View Full Version : Forced Induction
- 81.5mm cp pistons stock sleeve b18b1
- Obd1 b18b1 wiring harness on obd2 motor?
- $600.00 bucks for turbonetics turbokit? t3t4. b series fit d15?
- Clutch and injector question
- attempting to "spike" boost in lower rpm's
- Ls/Vtec Turbo 500+ hp
- Wastegate elbow to clear ac?
- REBUILT JRSC M45JR BLOWER
- Longshot basemap question
- Y7 boosted
- VTEC & Turbo
- Potentially silly question
- Smoking problem
- 530 HP/360 TQ B-Series: "What should I upgrade when "building" a transmission?
- SOHC Manifold
- Preparing block for more boost, what rods and pistons?
- looking for an exhaust flange for the GE8 L15A
- Integra GSR Oil Lines
- D16 A1 top mount mani?
- trackforged stubby trubo manifold ne good???
- budget build GSR now a fully built project
- Any high HP Vitara "Nipon Racing Piston" builds?
- d16z6 idea?
- oem oil filter cooler install a turbo feed lines w/sandwitch plate?
- z6-t
- K20A2. Full-Race. A Long Journey.
- anyone tune a d16y8 with hondata timing related
- Questions/help for Turbo b18c1
- Coolant in catch can?
- catch can port question
- Got my newbe list together, scheduling the install
- B18A1 LST VTEC or B18C1 W/Turbo DD
- Looking for 10 seconds
- oil restrictor
- Is it normal to puff oil during break in?
- help! b18c5 stroked has a little blow by
- Filter options for E85. Fuelab or ???
- Help please!!!!Turbo integra overheating with ac on.
- noob help me honda tech with my poor man
- Building Boost quicker with current set up.
- power related question with d16z6
- F2B Trackday/Street EK - Looking for the right turbo...
- d16z6 turbo
- obd1 injector clips
- Head lifted tonight, help me get pistons & rings in.
- Lots of oil coming out of the wastegate dump tube
- bad piston rings? tons of oil blowing out breather can
- 300whp?? greddy td04 15g kit
- gsr crank/eagle rods bearing size
- 60 trim, 7lbs to 10lbs question
- typr r cams with adjustable camgears what degree
- Im having a weird issue with my FI B20/b16.help
- CP piston Ring Gap
- top mount vs ram horn bottom mount aerodynamics
- Tune question regarding injectors
- Cel codes since I installed Dsm 440cc injectors
- leaking at turbo drain flange after start up
- Turbo 2000 Civic Si is complete! New member ? too
- turbo feed line restricter fitment issue
- injector sizing help
- Reliable Ignition for 450whp B18c1
- help please boost problem
- turbo with stock sleeve build
- Tial bov spring help
- B18B vs B18C block for turbo?
- what throttle body to use with water/meth???
- Ls vtec timing adjustment!!!
- has anyone order from this guy before?
- Eg rusted fuel tank E85 setup
- AEM fuel rail
- engine build question
- do i need an after market intake manifold?
- LSThatch/Blacktyper01 Turbo v6 Build
- f22 sohc turbo help ideas
- 98 Spec ITR vs Edelbrock 4730
- rocker arms suffer damage all the time on turbo B16
- Need help Bov not Blowing off.
- B series tubro
- PTE 3431e on H22
- I Need Install Directions for a B18C5 JRSC setup!
- please chime in *flame suit on*
- turbo sponsorship
- Help me piece together a turbo kit
- Injector Dynamics install question
- Buddyclub Spec 3+ Cam problem in Boosted setup
- stock ls, 60 trim, arp studs, 12lbs?
- Access to negative side of ignition coil?
- ne experience with cxracing fpr
- How far would you push it?
- NEW Ramhorn Manifold! Should i Buy?? new style
- Need some suggestions for air filter...
- Urgent catch can question
- Boost controller
- carbon deposits at exhaust runners
- oil and draining for a borg warner s360
- need help on b20 turbo set up
- Lots of crankcase pressure on rebuild.
- Fuel Pumps
- Bolts Loosening up?
- where to buy jrsc parts? for b16 motor
- Help with Compressor Map
- Boost controller how do you control your W/G?
- d16y8 turbo project help
- To everyone using E85
- Building block
- How hot is to hot for engine?
- Are 440cc big enough for my setup
- Turbo help
- capped off boost controller
- B20b (JDM High Comp) with T3 60-1 spool characteristics and power output
- Oil in exhaust and intake ports high PCV preesure
- Water Methanol Injection Questions?
- 96 d16y8-t 25 w/ ac and ps
- 1100cc FIC injector figment issues?
- Turbo parts
- At what point do you need a bigger fuel return?
- Worlds Quickest & Fastest True Street RSX- 10.412142mph
- noob needs some help with turbo build
- Gsr turbo bogging when in gear
- few issues with je pro seal rings, marked n150
- Help with turbo
- Speedfactory MAP installed - No Start
- Sleeved b16
- recomended oil presure on a turbo engine
- KMOD Performance RSX Turbo Kit-580whp 392wtq
- poor man type r turbo. I need spark plug and freeze plug part numbers
- D15B Boost
- first turbo build and on a budget, about how much to tune?
- 97 del sol d16y8, lost basemap... None are working
- Cooling problems with turbo B series
- need some clarity on rod choice for D15 mini me turbo build
- MSD 2step/revlimit verse s300
- 94 integra RS NOT BOOSTING........PLEASE HELP!
- I'm kinda confused on what turbo i have.
- My 93 Del Sol turbo build
- Turbo Question
- What drag slicks for Itr suspension ?
- Gsr turbo Forged piston dilemma
- quick vacuum line question
- ***Official Boosted EM-1 Thread***
- Idling problems.
- Need Help with First Build
- Oil return line picture
- smfh got car tuned and bottom end fully built @cnc by miller..
- Turbo for b18b
- Ls Vtec turbo build help!
- What do we think of this turbo kit?
- Spark plugs for turbo, NGK 7098?
- b16 valves?
- help with my boost by gear
- stock cb7 dd on boost, what injectors & ecu?
- What turbo is this??? Calling all turbo GURUS PLEASE HELP!!!
- Stuck between Stc & Shodan "Reaper" Vs Borg Warner S300sx FMW
- GSP Turbo kit for RSX EP3 8thgen SI
- Oil starvation - First was the GT3076R, now the Laskey built bottom end...
- Impressions
- Hks ssq c clip, having some trouble
- Thermostat / Rad hoses for JDM Dohc ZC. Same as usdm?
- N/A or Boost?
- LS Turbo Custom Tranny gearing question
- quick 76 racegas ? would it do anything?
- where to get my block sleeved and built?
- Turbo build part thread #893989483
- Rebuilt b16 turbo, blowing lots of white smoke!
- Shortest (front to back) turbo instillation
- First Time on Track! HELP!
- Running a vacuum block wondering I should T the ebc
- Is $700 good for a turbonetics turbo kit?!help
- Vacuum line on hondata map sensor
- %%please for love of god help somebody $$$
- Integra misfiring at high RPM|Turbo has no vacuum port| **VIDEO**
- Oil Pressure...acting odd
- Ruing nitrous without relay
- 2-Step & RevLimit Settings
- question on z6 head.. pic included
- B20 boost questions
- catch can question
- Will I need to get a 3 bar map?
- does this scavange pump sound bad?
- how do i install an MV-S ???
- Nitrous bottle mounting?
- Check engine Code 3, running extremely rich
- turbo woes
- GSR Block Bored to 82mm stock sleeve, OK for Boost?
- b20 vtec turbo help
- Do I need these 3 Block Port fittings?
- BOOSTED B18C5 COMPLETE BUILD DAILY DRIVER 400HP?
- 12 psi or 8psi, supposed to be built..
- WHERE ARE YOU GUYS MOUNTING YOUR BOOST SOLENOIDS?
- Lucas oil stabilizer or no?
- Motor mounts
- Suggestion to the turbo thread
- Turbo id?
- turbo filters/screens
- b18a(LS) Turbo?
- Another turbo ??
- nitrous not working??
- 5858cea turbo...feedback?
- Wire Diagram
- Turbo Gsr very HIGH IDLE
- Boosted 97 ek coupe with JDM B18c?
- 353bhp B18c1 GT28RS - Which turbo next??
- Oil Breathers
- 93 hatch d16 tuning?
- i need help....cp piston crack
- civic king kong from italy
- Towing with your FI car ??
- It's official
- noob to turbo question!
- GSR BUILD 500+ HP...the beginning
- Turbo D16z6/y8 - Base Timing & Ignition problem... please help!
- 38mm Wastegate, 44mm Flange. What to do?
- Fuel pressure issues version 2.0 (drawing)
- Where can I find this manifold?!?!
- Oil sandwhich plate question.
- moroso oil pan return line help
- b20b w/ ls tranny turbo build.....what all shud i switch?
- need upgrade the fuel system or not for 600hp?
- Not sure if this is frequently asked
- 468whp on 17.5psi STOCK GSR
- Oil sitting in turbo
- will this turbo work
- tial mvs line hookup?
- Hondata pwm install
- Fast Turbo Oil Line Kit Question
- Strange problem with Turbo GSR
- Journal bearing turbo wheel is suppose to be tight to spin???
- T fitting on block for oil feed leaking, options?
- B18b, LsVtec, or B18c...Which should i boost?
- suzuki swift gti 1.3 turbo 301hp 15 psi
- b16 nippon racing head gasket... boost
- FUEL PRESSURE!!
- hp rating?
- sohc ZC - stock crank/cylinder boost limit?
- s300 help needed-USB drivers
- cannot find a company that sells jrsc for gsr!..
- H22 Mahle Gold Series Pistons?
- I need some help from the turbo gurus
- To all of my Holset users
- h22 trans and clutch
- Oil restrictor garret turbo
- Help finding a FMIC
- 1992 Civic Sedan B20
- Honda Tech RENO NV?
- 2001 honda civic d17a2 problems
- turbo hitting radiator
- Blox IM / Need to be replaced?
- B18B modest turbo set up
- Turbo oil feed : Homemade gasket? Banjo bolt oil flow?
