View Full Version : Forced Induction
- help with turbo ls just a few questions
- Rank1Racing/ShitBird Manifolds
- Finally got my car rolling... couple of pics
- D16z6 Turbo Questions.
- 20G set up
- Minor leak/block crack.. advice? no boost for now :(
- Sleeve Or No Sleeve *Discussion*
- blaast performance wastegates???
- Please review my set up.
- Compression Test #'s B16 w/ 9.1 pistons HELP!!!
- ZEX dry 55 shot on stock B16 questions
- Lightend flywheel with turbo.
- Just a quick question= T3 Exhaust gasket.
- coolant turns a darker color after a few days? whats going on here
- boost
- Which head is better to fully build p72 or pr3?
- block guard
- Boost Problems
- EXACTLY HOW FUNCTIONAL IS RAM AIR? <--- NASA EXPLAINS THE VENOM 600 RAM AIR SCOOP
- HELP PLEASE! SMOKING T25!! Pics of setup inside...
- yes yes i kno another ssac thread....
- Disable secondaries on GSR running chipped P28?
- keyway for timing gear gsr motor
- cheapest place to buy greddy kit, City something..........
- what turbo to get?
- Do the RPM gain of a b16 outweigh the power from a b18c, both boosted?
- Laskey racing shop hours?
- Oil restrictors that dont cost $30?
- D series Turbo Kit?
- Pistons, pistons, pistons....
- Jumping tach when boostin
- ***Precision Injector Install HELP*** pics inside. A little help from the experts please.
- Whats the best single cam
- If I wanted to turbo my car one day with this Edelbrock turbo kit...
- Which trim t3/60-1
- who else makes a 2mm head gasket for a d16
- gsr cams shafts for a b16 turbo
- b16 turbo,stock motor
- help with a B18C setup
- Some turbo help For a noob, Budget Build Time
- 300WHP STock H22T, Project, Tuned by Teknotik
- Having trouble finding a particular thread...
- Finally killed it! Lame vid inside
- sleeving block prices
- on my blow off vavle what does soft and hard do
- pic request
- b18b Turbo Setups
- Bought a used turbo kit for my 95 gsr (BOV is in a weird spot) why?
- another boosted LS
- Upgrading MAP sensor...When??
- Tial Springs (Big Blue, Small Blue, Small Yellow, Small Red)
- stock or go with a big one, D16Z6 engine Throttle body
- Who's going to NOPI ????? , Many LHT cars will be there ,,,,finger
- b16 with GM 3 BAR map sensor, what wires go where??????????
- turbo d16z6 smoking hard
- What Turbo Is This (I'm Noob)
- sc44 on a stock gsr
- Borg Warner Turbos aka bullseye turbos
- Boost leak but holding boost perfectly?
- HP Limit for a GT28RS???
- Compression #'s for a 9.1 B16
- How much HP is -6 fuel line good for
- Black stuff on my turbo
- Question about trap speed/rpm/tire size...
- anyone ever thought of using blowers in the exhaust like diesel engines
- Getting a d15b ready for boost
- O2 Bung - Quick Question
- Anyone running a restrictor on a t3/t04e?
- vtec setting
- Tuning past 12 psi (afr)
- free turbo
- no primary O2?
- Engine managemnt boosted ls
- ROD BOLTS BREAKING?
- GSR w/ JRSC slow as crap?????
- Aftermarket Intake manifold Flowrates/charts...
- brake boosting!? YEAAYY! Good/Bad? Discuss plez!
- Motor building Tools
- Noobs and EBAY turbo's, your question's answered.
- 380whp 300lbstq. and 20# of boost
- blown ls motor
- how much i need to make realy 400-500hp turbo and safty engine ..
- will a 14b hold 250 hp?
- D16z6 Build: Wiseco (.50 over) or CP (std bore)?
- POST UR H22 BOOOSTed HORSEPOWER numbers
- How you can tell if is a fake or real Walbro fuel pump
- T3/T4 Turbo Oil Line?
- Should i upgrade my intercooler?????
- The Official Fastest/Quickest SOHC Turbo thread
- a/f ratio at idle??help
- arias pistons on summit (which one should i get? if any?)
- turbo materials?
- What you think??
- How to make a B-series handle long pulls with boost?
- can i use a p05 ecu to chip it for my b16 turbo?
- Another SOHC w/ 400+whp on the vitara's !
- what kind of boost controller do you guys recommend?
- uego
- xs power 46mm wastegate, how good are they
- STOCK B16 WITH GREDDY TURBO KIT:WHAT DO I NEED
- What Spark Plugs?
- Another SOHC-T in the works
- Identifying this turbo's specs...
- carbon hood + Boosted underhood temps
- swap questions
- Might sound dum but could use some help
- auto 97 coupe ex turbo questions
- looking for jeff evans dyno
- any one running crower 403 non vtec on turbo set up??????????
- Need Help...wastegate
- t3 super 60. or greddy 18g??????? on a stock ls.......
- help with turbo ID and power output
- LsVtec Turbo Not Running Properly Need Help!!!
- ebay catch cans
- catch can or a breather
- hondata s300 question?...
- boost controller
- motor internals from b16a
- TE Datalogging issue
- My setup low budget to HT standarts
- Seems like clutch slip (boost problem)
- anyone make a d series manifold with a ko3 flange? t3-ko3 adapters?
- Wastegate Leaking, Help!!!
- Turbo B16a - What turbo to meet my goals?
- anyone make 500+ on the inline pro ac manifold?
- where can i get reflective heat wrap?
- Opinions on edelbrock turbo kits
- How much power does a .48 hold back?
- To Much Timing? Heres My Bin - Built D16a6 SOHC
- Y8 - Dyno & Street Tuned This Weekend: 205whp/174ft-lbs 10psi
- Blow'n headgasket.. Need Help!
- Searched: CEL after fuel pump upgrade
- after 3 yrs of abuse, how do my internals look *pics inside*
- turbo intake tube
- Got a quick ? about my idle problem
- ~ B17 build? ~
- Noob ?'s
- yall opinions on lightweight flywheels
- IHI BB RHF5 Turbo!!!
- help me with my turbo selection
- LM-1 wired into EMS?
- fuel ?
- idleing problems after JRSC install please read!!
- Is it ok to buy a sleeved block?
- two small sidemount vs. one big fron mount intercooler
- Boosted B16 on stock ecu?
- Who makes custom a/c lines (so I dont lose a/c)
- LS build inside any insight? PICS!
- boost spiking! profec2! cant seem to tune it out please help!
- Maker of Manifold in Canada???? silly sohc????
- AEM 3.5 bar map specs, need help.
- If you have a turbo car with rsr exmag or world sport please chime in.
- **PiC Request!!**Filter location with ABS
- is the obx intake mani really that bad ??
- GSR injectors?
- Accusump Turbo-Oiler
- over flow can problem?
- who here is using a y7 tranny
- d16z6 with 8.5:1 compression, how much boost on pump gas?
- bad day at the track
- which turbo is better?
- lower torque mount question
- Blox H22 cams
- where to get 3" resonator?
- stripped oil feed
- My experience with the H22 Mahle "FRM Compatible" Pistons
- "mtber" Tuned Single Cam !!! Dyno plot Inside !!!
- Thought I would post some pics.....
- head parts
- turbo's 99 civic si whp numbers
- FJO/1000cc RC's now wont idle (FR stage2)
- ebay radiator and overflow resevior
- Valvespring rate
- Tell me how your skunk2stage2 worked with boost
- T4 to T3 turbo Adapter??Help!
- GT30R Spool time and which Trim and A/R?
- Is the t3t04e good for a ls vtech
- tial wastegate 38mm problem
- Who is running a 60-1on a GSR and what are your setups and numbers
- Teflon tape needed on 3/8NPT fitting for oil drain?
- GT3567R 700whp yet?
- Bad Hondata S200 or ECU? Problems, please help.
- headgasket blown
- what compression ratio?
- inline pro/sc61 ??
- b16 turbo
- i think i need to replace my headgasket.....can i get some opinions?!???
- GT28R vs T3 .60/.48
- TUrboing 99 si
- 14b with ps
- Turbo kits for DA's? will piping from other kits fit?
- The start of something great.....i hope
- d16a6, stock head, stock cam, 300 whp.
- Which Motor Mounts for turbo??
- M&W PRO-10 HELP!!!
- Normal Engine Temp
- Hondata Launch Control on S300 for 96-00 civic
- 12.1 cpompresion and nitrous
- which turbo kit
- greddy turbo timer help
- My terd is back together after 2 months
- Wiring Diagram needed for ECG Electronics O2 Sim
- help me choose turbo for my goal
- Crome basemap needed
- need to know which item is more important right now?
- msd 6al or sci?
- I just bought a boosted gsr and have a ?
- Twin Scroll dyno sheets?
- ebay bar and plate vs. jrc
- anyone thought about using the new turbos from the RDX?
- turbo cam pole
- So i got a JRSC for my 94 dc4 and I was wondering.......
- mounting slim fan offset on radiator
- Wastegate Hose Barbs
- Im confused, full race or peakboost??
- deciding factor (poll) what brand turbo should i buy
- where can i buy alot of t3 sheet metal gaskets?
- well i blew a headgasket, pulled it off and this is what i found, also wondering whp limits of 85mm
- turbo help
- This T3 good for d16z6? pics inside
- Do they make this housing in T3 flange
- sound like a good d16y8 build up for boost?
- !urgent! need part number for apex map sensor
- D series build up help!!!
- building a turbo kit..help needed
- what radiator cap lbs to get
- Where da hell can i find a borg warner gm-8!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- can someone post pics. 97 civic turbo
- need help on my turbo project?
- NEED HELP ASAP
- topmout vs. ramhorn
- -ARTURBO-> Stage 1, 2, 3, N, O, P, etc. Turbine wheels... How can you ID them?
- HELP! Boost falling off with greddy profec b2! grrr! help!
- B16 build help
- Finally Someone learns...
- ballbearing
- ssqv question
- how accurate is the megan racing EGT gauge...
- Rebuilding Engine: Opinions on my new 400whp Setup!
- Wanted: Pictures of Corroded and Discolored Stainless Turbo Manifolds
- Need help making a reasonable price
- Catch can setup - will this be okay?
- 120k miles to high to turbo?
- 5 MAIN GIRDLE or 3 MAIN
- Type R vavletrain?? NEED HELP
- T-3 TURBO ????
- boosted k20a2 having issues
- New to FI
- Phantom Grip LSD conversion, you like it?
- Ignition timing retard
