View Full Version : Forced Induction
- where to buy compressor housings?
- VSRacingparts.com
- Vortech Bov (questions)
- 84mm and stock ecu
- garrett TAO301
- how much shots of NOS,,,newbie
- Boosted LS's
- How can you tell when your O2 sensor is going bad????
- how do u tell if injectors are high or low impentance..
- Haltech Haltuner,Is this a wideband o2?
- Looking for stand alone engine managment for D-series w/auto tranny
- Please help...which oil pan should I run? (pics inside)
- Swain Tech BBE on IC.
- Arias Pistons?
- Question: what do I have to do to get 275-300 ft pounds of torque out of a B SERIES,
- Where's Rocket??
- first gen b16 rods??
- ... deals on forged internals... know of any?... groupbuys?
- How Much horsepower is a Stock B16 Manifold Good for??
- Anyone else have this problem with their SFP manifold
- Help! my GReddy blue box is throwing a code! >^|
- need some help..crankcase blowby
- Ok, WTF is going on, help plz...
- ... valvetrain... aftermarket vs stock... suggestions/thoughts...
- OBD0 Better than OBD1 ECU for turbo b16
- how much boost on regular gas?
- check out my b-day gift
- Spark plugs again with MSD
- Need help from the experienced...
- boosting in 5th gear...bad?
- Whats the biggest direct port shot a fully built f22b could handle?
- 2001 civic turbo kit
- Lost Motion Assemblies...
- wastegate help
- cams
- COLDER PLUG FOR D16Z6 ?? what model ?!?
- which turbo manifold for the street
- Need help with settings on my Field SFC!!!
- T3/T4b with 60-1 wheel???
- Help me identify this manifold....
- Summery of all Golden Eagles new Products.
- AFC or SMC??
- oil in BOV! and turbine! and piping!
- intercooler piping....different sizes, is that a problem?
- help with turbo choice?!?
- Open DP -> Stock Exhaust = Unhappiness
- more praise for full-race
- Question about gauges
- 96 Turbo Ls about to go LS/Vtec Turbo, questions....
- Has anyone ever tried...
- Just for fun.. Lets see those Turbos (add pics)....
- lol.... i had my auto-tech teacher messed up today
- want to go turbo. whats first?
- could Vortech after cooler be used for turbo setup?
- anyone running air to water IC?
- Car won't start!
- need a hondata base map
- JRSC vs. Vortech ** Dyno Overlay **
- new meaning of 'junkyard turbo'
- lean with 450s ??
- Damn charge pipe too high and BOV hits hood
- Some comments on AEM EMS's "Autotuning" feature
- What should I do?
- Battle of Widebands? FJO or Techedge?
- greddy 320cc injectors
- Loctite for LSD install?
- Where the heck does this plug go??
- calculating rod angles
- **is greddy typeS BOV flange the same as typeR**
- Do JE pistons come with chromoly rings?
- Here is some head work for the D guys
- will a single cam radiator work in a turbo integra?
- How much head clearance is needed between the piston and head.
- Where's Viren?
- Pulling the head?
- Car is "missing" after putting turbo back on
- Turbo model TE04H?
- Need help finding a turbo manifold.....1990 H22 swapped accord...
- Why do my spark plug wires keep popping off?
- Stock LS Turbo Set Up
- Better mounting location for mbc?
- Integra GS???
- down pipe gasket?
- turbo size question
- Any updates on DROP SHOP
- Greddy EO #'s, will it still work?
- fuel setup kinda has me puzzled
- sleeve
- Weight of Greddy Turbo kit + FMI
- Newbie Question
- Boost Controller Tuning
- kit vs. your own
- FS:3" Thermal full stainless catback for EG's!!!
- NSX Supercharger?
- Need some help guys.
- www.diy-wb.org Wideband kit.. anyone have any luck?
- AAM Hiring - Sales
- AFR Gauge not reading. help!
- how much boost
- Sleeves for a ZC
- SMall boost? big significant difference?
- Most important guages to have?
- Who here can get good deals on or make Tubular manifolds?
- does anyone knows where Viren ( b18bturbo ) is ???
- compare and contrast T25 & TD04h 15g for me!!!
- wiring up boost and egt gauge
- Inside a 60-1
- Do you NEED bigname sleeves?
- quick question for hks ss bov
- Turbo on 91 integra
- 60-1 vs 60-1 hifi
- I freakin HATE DRAG manifolds!
- Manual boost controller question
- Looking for a bigger turbo........
- How much boost can I safely run on this kit?
- DIY manifold questoiions .. grind welds or no grind ??
- What exactly is included with the Greddy SOHC kit?
- Full-Race manifold or a Rev-Hard manifold
- Turbo theory: Turbocharging a turbocharger...?
- #$%&! I think I got ripped off!
- KS Motorsports Testimonials -- Please read and help if you can.
- Difference between Greddy 9mm and 15mm catch can?
- How many of you actually have boost? BOOSTED PEEPS HOLLA!
- LS Turbo vs. GSR Turbo ?
- Golden Eagle Mfg. Adjustru Cam Gears!!!
- Revhard Intercooler
- turbo adaptor plate material?
- Hondata and air condition not working
- Sleeving in the Pa, NY, NJ area
- 10 psi on GSR???
- Anyone seen the new Greddy Profec E-01? (link inside)
- FI and tires & FI and racing questions
- need help on turbo build up
- What Head gasket?????????
- Went to the track and dynoed. Pic video + datalogs
- JRSC chattering...buy Vortech?
- Golden Eagle Mfg. Cast Manifold!
- turbo setup HELP NEEDED
- optimum psi of NX ewt nitrous kit?
- greddy sohc kit max psi question
- Problem with my MOTOR possibly a nitrous problem, please help!!!
- build ls for turbo
- truely crx hf turbo
- 3" downpipes?
- carb exempt?
- Anyone running the Drag 4 kit on a prelude with a T04E compressor?
- My exhaust is too loud, help me quiet it down!
- MAX rev is good!!
- STR CaStEd DrAg MaNiFoLd
- Fuel Managment myths, theories etc.. (already searched)
- t3 and t4 60-1
- 90-93 integra turbo charge pipe questions
- Anyone in columbus ohio willing to help me?
- Question for the FI freaks!
- how reliable is your car with turbo?
- AFC/Injector/FMU questions...
- does anybody in here have a l integra thats runing in the high 11's
- Need help finding a place that sells manifolds for Eclipses
- will turbo fit? (did search already)
- Anybody have experience with Jet-Hot coatings?
- How much gain from 3 inch Thermal on 7 psi?
- Need Some help choosing Turbo parts....
- inspection and emmisson in nyc with a revhard or drag turbo kit
- RS Motorworks
- I have a nitrous kit... I am going turbo.
- Would boost cause the coolant line to pop off the overflow?
- TURBO***lighten and polish crankshaft??? Lightened flywheel and crank pulley???
- AEM adjustable Fpr question
- emissions with turbo car?
- Is this a potential problem
- ... darton sleeves... sport block kit vs pro solid deck kit... differences???
- stock turbo from any car bolt onto d16 greddy kit?
- OK , long weekend , but finally boosted, question insde.
- engine management
- B20A5 Turbo
- 500whp non-VTEC (dyno vids, etc.)
- ***blockgaurd ?***
- don't see a lot of turbo'd accords..? well look here..!
- EGT vs Safeguard
- turbo is now in and got a dyno too!
- Golden Eagle Mfg. Fuel Rail!
- I need help with a fuel problem?!?!?
- Which crank to use?
- CFM enough to cool a Boosted R??
- Golden Eagle Mfg. Factory Over-Bored Head Gaskets!!!
- OEM valvetrain w/ exception of springs
- Precision turbo specs.......finally!
- Golden Eagle Mfg. Engine Mounts!
- Golden eagle Mfg. Vacuum Manifold!
- B20/VTEC at 4psi... for now?
- why are drag turbos so LOUD
- How much boost can a stock radiator handle?
- Getting out of the forced induction scene for awhile...
- why flame from exhaust on turbo cars
- Number stamped on compressor outlet, what does it mean?
- hondas arn't ment to be turbocharged
- Walbro gss-342...need to run new wire?
- Has anyone here had their turbo pipiing cutom done?
- Engine tuners in Indianapolis or chicago area
- Going turbo need some advice
- Look at what i got in the mail....
- down pipe question
- is this a good size turbo
- Golden Eagle VTEC Conversion Kit!
- i think they sent me the wrong manifold!!!!!!!!!!!!!!!!!!!!!!!!!
- tuning with no exhaust?
- Just picked up Rebuilt Turbo GSR from shop....big problems!!
- any dyno graphs for the MaxRev set up yet? im itching to see this baby....
- What will the compression come out to?
- NOS jet on ZEX kit?
- ITR pistons to GSR pistons?
- Lookin to build a 1500 $ turbo kit for b18a.
- ls turbo
- ls headgasket
- lower boost level below stock 14b
- Boost spike with FMU
- Getting a new car!
- How much boost?
- msd digital 6 with boost??
- first traction upgrade (poll)
- My turbo project (pics)!!!!!!!
- Need some clutch advice....
- Where to buy a Wideband O2
- Michigan Honda-tech Kart to Kart meet?
- does any body need one??
- Dart blocks
- Bigger crank for more boost
- 100 Octane Gas On Boost?
- How high can i go???
- MoTech M4
- Should i disable the knock sensor?
- D16z6 Turbo Questions
- check out this flow!!
- Injector Swap
- Anyone with a T3/T04E........(I Need one)
- ... sleeved block vs headwork... where would you spend the money???
- intank fuel pump
- where does coolant go into the turbo
- Turbo real close to radiator, suggestions needed!!!!
- H23 build up questions
- Help on T3/TO4b
- Anyone use the hondata rom editor 3.0 software?
- ls turbo tranny (cable)
- i need to know a ggod block setup for nitrous?
- khiem nguyen@redline-performance.net
- pics of b20vtec.com turbo projects
- Resleeving b16
- Wastegate question
- Help code 13, just finished turbo setup
