B16
Ferrea 6000 turbo valves
Ferrea Valve Locks
Supertech Dual Valve Springs and Retainers - 85lbs
Port and Polish
Gsr Cams
Skunk2 cam gears - not sure if I'll will end up using them yet/ heard bad stories if they slip and move.
Hondata Thermal intake gasket
BWR cam seal
Arp bolts
Oem head gasket
Block
B20
Eagle H rods
Supertech 9.5:1 Pistons
Oem gaskets and Seal
Modified Oem oil pump
Golden eagle b20/vtec Kit
Turbo kit
Go-autoworks AC Friendly manifold and down-pipe 2.5 inch
Garrett t3/t4 .57 trim
HKS Bov
600hp intercooler
Hondata s300 v2
PLX Wideband
as much i like skunk2 products, you may want to skip those cam gears. theres been issues from slippage to breakage. good ones are golden eagle, toda, old skool aem 3 bolt pattern, and i think buddy club has a nice meaty gear. some of the hardware on those may need replace with something stronger. i just remember if that was skunk2 or another gear when the hardware need replaced.
i think it was the old school 3 bolt aem's that had a bad track record of slipping..
i have a set of sk2 gears and some of the bolt threads stripped out (not the bolts themselves). i drilled them out and tapped them the next size up i just dont remember what it was. no issues since but keep in mind the aluminum is quite soft and most of these gear bolts only require like 6-8ftlbs and some recommend a bit of loctite to keep from slipping
Just have to make sure you have the bolts torqued down properly - I purchased a set of used AEM adjustable cam-gears back in 2009, 6 (going on 7) years, and damn near 600 WHP later, they have not slipped once.
