View Full Version : Forced Induction
- just done a compression test. need help
- Props to Full Race
- smokin Teg
- Where to get a 16G turbo? How much should I expect to pay?
- help me turbo my 92 accord please!!!
- TT audi
- Eagle Rod installation question:
- What alternator belt with an ATI Dampener?
- B16 rods in a6 block ??
- F series turbo kit
- ESTIMATE HP Output w/Ls vtec w/9.0 pistons h-eagle rods t3/t4 turbo @15 psi boost 3"exhaust cam gear
- crower econo rods
- Anyone use a similar set up before ? LS b18b1 motor b16 tranny and t25 turbo .
- need someones help with vafc wiring on obd1
- So confused - what bottom end bearings do I need for rebuild?
- building d-series: couple questions
- inspection coming up
- Can i use the output of Plxr500 to display a/f onto the Apexi Timer???
- Hondata on a ob2 vehicle...........
- wideband o2 sensor: do you use it daily or just for tunning?
- Manley Pistons
- How Big is your Turbo
- just boosted my 00 si, im now running into some kinks
- Boosting a CX hatch?
- using moates burn1...what is verify chip w/ guffer?
- turbo cam question
- Defi gauge recall
- Can anyone tell me if this is ball bearing
- what do I need to do to have a/c this summer?
- problem with fully built engine, help ....
- If Darth Vader ever ran a turbo......
- how good is the hondata s300?
- uberdata tuners in PA??
- chipped ecu working on friends gsr but not my ls?
- boost gauge question kinda strange , lol
- What e/h for an ep3 with JRSC-R?
- vafc wiring throttle help
- turbo cold air intake
- Cutting new turbo
- Crome tuners in San Diego??
- HELP: turbo not spinning at idle....
- A few new pics of my setup......
- turbo tuning low idle HELP!!
- to4b to4e question
- FI Viper build continues...
- HELP....dnt no which TURBO 2 use
- Getting ready for boost
- New eBay seller LEGIT? $1600 GReddy Kit & $1700 Drag Kits NIB?
- boosting my d15b2with Si head...results?
- b18b turbo running
- Hardware for tuning Chrome.
- My Manifoldless Hatchcrap
- Help me find a compressor map!!
- Boosted mini me overheating(head gasket?)
- newb questions
- fuelpump and ecu failure
- Bare B18C1 Block + 84mm LS Internals and Crank
- Stock GSR dyno #'s, anybody esle use larger turbo's at low boost??
- everythings hooked up, no vtec?
- control boost on centrifugal supercharger with External wastegate????
- Well, it's official. Going Full race w/ rebuild.
- Hondata s200 nitrous control questions
- s200, fmu 8:1 and missing link?
- Going for 400WHP with my SOHC
- What does the stock Greddy WG position looks like?
- Shop Hit, car stolen, Bloomfield, NJ...please look out for these parts
- V-band ?
- Boost guage bounces
- which guages are you guys running with?
- PEAKBOOST KITS?
- HOW TO CHECK TO SEE IF THEY STILL WORK!!!
- TBS!
- anyone use $18 motorolla 3 bar map sensor?
- Turbo Manifold Decision
- Built B18A Question
- Quick Traction Question!! Pro Help Me Out!
- greddy type r bov
- PROJECT TURBO LUDE IS DONE!!!
- first new turbo start!!! ASAP!!!
- Friend's project near completion. We need some input
- Crome and PLX-M300R
- quick question bout zex wet nitrous kit using NOS wet fogger
- Should I install my ARP headstuds or wait?
- how to leak down boost???
- Charge pipe help - CRX
- Problem with a friend's Turbo DA tuned with chrome
- hy-tech turbo headers- anyone running them?
- my new ls turbo setup
- boost creep once it hits vtec, help out pls
- Are these rods legit??
- walbro 341 and 342 differences?
- nitrous wiring help ???
- UTAH TUNNING (crome or uber)
- Going LSVTEC - Any Problems with Keeping Current Pistons?
- hks ssqv or tial 50mm???
- XS AX-1 BALL BEARING VF-23 Questions.
- check valves
- B series oil pans?
- engine miss...help me read plugs!
- K20 Turbo or K24 Turbo ???
- Problems with Alaniz Technologies
- Clutch Upgrade.
- affordable cams for turbo B16 ???
- Jackson Racing Supercharger for b18c5
- HELP! which ecu tuning for turbo d16y7?
- Can i get a ls engine shot?
- do i need thermal wrap?
- tuning my d16
- Throttle Body Water Line (Greddy Kit) Q
- H22 Nitrous Question: recommended shot/opinions/experiences?
- check valves
- new car + block guard
- does street tuning require datalogging on an ecu?
- exhaust
- 325hp B16?
- injectors!!
- B20Z with NOS?
- what would a gt3037 AKA gt3076 do on say................
- new stuff from ssautochrome
- Why..?
- Which cams are these???
- Liquid 2 Ar intercooler question
- Methanol on Boosted engine ???
- exaust question
- When to install turbo components/upgrades?
- Chrome installer in NC?
- lookin 4 turbo kit cbr600
- WHERE CAN I GET THIS
- Anyone know about the *fastest* NON-vtec D powered car???
- B18B LS dyno w/ Nitrous
- RC 440 injector seals?
- GT4082R ? and TR30R Turbos .
- car is running like crap
- D16a6 arp head studs?
- why is my chipped p28 throwing a vtec code when its an LS motor?
- Who has Apexi El1 boost gauge? need help....
- ITR + JRSC. Should I lower compression?
- Little Help Please
- Pistons
- Rollerwave Rings
- Anyone heard of this deal?? Sound good?
- shaft play?
- difference in Golden eagle 84mm gasket and drilling a CR-V gasket??
- ITR/CTR, BLOX TYPE A or BLOX TURBO
- B16 Injectors? and CC-Fab Wastegates q's
- where can i find axles for a boosted gsr
- Greddy 15g rebuild kit??????
- Why limp mode??!
- oil seepin from headgasket
- quick question can u use a 88-91 civic non si resistor box for 450cc's?
- where can i get a t3/t4 flange?
- gt40/67 or pt67
- Hondata harness need help broke plug....
- missing link and fmu(h22a)
- What can i run with..
- Could Nitrous line be used for oil feed and clutch line
- PROOF!!!! Sohc non vtec.. 300+whp and 11 sec runs..Vitara setup
- TurboEDIT with ODB0?
- The Official 99-00 Civic Intercooler + Foglights Thread
- 278hp GSR on crome
- Best Mounts for jrsc b18 w/ hydro tranny into EF (crx)
- Turbo question?
- Question About Wideband o2 w/o controller....
- how to test boost controller?
- Whats the difference in Blue top 450cc and black top 450cc injectors
- Charge piping not perfectly mandrel bent..
- ATP Boost Controlled Cutout or 3" Exhaust
- what size trubo is this ???
- new pics... y8 turbo ej1
- HDMmotorsports Hatchback -Street Tuned Crome- (Video)
- daily driver sohc v-tec
- 450cc injectors on a d16z6 turbo
- new turbo, oil *searched*
- At what air intake temps do we need to start using an intercooler???
- Turbo Crossmember question
- GT25 users?
- what is the best cable trans to have with a b18a turbo?
- 1/2 Core Radiator on a Teg?
- jrsc and 25-35 shot.... plug question.
- Built and Boosted D series part 2: Throwing more money in the bottomless pit
- Greddy Installation manual
- intake manifold~fuel injectors
- Aem Fpr question
- T3 question.
- cam suggestions for d16
- a little something something
- tuning question?
- second attempt at charge piping....
- prelude oil pan
- Wondering how to break in a new clutch??
- ARP headstuds, or OEM bolts?
- Clutch problems!! NEED HELP NOW!!
- bov maintenance
- Reccomendations on Cam Gears and Cams Turbo set up
- car for sale
- aluminum exhaust
- Stage 3 Blowzilla vs Stage 5 SC61
- injector/drivability question!
- were can i purchse the cheapest moroso,or pre tapped oil pan from?????
- Turbo ITR Problems
- offset center manifold for backdoor setup
- Where is the wire for knock sensor?
- How does this setup look to you turbo buffs?
- turbo + syntetic oil = good or bad?!
- d16z6 cams?
- BOOST SPIKE is there any thing i can do???
- Need bumper grill mesh, where can I get it?
- Need Input..D16Z6 Turbo Build
- Where does missing link go?
- Problem torqing down headstuds/messed up thread maybe? Help me plz.
- PLX R-500 knock monitoring
- Running a test pipe
- Anodizing Shops?
- Looking for a 2 in 1 gauge (2 1/16)
- Welded diff?
- GE intakemanifold
- Best STREET tire for DRY traction?
- HELP.. need help with 18G DP and exhaust size selection...
- Running Nitrous, Cam selection Question.
- 350HP and drag radials on the street???????
- new video (402m racing) all boosted cars
- power chamber intake w/jrsc
- found an interesting and promising write up on ssautochrome's kit.
- Need some help regarding SLICKS
- full race top mount >42r??
- bought (3) used SRP pistons.. have a couple questions.
- pr3 pistons lsr rods and crank on gsr
- My new favorite!!
- New Honda B-series oil pan design
- Is the Hondata Rom Editor Software Necessary to Program your Hondata Chipped ECU?
- Clocking an Ihi turbo
- help with my turbo installation!?
- My new ported/built LS head came in today! Few pics inside.
- going turbo with depo foglights "EK"
- Just Dyno'd: SOHC Turbo ~12.5psi
- What is the base ignition timing with lowerd c/r
- Intercooler mounting...
- anyone running the wastegate off the downpipe?
- HUGE TURBO PROBLEM. PLEASE HELP ME!!!
- Lightweight crank pulley... why they are supposed to be bad ?
- what kind of turbo do you have on your stock sohc?
- FITV Leaking.... Need help!
- vafc and chip?
- WHat does everyone think of my new hat...
- So Its A B20 BoosteD
- anyone runnin with gt non BB turbos... i got a question...
- B16 swap... with an LS tranny... UHHH!
- Intercooler Piping..........
- How far do you guys push the DRAG kit?
