View Full Version : Forced Induction
- This is for you guys...
- Internal wastegate issues DIY help. Rotating the center section helP!
- problem w/ Hallman ES boost controller and tial wastegate
- A/F gauge install question 96-98 civic (did Search)
- B17a pistons
- tapping manifold for egt probe?
- BLOWN BLOCK along with my head from the headaches
- NGK Plug Chart-Everything you wanted to know
- need some help installing wastegate please?
- B16a1 integra on boost? need some info
- thermal 3" oval mufler compared to apexi N1 3" canister
- doing turbo install right now......NEEDS SOME HELP PLEASE!!!!!!!!!
- Quick question: t3/t4 oil drain bolt thread
- Installing my turbo
- ok pics up!!!! Need help with these turbo timer pics
- Sorry...but I'm a complete turbo n00b...
- 1990 Integra Turbo Question
- Hondata fuel ratio?
- anyone use oxygensensor.net?
- Set my turbo back to Precision for exhange
- Oil pressure is too high? WHY?!! Tony1, earl, help!?
- open/closed loop with hondata & vtec?
- chip to retard timing instead of advancing??
- Is This TURBO To Big ?
- Valve
- powder coating question
- bov question
- Timing cover question
- Hondata with 95lb/hr injectors?????
- how much boost can the f22 hold?
- how do you upload pics to this site?
- Getting out of the darkside
- Internal wastegate question
- new short block (pics)
- What about this kit?
- GReddy Boost Gauge Fluttering...
- !!Bolt Broke Inside Turbo!!! D:
- Greddy full auto timer???
- Settle something for us. 566whp on 4-550's?
- few pics of my turbo DA!
- paypal question.. Somewhat FI related.
- calculus applied to motors.....
- DSM chargepipe and BOV kit?
- Radiator/Fan Help
- Oil Pan Tapped incorrectly????
- dump tube
- turboxs rfl
- MSD btm wiring question
- Dump tube?
- Injector wiring ?
- Which Hondata Should I Get?
- plugs for dsm injectors
- Tell Your First Boosting Experience With Your car
- b16 jrsc on a b16/gsr head with a jrsc gsr manifold?? read on!!!
- Greddy type 31
- Why is my exhaust popping?
- every happend to you?
- Downpipe Help
- Gear based boost controllers?
- TIG Aluminum help...
- About to turbocharge....what next???
- Baseline Settings - Need Help
- ** -- Can I use a V-AFC on a NON-VTEC engine -- ** ?
- Flywheel owners!!!!
- E-manage users where are you?
- Freezing weather is A/F sensor readings
- Are bleeder valve type boost controllers bad?
- EG6TURBO D15B 1/4 Mile Time
- Turbocharger Exhaust Manifold Material Selection
- b16 crx.. looking at turbo kits. recommendations?
- Good place to get a new DP made in MD/PA area
- Help Strip bolts
- 250whp on a semi-built d16. What turbo can do it?
- almost done turbocharged 95 gs-r 4dr. just waiting on my hondata to come back !!!!!
- honing block for new pistons????
- Pr3 pistons on LS (b18a1) rods?
- Help Installing Turbo in H22 accord
- OT: finally finished piecing together my setup...pix inside
- Where to get the Bolts to mount the turbo to the Manifold?
- Anyone using the Apexi Universal filter with custom flange?
- WOOHOO GOT MY TURBO TODAY!!! questions tho.
- Questions on ZDYNE ECU! please help
- how to tune hondata..plug in where?
- JG = Just Garbage
- cheapest place to buy je piston b18c
- vacuum leak, hole in the fuel map (fast and furious) ???
- been on my mind....turbo and cali don't mix
- Gauges: Why do many of you only have boost?
- gsr motor with b16 jrsc?????
- are b16 and b18 main caps the same?
- What turbo comes standard with the F-max kit for a 99 lude?
- Anyone have a fREAKIN' idea how to put earl hosends on without hurting themselves?
- Question about my turbo 99 lude
- Someone please give up the number for Drag Competition Products
- Running AEM EMS with nitrous
- painting charge pipes black
- Would a T3 downpipe from an 98 SOHC fit a 99 DOHC b16?
- Anyone know what internal wastegate actuator for 5 or 6psi?
- Ignition Question For turbo 99 lude
- who here has a light fly wheel on their turbo car?
- How much more oil w/ turbo?
- need what to run more boost jrsc
- slap
- Block Sleeving
- when to sleeve?
- whats the biggest valve size I can go on my stock bottom end?
- need a LS crank asap
- Tapping manifold for external gate question. Placement of hole?
- Just did Skunk 2 OBD2 to OBD1 conversion and have question...
- Present STATUS of your FI car?
- What max psi should I tune vafc hack setup on my h22
- Pipe Coupling from menards work for turbo charging?
- Retorque of ARP's nessecary?
- Weird Sound and weird question for you.
- Looking for a picture of a big turbo.....
- WOT for how long?
- wtf need help
- VAFC hack- safe settings for D16 @ 6psi?
- Jackson Racing fuel problem question
- Need help on which Hondata to Choose
- Motor Oil Question with Turbo: Synthetic to Non- and back to Synthetic
- Should I drive my car on a 1500 Mile road trip.
- what's the best way to route water lines for turbo?
- Can anyone teach me about trim
- Pick my turbo guys...
- what to do??
- Ok, ALLLLL you 450cc dsm injector guys.. whats the deal with this???
- where to get piping couplings?
- Used gsr greddy kit fit b18b?
- Not Honda, but turbo related
- turbo cams
- Best ECU Set up....
- 4 port oil sandwich adapter?
- Where can I f'ng get this valve?
- What's the best turbo for 300hp on a built B18B????
- Turbo Kit on a ITR
- Upgrade from stock Injectors to 450's... does the Hondata need to be re-tuned?
- anyone got a extra spring for a mark II deltagate
- What Increases Injector Duty-Cycle?
- HELP HELP Threaded Part fell off my BOV
- 1990 Integra LS...turbocharge it or not?
- drag kit fitment?
- Boosted D16 Lean....
- TechEdge WB Questions. (already searched!)
- Piston/wall clearance using stock bore pistons
- turbo bugs,please help with my friends ride.
- bigger turbo= more power on pump gaz ?
- Accurate measurement on Piston pin-to-Bushing clearnce on a Eagle rod...
- GT Series Maps
- Headwork on your boosted setup?
- Exospeed
- is it bad running without chargepipe connected?
- What do you think of this wheel
- Can a stock head gasket hold at 20psi
- my turbo honda videos
- Injector cleaning service
- Harness no good?
- hondata....resistor box
- Pistons Breaking
- Whos running the most boost on stock bottom C5?
- going from internal to external wastegate...is this a nice wastegate?
- The shop said I need new muffler bearings....
- My old b18a pistons...analyse them!
- )2 sensor question
- Some videos of my turbo hatchback.............
- californians and boost.
- Question About Routing Charge Pipe (without intercooler)
- should i go .48 or .63 a/r?
- Supercharged Moped... the carb doesn't like the boost.
- inline fuel pump vafc hack
- A few questions about doing a turbo D series..any help is appriciated
- Traction
- CEL 72?? after vafc hack installed
- Boost Lag!? What is it and how do I get rid of it!
- My car has the hiccups
- HEY Guys i got a ford T3 it steh SVO turbo........
- JRSC D15/D16 belt?
- stepper pulley and CEL
- Exhaust mani's
- Manley valves
- please post your afc hack/map limiter idle setting???
- Eight 450cc injectors complete
- Whats a good turbo
- What to get with this turbo
- blowby
- Turbo SC300 forums?
- Haman MBC question
- what brand clutches do you guys use???
- OVERbore folks
- sohc turbo....new motor or rebuild?
- need help with intercooler install on 90 hf crx with b16a
- Timing, plugs, wires, o2 sensor?
- 3" exhaust deibel concern! HT members I'm confused
- insurance and your turbo?
- What is an direct bolt on turbo upgrade for the sohc Greddy manifold?
- Just got my Pauter Rods for my B16A Buildup(rebuildup) Gotta question about bearing sizing?
- What is the best Engine Management ofr my B16A1 CRX VTEC Turbo?
- T3 turbo Spools but doesnt go?
- air 2 air and air 2 water intercooled done already?
- Does altitude effect where Tial wastegate opens?
- Dodge colt 2.0 turbo
- Tial blue spring
- I can't sell these cams, would I be able to use them for FI?
- help with fuel pump
- turbo kit for Civic type-R EP3?!
- Simple question or two.
- intercooler fitment
- Boost numbers
- O2 sensor stuffed!!will safc still work??
- New 03' Dodge Neon SRT Dyno (pics Inside)
- finally got new clutch in!!
- Defi?
- Defi Boost & Timer Virtual Super Display
- Need Help - Got Wrong size turbo ---- Round 2
- Pass emitions with a turbo?
- HELP ME!!!! Need help with fmu for greddy turbo kit
- need help on nos!!!
- sparkplug help
- Easy way to hookup an external fuel pump <no welding>
- extra injector question
- REv hard manifold rusting??
- Tuning for dummies
- wtf is:360 degree thrust bearing?
- garrett t3 is gone...tell me what you think of my next project
- Pics of the goods
- Oil pan tapping help
- What c.r. will 8.8:1 gsr pistons yield in a b16?
- Too much retard on intake cam gear?
- smoking turbo on a b18b?
- Exhaust question for supercharged applications
- Piston help ASAP!!!!!!!
- just received maxrev manifold
- need help with my nitrous setup
- Power output off of a Drag Kit?
- Shooting for 330whp . What do you guys think?
- got NX? pics inside
- finally got my car back...got some questions
- plugs and fuel
- What's the Max WHP on 91 Octane?
- All you need to know about nitrous oxide!!
- Anyone have a T04E on an 88-91 B16 w/ Place kit???
- Subaru injectors on a honda?
- What electronic boost controller to go with
- Detonation?
- Who's using a TurboXS dual stage boost controller?
- best drag radials? kinda OT
- Please help ...I'm giving myself ulcers!!!!!
- GE- coolent additive?
- Long time no talk, questions for my friend about his ef hatch project
- One last question about vafc w/440's
