedy Stage 1-will it hold?
- Lowering compression with a thicker head gasket...
- Ericks Racing built
- so i spun a bearing
- Brisk Racing Turbo Spark Plugs
- What do you Think?
- help! low compression test
- Attempting to pass Fairfax Emissions... Need advice.
- Injector clip wiring help *pic*
- Civic GX pistons factory forged?
- which tranny should i get for turbo gearing (prelude)
- Supercharger...need help!!!
- any street tuners in san diego or local ?
- Crome / Uberdata / datalogging newb questions
- Best site to order EEPROM chips for uberdata/chrome/neptune (searched)
- dyno'd the sol
- 4" vs 3" exhuast
- velocity stack
- Intercooler questions
- Y shaped barb fittings?
- Fully Built D16z6--What Turbo for 420whp????
- Question about Crome Pro?
- Blown blocks, what do you do with them?
- Intake M Throttlebody with turbo car any difference??
- Piston ring filers
- Is there any good tuners in the (772)/(561) area?
- yellow top dsm
- what year prelude injectors...
- NJ Inspection Suggestions/Regulations
- NEED HELP WITH JRSC ON A GSR
- return line hose type?
- Running a turbo open with out a filter?
- What size intercooler will work with a 99-00 civic?
- H22a build for 22Lbs boost
- little black marks on cylinder walls?
- compression question
- MISFIRE!! went away, came back...
- Ramhorn or Top Mount????
- greddy rs blow off
- WANTED: D16vtec Engine
- *CC Fab update thread*
- Found some dyno time last friday. Thanks Servion!!!
- Q On Exhuast Piping HKS
- bleed valve boost controllers, do they really cause lag?
- MBC problem
- Boost....then no boost.....??
- Buying new turbo Manifold????????
- exhaust a little too high
- is this a good B18B turbo set-up
- ebay wastegate spring
- SC question
- having problem tuning my car with zeitronix 3.5 bar map w/ hondata s100b..
- new toy
- where can i buy turbonatics turbo's rebuild kits?
- Turbo oil drain help
- Motorola 2.5 bar map sensor
- crower turbo cams opions
- Downpipe Fabricator in Los Angeles ?
- What cams should I use in a Supercharged LS?
- *PLEASE* HELP!!!
- Bought Precision 1000cc inj. don't fit OBD1 clips
- Learning the turbo basics... need an asnwer
- how do you know when your a/r is too small?
- 3.5" Downpipe on a DC2 w/ Ramhorn?
- self tuners/tuners, do you use the grid or graph format to make corrections with??
- ?? STOCK H22 TURBO ??
- OVERHEATING PROBLEM!!!!!!!!!!!!!!!!
- Throwing code 1? Using wideband for ecu o2 input
- Quick ?, TB vacuum line
- 2 step....or 3 step
- pump gas or race gas?
- 86 Si finally finished!!! 592whp evans tuned...
- turbo setup... b16, ramhorn, hy35, and alot more. check it out, ef...
- Internal Wastegate Broken...how the hell do i find a new one.....
